- H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
- 01-Compatible Product Models
- 02-Configuring Web Login with the Default IP
- 03-Web Login to a Device Without a Default IP
- 04-Interface Settings
- 05-PoE
- 06-VLAN
- 07-DHCP Server
- 08-DHCP Relay Agent
- 09-Static Routing
- 10-Policy-Based Routing
- 11-Ethernet Link Aggregation
- 12-Port Mirroring
- 13-Packet Filtering
- 14-Interface Rate Limit
- 15-Traffic Constrain
- 16-Spanning Tree
- 17-Direct Portal Authentication
- 18-Port Security
- 19-Port Isolation
- 20-ARP Attack Protection
- 21-Configuring a Static ARP Entry
- 22-IGMP Snooping
- 23-Enabling IPSG on an Interface
- 24-Software Upgrade
- 25-Adding Administrator Accounts
- 26-Ping and Tracert
- 27-Password Change
- 28-System Time
- 29-System Log
- 30-Configuration Backup, Export, Restoration to Factory Default
- 31-Device Reboot
- 32-Small-Sized Campus Network Configuration Guide
22-IGMP Snooping | 208.32 KB |
IGMP Snooping Quick Start Configuration Guide
As shown in Figure 1:
· The network is a Layer 2-only network.
· The multicast source sends multicast data to multicast group 224.1.1.1.
· Host A and Host B are receivers of multicast group 224.1.1.1, and Host C is not a receiver of multicast group 224.1.1.1.
· All host receivers run IGMPv2, and all switches run IGMPv2 snooping. Switch A (which is close to the multicast sources) acts as the IGMP snooping querier.
To send multicast data only to Host A and Host B in the Layer 2-only network, enable IGMP snooping on Switch B.
Procedures
Configuring Switch A
1. Assign IP addresses to the network interfaces. (Details not shown.)
2. Enable IGMP snooping:
a. From the left navigation pane, select Network > Multicast > IGMP Snooping.
b. On the IGMP Snooping page, click Enable IGMP Snooping.
Figure 2 Enabling IGMP snooping
3. Enable IGMP snooping in a VLAN. Configure the following parameters on the page:
a. Click the Add icon to open the Enable IGMP Snooping on VLANs page.
b. Enter 10 in the VLAN field.
c. Select 2 from the Version of IGMP snooping list.
d. Select Act as IGMP querier.
e. Select Enable dropping unknown multicast data.
f. Enter 10.1.1.1 in the Source IP address of IGMP general queries field.
g. Enter 10.1.1.1 in the Source IP address of IGMP group-specific queries field.
h. Click Apply.
Figure 3 Enabling IGMP snooping in a VLAN
4. Save the configuration:
Click the Save icon at the upper left of the page.
Configuring Switch B
Figure 4 Enabling IGMP snooping
d. Select Enable dropping unknown multicast data.
e. Click Apply.
Figure 5 Enabling IGMP snooping in a VLAN
Configure Switch C in the same way Switch B is configured. (Details not shown.)
Verify the configuration
# On the Network > Multicast > IGMP Snooping page, verify that the IGMP snooping settings have been configured correctly on each switch.
