H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
28-System Time
28-System Time 182.02 KB
System Time Quick Start Configuration Guide
You are required to configure daylight saving time only for countries or regions that use daylight saving time.
Procedures
Assigning IP addresses to the network interfaces
Details not shown.
Configuring the system time
1.     From the left navigation pane, select Device > Maintenance > Settings.
2.     Click the Expand icon  to the left of the Date & Time title to configure the system date and time.
b.     Select Manually set the clock to set the system date and time manually.
c.     Click the  icon to set the date.
d.     Click the  icon to set the time.
Figure 1 Setting the system date and time manually
d.     Select the time zone.
e.     (Optional.) Select Adjust the clock for daylight saving and then set the start and end date and time for daylight saving time.
Figure 2 Adjusting the clock for daylight saving
f.     Click Apply.
