H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
31-Device Reboot
31-Device Reboot 41.96 KB
Device Reboot Quick Start Configuration Guide
A device reboot might interrupt the ongoing services. Use caution when you perform this operation.
If you select Force reboot the device immediately without performing any software check to reboot the device, no protective measures will be taken for the device and the file system might be damaged during reboot. As a best practice, select this reboot approach only when the system is faulty or cannot reboot normally.
1.     From the left navigation pane, select Device > Maintenance > Reboot. The Reboot configuration page opens.
Figure 1 Reboot configuration page
2.     Click Reboot Device.
3.     Click Apply in the dialog box that opens.
Figure 2 Confirming to reboot the device
Then the device will be rebooted. After the device is rebooted, you can re-access the Web configuration page.
