- H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
- 01-H3C Access Controllers AP's Association with the AC at Layer 2 Configuration Examples
- 02-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 2 (IPv6) Configuration Examples
- 03-H3C Access Controllers AP's Association with the AC at Layer 3 Configuration Examples
- 04-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 3 (IPv6) Configuration Examples
- 05-H3C Access Controllers Local MAC Authentication Configuration Examples (V7)
- 06-H3C Access Controllers MAC Authentication with Guest VLAN Assignment Configuration Examples (V7)
- 07-H3C Access Controllers Comware 7 MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 08-H3C Access Controllers MAC Authentication and PSK Authentication Configuration Examples (V7)
- 09-H3C Access Controllers Auto AP Configuration Examples (V7)
- 10-H3C Access Controllers WLAN Load Balancing Configuration Examples (V7)
- 11-H3C Access Controllers WEP Encryption Configuration Examples
- 12-H3C Access Controllers Local Forwarding Configuration Examples
- 13-H3C Access Controllers Layer 2 Static Aggregation Configuration Examples (V7)
- 14-H3C Access Controllers Remote 802.1X Authentication Configuration Examples (V7)
- 15-H3C Access Controllers Comware 7 Remote 802.1X Authentication (IPv6) Configuration Examples
- 16-H3C Access Controllers 802.1X Authentication with ACL Assignment Through IMC Server @CE@ (V7)
- 17-H3C Access Controllers 802.1X Authentication with User Profile Assignment Through IMC Server @CE@ (V7)
- 18-H3C Access Controllers EAD Authentication Configuration Examples (V7)
- 19-H3C Access Controllers Comware 7 EAD Authentication (IPv6) Configuration Examples
- 20-H3C Access Controllers Remote Portal Authenticaiton Configuration Examples (V7)
- 21-H3C Access Controllers Comware 7 Remote Portal Authenticaiton (IPv6) Configuration Examples
- 22-H3C Access Controllers Local Portal Authentication Configuration Examples (V7)
- 23-H3C Access Controllers Comware 7 Local Portal Authentication (IPv6) Configuration Examples
- 24-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication Configuration Examples (V7)
- 25-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples(V7)
- 26-H3C Access Controllers Local Portal Authentication through LDAP Server Configuration Examples (V7)
- 27-H3C Access Controllers Local Portal Authentication through LDAP Server (IPv6) Configuration Examples(V7)
- 28-H3C Access Controllers MAC-based Portal Quick Authenticaiton Configuration Example (V7)
- 29-H3C Access Controllers Comware 7 MAC-based Quick Portal Authenticaiton (IPv6) Configuration Example
- 30-H3C Access Controllers SSH Configuration Examples (7)
- 31-H3C Access Controllers Internal-to-External Access Through NAT Configuration Examples (V7)
- 32-H3C Access Controllers Static Blacklist Configuration Examples
- 33-H3C Access Controllers Comware 7 WLAN Access (IPv6) Configuration Examples
- 34-H3C Access Controllers Inter-AC Roaming Configuration Examples (V7)
- 35-H3C Access Controllers Comware 7 Inter-AC Roaming (IPv6) Configuration Examples
- 36-H3C Access Controllers HTTPS Login Configuration Examples (V7)
- 37-H3C Access Controllers Client Rate Limiting Configuration Examples (V7)
- 38-H3C Access Controllers Client Quantity Control Configuration Examples
- 39-H3C Access Controllers Medical RFID Tag Management Configuration Examples (V7)
- 40-H3C Access Controllers iBeacon Management Configuration Examples (V7)
- 41-H3C Access Controllers Remote AP Configuration Examples (V7)
- 42-H3C Access Controllers PSK Encryption Configuration Examples
- 43-H3C Access Controllers WIPS Configuration Examples (V7)
- 44-H3C Access Controllers Layer 2 Multicast Configuration Example (V7)
- 45-H3C Access Controllers IRF Setup with Members Directly Connected Configuration Examples (V7)
- 46-H3C Access Controllers IRF Setup with Members Not Directly Connected Configuration Examples (V7)
- 47-H3C Access Controller Modules IRF Setup with Members in One Chassis Configuration Examples (V7)
- 48-H3C Access Controller Modules IRF Setup with Members in Different Chassis Configuration Examples (V7)
- 49-H3C Access Controllers Comware 7 IP Source Guard (IPv6) Configuration Examples
- 50-Policy-Based Forwarding with Dual Gateways Configuration Example
- 51-H3C Access Controllers Comware 7 Policy-Based Forwarding with Dual Gateways (IPv6) Configuration Example
- 52-Policy-Based Local Forwarding Configuration Examples
38-H3C Access Controllers Client Quantity Control Configuration Examples | 79.54 KB |
H3C Access Controllers |
Comware 7 Client Quantity Control |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides an example for configuring client quantity control.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of client quantity control.
Example: Configuring client quantity control
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the APs and clients. The AC forwards client traffic. Perform the following tasks:
· Set the maximum number of clients that can associate with a radio to enable AP 1 to permit only Client 1.
· Set the maximum number of clients that can associate with a service template to enable AP 2 to permit only Client 2 and Client 3.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1. Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. Clients will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.0.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, and assign the port to VLANs 1, 100, and 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
2. Configure wireless services:
# Create service template service and enter its view.
[AC] wlan service-template service
# Configure the SSID as service.
[AC-wlan-st-service] ssid service
# Specify VLAN 200 for clients to access the WLAN defined by the service template.
[AC-wlan-st-service] vlan 200
# Set the maximum number of clients that can associate with the service template to 2.
[AC-wlan-st-service] client max-count 2
# Enable the service template.
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
3. Configure the AP:
# Create manual AP officeap1, and specify the AP model and serial ID.
[AC] wlan ap officeap1 model WA560-WW
[AC-wlan-ap-officeap1] serial-id 219801A1NM8182032235
# Set the maximum number of clients that can associate with radio 1.
[AC-wlan-ap-officeap1] radio 1
[AC-wlan-ap-officeap1-radio-1] client max-count 1
# Bind service template service to radio 1.
[AC-wlan-ap-officeap1-radio-1] service-template service
# Enable radio 1.
[AC-wlan-ap-officeap1-radio-1] radio enable
[AC-wlan-ap-officeap1-radio-1] quit
[AC-wlan-ap-officeap1] quit
# Create manual AP officeap2, and specify the AP model and serial ID.
[AC] wlan ap officeap2 model WA560-WW
[AC-wlan-ap-officeap2] serial-id 219801A1NM8182032237
[AC-wlan-ap-officeap2] radio 1
[AC-wlan-ap-officeap2-radio-1] service-template service
# Enable radio 1.
[AC-wlan-ap-officeap2-radio-1] radio enable
[AC-wlan-ap-officeap2-radio-1] quit
[AC-wlan-ap-officeap2] quit
Configuring the switch
1. Configure switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward packets between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 200 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, and assign the port to VLANs 1, 100, and 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch to AP 1 as an access port, and assign the port to VLAN 100.
# Enable PoE on GigabitEthernet 1/0/2.
# Configure GigabitEthernet 1/0/3 that connects the switch to AP 2 as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 100
# Enable PoE on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool 100 to assign an IP address to the AP, and specify subnet 192.1.0.0/16 in the DHCP address pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 192.1.0.0 mask 255.255.0.0
# Specify the gateway address as 192.1.0.1 in the DHCP address pool.
[Switch-dhcp-pool-100] gateway-list 192.1.0.1
[Switch-dhcp-pool-100] quit
# Create DHCP address pool 200 to assign IP addresses to clients, and specify subnet 192.2.0.0/24 in the DHCP address pool.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 192.2.0.0 mask 255.255.255.0
# Specify the gateway address as 192.2.0.1 in the DHCP address pool.
[Switch-dhcp-pool-200] gateway-list 192.2.0.1
[Switch-dhcp-pool-200] quit
# Try to associate client 1, client 2, client 3, and client 4 with the WLAN successively. (Details not shown.)
# Verify that only client 1, client 2, and client 3 have successfully associated with the WLAN.
[AC] display wlan client
Total number of clients: 3
MAC address Username AP name RID IP address IPv6 address VLAN
0000-000f-1211 N/A officeap1 1 192.2.0.3 N/A 200
0000-000f-1212 N/A officeap2 1 192.2.0.4 N/A 200
0000-000f-1213 N/A officeap2 1 192.2.0.5 N/A 200
Configuration files
· AC:
vlan 1
vlan 100
vlan 200
ssid service
vlan 200
client max-count 2
interface Vlan-interface100
ip address 192.1.0.1 255.255.0.0
interface Vlan-interface200
ip address 192.2.0.1 255.255.255.0
radio 1
radio enable
client max-count 1
radio 1
radio enable
· Switch:
vlan 1
vlan 100
vlan 200
ip address 192.1.0.2 255.255.0.0
ip address 192.2.0.2 255.255.255.0
port access permit vlan 100
poe enable
poe enable
Related documentation
· WLAN Command Reference in H3C Access Controllers Command References
· WLAN Configuration Guide in H3C Access Controllers Configuration Guides
