- H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
- 01-H3C Access Controllers AP's Association with the AC at Layer 2 Configuration Examples
- 02-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 2 (IPv6) Configuration Examples
- 03-H3C Access Controllers AP's Association with the AC at Layer 3 Configuration Examples
- 04-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 3 (IPv6) Configuration Examples
- 05-H3C Access Controllers Local MAC Authentication Configuration Examples (V7)
- 06-H3C Access Controllers MAC Authentication with Guest VLAN Assignment Configuration Examples (V7)
- 07-H3C Access Controllers Comware 7 MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 08-H3C Access Controllers MAC Authentication and PSK Authentication Configuration Examples (V7)
- 09-H3C Access Controllers Auto AP Configuration Examples (V7)
- 10-H3C Access Controllers WLAN Load Balancing Configuration Examples (V7)
- 11-H3C Access Controllers WEP Encryption Configuration Examples
- 12-H3C Access Controllers Local Forwarding Configuration Examples
- 13-H3C Access Controllers Layer 2 Static Aggregation Configuration Examples (V7)
- 14-H3C Access Controllers Remote 802.1X Authentication Configuration Examples (V7)
- 15-H3C Access Controllers Comware 7 Remote 802.1X Authentication (IPv6) Configuration Examples
- 16-H3C Access Controllers 802.1X Authentication with ACL Assignment Through IMC Server @CE@ (V7)
- 17-H3C Access Controllers 802.1X Authentication with User Profile Assignment Through IMC Server @CE@ (V7)
- 18-H3C Access Controllers EAD Authentication Configuration Examples (V7)
- 19-H3C Access Controllers Comware 7 EAD Authentication (IPv6) Configuration Examples
- 20-H3C Access Controllers Remote Portal Authenticaiton Configuration Examples (V7)
- 21-H3C Access Controllers Comware 7 Remote Portal Authenticaiton (IPv6) Configuration Examples
- 22-H3C Access Controllers Local Portal Authentication Configuration Examples (V7)
- 23-H3C Access Controllers Comware 7 Local Portal Authentication (IPv6) Configuration Examples
- 24-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication Configuration Examples (V7)
- 25-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples(V7)
- 26-H3C Access Controllers Local Portal Authentication through LDAP Server Configuration Examples (V7)
- 27-H3C Access Controllers Local Portal Authentication through LDAP Server (IPv6) Configuration Examples(V7)
- 28-H3C Access Controllers MAC-based Portal Quick Authenticaiton Configuration Example (V7)
- 29-H3C Access Controllers Comware 7 MAC-based Quick Portal Authenticaiton (IPv6) Configuration Example
- 30-H3C Access Controllers SSH Configuration Examples (7)
- 31-H3C Access Controllers Internal-to-External Access Through NAT Configuration Examples (V7)
- 32-H3C Access Controllers Static Blacklist Configuration Examples
- 33-H3C Access Controllers Comware 7 WLAN Access (IPv6) Configuration Examples
- 34-H3C Access Controllers Inter-AC Roaming Configuration Examples (V7)
- 35-H3C Access Controllers Comware 7 Inter-AC Roaming (IPv6) Configuration Examples
- 36-H3C Access Controllers HTTPS Login Configuration Examples (V7)
- 37-H3C Access Controllers Client Rate Limiting Configuration Examples (V7)
- 38-H3C Access Controllers Client Quantity Control Configuration Examples
- 39-H3C Access Controllers Medical RFID Tag Management Configuration Examples (V7)
- 40-H3C Access Controllers iBeacon Management Configuration Examples (V7)
- 41-H3C Access Controllers Remote AP Configuration Examples (V7)
- 42-H3C Access Controllers PSK Encryption Configuration Examples
- 43-H3C Access Controllers WIPS Configuration Examples (V7)
- 44-H3C Access Controllers Layer 2 Multicast Configuration Example (V7)
- 45-H3C Access Controllers IRF Setup with Members Directly Connected Configuration Examples (V7)
- 46-H3C Access Controllers IRF Setup with Members Not Directly Connected Configuration Examples (V7)
- 47-H3C Access Controller Modules IRF Setup with Members in One Chassis Configuration Examples (V7)
- 48-H3C Access Controller Modules IRF Setup with Members in Different Chassis Configuration Examples (V7)
- 49-H3C Access Controllers Comware 7 IP Source Guard (IPv6) Configuration Examples
- 50-Policy-Based Forwarding with Dual Gateways Configuration Example
- 51-H3C Access Controllers Comware 7 Policy-Based Forwarding with Dual Gateways (IPv6) Configuration Example
- 52-Policy-Based Local Forwarding Configuration Examples
01-H3C Access Controllers AP's Association with the AC at Layer 2 Configuration Examples | 68.15 KB |
H3C Access Controllers |
Comware 7 AP's Association with the AC at |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring an AP to associate with the AC at Layer 2
Configuring the Layer 2 switch
Introduction
This document provides an example for configuring APs to associate with the AC at Layer 2.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of WLAN access.
As shown in Figure 1, the AC acts as a DHCP server to assign IP addresses to the AP, client, and host, and the Layer 2 switch supplies power to the AP. Assume centralized forwarding is used in this example.
Configure wireless services to enable the client to associate with the AC through the AP and communicate with the host.
When you configure AP's association with the AC at Layer 2, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· Configure the switch's interface that connects the switch to the AP to deny packets from VLAN 1 in case there are too many packets in VLAN 1.
Procedures
Configuring the AC
1. Configure DHCP:
# Enable DHCP.
<AC> system-view
[AC] dhcp enable
# Create DHCP address pool 1 to assign an IP address to the AP, and specify subnet 192.168.201.0/24 in the DHCP address pool.
[AC] dhcp server ip-pool 1
[AC-dhcp-pool-1] network 192.168.201.0 mask 255.255.255.0
# Specify the gateway address as 192.168.201.1 in the DHCP address pool.
[AC-dhcp-pool-1] gateway-list 192.168.201.1
[AC-dhcp-pool-1] quit
# Create DHCP address pool 2 to assign an IP address to the client, and specify subnet 192.168.202.0/24 in the DHCP address pool.
[AC] dhcp server ip-pool 2
[AC-dhcp-pool-2] network 192.168.202.0 mask 255.255.255.0
# Specify the gateway address as 192.168.202.1 in the DHCP address pool.
[AC-dhcp-pool-2] gateway-list 192.168.202.1
[AC-dhcp-pool-2] quit
# Create DHCP address pool 3 to assign an IP address to the host, and specify subnet 192.168.203.0/24 in the DHCP address pool.
[AC] dhcp server ip-pool 3
[AC-dhcp-pool-3] network 192.168.203.0 mask 255.255.255.0
# Specify the gateway address as 192.168.203.1 in the DHCP address pool.
[AC-dhcp-pool-3] gateway-list 192.168.203.1
[AC-dhcp-pool-3] quit
2. Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.201.1 255.255.255.0
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. VLAN 200 will be used for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.168.202.1 24
[AC-Vlan-interface200] quit
# Create VLAN 300 and VLAN-interface 300, and assign an IP address to the VLAN interface. The AC will use this IP address to associate with the host.
[AC] vlan 300
[AC-vlan300] quit
[AC] interface vlan-interface 300
[AC-Vlan-interface300] ip address 192.168.203.1 24
[AC-Vlan-interface300] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100, 200, and 300.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200 300
# Configure the PVID as VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
3. Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID as service.
[AC-wlan-st-1] ssid service
# Enable the service template.
[AC-wlan-st-1] quit
4. Configure the AP:
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA560-WW
[AC-wlan-ap-officeap] serial-id 219801A1NM8182032235
# Bind service template 1 and VLAN 200 to radio 1.
[AC-wlan-ap-officeap] radio 1
[AC-wlan-ap-officeap-radio-1] service-template 1 vlan 200
# Enable radio 1.
[AC-wlan-ap-officeap-radio-1] radio enable
[AC-wlan-ap-officeap-radio-1] return
# Create VLANs 100, 200, and 300. The switch will use VLAN 100 to forward packets between the AC and the AP. VLAN 200 will be used for client access. VLAN 300 will be used for host access.
<L2 switch> system-view
[L2 switch] vlan 100
[L2 switch-vlan100] quit
[L2 switch] vlan 200
[L2 switch-vlan200] quit
[L2 switch] vlan 300
[L2 switch-vlan300] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, configure the PVID as VLAN 100, and assign the port to VLANs 100, 200, and 300.
[L2 switch] interface gigabitEthernet 1/0/1
[L2 switch-GigabitEthernet1/0/1] port link-type trunk
[L2 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200 300
[L2 switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
[L2 switch-GigabitEthernet1/0/1] quit
[L2 switch] interface gigabitEthernet 1/0/2
[L2 switch-GigabitEthernet1/0/2] port link-type trunk
[L2 switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[L2 switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200
[L2 switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
[L2 switch-GigabitEthernet1/0/2] poe enable
[L2 switch-GigabitEthernet1/0/2] quit
# Configure GigabitEthernet 1/0/3 that connects the switch to the host as an access port, and assign the port to VLAN 300.
[L2 switch] interface gigabitEthernet 1/0/3
[L2 switch-GigabitEthernet1/0/3] port access vlan 300
[L2 switch-GigabitEthernet1/0/3] quit
# Verify that the AP is in R/M state.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 256
Remaining APs: 255
Total AP licenses: 128
Remaining AP licenses: 127
Sync AP licenses: 0
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
officeap 1 R/M WA560-WW 219801A1NM8182032235
# Verify that the client is connected to radio 1 on AP officeap.
<AC> display wlan client
Total number of clients: 1
MAC address Username AP name RID IP address IPv6 address VLAN
109a-dd9d-fc68 N/A officeap 1 192.168.202.4 N/A 200
# Verify that the client and the host can ping each other successfully.
C:\Users\system32>ping 192.168.202.4 -t
Pinging 192.168.202.4 with 32 bytes of data:
Reply from 192.168.202.4: bytes=32 time=8ms TTL=255
Reply from 192.168.202.4: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.202.4:
Packets: Sent = 11, Received = 11, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 8ms, Average = 0ms
Control-C
^C
C:\Users\system32>
Configuration files
· AC:
dhcp enable
vlan 1
vlan 100
vlan 200
vlan 300
ssid service
interface Vlan-interface1
interface Vlan-interface100
interface Vlan-interface200
ip address 192.168.202.1 255.255.255.0
interface Vlan-interface300
ip address 192.168.203.1 255.255.255.0
vlan 1
radio 1
radio enable
radio 2
· Layer 2 switch:
vlan 100
vlan 200
vlan 300
undo port trunk permit vlan 1 100 200 300
poe enable
Related documentation
· Layer 2 Command Reference in H3C Access Controllers Command References
· Layer 2 Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Command Reference in H3C Access Controllers Command References
· WLAN Configuration Guide in H3C Access Controllers Configuration Guides
