H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
05-PoE
05-PoE 99.86 KB
PoE Quick Start Configuration Guide
None.
The system reserves and supplies power to the PD connected to a PI only after you enable PoE for that PI.
After you enable PoE for a PI, the PI supplies power to the connected PD if the PI will not result in PSE power overload.
If the PI will result in PSE power overload, the following restrictions apply:
·     If the PoE priority policy is not enabled on the PI, the PI does not supply power to the connected PD.
·     If the PoE priority policy is enabled on the PI, whether the PD will be powered depends on the priority of the PI.
1.     From the left navigation pane, select PoE > PoE.
Figure 1 PoE management page
2.     Select the interface for which you want to enable PoE on the interface panel. In this example, GigabitEthernet1/0/1 is selected.
¡     Click the chevron icon to the right of the PI field to expand the field. Select Enabled for PoE, and edit the maximum PI power as needed.
¡     Click OK.
Figure 2 Enabling PoE
3.     Click the Save icon  at the upper left of the page to save the configuration.
# Verify that the device is supplying power correctly to the PIs, and the PIs are operating correctly.
