H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers and Access Points Configuration Examples(V7)-6W101
Table of Contents
Related Documents
45-H3C Access Controllers IRF Setup with Members Directly Connected Configuration Examples (V7)
Comware 7 IRF Setup with Members Directly Connected
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides an example for setting up an IRF fabric with two member devices that are directly connected.
The Intelligent Resilient Framework (IRF) technology is proprietary to H3C. This technology is a true stacking technology that creates a large virtual stack called IRF fabric from multiple devices to provide data center class availability and scalability. IRF offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IRF and Ethernet link aggregation.
Example: Setting up a two-member IRF fabric with members directly connected
As shown in Figure 1, use AC 1 and AC 2 to set up an IRF fabric. The IRF network interfaces on the ACs are directly connected.
Configure LACP MAD on the multi-member link aggregation to the switch, an H3C device that supports extended LACP.
Assign IRF links and non-IRF links to different VLANs for traffic isolation at Layer 2.
Figure 1 Network diagram
When you set up an IRF fabric with members directly connected, follow the restrictions and guidelines in this section.
Hardware compatibility
An access controller can form an IRF fabric only with access controllers of the same model.
Software requirements
All IRF member devices must run the same software image version as the master. For software synchronization, make sure the software auto-update feature is enabled.
IRF size restrictions
The maximum number of member devices in an IRF fabric varies by device model.
IRF member ID restrictions
Make sure each IRF member device is assigned a unique member ID. For a new member ID to take effect, you must reboot the device.
The port number of the IRF port is the same as the IRF member ID of the device.
IRF topo-domain ID and MAD domain ID restrictions
Make sure all member devices have the same topo-domain ID and MAD domain ID. For a new topo-domain ID to take effect on a device, you must reboot the device.
IRF port binding requirements
An IRF port must have a minimum of one hybrid channel, or a minimum of one data channel and one control channel.
The network interfaces bound to an IRF port must operate at the same rate. The two ends of an IRF link must operate at the same rate.
For the port bindings to take effect, perform the following tasks:
1.     Save the configuration.
2.     Reboot the device or activate the IRF port configuration.
IRF network interface shutdown restrictions
Do not use the shutdown command on an IRF network interface if the interface is the only control channel available on the IRF standby device. If removing the channel is required, shut down the master's IRF network interfaces that have Layer 2 connectivity to that interface.
Connectivity requirements
Make sure the member devices have Layer 2 connectivity with each other.
If the IRF fabric contains only two member devices, you can connect the member devices directly or through Layer 2 intermediate devices. If the IRF fabric contains more than two member devices, you must connect the member devices through Layer 2 intermediate devices.
IRF merge restrictions
If the IRF fabric splits, do not change the IRF settings on any IRF member devices before they reunite.
IRF member device bridge MAC address restrictions
Member devices cannot join the same IRF fabric if they have the same bridge MAC address.
IRF port binding removal restrictions
To remove a network interface from an IRF port, you must first shut down the IRF network interface.
Feature compatibility and configuration restrictions
Ethernet link aggregation restrictions
On the Layer 2 intermediate devices, do not configure per-packet load sharing on the Layer 2 link aggregation groups that connect to multiple member devices of the IRF fabric.
As a best practice, configure Ethernet link aggregation settings after the IRF fabric is formed.
VLAN restrictions
Do not assign IRF links to VLANs that run on links that forward data traffic.
NAT restrictions
NAT is not supported on an IRF fabric.
Procedures
Configuring the switch
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the aggregation group of the aggregate interface to operate in dynamic mode.
<Switch> system-view
[Switch] interface bridge-aggregation 1
[Switch-Bridge-Aggregation1] link-aggregation mode dynamic
[Switch-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 to aggregation group 1.
[Switch-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign GigabitEthernet 1/0/2 to aggregation group 1.
[Switch-GigabitEthernet1/0/2] port link-aggregation group 1
# Enable link-aggregation traffic redirection.
[Switch] link-aggregation lacp traffic-redirect-notification enable
Configuring AC 1
# Assign Ten-GigabitEthernet 1/0/25 to IRF-port 1.
<AC1> system-view
[AC1] irf-port 1
[AC1-irf-port1] port group interface ten-gigabitethernet 1/0/25
[AC1-irf-port1] quit
# Specify the member priority as 2. AC 1 will be the master device.
[AC1] irf member 1 priority 2
# Save the configuration.
[AC1] save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
# Activate the IRF port configuration.
[AC1] irf-port-configuration active
Configuring AC 2
# Change the IRF member ID to 2.
<AC2> system-view
[AC2] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue?[
Y/N]:y
[AC2] quit
# Reboot the AC for the new member ID to take effect.
<AC2> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
Now rebooting, please wait...
# Assign Ten-GigabitEthernet 2/0/25 to the IRF port.
<AC2> system-view
[AC2] irf-port 2
[AC2-irf-port2] port group interface ten-gigabitethernet 2/0/25
[AC2-irf-port2] quit
[AC2] save
[AC2] irf-port-configuration active
System is starting...
AC 1 and AC 2 perform master election. AC 2 fails master election and reboots to form an IRF fabric with AC 1.
Configuring the IRF fabric
# Change the name of the IRF fabric to IRF.
<AC1> system-view
[AC1] system-name IRF
# Configure descriptions for AC 1 and AC 2, respectively.
[IRF] irf member 1 description AC 1
[IRF] irf member 2 description AC 2
# Create a Layer 2 aggregate interface named Bridge-Aggregation 1, and configure the aggregation group of the aggregate interface to operate in dynamic mode.
[IRF] interface bridge-aggregation 1
[IRF-Bridge-Aggregation1] link-aggregation mode dynamic
# Enable LACP MAD on the aggregate interface.
[IRF-Bridge-Aggregation1] mad enable
[IRF-Bridge-Aggregation1] quit
[IRF] link-aggregation lacp traffic-redirect-notification enable
[IRF] interface gigabitethernet 1/0/1
[IRF-GigabitEthernet1/0/1] port link-aggregation group 1
[IRF-GigabitEthernet1/0/1] quit
# Assign GigabitEthernet 2/0/1 to aggregation group 1.
[IRF] interface gigabitethernet 2/0/1
[IRF-GigabitEthernet2/0/1] port link-aggregation group 1
[IRF-GigabitEthernet2/0/1] quit
# Create VLAN 400 and assign IRF network interfaces Ten-GigabitEthernet 1/0/25 and Ten-GigabitEthernet 2/0/25 to the VLAN. The VLAN will transmit traffic for IRF links.
[IRF] vlan 400
[IRF-vlan400] port ten-gigabitethernet 1/0/25
[IRF-vlan400] port ten-gigabitethernet 2/0/25
[IRF-vlan400] quit
# Display IRF information. Verify that AC 1 is the master device.
[IRF] display irf
Member ID    Role    Priority  CPU MAC         Description
   *1        Master  2         50da-0051-2608  AC 1
   +2        Standby 1         50da-0051-2670  AC 2
The asterisk (*) indicates the master.
The plus sign (+) indicates the device through which you are logged in.
The right angle bracket (>) indicates the device's stack capability is disabled.
Bridge MAC of the IRF: 50da-0051-2608
Auto upgrade         : Enabled
MAC persistence      : 6 min
Topo-domain ID       : 0
Auto merge           : Enabled
# Display IRF link information. Verify that the IRF network interfaces on both member devices are up.
[IRF] display irf link
Member ID   Member Interfaces                   Status
1           XGE1/0/25(ctrl&data)                Up
2           XGE2/0/25(ctrl&data)                Up
# On the IRF fabric, display detailed information about aggregation groups. Verify that GigabitEthernet 1/0/1 and GigabitEthernet 2/0/1 are in aggregation group 1 and in Selected state.
[IRF] display link-aggregation verbose
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Dynamic
System ID: 0x8000, 50da-0051-2608
Local:
  Port             Status  Priority Oper-Key  Flag
  GE1/0/1          S       32768    1         {ACDEF}
  GE2/0/1          S       32768    1         {ACDEF}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  GE1/0/1          1       32768    1         0x8000, 3897-d633-f3c6 {ACDEF}
  GE2/0/1          2       32768    1         0x8000, 3897-d633-f3c6 {ACDEF}
# On the switch, display detailed information about aggregation groups. Verify that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are in aggregation group 1 and in Selected state.
[Switch] display link-aggregation verbose
             I -- Individual, * -- Management port
Management VLAN : None
System ID: 0x8000, 3897-d633-f3c6
Local:
  GE1/0/2          S       32768    1         {ACDEF}
Remote:
  GE1/0/1          2       32768    1         0x8000, 50da-0051-2608 {ACDEF}
  GE1/0/2          31      32768    1         0x8000, 50da-0051-2608 {ACDEF}
Configuration files
·     IRF fabric:
 sysname IRF
 irf mac-address persistent timer
 irf auto-update enable
 irf auto-merge enable
 irf member 2 priority 1
vlan 400
irf-port 1
 port group interface Ten-GigabitEthernet1/0/25
irf-port 2
 port group interface Ten-GigabitEthernet2/0/25
interface Bridge-Aggregation1
 mad enable
interface GigabitEthernet2/0/1
 port access vlan 400
·     Switch:
Related documentation
·     IRF Command Reference in H3C Access Controllers Command References
·     IRF Configuration Guide in H3C Access Controllers Configuration Guides
·     Layer 2LAN Switching Command Reference in H3C Access Controllers Command References
·     Layer 2LAN Switching Configuration Guide in H3C Access Controllers Configuration Guides
