- H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
- 01-Compatible Product Models
- 02-Configuring Web Login with the Default IP
- 03-Web Login to a Device Without a Default IP
- 04-Interface Settings
- 05-PoE
- 06-VLAN
- 07-DHCP Server
- 08-DHCP Relay Agent
- 09-Static Routing
- 10-Policy-Based Routing
- 11-Ethernet Link Aggregation
- 12-Port Mirroring
- 13-Packet Filtering
- 14-Interface Rate Limit
- 15-Traffic Constrain
- 16-Spanning Tree
- 17-Direct Portal Authentication
- 18-Port Security
- 19-Port Isolation
- 20-ARP Attack Protection
- 21-Configuring a Static ARP Entry
- 22-IGMP Snooping
- 23-Enabling IPSG on an Interface
- 24-Software Upgrade
- 25-Adding Administrator Accounts
- 26-Ping and Tracert
- 27-Password Change
- 28-System Time
- 29-System Log
- 30-Configuration Backup, Export, Restoration to Factory Default
- 31-Device Reboot
- 32-Small-Sized Campus Network Configuration Guide
30-Configuration Backup, Export, Restoration to Factory Default | 59.58 KB |
Configuration Backup, Export, Restoration to Factory Defaults Quick Start Configuration Guide
Procedures
Backing up the configuration
1. From the left navigation pane, select Device > Maintenance > Configuration.
2. Click Save Running Configuration.
3. Select to save the running configuration to a file and set the file name to config.cfg.
4. Click Apply.
Figure 1 Saving the running configuration
Exporting the configuration
2. Click Exporting Running Configuration.
The configuration file will be downloaded locally.
NOTE: The backup configuration file is in .cfg format. It is displayed at the bottom of the browser when it is downloaded. |
Restoring the factory-default configuration
2. Click the icon
for the Reset to factory defaults item.
3. Click Reset.
Figure 2 Resetting to factory defaults
