- H3C Access Controllers and Access Points Configuration Examples(V7)-6W101
- 01-H3C Access Controllers AP's Association with the AC at Layer 2 Configuration Examples
- 02-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 2 (IPv6) Configuration Examples
- 03-H3C Access Controllers AP's Association with the AC at Layer 3 Configuration Examples
- 04-H3C Access Controllers Comware 7 AP's Association with the AC at Layer 3 (IPv6) Configuration Examples
- 05-H3C Access Controllers Local MAC Authentication Configuration Examples (V7)
- 06-H3C Access Controllers MAC Authentication with Guest VLAN Assignment Configuration Examples (V7)
- 07-H3C Access Controllers Comware 7 MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 08-H3C Access Controllers MAC Authentication and PSK Authentication Configuration Examples (V7)
- 09-H3C Access Controllers Auto AP Configuration Examples (V7)
- 10-H3C Access Controllers WLAN Load Balancing Configuration Examples (V7)
- 11-H3C Access Controllers WEP Encryption Configuration Examples
- 12-H3C Access Controllers Local Forwarding Configuration Examples
- 13-H3C Access Controllers Layer 2 Static Aggregation Configuration Examples (V7)
- 14-H3C Access Controllers Remote 802.1X Authentication Configuration Examples (V7)
- 15-H3C Access Controllers Comware 7 Remote 802.1X Authentication (IPv6) Configuration Examples
- 16-H3C Access Controllers 802.1X Authentication with ACL Assignment Through IMC Server @CE@ (V7)
- 17-H3C Access Controllers 802.1X Authentication with User Profile Assignment Through IMC Server @CE@ (V7)
- 18-H3C Access Controllers EAD Authentication Configuration Examples (V7)
- 19-H3C Access Controllers Comware 7 EAD Authentication (IPv6) Configuration Examples
- 20-H3C Access Controllers Remote Portal Authenticaiton Configuration Examples (V7)
- 21-H3C Access Controllers Comware 7 Remote Portal Authenticaiton (IPv6) Configuration Examples
- 22-H3C Access Controllers Local Portal Authentication Configuration Examples (V7)
- 23-H3C Access Controllers Comware 7 Local Portal Authentication (IPv6) Configuration Examples
- 24-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication Configuration Examples (V7)
- 25-H3C Access Controllers Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples(V7)
- 26-H3C Access Controllers Local Portal Authentication through LDAP Server Configuration Examples (V7)
- 27-H3C Access Controllers Local Portal Authentication through LDAP Server (IPv6) Configuration Examples(V7)
- 28-H3C Access Controllers MAC-based Portal Quick Authenticaiton Configuration Example (V7)
- 29-H3C Access Controllers Comware 7 MAC-based Quick Portal Authenticaiton (IPv6) Configuration Example
- 30-H3C Access Controllers SSH Configuration Examples (7)
- 31-H3C Access Controllers Internal-to-External Access Through NAT Configuration Examples (V7)
- 32-H3C Access Controllers Static Blacklist Configuration Examples
- 33-H3C Access Controllers Comware 7 WLAN Access (IPv6) Configuration Examples
- 34-H3C Access Controllers Inter-AC Roaming Configuration Examples (V7)
- 35-H3C Access Controllers Comware 7 Inter-AC Roaming (IPv6) Configuration Examples
- 36-H3C Access Controllers HTTPS Login Configuration Examples (V7)
- 37-H3C Access Controllers Client Rate Limiting Configuration Examples (V7)
- 38-H3C Access Controllers Client Quantity Control Configuration Examples
- 39-H3C Access Controllers Medical RFID Tag Management Configuration Examples (V7)
- 40-H3C Access Controllers iBeacon Management Configuration Examples (V7)
- 41-H3C Access Controllers Remote AP Configuration Examples (V7)
- 42-H3C Access Controllers PSK Encryption Configuration Examples
- 43-H3C Access Controllers WIPS Configuration Examples (V7)
- 44-H3C Access Controllers Layer 2 Multicast Configuration Example (V7)
- 45-H3C Access Controllers IRF Setup with Members Directly Connected Configuration Examples (V7)
- 46-H3C Access Controllers IRF Setup with Members Not Directly Connected Configuration Examples (V7)
- 47-H3C Access Controller Modules IRF Setup with Members in One Chassis Configuration Examples (V7)
- 48-H3C Access Controller Modules IRF Setup with Members in Different Chassis Configuration Examples (V7)
- 49-H3C Access Controllers Comware 7 IP Source Guard (IPv6) Configuration Examples
- 50-Policy-Based Forwarding with Dual Gateways Configuration Example
- 51-H3C Access Controllers Comware 7 Policy-Based Forwarding with Dual Gateways (IPv6) Configuration Example
- 52-Policy-Based Local Forwarding Configuration Examples
43-H3C Access Controllers WIPS Configuration Examples (V7) | 145.83 KB |
H3C Access Controllers |
Comware 7 WIPS Configuration Examples |
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring WIPS.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of WIPS.
Example: Configuring WIPS
As shown in Figure 1, AP 1 and AP 2 provide wireless services for clients through SSID service.
Enable WIPS on the sensor to take countermeasures against the rogue AP that uses the same SSID as AP 1 and AP 2.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Configure VLAN-interface 100 and assign it an IP address. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 112.12.1.25 16
[AC-Vlan-interface100] quit
# Configure VLAN-interface 200 and assign it an IP address. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 112.13.1.25 16
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port.
[AC] interface gigabitethernet1/0/1
# Remove the trunk port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Specify the PVID of the trunk port as VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2. Configure DHCP:
# Enable DHCP on the AC.
[AC] dhcp enable
# Create DHCP address pool vlan100 to assign IP addresses for APs, and specify the IP address range for the DHCP address pool.
[AC] dhcp server ip-pool vlan100
[AC-dhcp-pool-vlan100] network 112.12.0.0 mask 255.255.0.0
# Specify gateway IP address 112.12.1.25 in the DHCP address pool.
[AC-dhcp-pool-vlan100] gateway-list 112.12.1.25
[AC-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign IP addresses for clients, and specify the IP address range for the DHCP address pool.
[AC] dhcp server ip-pool vlan200
[AC-dhcp-pool-vlan200] network 112.13.0.0 mask 255.255.0.0
# Specify gateway IP address 112.13.1.25 in the DHCP address pool.
[AC-dhcp-pool-vlan200] gateway-list 112.13.1.25
[AC-dhcp-pool-vlan200] quit
3. Configure WIPS:
# Enter WIPS view.
[AC] wips
# Create AP classification rule 1 and configure the rule to match APs that use SSID service.
[AC-wips] ap-classification rule 1
[AC-wips-cls-rule-1] ssid equal service
[AC-wips-cls-rule-1] quit
# Create classification policy class1.
[AC-wips] classification policy class1
# Bind AP classification rule 1 to classification policy class1, and specify APs that match AP classification rule 1 as rogue APs.
[AC-wips-cls-class1] apply ap-classification rule 1 rogue-ap
[AC-wips-cls-class1] quit
# Create virtual security domain (VSD) vsd1, and apply classification policy class1 to the VSD.
[AC-wips] virtual-security-domain vsd1
[AC-wips-vsd-1] apply classification policy class1
[AC-wips-vsd-1] quit
# Create countermeasure policy 1 and enable WIPS to take countermeasures against rogue APs.
[AC-wips] countermeasure policy 1
[AC-wips-cms-1] countermeasure rogue-ap
[AC-wips-cms-1] quit
# Apply countermeasure policy 1 to VSD vsd1.
[AC-wips-vsd-vsd1] apply countermeasure policy 1
[AC-wips-vsd-vsd1] quit
[AC-wips] quit
4. Configure the APs:
# Create service template service and set its SSID to service.
[AC] wlan service-template service
[AC-wlan-st-service] ssid service
# Assign clients that come online through service template service to VLAN 200.
[AC-wlan-st-service] vlan 200
# Enable service template service.
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
# Create AP ap1 and specify its model and serial ID.
[AC] wlan ap ap1 model WA560-WW
[AC-wlan-ap-ap1] serial-id 219801A1NM8182032235
# Enable radio 1 of AP ap1 and bind service template service to radio 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template service
[AC-wlan-ap-ap1-radio-1] quit
# Create AP ap2 and specify its model and serial ID.
[AC] wlan ap ap2 model WA560-WW
[AC-wlan-ap-ap2] serial-id 219801A1NM8182032237
# Enable radio 1 of AP ap2 and bind service template service to radio 1.
[AC-wlan-ap-ap2] radio 1
[AC-wlan-ap-ap2-radio-1] radio enable
[AC-wlan-ap-ap2-radio-1] service-template service
[AC-wlan-ap-ap2-radio-1] quit
# Create AP sensor and specify its model and serial ID.
[AC] wlan ap sensor model WA560-WW
[AC-wlan-ap-sensor] serial-id 219801A1NM8182032239
# Enable radio 1 of AP sensor, and enable WIPS for the radio.
[AC-wlan-ap-sensor] radio 1
[AC-wlan-ap-sensor-radio-1] radio enable
[AC-wlan-ap-sensor-radio-1] wips enable
[AC-wlan-ap-sensor-radio-1] quit
# Add AP sensor to VSD vsd1.
[AC-wlan-ap-sensor] wips virtual-security-domain vsd1
[AC-wlan-ap-sensor] return
Configuring the switch
# Create VLANs 100 and 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port.
[Switch] interface gigabitethernet1/0/1
# Remove the trunk port from VLAN 1, and assign the port to VLAN 100.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 that connects the switch to AP sensor as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/2
# Enable PoE on the access port.
# Configure GigabitEthernet 1/0/3 that connects the switch to AP ap1 as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 100
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/4 that connects the switch to AP ap2 as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/4
[Switch-GigabitEthernet1/0/4] port link-type access
[Switch-GigabitEthernet1/0/4] port access vlan 100
[Switch-GigabitEthernet1/0/4] poe enable
[Switch-GigabitEthernet1/0/4] quit
1. Verify that WIPS has classified the AP that uses SSID service as a rogue AP and the service APs as authorized APs.
<AC> display wips virtual-security-domain vsd1 device
Total 3 detected devices in virtual-security-domain vsd1
Class: Auth - authorization; Ext - external; Mis - mistake;
Unauth - unauthorized; Uncate - uncategorized;
(A) - associate; (C) - config; (P) - potential
MAC address Type Class Duration Sensors Channel Status
000f-1111-0101 AP Auth 00h 05m 24s 1 161 Active
000f-1111-0111 AP Auth 00h 05m 26s 1 13 Active
000f-e200-1202 AP Rogue 00h 05m 26s 1 161 Active
2. Verify that WIPS has taken countermeasures against the rogue AP.
<AC> display wips virtual-security-domain vsd1 countermeasure record
Total 1 times countermeasure, current 1 countermeasure record in virtual-security-domain vsd1
Reason: Attack; Ass - associated; Black - blacklist;
Class - classification; Manu - manual;
MAC address Type Reason Countermeasure AP Radio ID Time
000f-e200-1202 AP Manu sensor 1 2015-11-27/15:52:53
Configuration files
· AC:
dhcp enable
vlan 100
vlan 200
ssid service
vlan 200
interface Vlan-interface100
ip address 112.12.1.25 255.255.0.0
interface Vlan-interface200
ip address 112.13.1.25 255.255.0.0
radio 1
radio enable
radio 1
radio enable
radio 1
radio enable
wips enable
wips
ssid equal service
· Switch:
vlan 100
vlan 200
poe enable
poe enable
interface GigabitEthernet1/0/4
poe enable
Related documentation
· WLAN Command Reference in H3C Access Controllers Command References
· WLAN Configuration Guide in H3C Access Controllers Configuration Guides
