H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
17-Direct Portal Authentication
17-Direct Portal Authentication 846.71 KB
Direct Portal Authentication Quick Start Configuration Guide
As shown in Figure 1, a host is directly connected to the switch (the access device).
·     Assign a public IP address to the host either manually or through DHCP.
·     Configure direct portal authentication on the switch, so the host can access only the portal Web server before passing the authentication and can access other network resources after passing the authentication.
·     Use a portal server as both a portal authentication server and a portal Web server.
·     Use a RADIUS server as the authentication and accounting server.
Figure 1 Network diagram
Procedures
Configuring the portal server
Details not shown.
Configuring the switch
1.     Configure a RADIUS scheme:
a.     From the left navigation pane, select Security > Authentication > RADIUS.
b.     Click the Add icon  at the upper right of the page to add a RADIUS scheme.
c.     Set the scheme name to rs1.
d.     Configure the primary authentication server. Set its IP address to 192.168.0.112, port number to 1812, and shared key to radius. Set its state to Active, and then click the Add icon  next to it to add the primary authentication server.
e.     Configure the primary accounting server. Set its IP address to 192.168.0.112, port number to 1813, and shared key to radius. Set its state to Active, and then click the Add icon  next to it to add the primary accounting server.
Figure 2 Adding a RADIUS scheme
f.     Click Show advanced settings.
g.     Select Excludes the domain name from the Format for the usernames sent to the RADIUS server list.
h.     Click Apply.
The system displays a success message after it adds the RADIUS scheme.
Figure 3 Adding a RADIUS scheme
i.     Click the Settings icon  at the upper right of the RADIUS configuration page to enter the RADIUS Advanced Settings page.
j.     Enable the session control function.
Figure 4 Enabling RADIUS session control
2.     Configure an ISP domain:
a.     From the left navigation pane, select Security > Authentication > ISP Domains.
b.     Click the Add icon  at the upper right of the page to add an ISP domain.
c.     Set the domain name to dm1 and set its state to Active.
d.     Set the service type to Portal.
e.     Select RADIUS for authentication, authorization, and accounting and select the rs1 RADIUS scheme as the scheme for each of them.
f.     Click Apply.
The system displays a success message after it adds the ISP domain.
Figure 5 Adding an ISP domain
g.     Click the Settings icon  at the upper right of the ISP domain configuration page to enter the ISP Domain Advanced Settings page. Specify domain dm1 as the default ISP domain.
If a user enters the username without the ISP domain name at login, the authentication and accounting methods of the default domain are used for the user.
h.     Click Apply.
The system displays a success message after the configuration.
Figure 6 Configuring advanced settings for the ISP Domain
3.     Configure VLANs and VLAN interfaces:
a.     From the left navigation pane, select Network > Links > VLAN.
b.     Click the Add icon  at the upper right of the page to create VLAN 100.
c.     Enter 100 in the VLAN list field.
d.     Click Apply.
The system displays a success message after it adds the VLAN.
Figure 7 Creating VLAN 100
e.     Click the  icon to enter the Edit VLAN page.
f.     Assign GE1/0/1 to the untagged port list of VLAN 100.
g.     Select Configure VLAN interface for the IP address of the VLAN interface field. Select Manual assignment. Specify the IP address of the VLAN interface as 2.2.2.1. Specify the mask as 255.255.255.0.
h.     Click Apply.
Figure 8 Editing VLAN 100
i.     Configure VLAN 2 and its VLAN interface in the same way VLAN 100 and its VLAN interface are configured. (Details not shown.).
4.     Configure portal authentication:
a.     From the left navigation pane, select Security > Access Control > Portal enter the portal configuration page.
Figure 9 Portal configuration page
b.     Click the  icon on the right side of Portal authentication server to enter the Portal Authentication Server page.
Figure 10 Portal authentication server page
c.     Click the Add icon  at the upper right of the page to add a portal authentication server.
d.     Set the server name as newpt. Specify its IP address as 192.168.0.111, the shared key as portal, and port number to 50100.
e.     Click Apply.
Figure 11 Adding a portal authentication server
f.     Return back to the portal configuration page.
Figure 12 Portal configuration page
g.     Click the  icon on the right side of Portal Web server to enter the Portal Web Server page.
Figure 13 Portal web server page
h.     Click the Add icon  at the upper right of the page to add a portal Web server.
i.     Set the server name as newpt. Specify the URL as http://192.168.0.111:8080/portal. (Configure the actual portal Web server URL used. The URL in the following figure is for illustration only.)
j.     Click Apply.
Figure 14 Adding a portal Web server
k.     Return back to the portal configuration page.
Figure 15 Portal configuration page
l.     Click the  icon on the right side of Interface policy to enter the Interface Policy page.
Figure 16 Interface policy page
m.     Click the Add icon  at the upper right of the page to add an interface policy.
n.     Select interface Vlan100. Select IPv4 configuration and enable portal authentication. Use the direct authentication method. Apply portal Web server newpt and specify the BAS-IP address as 2.2.2.1.
o.     Click Apply.
Figure 17 Adding an interface policy
5.     Save the configuration:
Click the Save icon  at the upper left of the page.
Configuring the RADIUS server
Add user accounts on the RADIUS server and make sure it can provide authentication, authorization, and accounting services.
For more information about configuring user accounts on the RADIUS server, see the user guide for the RADIUS server.
1.     On the Security > Authentication > RADIUS page, verify that the rs1 RADIUS scheme has been added correctly.
2.     On the Security > Authentication > ISP Domains page, verify that the dm1 ISP domain has been added correctly.
3.     After the portal user comes online, access the Security > Access Control > Portal page to verify that the number of users on interface Vlan100 is 1.
