H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
29-System Log
29-System Log 45.35 KB
System Log Quick Start Configuration Guide
None.
The system can output log messages to different destinations, such as the log buffer and log hosts. You can set the log output destinations independently on their configuration pages.
Procedures
1.     Configure log hosts:
# From the left navigation pane, select Log > Settings.
# On the system log settings page, enter the IP address of a log host (192.168.1.1 in this example), and then click the Add icon  to add the log host.
Figure 1 System log settings – adding a log host
2.     Save the configuration.
Click the Save icon  at the upper left of the page.
None.
