H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
16-Spanning Tree
16-Spanning Tree 272.58 KB
Configuring MSTP
As shown in Figure 1, Device A and Device B operate at the core layer, and Device C and Device D operate at the distribution layer. The ports on the devices have the same path cost, and they all permit VLANs 11 through 30.
Configure MSTP to meet the following requirements:
·     Device A, Device B, Device C, and Device D belong to the same MST region.
·     MSTIs are used to share the traffic of VLANs 11 through 20 and of VLANs 21 through 30.
Figure 1 Network diagram
Analysis
To assign the devices to the same MST region, make sure the following MST region parameters are the same on the devices:
·     Spanning tree mode (the default mode MSTP is used).
·     Region name (test in this example).
·     Revision level (the default value 0 is used).
·     VLAN-to-instance mappings (VLANs 11 through 20 to MSTI 1, and VLANs 21 through 30 to MSTI 2).
To use redundant links to share the traffic of different VLANs (as shown in Figure 2), perform the following tasks:
·     Configure Device A as the root bridge of MSTI 1.
·     Configure Device B as the root bridge of MIST 2.
·     Assign priorities to Device A, Device B, Device C, and Device D in MSTI 0 in descending order for Device A to be the regional root bridge.
Figure 2 MSTIs mapped to different VLANs
Configuring Device A
1.     Create VLANs 11 through 30:
a.     From the left navigation pane, select Network > Links > VLAN.
b.     Click the Add icon  to create VLANs 11 through 30.
c.     Enter 11-30 in the VLAN list field.
d.     Click Apply.
Figure 3 Creating VLANs
2.     Configure GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to trunk VLANs 11 through 30:
a.     From the left navigation pane, select Network > Interfaces > Interfaces.
b.     Click the  icon next to GigabitEthernet 1/0/1.
c.     Set the link type to Trunk.
d.     Enter 11-30 in the Permit VLAN List field.
e.     Click Apply.
The system displays a success message after it configures VLAN parameters for the interfaces.
f.     Configure GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 in the same way GigabitEthernet 1/0/1 is configured. (Details not shown.)
Figure 4 Configuring VLAN parameters
3.     Enable STP:
a.     From the left navigation pane, select Network > Links > STP.
b.     Click Enable STP.
The default spanning tree mode is MSTP.
Figure 5 Enabling STP
4.     Configure the MST region name and VLAN-to-MSTI mapping:
a.     Click the  icon next to MST region to access the MST Region Settings page.
b.     Configure the MST region name as Test.
c.     Map VLANs 11 through 20 to MSTI 1.
d.     Map VLANs 21 through 30 to MSTI 2, and set the MSTP revision level to 0.
e.     Click the  icon next to MST Region Settings to return to the STP page.
Figure 6 Configuring the MST region
5.     Configure Device A as the root bridge of MSTI 0 and MSTI 1:
a.     Click the  icon next to MSTI settings to access the STI Settings page.
b.     Set the root type for MSTI 0 to Primary root.
c.     Set the root type for MSTI 1 to Primary root.
d.     Click Apply.
The system displays a success message after it configures STI settings.
Figure 7 Configuring STI settings
6.     Save the configuration:
Click the Save icon  at the upper left of the page.
Configuring Device B
d.     Click Apply.
e.     Click Apply.
3.     Enable STP:
Figure 8 Configuring the MST region
5.     Configure Device B as the root bridge of MSTI 2 and a secondary root bridge of MSTI 0:
b.     Set the root type for MSTI 0 to Secondary root.
c.     Set the root type for MSTI 2 to Primary root.
d.     Click Apply.
Figure 9 Configuring STI setting
Configuring Device C
d.     Click Apply.
2.     Configure GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 as trunk VLANs 11 through 30:
e.     Click Apply.
3.     Enable STP:
Figure 10 Configuring the MST region
5.     Save the configuration:
Configuring Device D
d.     Click Apply.
e.     Click Apply.
3.     Enable STP:
Figure 11 Configuring the MST region
5.     Set the device priority to 36864 in MSTI 0, which is lower than the default priority 32768 of Device C:
b.     Set the priority for MSTI 0 to 36864.
c.     Click Apply.
Figure 12 Configuring STI settings
1.     On the Network > Links > STP > Port Instance State page, view the port role and STP state for each interface to verify that Layer 2 loops have been eliminated in each MSTI.
2.     Verify that the network can accommodate topology changes:
a.     Shut down GigabitEthernet 1/0/1 on Device C.
b.     On the Network > Links > STP > Port Instance State page for Device C, verify that GigabitEthernet 1/0/2 becomes the uplink port for MSTI 0 and MSTI 1.
