H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
26-Ping and Tracert
26-Ping and Tracert 142.50 KB
Ping and Tracert Quick Start Configuration Guide
The ping and tracert utility using methods are the same on IPv4 and IPv6 networks. The following procedures use the utilities on the IPv4 network.
Procedures
Using the ping utility to text link connectivity
1.     Assigning IP addresses to the network interfaces. (Details not shown.)
2.     Perform a ping test.
a.     From the left navigation pane, select Network > Probe > Ping.
b.     Click the IPv4 Ping tab.
c.     Specify the destination IP address or host name.
d.     Click Start. The ping test result will be displayed in the Result area.
Figure 1 Successful ping
Figure 2 Failed ping
Using the Tracert utility to text link connectivity
2.     Perform a tracert test.
a.     From the left navigation pane, select Network > Probe > Tracert.
b.     Click the IPv4 Tracert tab.
d.     Click Start. The Tracert test result will be displayed in the Result area.
Figure 3 Successful tracert
Figure 4 Failed tracert
