H3C Fixed Port Campus Switches Configuration Examples-6W103
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W103
Table of Contents
Related Documents
78-IRF Software Upgrade Configuration Examples
78-IRF Software Upgrade Configuration Examples 145.46 KB
Introduction
This document provides examples for upgrading software on an IRF fabric.
This document assumes that you have basic knowledge of IRF.
Example: Upgrading software on an IRF fabric
As shown in Figure 1, Device A and Device B have set up an IRF fabric. Device A is the master device and its member ID is 1, and Device B is the standby device and its member ID is 2. BFD MAD is used for multi-active collision detection.
The current software version of the IRF fabric is R2432p06. Upgrade the software version to R2720. After software upgrade, Device A is still the master device.
Figure 1 Network diagram
Analysis
H3C devices support upgrade methods as shown in Table 1. In this example, software is upgraded from the CLI by using the boot loader method. To reduce service interruption time during the upgrade process, IRF split and IRF merge will be performed during the upgrade process.
Table 1 Software upgrade methods
Upgrade method
Software types
Remarks
Upgrading from the CLI by using the boot loader method
·     BootWare image
·     Comware images (excluding incremental patches)
This method is disruptive. You must reboot the entire device to complete the upgrade.
All models support this method.
Performing an ISSU from the CLI
Comware images
This method enables a software upgrade with a minimum amount of downtime.
Some models support this method.
Upgrading from the BootWare menu
·     BootWare image
·     Comware images
Use this method when the device cannot start up correctly.
To use this method, first connect to the console port and power cycle the device. Then, press Ctrl+B at prompt to access the BootWare menu.
For more information about upgrading software from the BootWare menu, see the release notes for the software version.
To upgrade software on an IRF fabric from the CLI by using the boot loader method:
1.     Shut down all uplink and downlink service interfaces on the master device (Device A) in bulk to switch traffic from Device A to Device B. To enter interface range view, use the interface range command.
2.     Upgrade software on Device A from the CLI by using the boot loader method and reboot the device. During the reboot, shut down IRF physical interfaces Ten-GigabitEthernet 2/0/27 and Ten-GigabitEthernet 2/0/28 on Device B. The IRF fabric splits.
CAUTION
CAUTION:
To prevent configuration loss from affecting interface status and causing IRF merge failure or service traffic interruption, do not save the running configuration on any IRF member device when the IRF fabric splits.
To split an IRF fabric, you can remove cables from IRF physical interfaces or shut down all IRF physical interfaces on the standby device. The latter method is simpler. In this example, the latter method is used.
3.     Shut down all uplink and downlink service interfaces on the standby device (Device B) in bulk. Bring up all uplink and downlink service interfaces on Device A to switch service traffic back to Device A.
4.     Upgrade software on Device B. After Device B reboots, Device A and Device B automatically form an IRF fabric.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S6550XE-HI switch series
Release 6008 and later
S6525XE-HI switch series
S5850 switch series
Release 8005 and later
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 66xx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Release 63xx
S5500V3-SI switch series (except the S5500V3-24P-SI and S5500V3-48P-SI switches)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Release 11xx
S5120V3-SI switch series (except the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI switches)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
Whole upgrade process
As a best practice to discover, locate, and analyze issues in time, record all operations during the whole upgrade process.
Before IRF software upgrade
·     Make sure all member devices and cards are in stable state. For this purpose, execute the display system stable state command and verify that the value for the State field is Stable. If a member device or card is not in stable state, identify the reason. Do not upgrade software on the IRF fabric unless all member devices and cards are in stable state.
·     Prepare scripts in advance for shutting down and bringing up uplink and downlink service interfaces. To prevent omission of service interfaces from resulting in exceptions in the upgrade process, make sure the scripts contain all service interfaces on the IRF fabric.
During IRF software upgrade
·     First upgrade software for the master device. Make sure the master device has a higher member priority than the standby device.
·     To avoid configuration loss, do not save the running configuration on any IRF member device when the IRF fabric splits.
·     After the master device starts up after software upgrade, make sure all member devices and cards are running correctly. Use the display interface command to verify that all interfaces are displayed, and then wait for 2 minutes before you move to the next step.
·     After the standby device reboots, reconnect IRF links before the standby device finishes restartup. If you reconnect IRF links after the standby device finishes restartup, the standby device must reboot again to complete IRF merge with the master device.
After IRF software upgrade
·     Verify that all services on the IRF fabric are running correctly. If a service cannot run correctly, locate and resolve the issue as soon as possible.
1.     Configure NSR settings on the IRF fabric:
During the upgrade process, master/standby switchover will occur. If the IRF fabric runs routing protocols, for example, BGP and OSPF, the switchover issue might cause routing neighbor flapping and affect packet forwarding. For high availability, configure NSR for routing protocols. Before upgrading software on the IRF fabric, configure NSR settings and save the configuration. In this example, OSPF NSR and BGP NSR are configured for illustration.
# Enable NSR for OSPF process 100.
<IRF> system-view
[IRF] ospf 100
[IRF-ospf-100] non-stop-routing
[IRF-ospf-100] display ospf non-stop-routing status
         OSPF Process 100 with Router ID 1.1.1.1
                  Non Stop Routing information
 Non Stop Routing capability : Enabled
 Upgrade phase : Normal
[IRF-ospf-100] quit
[IRF] quit
# Enable NSR for BGP process 100.
[IRF] bgp 100
[IRF-bgp-default] non-stop-routing
[IRF-bgp-default] display bgp non-stop-routing status
 BGP NSR status: Ready
 Location of preferred standby process: Slot 2
 TCP NSR status: Ready
[IRF-bgp-default] quit
[IRF-bgp] quit
2.     Verify that the master device is assigned a higher member priority than the standby device. The higher the priority value, the higher the priority to be the master device. In this example, set the member priority of Device A to 32.
[IRF] irf member 1 priority 32
3.     Check single-armed service links.
IRF split will occur during the upgrade process. In addition, you need to shut down all service interfaces on one member device. For high availability, deploy physical links dual-homed to both member devices for each uplink device and downlink device. That is, connect Device D to both Device A and Device B, and connect Device C to both Device A and Device B. If single-armed services exist, service access exception will occur during the upgrade process. As a best practice, add backup links for single-armed services.
4.     Check IRF status and collect information:
Before the upgrade process, you must check the device status, HA status, IRF status, and MAD status.
IMPORTANT
IMPORTANT:
Make sure all member devices and cards are in stable state. If a member device or card is not in stable state, identify the reason. Do not upgrade software on an IRF fabric unless all member devices and cards are in stable state.
# Display device information.
[IRF] display device
Slot Type             State    Subslot  Soft Ver             Patch Ver
1    S5560X-30C-PWR-EIMaster   0        2432p06              None
2    S5560X-30C-PWR-EIStandby  0        2432p06              None
# Display system stable status.
[IRF] display system stable state
System state     : Stable
Redundancy state : Stable
  Slot    CPU    Role       State
  1       0      Active     Stable
  2       0      Standby    Stable
# Display brief information about system stability and status, including CPU running status, redundancy status, and NSR status.
[IRF] display system stable state summary
NSR     state     : Ready
# Display IRF information.
<IRF> display irf
MemberID    Role    Priority  CPU-Mac         Description
 *+1        Master  32        f010-90db-7402  ---
   2        Standby 1         f010-90db-0204  ---
 The bridge MAC of the IRF is: 0000-0001-0002
 Auto upgrade                : yes
 Mac persistent              : 12 min
 Domain ID                   : 0
# Display IRF configuration on all IRF member devices.
<IRF> display irf configuration
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        Ten-GigabitEthernet1/0/27     disable
                   Ten-GigabitEthernet1/0/28
 2        2        disable                       Ten-GigabitEthernet2/0/27
                                                 Ten-GigabitEthernet2/0/28
# Display IRF link information.
<IRF> display irf link
Member 1
 IRF Port  Interface                             Status
 1         Ten-GigabitEthernet1/0/27             UP
           Ten-GigabitEthernet1/0/28             UP
 2         disable                               --
Member 2
 1         disable                               --
 2         Ten-GigabitEthernet2/0/27             UP
           Ten-GigabitEthernet2/0/28             UP
# Display IRF topology information.
<IRF> display irf topology
                              Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 2           DIS        ---           UP         1           f010-90db-7402
 1           UP         2             DIS        ---         f010-90db-7402
# Display detailed MAD information.
<IRF> display mad verbose
Multi-active recovery state: No
Excluded ports (user-configured):
Excluded ports (system-configured):
  IRF physical interfaces:
  BFD MAD interfaces:
    Vlan-interface2
MAD ARP disabled.
MAD ND disabled.
MAD LACP disabled.
MAD BFD enabled interface: Vlan-interface2
  MAD status                 : Normal
  Member ID   MAD IP address       Neighbor   MAD status
  1           192.168.2.1/24       2          Normal
  2           192.168.2.2/24       1          Normal
# Display BFD session information.
[IRF] display bfd session
 Total Sessions: 1     Up Sessions: 1     Init mode: Active
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 32833/0        192.168.2.1     192.168.2.2     Down        /        Vlan2
5.     Verify that the IRF fabric is running correctly, and collect status information, including status information for protocols, ports, and table entries, for comparing the information with the information collected after the upgrade:
# Display system version information.
<IRF> display version
H3C Comware Software, Version 7.1.070, Release 2432p06
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.
H3C S5560X-30C-PWR-EI uptime is 4 weeks, 2 days, 22 hours, 3 minutes
Last reboot reason : User reboot
Boot image: flash:/cmw710-system-r2432p06.bin
Boot image version: 7.1.070, Release 2432p06
  Compiled Sep 29 2021 11:00:00
System image: flash:/cmw710-system-r2432p06.bin
System image version: 7.1.070, Release 2432p06
# Display the running configuration.
<IRF> display current-configuration
 version 7.1.070, Release 2432p06
 sysname IRF
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 2 priority 1
ospf 100
 non-stop-routing
# Display brief interface information.
<IRF> display interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP        Description
InLoop0              UP   UP(s)    --
MGE0/0/0             DOWN DOWN     --
NULL0                UP   UP(s)    --
REG0                 UP   --       --
Vlan2                UP   UP       192.168.2.1
Speed: (a) - auto
Interface            Link Speed     Duplex Type PVID Description
GE1/0/1               UP   1G(a)     F(a)   A    2
GE1/0/2               DOWN auto      A      A    1
GE1/0/3               DOWN auto      A      A    1
# Display ARP entries.
<IRF> display arp
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
2.2.2.2         6451-c3f1-0302 20            BAGG1                    941   D
3.3.3.2         6451-ccf3-0402 30            BAGG2                    1020  D
# Display MAC address table information.
<IRF> display mac-address
MAC Address      VLAN ID    State            Port/Nickname            Aging
a442-f6d0-9344   2          Learned          GE1/0/1                  Y
6451-c3f1-0302   23         Learned          BAGG1                    Y
6451-ccf3-0402   24         Learned          BAGG2                    Y
# Display information about OSPF neighbors. In this example, static routing is used. The command does not display any information.
<IRF> display ospf peer
# Display routing table information.
<IRF> display ip routing-table
Destinations : 21       Routes : 21
0.0.0.0/32         Direct  60  0           2.2.2.2         Vlan23
1.1.1.1/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.0/24         Direct  0   0           2.2.2.1         Vlan23
2.2.2.0/32         Direct  0   0           2.2.2.1         Vlan23
2.2.2.1/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.255/32       Direct  0   0           2.2.2.1         Vlan23
3.3.3.0/24         Direct  0   0           3.3.3.1         Vlan24
3.3.3.0/32         Direct  0   0           3.3.3.1         Vlan24
3.3.3.1/32         Direct  0   0           127.0.0.1       InLoop0
3.3.3.255/32       Direct  0   0           3.3.3.1         Vlan24
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
192.168.2.0/24     Direct  0   0           192.168.2.1     Vlan2
192.168.2.0/32     Direct  0   0           192.168.2.1     Vlan2
192.168.2.1/32     Direct  0   0           127.0.0.1       InLoop0
192.168.2.255/32   Direct  0   0           192.168.2.1     Vlan2
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Display detailed information about aggregation groups.
<IRF> display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority Oper-Key
  GE1/0/10(R)     S       32768    1
  GE2/0/10        S       32768    1
Aggregate Interface: Bridge-Aggregation2
  GE1/0/23         S       32768    2
  GE2/0/23(R)      S       32768    2
6.     Back up the main next-startup configuration file:
# Save the running configuration to the main next-startup configuration file.
<IRF> save
The startup.cfg file already exists.
Compared with the startup.cfg file, The current configuration adds 0 commands and deletes 0 commands.
If you want to see the configuration differences, please cancel this operation, and then use the display diff command to show the details.
If you continue the save operation, the file will be overwritten.
Are you sure you want to continue the save operation? [Y/N]:y
Saving the current configuration to the file. Please wait...
Slot 2:
Save next configuration file successfully.
# Display the names of the current startup configuration file and the next-startup configuration files.
<IRF> display startup
MainBoard:
 Current startup saved-configuration file: NULL
 Next main startup saved-configuration file: flash:/startup.cfg
 Next backup startup saved-configuration file: NULL
Slot 2:
# Back up next-startup configuration file startup.cfg.
<IRF> tftp 2.2.2.3 put startup.cfg
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  8128    0     0  100  8128      0   170k --:--:-- --:--:-- --:--:--  233k
<IRF>
7.     Verify that the member devices have sufficient storage space to store the new startup image file:
# On Device A, display information about files and directories in the current directory.
<IRF> dir
Directory of flash:
   1 -rw-      220684 Nov 15 2021 17:37:48   defaultfile.zip
   2 drw-           - Jan 01 2021 00:01:33   diagfile
554288 KB total (228880 KB free)
# On Device B, display information about files and directories in the current directory.
<IRF> dir slot2#flash:/
Directory of flash:
   2 drw-           - Jan 01 2011 00:01:33   diagfile
554288 KB total (221104 KB free)
8.     Upload the new startup image file and validate the file:
# Upload image file r2702.ipe to Device A, and verify that the size of the uploaded file on Device A is the same as that of the officially released one. If the file sizes are different, upload the file again.
<IRF> tftp 2.2.2.3 get r2702.ipe
100  133M  100  133M    0     0   180k      0  0:12:33  0:12:33 --:--:--  177k
Writing file...Done.
<IRF> dir r2702.ipe
Directory of flash:
   25 -rw-   139699200 Nov 19 2021 12:07:56   r2702.ipe
524288 KB total (167504 KB free)
# Use MD5 digest to validate the new startup image file. The file is valid if the digest calculated by using the md5sum command is the same as the MD5 digest published when the image file was released or the same as the file's digest generated by using an MD5 tool.
<IRF> md5sum r2702.ipe
MD5 digest:
33d9e48423f7cc67fcaf7d674cf1dbe8
Figure 2 Using an MD5 tool to generate a digest
9.     Copy the new startup image file to Device B for backup.
<IRF> copy r2702.ipe slot2#flash:/
Copy flash:/r2702.ipe to slot2#flash:/r2702.ipe? [Y/N]:y
Copying file flash:/r2702.ipe to slot2#flash:/r2702.ipe.................. Done.
Procedures
Specifying the new startup image file and verifying the configuration
# Specifying file r2702.ipe as the main startup image file.
<IRF> boot-loader file flash:/r2702.ipe all main
Verifying the file flash:/r2702.ipe on slot 1...................................
..................Done.
H3C S5560X-30C-PWR-EI images in IPE:
  cmw710-boot-r2702.bin
  cmw710-system-r2702.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1.
Decompressing file cmw710-boot-r2702.bin to flash:/cmw710-boot-r2702.bin...........................Done.
Decompressing file cmw710-system-r2702.bin to flash:/cmw710-system-r2702.bin.......................................................................................................................................................................Done.
Verifying the file flash:/cmw710-boot-r2702.bin on slot 1........Done.
Verifying the file flash:/cmw710-system-r2702.bin on slot 1................................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
Loading............................................................Done.
Loading....................................................................................................................................................................................................................................................Done.
Verifying the file flash:/cmw710-boot-r2702.bin on slot 2....Done.
Verifying the file flash:/cmw710-system-r2702.bin on slot 2...................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 2.
Decompression completed.
Do you want to delete flash:/5560.ipe now? [Y/N]:n
# Verify that file r2702.ipe has been specified as the main startup image file on all slots.
<IRF> display boot-loader
Software images on slot 1:
Current software images:
  flash:/cmw710-boot-r2432p06.bin
Main startup software images:
Backup startup software images:
Software images on slot 2:
  flash:cmw710-boot-r2432p06.bin
Disabling MAD (BFD MAD in the example)
# Disable MAD and remove cables from the interfaces used for MAD. In this example, VLAN-interface 2 is used for BFD MAD.
<IRF> system-view
[IRF] interface vlan-interface 2
[IRF-Vlan-interface2] undo mad bfd enable
[IRF-Vlan-interface2] display this
interface Vlan-interface2
return
Shutting down service interfaces on the master device and saving the configuration
# Shut down all uplink and downlink interfaces on Device A. Do not shut down IRF physical interfaces and the interfaces used for BFD MAD on Device A.
[IRF] interface range name yewu interface gigabitethernet 1/0/2 to gigabitethernet 1/0/22 ten-gigabitethernet 1/0/25 to ten-gigabitethernet 1/0/26
[IRF-if-range-yewu] shutdown
[IRF-if-range-yewu] quit
[IRF] quit
# On Device D and Device C, ping each other. If the ping operations succeed, Device C and Device D are reachable. If the ping operations fail, locate and resolve the communication failure issue. (Details not shown.)
# Verify that all services have been switched from Device A to Device B. (Details not shown.)
# Save the running configuration.
<IRF> save
Slot 2:
Rebooting the master device and splitting the IRF fabric
# Reboot the master device (Device A).
<IRF> reboot slot 1
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
Now rebooting, please wait..........
# Shut down IRF physical interfaces Ten-GigabitEthernet 2/0/27 and Ten-GigabitEthernet 2/0/28 on Device B to cause IRF split.
CAUTION
CAUTION:
The IRF fabric splits after you shut down all IRF physical interfaces on Device B. To prevent configuration loss from affecting interface status and causing IRF merge failure or service traffic interruption, do not save the running configuration on the master device (Device A) when the IRF fabric splits.
<IRF> system-view
[IRF] interface range name irf-port interface ten-gigabitethernet 2/0/27 to ten-gigabitethernet 2/0/28
[IRF-if-range-irf-port] shutdown
Shutting down service interfaces on the standby device and bringing up service interfaces on the master device
IMPORTANT
IMPORTANT:
To reduce the service interruption time, shorten the operation time as much as possible. As a best practice, prepare the required command lines in advance and copy and paste the command lines to the devices.
# After Device A finishes startup, verify that all interfaces are displayed.
# Wait for about 2 minutes for forwarding entry convergence on Device A.
# Verify that Device A is stable.
<IRF> display system stable state
Redundancy state : No redundancy
  Slot    CPU    Role       State
  1        0          Active     Stable
# Log in to Device B and shut down all service interfaces on the device. Do not shut down IRF physical interfaces and the interfaces used for BFD MAD.
<IRF> system-view
[IRF] interface range name yewu-2 interface gigabitethernet 2/0/2 to gigabitethernet 2/0/22 ten-gigabitethernet 2/0/25 to ten-gigabitethernet 2/0/26
[IRF-if-range-yewu-2] shutdown
# Log in to Device A and bring up all service interfaces on the device.
<IRF> system-view
[IRF-if-range-yewu] undo shutdown
Rebooting the standby device
# Verify that services have been switched back to Device A. (Details not shown.)
# ,Log in to Device B and reboot Device B.
<IRF> reboot slot 2
.......DONE!
[Y/N]:y
After Device B reboots, it acts as a standby device to complete IRF merge with Device A.
Checking the environment after IRF software upgrade
1.     Check IRF status and services:
# After Device B reboots, check IRF status and service status, collect status information, and compare the status information with that before the upgrade process. If the status information is inconsistent before and after upgrade, locate and resolve the issue.
[IRF] display irf
[IRF] display irf configuration
[IRF] display irf link
[IRF] display irf topology
2.     Enable MAD and verify the configuration.
[IRF-Vlan-interface2] mad bfd enable
[IRF-Vlan-interface2] mad ip address 192.168.2.1 24 member 1
[IRF-Vlan-interface2] mad ip address 192.168.2.2 24 member 2
[IRF-Vlan-interface2] quit
[IRF] display mad verbose
  BFD MAD interfaces:
    Vlan-interface2
MAD ARP disabled.
MAD ND disabled.
MAD LACP disabled.
  MAD status                 : Normal
3.     Delete unused settings as needed and save the configuration.
[IRF] undo interface range yewu
[IRF] undo interface range yewu-2
[IRF] save
4.     Check the device status, collect device status information, and compare the device status with that before the upgrade process. If the device status information is inconsistent before and after upgrade, locate and resolve the issue.
<IRF> display arp
<IRF> displayplay ospf peer
# Display IRF version information. Verify that the software version has been upgraded from R2432p06 to R2720.
H3C Comware Software, Version 7.1.070, Release 2720
H3C S5560X-30C-PWR-EI uptime is 4 weeks, 5 days, 14 hours, 32 minutes
Boot image: flash:/cmw710-boot-r2720.bin
Boot image version: 7.1.070, Release 2720
System image: flash:/cmw710-system-r2720.bin
System image version: 7.1.070, Release 2720
Slot 1:
Uptime is 4 weeks,5 days,14 hours,32 minutes
S5560X-30C-PWR-EI with 1 RMI XLS408 Processor
BOARD TYPE:         S5560X-30C-PWR-EI
DRAM:               2048M bytes
FLASH:              512M bytes
PCB 1 Version:      VER.A
FPGA Version:       NONE
Bootrom Version:    158
CPLD 1 Version:     002
CPLD 2 Version:     001
Release Version:    H3C S5560X-30C-PWR-EI-2720
Patch Version:      None
Reboot Cause:       UserReboot
[SubSlot 0] 48XGT+6QSFP Plus
