H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
13-Packet Filtering
13-Packet Filtering 233.81 KB
Packet Filtering Quick Start Configuration Guide
As shown in Figure 1, a company interconnects its departments through the device. Configure packet filtering to:
·     Permit access from the President's office at any time to the financial database server.
·     Permit access from the Financial department to the database server only during working hours (from 8:00 to 18:00) on working days.
·     Deny access from any other department to the database server.
Figure 1 Network diagram
Procedures
1.     From the left navigation pane, select Security > Packet Filter > Packet Filter.
2.     Click the Add icon  at the upper right of the page to add an interface packet filter policy:
a.     Select GE1/0/1 from the Interface list.
b.     Select Outgoing for the Direction field.
c.     Select IPv4 ACL for the Packet filter field.
d.     Select an ACL from the ACL list, and click Apply.
Figure 2 Adding an interface packet filter
3.     If no ACLs exist, click the Add icon  next to the ACL field to add an ACL. On the New ACL page, select IPv4 ACL, and click Apply.
Figure 3 Adding an ACL
4.     On the New IPv4 ACL page, configure the following parameters:
a.     Select Advanced from the ACL Category list.
b.     Enter an ACL number.
c.     Configure other parameters as needed. In this example, use the default settings.
d.     Click Apply to add a rule. The Continue to add rule option is selected by default.
Figure 4 Adding an IPv4 ACL
5.     Add a rule for the President's office.
a.     Select the Permit action.
b.     Select 256 (IP) from the IP protocol list.
c.     Set the source IP address/wildcard mask to 192.168.1.0/0.0.0.255.
d.     Set the destination IP address/wildcard mask to 192.168.100.0/0.0.0.0.
e.     Use default settings for other parameters.
f.     Click Apply to add the rule and continue to add another rule.
Figure 5 Adding a rule for the President's office
6.     On the New Rule for IPv4 Advanced ACL page, click the Add icon  next to the Time range field to add a time range for the financial department.
a.     Enter time range name working-day.
b.     Add a periodic time range, and click the Add icon  to add the time range.
c.     Click Apply to add the time range and continue to add another rule.
Figure 6 Adding a time range
7.     Add a rule for the financial department.
c.     Set the source IP address/wildcard mask to 192.168.2.0/0.0.0.255.
e.     Select time range working-day.
f.     Use default settings for other parameters.
g.     Click Apply to add the rule and continue to add another rule.
Figure 7 Adding a rule for the financial department
8.     Add a rule for other departments.
a.     Select the Deny action.
c.     Set the destination IP address/wildcard mask to 192.168.100.0/0.0.0.0.
d.     Deselect the Continue to add rule option.
f.     Click Apply to add the rule.
Figure 8 Adding a rule for other departments
9.     Click Apply to add the interface packet filter.
Figure 9 Interface packet filter information
10.     Save the configuration:
Click the Save icon  at the upper left of the page.
Verify the configuration
1.     On the Security > Packet Filter > Packet Filter page, verify that the interface packet filter has been added correctly.
Figure 10 Packet filter information
