H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
01-Compatible Product Models
01-Compatible Product Models 181.11 KB
Table 1 shows the switch series that supports Web login by default. For these switch series, HTTP and HTTPS are enabled and Web login information is configured by default. You can use the default login information to log in to the device from the Web interface, including the device IP, username, password, and user role.
Table 1 Switch series that supports Web login by default
Switch series
Device IP
Username/password
MS4100V2-EI switch series
192.168.0.233
admin/admin
S1850-X switch series
S1850V2-X switch series
S1850V2-EI switch series
S5000V3-EI switch series
S5000V5-EI switch series
S5000E-X switch series
S5000X-EI switch series
S5000-E switch series
US300 switch series
WAS6000 switch series
WS5810-WiNet switch series
WS5820-WiNet switch series
WS5850-WiNet switch series
NS200 switch series
192.168.1.1 (Release 3115P03 and later)
admin/admin
NS300 switch series
192.168.1.1
admin/admin
S5130-WiNet switch series
192.168.0.233
admin/admin
S5500V2-WiNet switch series
192.168.0.233
admin/admin
To log in to the device from the Web interface of other switch series:
1.     Make sure the switch supports Web login. For the support for Web login, see login management configuration in Fundamentals Configuration Guide for the switch.
2.     Log in to the device from the console port and configure required settings for Web login.
¡     Enable HTTP and HTTPS.
¡     Configure the IP address, username, password, and user role.
3.     Log in to the device from the Web interface.
The switch series that supports Web login by default is subject to change over time. For more information, see the device nameplate. If a switch supports Web login by default, you can obtain the device IP, username, and password from its nameplate.
Figure 1 Device nameplate (S5130-28S-WiNet)
