H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
25-Adding Administrator Accounts
25-Adding Administrator Accounts 153.31 KB
Quick Start Configuration Guide for Adding Administrator Accounts
On Switch, add an administrator account. A user can use this account to log in to Switch through HTTP. The requirements are as follows:
·     When a user uses the administrator account to log in, Switch performs local authentication for the user.
·     The administrator account name is webuser, and the password is 12345.
·     After the user passes authentication, the user will be assigned the role of network-admin.
Figure 1 Network diagram
1.     Configure VLANs and VLAN interfaces:
a.     From the left navigation pane, select Network > Links > VLAN.
The VLAN page opens.
b.     Click the Create icon  in the right. On the Create VLAN list page that opens, enter 2 in the VLAN list field, and click Apply.
Figure 2 Creating a VLAN
c.     Click the Edit icon  in the right of VLAN 2 to enter the Edit VLAN page.
d.     Add the interface that connects to the administrator’s PC to the untagged port list of VLAN 2.
e.     In the IP address of the VLAN interface area, select Configure VLAN interface, and assign IP address 192.168.1.20 and mask 255.255.255.0 to the VLAN interface.
f.     Click Apply.
The system displays a success message after it configures the VLAN and VLAN interface.
Figure 3 Configuring VLANs and VLAN interfaces
2.     Configure an administrator account:
a.     From the left navigation pane, select Device > Maintenance >Administrators.
The Administrators page opens.
b.     On this page, perform the following tasks:
-     Click the Add icon  to add an administrator.
-     Configure the username as webuser.
-     Configure the password as 12345.
-     Select network-admin from the User roles list.
-     Select HTTP for the Permitted access types field.
-     Click Apply.
The system displays a success message after it adds the administrator account.
Figure 4 Add an administrator account
3.     Enable the HTTP and HTTPS services:
a.     From the left navigation pane, select Network > Service > HTTP/HTTPS.
The Network Service page opens.
-     Click ON for HTTP service to enable the HTTP login service.
-     Click ON for HTTPS service to enable the HTTPS login service.
The system displays a success message after it enables the HTTP login service and the HTTPS login service.
Figure 5 Enabling the HTTP and HTTPS services
4.     Save the configuration.
Click the Save icon  at the upper left of the page.
1.     Verify that you can see the added administrator account on the Administrators page.
2.     On your PC, enter http://192.168.1.20 in the address bar of a browser. The Web login page opens. On the login page, enter the administrator account name, password, and verification code. Verify that you can successfully log in to the Web page of the device and configure related settings.
