H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers and Access Points Configuration Examples(V7)-6W101
Table of Contents
Related Documents
03-H3C Access Controllers AP's Association with the AC at Layer 3 Configuration Examples
Comware 7 AP's Association with the AC at
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides an example for configuring APs to associate with the AC at Layer 3.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of WLAN access.
Example: Configuring an AP to associate with the AC at Layer 3
As shown in Figure 1, the Layer 3 switch acts as a DHCP server to assign IP addresses to the AP, client, and host. Assume centralized forwarding is used in this example.
Configure wireless services to enable the client to associate with the AC through the AP and enable the client to communicate with the host. Assign the AC, AP, client, and host to VLANs 100, 400, 200, and 300, respectively.
Figure 1 Network diagram
When you configure AP's association with the AC at Layer 3, follow these restrictions and guidelines:
·     Use the serial ID labeled on the AP's rear panel to specify an AP.
·     Configure the switch's interface that connects the switch to the AP to deny packets from VLAN 1 in case there are too many packets in VLAN 1.
Procedures
Configuring the AC
1.     Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC] interface vlan-interface100
[AC-Vlan-interface100] ip address 192.168.10.1 255.255.255.0
[AC-Vlan-interface100] quit
# Create VLAN 200. The AC will use VLAN 200 to forward client traffic.
[AC] vlan 200
[AC-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure a static route to the switch.
[AC] ip route-static 192.168.40.0 24 192.168.10.83
3.     Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID as service.
[AC-wlan-st-1] ssid service
# Enable the service template.
[AC-wlan-st-1] quit
4.     Configure the AP:
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA560-WW
[AC-wlan-ap-officeap] serial-id 219801A1NM8182032235
# Bind service template 1 and VLAN 200 to radio 1.
[AC-wlan-ap-officeap] radio 1
[AC-wlan-ap-officeap-radio-1] service-template 1 vlan 200
# Enable radio 1.
[AC-wlan-ap-officeap-radio-1] radio enable
[AC-wlan-ap-officeap-radio-1] return
Configuring the Layer 3 switch
1.     Configure switch interfaces:
# Create VLAN 100, VLAN 400, VLAN-interface 100 and VLAN-interface 400, and assign IP addresses to the VLAN interfaces. The switch will use VLAN 100 and VLAN 400 to forward packets between the AC and the AP.
<L3 switch> system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface100] ip address 192.168.10.83 255.255.255.0
[L3 switch-Vlan-interface100] quit
[L3 switch] vlan 400
[L3 switch-vlan400] quit
[L3 switch] interface vlan-interface 400
[L3 switch-Vlan-interface400] ip address 192.168.40.1 255.255.255.0
[L3 switch-Vlan-interface400] quit
# Create VLAN 200 and VLAN-interface 200 and assign an IP address to the VLAN interface. This VLAN will be used for client access.
[L3 switch] vlan 200
[L3 switch-vlan200] quit
[L3 switch] interface vlan-interface 200
[L3 switch-Vlan-interface200] ip address 192.168.20.1 255.255.255.0
[L3 switch-Vlan-interface200] quit
# Create VLAN 300 and VLAN-interface 300 and assign an IP address to the VLAN interface. This VLAN will be used for host access.
[L3 switch] vlan 300
[L3 switch-vlan300] quit
[L3 switch] interface vlan-interface 300
[L3 switch-Vlan-interface300] ip address 192.168.30.1 255.255.255.0
[L3 switch-Vlan-interface300] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, and assign the port to VLANs 100 and 200.
[L3 switch] interface gigabitEthernet 1/0/1
[L3 switch-GigabitEthernet1/0/1] port link-type trunk
[L3 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[L3 switch-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, remove the port from VLAN 1, configure the PVID as VLAN 400, and assign the port to VLANs 200 and 400.
[L3 switch] interface gigabitEthernet 1/0/2
[L3 switch-GigabitEthernet1/0/2] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[L3 switch-GigabitEthernet1/0/2] port trunk permit vlan 200 400
[L3 switch-GigabitEthernet1/0/2] port trunk pvid vlan 400
[L3 switch-GigabitEthernet1/0/2] quit
# Configure GigabitEthernet 1/0/3 that connects the switch to the host as an access port, and assign the port to VLAN 300.
[L3 switch] interface gigabitEthernet 1/0/3
[L3 switch-GigabitEthernet1/0/3] port access vlan 300
[L3 switch-GigabitEthernet1/0/3] quit
2.     Configure DHCP:
# Enable DHCP.
[L3 switch] dhcp enable
# Create DHCP address pool 1 to assign an IP address to the AP, and specify subnet 192.168.40.0/24 in the DHCP address pool.
[L3 switch] dhcp server ip-pool 1
[L3 switch-dhcp-pool-1] network 192.168.40.0 mask 255.255.255.0
# Specify the gateway address as 192.168.40.1 in the DHCP address pool.
[L3 switch-dhcp-pool-1] gateway-list 192.168.40.1
# Configure Option 43 to specify AC IP address in the hexadecimal format in DHCP address pool 1.
[L3 switch-dhcp-pool-1] option 43 hex 8007000001c0a80a01
[L3 switch-dhcp-pool-1] quit
# Create DHCP address pool 2 to assign an IP address to the client, and specify subnet 192.168.20.0/24 in the DHCP address pool.
[L3 switch] dhcp server ip-pool 2
[L3 switch-dhcp-pool-2] network 192.168.20.0 mask 255.255.255.0
# Specify the gateway address as 192.168.20.1 in the DHCP address pool.
[L3 switch-dhcp-pool-2] gateway-list 192.168.20.1
[L3 switch-dhcp-pool-2] quit
# Create DHCP address pool 3 to assign an IP address to the host, and specify subnet 192.168.30.0/24 in the DHCP address pool.
[L3 switch] dhcp server ip-pool 3
[L3 switch-dhcp-pool-3] network 192.168.30.0 mask 255.255.255.0
# Specify the gateway address as 192.168.30.1 in the DHCP address pool.
[L3 switch-dhcp-pool-3] gateway-list 192.168.30.1
[L3 switch-dhcp-pool-3] quit
# Verify that the AP is in R/M state.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 256
Remaining APs: 255
Total AP licenses: 128
Remaining AP licenses: 127
Sync AP licenses: 0
                                 AP information
 State : I = Idle,      J  = Join,        JA = JoinAck,    IL = ImageLoad
          C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
officeap                       1     R/M   WA560-WW        219801A1NM8182032235
# Verify that the client is connected to radio 1 on AP officeap.
<AC> display wlan client
Total number of clients: 1
MAC address     Username   AP name     RID   IP address      IPv6 address   VLAN
90b9-311a-bef6  N/A        officeap    1     192.168.20.3    N/A            200
# Verify that the client and the host can ping each other successfully.
C:\Users\system32>ping 192.168.20.3 -t
Pinging 192.168.20.3 with 32 bytes of data:
Reply from 192.168.20.3: bytes=32 time=2470ms TTL=63
Reply from 192.168.20.3: bytes=32 time=2ms TTL=63
Reply from 192.168.20.3: bytes=32 time=1427ms TTL=63
Reply from 192.168.20.3: bytes=32 time=86ms TTL=63
Reply from 192.168.20.3: bytes=32 time=142ms TTL=63
Reply from 192.168.20.3: bytes=32 time=561ms TTL=63
Reply from 192.168.20.3: bytes=32 time=84ms TTL=63
Reply from 192.168.20.3: bytes=32 time=465ms TTL=63
Reply from 192.168.20.3: bytes=32 time=114ms TTL=63
Reply from 192.168.20.3: bytes=32 time=124ms TTL=63
Reply from 192.168.20.3: bytes=32 time=446ms TTL=63
Ping statistics for 192.168.20.3:
    Packets: Sent = 12, Received = 12, Lost = 0 (0% loss),
    Minimum = 2ms, Maximum = 2470ms, Average = 495ms
Control-C
^C
C:\Users\system32>
Configuration files
·     AC:
vlan 100
vlan 200
interface Vlan-interface100
 ssid service
 vlan 1
 radio 1
  radio enable
 radio 2
·     Layer 3 switch:
 dhcp enable
vlan 100
vlan 200
vlan 300
vlan 400
interface Vlan-interface200
interface Vlan-interface300
interface Vlan-interface400
Related documentation
·     Layer 3 Command Reference in H3C Access Controllers Command References
·     Layer 3 Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Command Reference in H3C Access Controllers Command References
·     WLAN Configuration Guide in H3C Access Controllers Configuration Guides
