H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
09-Static Routing
09-Static Routing 156.62 KB
Static Routing Quick Start Configuration Guide
As shown in Figure 1, configure static routes on Switch A, Switch B, and Switch C for interconnections between any two hosts.
Figure 1 Network diagram
Configuring Switch A
1.     Configure VLAN interfaces and assign IP addresses to the interfaces:
From the left navigation pane, select Network > Links > VLAN.
¡     Click the Add icon  to add a VLAN.
¡     Set the VLAN ID to 300.
¡     Click Apply.
Figure 2 Creating a VLAN
¡     Click the  icon next to VLAN 300 on the VLAN configuration page to edit the VLAN.
¡     Add GE 1/0/1 connected to Host A to the untagged port list.
¡     Select Configure VLAN interface for IP address of the VLAN interface.
¡     Set the IP address to 1.1.2.3 and mask length to 24.
¡     Click Apply.
¡     Create VLAN-interface 500 and set its IP address. (Details not shown.)
Figure 3 Editing VLAN settings
2.     Configure a static route:
¡     From the left navigation pane, select Network > Routing > Static Routing.
¡     On the IPv4 static route configuration page that opens, click the Add icon  to add a static route.
¡     Set the destination IP address to 0.0.0.0 that matches any destination IP addresses.
¡     Set the mask length to 0.
¡     Clear the Output interface option.
¡     Set the next hop IP address to 1.1.4.2.
¡     Use default settings for other parameters.
¡     Click Apply.
Figure 4 Adding a static route
3.     Save the configuration:
Click the Save icon  to save the configuration.
Configuring Switch B
Details not shown.
¡     Set the destination IP address to 1.1.2.0.
¡     Set the mask length to 24.
¡     Set the next hop IP address to 1.1.4.1.
¡     Click Apply.
Figure 5 Adding a static route to the subnet attached to Host A
¡     Click the Add icon  to add a static route.
¡     Set the destination IP address to 1.1.3.0.
¡     Set the next hop IP address to 1.1.5.6.
¡     Click Apply.
Figure 6 Adding a static route to the subnet attached to Host C
Configuring Switch C
Details not shown.
¡     Set the destination IP address to 0.0.0.0.
¡     Set the next hop IP address to 1.1.5.5.
¡     Click Apply.
Figure 7 Configuring an IPv4 static route
On any host, verify that you can ping the other two hosts.
