H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers and Access Points Configuration Examples(V7)-6W101
Table of Contents
Related Documents
48-H3C Access Controller Modules IRF Setup with Members in Different Chassis Configuration Examples (V7)
Comware 7 IRF Setup with Members in Different Chassis
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides an example for setting up an IRF fabric with access controller modules in different chassis.
The Intelligent Resilient Framework (IRF) technology is proprietary to H3C. This technology is a true stacking technology that creates a large virtual stack called IRF fabric from multiple devices to provide data center class availability and scalability. IRF offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IRF and Ethernet link aggregation.
Example: Setting up an IRF fabric with access controller modules in different chassis
As shown in Figure 1, AC 1 is inserted into slot 1 on Switch A and AC 2 is inserted into slot 4 on Switch B. Switch A and Switch B are in an IRF fabric named IRF 1.
Use AC 1 and AC 2 to set up an IRF fabric named IRF 2. Configure LACP MAD on the multi-member link aggregation to IRF 1.
Figure 1 Network diagram
When you set up an IRF fabric with members in different chassis, follow the restrictions and guidelines in this section.
Hardware compatibility
An access controller module can form an IRF fabric only with access controller modules of the same model.
Software requirements
All IRF member devices must run the same software image version as the master. For software synchronization, make sure the software auto-update feature is enabled.
IRF size restrictions
The maximum number of member devices in an IRF fabric varies by device model.
IRF member ID restrictions
Make sure each IRF member device is assigned a unique member ID. For a new member ID to take effect, you must reboot the device.
The port number of the IRF port is the same as the IRF member ID of the device.
IRF topo-domain ID and MAD domain ID restrictions
Make sure all member devices have the same topo-domain ID and MAD domain ID. For a new topo-domain ID to take effect on a device, you must reboot the device.
IRF port binding requirements
An IRF port must have a minimum of one hybrid channel, or a minimum of one data channel and one control channel.
The network interfaces bound to an IRF port must operate at the same rate. The two ends of an IRF link must operate at the same rate.
For the port bindings to take effect, perform the following tasks:
1.     Save the configuration.
2.     Reboot the device or activate the IRF port configuration.
IRF network interface shutdown restrictions
Do not use the shutdown command on an IRF network interface if the interface is the only control channel available on the IRF standby device. If removing the channel is required, shut down the master's IRF network interfaces that have Layer 2 connectivity to that interface.
Connectivity requirements
Make sure the member devices have Layer 2 connectivity with each other.
If the IRF fabric contains only two member devices, you can connect the member devices directly or through Layer 2 intermediate devices. If the IRF fabric contains more than two member devices, you must connect the member devices through Layer 2 intermediate devices.
IRF merge restrictions
If the IRF fabric splits, do not change the IRF settings on any IRF member devices before they reunite.
IRF member device bridge MAC address restrictions
Member devices cannot join the same IRF fabric if they have the same bridge MAC address.
IRF port binding removal restrictions
To remove a network interface from an IRF port, you must first shut down the IRF network interface.
Feature compatibility and configuration restrictions
Ethernet link aggregation restrictions
On the Layer 2 intermediate devices, do not configure per-packet load sharing on the Layer 2 link aggregation groups that connect to multiple member devices of the IRF fabric.
On the intermediate devices, aggregate the physical links that connect to the IRF network interfaces of the IRF fabric.
If Bridge-Aggregation 1 exists by default, delete the aggregate interface to remove all its member ports from the aggregate interface.
As a best practice, configure Ethernet link aggregation settings after the IRF fabric is formed.
VLAN restrictions
Do not assign IRF links to VLANs that run on links that forward data traffic.
NAT restrictions
NAT is not supported on an IRF fabric.
Spanning tree feature restrictions
On the Layer 2 intermediate devices, disable the spanning tree feature on the ports through which packets of an IRF member device reaches another IRF member device.
WLAN hardware fast forwarding restrictions
To use WLAN hardware fast forwarding on an IRF fabric that contains access controller modules, follow these restrictions and guidelines:
·     For the EWPXM2WCMD0F, LSQM1WCMX20, and LSUM1WCMX20RT modules, make sure the following requirements are met: Each module has one Ten-GigabitEthernet interface to act as a non-IRF network interface and the other Ten-GigabitEthernet interface to act as an IRF network interface.
·     For the EWPXM1MAC0, EWPXM1WCME0, LSQM1WCMX40, LSUM1WCME0, and LSUM1WCMX40RT modules, make sure the following requirements are met: On each module, the Ten-GigabitEthernet interfaces in one group act as non-IRF network interfaces and the Ten-GigabitEthernet interfaces in the other group act as IRF network interfaces. Ten-GigabitEthernet n/0/1 and Ten-GigabitEthernet n/0/3 belong to one group, and Ten-GigabitEthernet n/0/2 and Ten-GigabitEthernet n/0/4 belong to another group. The integer n represents the IRF member ID.
Procedures
Configuring IRF 1
In this example, IRF 1 has been set up.
1.     Configure links used for transmitting LACP MAD packets between IRF 1 and IRF 2:
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the aggregation group of the aggregate interface to operate in dynamic mode.
<IRF1> system-view
[IRF1] interface bridge-aggregation 1
[IRF1-Bridge-Aggregation1] link-aggregation mode dynamic
[IRF1-Bridge-Aggregation1] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/2 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 1/2/0/2
[IRF1-Ten-GigabitEthernet1/2/0/2] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet1/2/0/2] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/4 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 1/2/0/4
[IRF1-Ten-GigabitEthernet1/2/0/4] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet1/2/0/4] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/2 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 2/4/0/2
[IRF1-Ten-GigabitEthernet2/4/0/2] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet2/4/0/2] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/4 to aggregation group 1.
[IRF1] interface ten-gigabitethernet 2/4/0/4
[IRF1-Ten-GigabitEthernet2/4/0/4] port link-aggregation group 1
[IRF1-Ten-GigabitEthernet2/4/0/4] quit
2.     Configure links used for network interfaces that connect to IRF 2:
# Create Layer 2 aggregate interface Bridge-Aggregation 2 for aggregating links to the IRF network interfaces of AC 1.
[IRF1] interface bridge-aggregation 2
[IRF1-Bridge-Aggregation2] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/1 to aggregation group 2.
[IRF1] interface ten-gigabitethernet 1/2/0/1
[IRF1-Ten-GigabitEthernet1/2/0/1] port link-aggregation group 2
[IRF1-Ten-GigabitEthernet1/2/0/1] quit
# Assign internal port Ten-GigabitEthernet 1/2/0/3 to aggregation group 2.
[IRF1] interface ten-gigabitethernet 1/2/0/3
[IRF1-Ten-GigabitEthernet1/2/0/3] port link-aggregation group 2
[IRF1-Ten-GigabitEthernet1/2/0/3] quit
# Create Layer 2 aggregate interface Bridge-Aggregation 3 for aggregating links to the IRF network interfaces of AC 2.
[IRF1] interface bridge-aggregation 3
[IRF1-Bridge-Aggregation3] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/1 to aggregation group 3.
[IRF1] interface ten-gigabitethernet 2/4/0/1
[IRF1-Ten-GigabitEthernet2/4/0/1] port link-aggregation group 3
[IRF1-Ten-GigabitEthernet2/4/0/1] quit
# Assign internal port Ten-GigabitEthernet 2/4/0/3 to aggregation group 3.
[IRF1] interface ten-gigabitethernet 2/4/0/3
[IRF1-Ten-GigabitEthernet2/4/0/3] port link-aggregation group 3
[IRF1-Ten-GigabitEthernet2/4/0/3] quit
# Create VLAN 400 and assign Bridge-Aggregation 2 and Bridge-Aggregation 3 to the VLAN. The VLAN will transmit traffic for IRF links.
[IRF1] vlan 400
[IRF1-vlan400] port bridge-aggregation 2
[IRF1-vlan400] port bridge-aggregation 3
[IRF1-vlan400] quit
# Disable the spanning tree feature on Bridge-Aggregation 2 and Bridge-Aggregation 3.
[IRF1-Bridge-Aggregation2] undo stp enable
[IRF1-Bridge-Aggregation3] undo stp enable
3.     Enable link-aggregation traffic redirection.
[IRF1] link-aggregation lacp traffic-redirect-notification enable
Configuring AC 1
# Assign internal ports Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/3 to the IRF port.
<AC1> system-view
[AC1] irf-port 1
[AC1-irf-port1] port group interface ten-gigabitethernet 1/0/1
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the \"irf-port-configuration active\" command to activate the IRF ports.
[AC1-irf-port1] port group interface ten-gigabitethernet 1/0/3
[AC1-irf-port1] quit
# Specify the member priority as 2. AC 1 will be the master device.
[AC1] irf member 1 priority 2
# Save the configuration.
[AC1] save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):irf.cfg
# Activate the IRF port configuration.
[AC1] irf-port-configuration active
Configuring AC 2
# Change the IRF member ID to 2.
<AC2> system-view
[AC2] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue?[
Y/N]:y
[AC2] quit
# Reboot AC 2 for the new member ID to take effect.
<AC2> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
Now rebooting, please wait...
# Assign internal ports Ten-GigabitEthernet 2/0/1 and Ten-GigabitEthernet 2/0/3 to the IRF port.
<AC2> system-view
[AC2] irf-port 2
[AC2-irf-port2] port group interface ten-gigabitethernet 2/0/1
[AC2-irf-port2] port group interface ten-gigabitethernet 2/0/3
[AC2-irf-port2] quit
[AC2] save
Please input the file name(*.cfg)[cfa0:/ irf.cfg]
# Activate IRF port configuration.
[AC2] irf-port-configuration active
AC 1 and AC 2 perform master election. AC 2 fails the master election and reboots to form an IRF fabric with AC 1.
Configuring IRF 2
# Change the name of the IRF fabric to IRF2.
<AC1> system-view
[AC1] system-name IRF2
# Configure descriptions for AC 1 and AC 2, respectively.
[IRF2] irf member 1 description AC 1
[IRF2] irf member 2 description AC 2
# Delete the system-defined aggregate interface named Bridge-Aggregation 1. The member ports will automatically leave the aggregation group of Bridge-Aggregation 1.
[IRF2] undo interface bridge-aggregation 1
[IRF2] interface bridge-aggregation 1
[IRF2-Bridge-Aggregation1] link-aggregation mode dynamic
# Enable LACP MAD on Bridge-Aggregation 1.
[IRF2-Bridge-Aggregation1] mad enable
[IRF2-Bridge-Aggregation1] quit
# Enable link-aggregation traffic redirection.
[IRF2] link-aggregation lacp traffic-redirect-notification enable
# Assign internal port Ten-GigabitEthernet 1/0/2 to aggregation group 1.
[IRF2] interface ten-gigabitethernet 1/0/2
[IRF2-Ten-GigabitEthernet1/0/2] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet1/0/2] quit
# Assign internal port Ten-GigabitEthernet 1/0/4 to aggregation group 1.
[IRF2] interface ten-gigabitethernet 1/0/4
[IRF2-Ten-GigabitEthernet1/0/4] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet1/0/4] quit
# Assign internal port Ten-GigabitEthernet 2/0/2 to aggregation group 1.
[IRF2] interface ten-gigabitethernet 2/0/2
[IRF2-Ten-GigabitEthernet2/0/2] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet2/0/2] quit
# Assign internal port Ten-GigabitEthernet 2/0/4 to aggregation group 1.
[IRF2] interface ten-gigabitEthernet 2/0/4
[IRF2-Ten-GigabitEthernet2/0/4] port link-aggregation group 1
[IRF2-Ten-GigabitEthernet2/0/4] quit
# Create VLAN 400.
[IRF2] vlan 400
[IRF2-vlan400] quit
# Display IRF information on IRF 2. Verify that AC 1 is the master device.
[IRF2] display irf
Member ID    Role    Priority  CPU MAC         Description
  *+1        Master  2         70f9-6d6d-5a10  AC 1
    2        Standby 1         70f9-6d6d-5a80  AC 2
The asterisk (*) indicates the master.
The plus sign (+) indicates the device through which you are logged in.
The right angle bracket (>) indicates the device's stack capability is disabled.
Bridge MAC of the IRF: 70f9-6d6d-5a10
Auto upgrade         : Enabled
MAC persistence      : 6 min
Topo-domain ID       : 0
Auto merge           : Enabled
# Display IRF link information. Verify that the IRF network interfaces on both member devices are up.
[IRF2] display irf link
Member ID   Member Interfaces                   Status
1           XGE1/0/1(ctrl&data)                 Up
            XGE1/0/3(ctrl&data)                 Up
2           XGE2/0/1(ctrl&data)                 Up
            XGE2/0/3(ctrl&data)                 Up
# On IRF 2, display detailed information about aggregation groups. Verify that Ten-GigabitEthernet 1/0/2, Ten-GigabitEthernet 1/0/4, Ten-GigabitEthernet 2/0/2, and Ten-GigabitEthernet 2/0/4 are in aggregation group 1 and in Selected state.
[IRF2] display link-aggregation verbose
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Dynamic
Loadsharing Type: NonS
System ID: 0x8000, 50da-005b-8b98
Local:
  Port             Status  Priority Oper-Key  Flag
  XGE1/0/2         S       32768    1         {ACDEF}
  XGE1/0/4         S       32768    1         {ACDEF}
  XGE2/0/2         S       32768    1         {ACDEF}
  XGE2/0/4         S       32768    1         {ACDEF}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  XGE1/0/2         1943    32768    3         0x8000, 741f-4a56-9890 {ACDEF}
  XGE1/0/4         1944    32768    3         0x8000, 741f-4a56-9890 {ACDEF}
  XGE2/0/2         2234    32768    3         0x8000, 741f-4a56-9890 {ACDEF}
  XGE2/0/4         2235    32768    3         0x8000, 741f-4a56-9890 {ACDEF}
# On IRF 1, display detailed information about aggregation groups. Verify the link aggregation settings and verify that all member ports in the aggregation groups are in Selected state.
[IRF1] display link-aggregation verbose
System ID: 0x8000, 0cda-41c5-a6a0
Local:
  XGE1/2/0/2       S       32768    1         {ACDEF}
  XGE1/2/0/4       S       32768    1         {ACDEF}
  XGE2/4/0/2       S       32768    1         {ACDEF}
  XGE2/4/0/4       S       32768    1         {ACDEF}
Remote:
  XGE1/2/0/2       5       32768    2         0x8000, 70f9-6d6d-5a80 {ACDEF}
  XGE1/2/0/4       6       32768    2         0x8000, 70f9-6d6d-5a80 {ACDEF}
  XGE2/4/0/2       11      32768    2         0x8000, 70f9-6d6d-5a80 {ACDEF}
  XGE2/4/0/4       12      32768    2         0x8000, 70f9-6d6d-5a80 {ACDEF}
Aggregate Interface: Bridge-Aggregation2
Aggregation Mode: Static
  XGE1/2/0/1       S       32768    3
  XGE1/2/0/3       S       32768    3
Aggregate Interface: Bridge-Aggregation3
  XGE2/4/0/1       S       32768    2
  XGE2/4/0/3       S       32768    2
Configuration files
·     IRF 2:
 sysname IRF2
 irf mac-address persistent timer
 irf auto-update enable
 irf auto-merge enable
 irf member 2 priority 1
vlan 400
irf-port 1
 port group interface Ten-GigabitEthernet1/0/1
 port group interface Ten-GigabitEthernet1/0/3
irf-port 2
 port group interface Ten-GigabitEthernet2/0/1
 port group interface Ten-GigabitEthernet2/0/3
interface Bridge-Aggregation1
 mad enable
interface Ten-GigabitEthernet1/0/4
interface Ten-GigabitEthernet2/0/2
interface Ten-GigabitEthernet2/0/4
·     IRF 1:
vlan 400
interface Bridge-Aggregation2
 port access vlan 400
 undo stp enable
interface Bridge-Aggregation3
 undo stp enable
interface Ten-GigabitEthernet1/2/0/1
 port link-mode bridge
interface Ten-GigabitEthernet1/2/0/2
interface Ten-GigabitEthernet1/2/0/3
interface Ten-GigabitEthernet1/2/0/4
interface Ten-GigabitEthernet2/4/0/1
interface Ten-GigabitEthernet2/4/0/2
interface Ten-GigabitEthernet2/4/0/3
interface Ten-GigabitEthernet2/4/0/4
Related documentation
·     IRF Command Reference in H3C Access Controllers Command References
·     IRF Configuration Guide in H3C Access Controllers Configuration Guides
·     Layer 2LAN Switching Command Reference in H3C Access Controllers Command References
·     Layer 2LAN Switching Configuration Guide in H3C Access Controllers Configuration Guides
