H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
10-Policy-Based Routing
10-Policy-Based Routing 110.37 KB
IPv4 Local PBR Quick Start Configuration Guide
As shown in Figure 1, configure PBR on Switch A to forward all TCP packets to the next hop 1.1.2.2 (Switch B).
Figure 1 Network diagram
Configuring Switch A
1.     Configure VLAN interfaces and assign IP addresses to the interfaces:
From the left navigation pane, select Network > Links > VLAN.
¡     Click the Add icon  to add a VLAN. Set the VLAN ID to 10. Click Apply.
Figure 2 Creating a VLAN
¡     Click the  icon next to VLAN 10 on the VLAN configuration page to edit the VLAN.
¡     Add GE 1/0/1 connected to Switch B to the untagged port list.
¡     Select Configure VLAN interface for IP address of the VLAN interface.
¡     Set the IP address to 1.1.2.1 and mask length to 24.
¡     Click Apply.
¡     Configure VLAN-interface 20 and set its IP address. (Details not shown.)
Figure 3 Editing VLAN settings
2.     Configure PBR settings:
From the left navigation pane, select Network > Routing > Policy-Based Routing.
¡     On the IPv4 PBR configuration page that opens, click the Add icon  to add an IPv4 PBR policy.
¡     Set the policy name to pbr.
¡     Select Local from the Applied on list.
¡     Click Add Node to add a node with number 5.
¡     Select Permit for Mode.
¡     Select Match IPv4 ACL for Match criterion, and add the  icon.
¡     Select the IPv4 ACL type in the dialog box that opens, and then click Apply.
¡     In the New IPv4 ACL dialog box that opens, select the advanced ACL category, set the ACL number to 3001, and then click Apply.
¡     In the New Rule for IPv4 Advanced ACL dialog box that opens, set the default permit action, set the IP protocol to 6 (TCP), clear the Continue to add next rule option, and then click Apply.
¡     Select Set the next hops for Action, and set the IP address to 1.1.2.2.
¡     Click Apply.
Figure 4 Adding an IPv4 PBR policy
3.     Save the configuration:
Click the Save icon  to save the configuration.
Configuring Switch B
Assign an IP address to each interface. (Details not shown.)
Configuring Switch C
1.     Perform telnet operations to verify that local PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Switch A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Switch A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Switch A. (Details not shown.)
