H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers and Access Points Configuration Examples(V7)-6W101
Table of Contents
Related Documents
50-Policy-Based Forwarding with Dual Gateways Configuration Example
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides a configuration example for configuring policy-based forwarding with dual gateways.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN access, AP management, NAT, and DHCP.
Example: Configuring policy-based forwarding with dual gateways
As shown in Figure 1, the AC is deployed at the headquarters and an AP is deployed at the branch. Router A and Router B act as the gateways for the branch and the headquarters, respectively. The AP associates with the AC across the Internet.
Configure network settings to meet the following requirements:
·     Packets destined to the headquarters are forwarded by the AC and packets destined to the branch or Internet are forwarded by the AP.
·     The AP obtains IP addresses from Router A and the client obtains IP addresses from the AC.
Figure 1 Network diagram
Analysis
·     For the AP to discover the AC through the Internet, configure Option 43 and manually specify the IP address of the AC on Router A.
·     For the AP to communicate with the AC, configure NAT on both Router A and Router B.
·     To simplify configurations when a large number of APs are deployed at branches, enable auto AP and auto AP conversion on the AC.
·     For both the AP and the AC to forward packets, configure policy-based forwarding on the AC.
·     For the AP to obtain configurations automatically from the AC, use a text editor to create an AP configuration file and upload the file to the AC.
Procedures
Configuring Router A
1.     Configure interface IP addresses and routes as needed for the devices can reach each other. (Details not shown.)
2.     Configure DHCP:
# Enable DHCP.
[RouterA] dhcp enable
# Create DHCP address pool ap, specify the subnet for dynamic allocation as 192.168.10.0/24, specify the gateway address as 192.168.10.1.
[RouterA] dhcp server ip-pool ap
[RouterA-dhcp-pool-ap] network 192.168.10.0 mask 255.255.255.0
[RouterA-dhcp-pool-ap] gateway-list 192.168.10.1
# Configure Option 43 that specifies the Router B's IP address 202.202.1.22/24.
[RouterA-dhcp-pool-ap] option 43 hex 8007000001CACA0116
[RouterA-dhcp-pool-ap] quit
3.     Configure NAT:
# Create NAT address group 0, and add address 202.20.1.20 to the group.
[RouterA] nat address-group 0
[RouterA-address-group-0] address 202.20.1.20 202.20.1.20
[RouterA-address-group-0] quit
# Create IPv4 basic ACL 2000 to permit only packets from source IP subnet 192.168.10.0/24.
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule permit source 192.168.10.0 0.0.0.255
[RouterA-acl-ipv4-basic-2000] quit
# Configure interface GigabitEthernet1/0/2 to translate the source addresses of outgoing packets permitted by ACL 2000 into the addresses in address group 0.
[RouterA-GigabitEthernet1/0/2] nat outbound 2000 address-group 0
[RouterA] quit
Configuring Router B
1.     Configure interface IP addresses and static routes as needed for the devices can reach each other. (Details not shown.)
2.     Configure NAT:
# Create IPv4 ACL 3000 to permit only packets from 202.20.1.0/24 to 202.202.1.22.
<RouterB> system-view
[RouterB] acl advanced 3000
[RouterB-acl-ipv4-adv-3000] rule 0 permit ip source 202.20.1.0 0.0.0.255 destination 202.202.1.22 0
[RouterB-acl-ipv4-adv-3000] quit
# Configure interface GigabitEthernet1/0/1 to allow users permitted by ACL 3000 to access the internal server at 192.168.1.111.
[RouterB-GigabitEthernet1/0/1] nat server global 3000 inside 192.168.1.111
[RouterB] quit
Configuring the AC
1.     Create AP configuration file map-OnAP.txt as follows and then upload the file to the AC.
vlan 2
interface Vlan-interface1
 nat outbound 3000
 port link-type trunk
 port trunk permit vlan 1
interface Vlan-interface2
 ip address 172.16.4.3 255.255.255.0
acl advanced 3000
 rule 0 permit ip source 172.16.4.0 0.0.0.255
2.     Configure basic AC functions:
# Configure interface IP addresses. (Details not shown.)
# Create VLAN 2 and VLAN-interface 2, and assign an IP address to the VLAN interface.
[AC] vlan 2
[AC-vlan2] quit
[AC] interface vlan-interface 2
[AC-Vlan-interface2] ip address 172.16.4.1 255.255.255.0
[AC-Vlan-interface2] quit
# Configure interface GigabitEthernet1/0/2 to operate in Layer 2 mode, set the port link type to trunk, remove the port from VLAN 1, and add the port to VLAN 2.
[AC] interface gigabitethernet 1/0/2
[AC-GigabitEthernet1/0/2] port link-mode bridge
[AC-GigabitEthernet1/0/2] port link-type trunk
[AC-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/2] port trunk permit vlan 2
[AC-GigabitEthernet1/0/2] quit
# Configure static routes to GigabitEthernet1/0/2 of Router A, GigabitEthernet1/0/1 of Router B, and headquarters' network segment 172.16.5.0/24.
[AC] ip route-static 202.20.1.0 24 192.168.1.22
[AC] ip route-static 202.202.1.0 24 192.168.1.22
[AC] ip route-static 172.16.5.0 24 172.16.4.2
[AC] quit
3.     Configure DHCP:
# Enable DHCP.
[AC] dhcp enable
# Create DHCP address pool sta, specify the subnet for dynamic allocation as 172.16.4.0/24, and specify the gateway address as 172.16.4.1.
[AC] dhcp server ip-pool sta
[AC-dhcp-pool-sta] network 172.16.4.0 mask 255.255.255.0
[AC-dhcp-pool-sta] gateway-list 172.16.4.1
# Specify the DNS server address as 192.168.1.10.
[AC-dhcp-pool-ap] dns-list 192.168.1.10
# Exclude IP addresses 172.16.4.1 and 172.16.4.3 from dynamic allocation in DHCP address pool sta.
[AC-dhcp-pool-ap] forbidden-ip 172.16.4.1 172.16.4.3
[AC-dhcp-pool-ap] quit
4.     Enable auto AP and auto AP conversion.
<AC> system-view
[AC] wlan auto-ap enable
[AC] wlan auto-persistent enable
5.     Configure policy-based forwarding:
# Create IPv4 advanced ACL 3001, and configure ACL rules to permit DNS, BOOTPC, and BOOTPS packets and packets from 172.16.4.0/24 to 172.16.4.0/24 or 172.16.5.0/24.
[AC] acl advanced 3001
[AC-acl-ipv4-adv-3001] rule 0 permit udp source-port eq dns
[AC-acl-ipv4-adv-3001] rule 1 permit udp destination-port eq dns
[AC-acl-ipv4-adv-3001] rule 2 permit udp source-port eq bootpc
[AC-acl-ipv4-adv-3001] rule 3 permit udp destination-port eq bootps
[AC-acl-ipv4-adv-3001] rule 4 permit ip source 172.16.4.0 0.0.0.255 destination 172.16.4.0 0.0.0.255
[AC-acl-ipv4-adv-3001] rule 5 permit ip source 172.16.4.0 0.0.0.255 destination 172.16.5.0 0.0.0.255
[AC-acl-ipv4-adv-3001] quit
# Create forwarding policy remote, and configure the forwarding policy to perform centralized forwarding on packets that match ACL 3001.
[AC] wlan forwarding-policy remote
[AC-wlan-fp-remote] classifier acl 3001 behavior remote
[AC-wlan-fp-remote] quit
# Create service template chn, set the SSID to CHN, and assign clients coming online through the service template to VLAN 2.
[AC] wlan service-template chn
[AC-wlan-st-chn] ssid CHN
[AC-wlan-st-chn] vlan 2
# Enable APs to forward client traffic, apply forwarding policy remote to the service template, and enable the forwarding policy.
[AC-wlan-st-chn] client forwarding-location ap
[AC-wlan-st-chn] client forwarding-policy-name remote
[AC-wlan-st-chn] client forwarding-policy enable
# Enable the service template.
[AC-wlan-st-chn] service-template enable
[AC-wlan-st-chn] quit
# Deploy configuration file map-OnAP.txt to WA560-WW APs in the default AP group.
[AC] wlan ap-group default-group
[AC-wlan-ap-group-default-group] ap-model WA560-WW
[AC-wlan-ap-group-default-group-ap-model-WA560-WW] map-configuration flash:/map-OnAP.txt
# Bind service template chn to radio 1 and enable radio 1.
[AC-wlan-ap-group-default-group-ap-model-WA560-WW] radio 1
[AC-wlan-ap-group-default-group-ap-model-WA560-WW-radio-1] service-template chn
[AC-wlan-ap-group-default-group-ap-model-WA560-WW-radio-1] radio enable
[AC-wlan-ap-group-default-group-ap-model-WA560-WW-radio-1] quit
[AC-wlan-ap-group-default-group-ap-model-WA560-WW] quit
[AC-wlan-ap-group-default-group] quit
# Verify that the AP has associated with the AC.
[AC] display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 2048
Remaining APs: 2047
Total AP licenses: 32
Remaining AP licenses: 31
                                 AP information
 State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
         C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name                        APID  State Model           Serial ID
ap1                            2     R/M   WA560-WW        219801A1NM8182032235
# Verify that the AP is in Run state, the discovery type is DHCP, and the AP's IP address is 202.20.1.20.
[AC] display wlan ap name ap1 verbose
AP name : ap1
AP ID : 2
AP group name : default-group
State : Run
Backup type : Master
Online time : 1 days 5 hours 25 minutes 22 seconds
System up time : 1 days 6 hours 30 minutes 4 seconds
Model : WA560-WW
Region code : CN
Region code lock : Disabled
Serial ID : 219801A1NM8182032235
MAC address : 70f9-6dd3-61e0
IP address : 202.20.1.20
UDP control port number : 1099
UDP data port number : 1102
H/W version : Ver.C
S/W version : R2215
Boot version : 7.10
USB state : N/A
Power Level : N/A
PowerInfo : N/A
Description : Not configured
Priority : 4
Echo interval : 10 seconds
Echo count : 3 counts
Keepalive interval : 10 seconds
Statistics report interval : 50 seconds
Fragment size (data) : 1500
Fragment size (control) : 1450
MAC type : Local MAC & Split MAC
Tunnel mode : Local Bridging & 802.3 Frame & Native Frame
Discovery type : DHCP
Retransmission count : 3
Retransmission interval : 5 seconds
Firmware upgrade : Enabled
Sent control packets : 34001
Received control packets : 34001
Echo requests : 10591
Lost echo responses : 3
Average echo delay : 3
Last reboot reason : User soft reboot
Latest IP address : 202.20.1.20
Tunnel down reason : Processed join request in Run state
Connection count : 15
Backup Ipv4 : Not configured
Backup Ipv6 : Not configured
Tunnel encryption : Disabled
LED mode : Normal
Remote configuration : Disabled
Radio 1:
    Basic BSSID : 70f9-6dd3-61e0
    Admin state : Up
    Radio type : 802.11ac
    Antenna type : internal
    Client dot11ac-only : Disabled
    Client dot11n-only : Disabled
    Channel band-width : 20/40/80MHz
    Active band-width : 20/40/80MHz
    Secondary channel offset : SCA
    Short GI for 20MHz : Supported
    Short GI for 40MHz : Supported
    Short GI for 80MHz : Supported
    Short GI for 160MHz : Not supported
    A-MSDU : Enabled
    A-MPDU : Enabled
    LDPC : Not Supported
    STBC : Supported
    Operational VHT-MCS Set:
        Mandatory : Not configured
        Supported : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast : Not configured
    Operational HT MCS Set:
        Supported : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel : 149(auto)
    Channel usage(%) : 0
    Max power : 20 dBm
    Operational rate:
        Mandatory : 6, 12, 24 Mbps
        Multicast : Auto
        Supported : 9, 18, 36, 48, 54 Mbps
        Disabled : Not configured
    Distance : 1 km
    ANI : Enabled
    Fragmentation threshold : 2346 bytes
    Beacon interval : 100 TU
    Protection threshold : 2346 bytes
    Long retry threshold : 4
    Short retry threshold : 7
    Maximum rx duration : 2000 ms
    Noise floor : -105 dBm
    Smart antenna : Enabled
    Smart antenna policy : Auto
    Protection mode : cts-to-self
    Continuous mode : N/A
    HT protection mode : No protection
Radio 2:
    Basic BSSID : 70f9-6dd3-61f0
    Admin state : Down
    Radio type : 802.11n(2.4GHz)
    Channel band-width : 20MHz
    Active band-width : 20MHz
    Secondary channel offset : SCN
    A-MSDU : Enabled
    A-MPDU : Enabled
    STBC : Supported
    Channel : 6(auto)
    Max power : 20 dBm
    Preamble type : Short
    Operational rate:
        Mandatory : 1, 2, 5.5, 11 Mbps
        Multicast : Auto
        Supported : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance : 1 km
    ANI : Enabled
    Noise floor : 0 dBm
# Verify that the client has come online with an IP address in subnet 172.16.4.0/24, and the forwarding policy is remote.
[AC] display wlan client
Total number of clients: 1
MAC address    User name  AP name        RID IP address      IPv6 address   VLAN
0015-005e-9348 N/A        ap1            1   172.16.4.11                    2
[AC] display wlan client verbose
 MAC address : 0015-005e-9348
 IPv4 address : 172.16.4.11
 IPv6 address : N/A
 Username : N/A
 AID : 1
 AP ID : 2
 AP name : ap1
 Radio ID : 1
 SSID : CHN
 VLAN ID : 2
 Sleep count : 0
 Wireless mode : 802.11an
 Channel bandwidth : 40MHz
 20/40 BSS Coexistence Management : Not supported
 SM power save : Disabled
 STBC RX capability : Supported
 STBC TX capability : Not supported
 LDPC RX capability : Not supported
 Block Ack : N/A
 Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
 Supported rates : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 QoS mode : WMM
 Listen interval : 100
 RSSI : 0
 Rx/Tx rate : 0/0
 Authentication method : Open system
 Security mode : PRE-RSNA
 AKM mode : N/A
 Cipher suite : N/A
 User authentication mode : Bypass
 Authorization ACL ID : N/A
 Authorization user profile : N/A
 Roam status : N/A
 Key derivation : N/A
 PMF status : N/A
 Forwarding policy name : remote
 Online time : 0days 0hours 0minutes 33seconds
 FT status : Inactive
# Verify that IP addresses (172.16.4.2, 172.16.5.1, and 172.16.5.2) in the headquarters' network can be pinged successfully.
C:\Users\h3c>ping 172.16.4.2
Pinging 172.16.4.2 with 32 bytes of data:
Reply from 172.16.4.2: bytes=32 time=6ms TTL=255
Reply from 172.16.4.2: bytes=32 time=3ms TTL=255
Reply from 172.16.4.2: bytes=32 time=1ms TTL=255
Ping statistics for 172.16.4.2:
    Minimum = 1ms, Maximum = 6ms, Average = 4ms
C:\Users\h3c>ping 172.16.5.1
Pinging 172.16.5.1 with 32 bytes of data:
Reply from 172.16.5.1: bytes=32 time=9ms TTL=255
Reply from 172.16.5.1: bytes=32 time=1ms TTL=255
Reply from 172.16.5.1: bytes=32 time=5ms TTL=255
Ping statistics for 172.16.5.1:
    Minimum = 1ms, Maximum = 9ms, Average = 4ms
C:\Users\h3c>ping 172.16.5.2
Pinging 172.16.5.2 with 32 bytes of data:
Reply from 172.16.5.2: bytes=32 time=8ms TTL=255
Reply from 172.16.5.2: bytes=32 time=2ms TTL=255
Reply from 172.16.5.2: bytes=32 time=5ms TTL=255
Reply from 172.16.5.2: bytes=32 time=3ms TTL=255
Ping statistics for 172.16.5.2:
    Minimum = 2ms, Maximum = 8ms, Average = 4ms
# Verify that a website on the Internet (for example, www.baidu.com) can be pinged successfully.
C:\Users\h3c>ping www.baidu.com
Pinging www.baidu.com [202.202.1.188] with 32 bytes of data:
Reply from 202.202.1.188: bytes=32 time=7ms TTL=255
Reply from 202.202.1.188: bytes=32 time=3ms TTL=255
Reply from 202.202.1.188: bytes=32 time=2ms TTL=255
Ping statistics for 202.202.1.188:
Minimum = 2ms, Maximum = 7ms, Average = 3ms
Configuration files
·     Router A
nat address-group 0
 dhcp enable
 option 43 hex 8007000001caca0116
acl basic 2000
 rule 0 permit source 192.168.10.0 0.0.0.255
·     Router B
acl advanced 3000
·     AC
 dhcp enable
vlan 2
 forbidden-ip 172.16.4.3
 ssid CHN
 vlan 2
acl advanced 3001
 wlan auto-ap enable
 ap-model WA4320i-ACN
  radio 1
   radio enable
  radio 2
  gigabitethernet 1
  gigabitethernet 2
Related documentation
·     Layer 3 Command Reference in H3C Access Controllers Command References
·     Layer 3 Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Command Reference in H3C Access Controllers Command References
·     WLAN Configuration Guide in H3C Access Controllers Configuration Guides
