H3C Fixed Port Campus Switches Configuration Examples-6W103
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W103
Table of Contents
Related Documents
66-BIDIR-PIM Configuration Examples
66-BIDIR-PIM Configuration Examples 112.43 KB
Introduction
This document introduces BIDIR-PIM configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BIDIR-PIM.
Example: Configuring BIDIR-PIM
As shown in Figure 1:
·     Switch A, Switch B, and Switch C run OSPF.
·     Source 1 and Source 2 send multicast data to multicast group 225.1.1.1.
·     Host A and Host B are member hosts of multicast group 225.1.1.1.
Configure BIDIR-PIM on the switches to implement multicast forwarding.
Figure 1 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
10.10.1.1/24
Switch C
Vlan-int102
10.102.1.1/24
Switch A
Vlan-int12
10.12.1.1/24
Switch C
Vlan-int13
10.13.1.3/24
Switch A
Vlan-int13
10.13.1.1/24
Switch C
Vlan-int23
10.23.1.3/24
Switch B
Vlan-int101
10.101.1.1/24
Switch C
Vlan-int33
10.33.1.3/24
Switch B
Vlan-int12
10.12.1.2/24
Source 1
10.10.1.2/24
Switch B
Vlan-int23
10.23.1.2/24
Source 2
10.33.1.4/24
Analysis
To meet the network requirements, perform the following tasks:
·     To establish the bidirectional RPT, configure VLAN-interface 12 on Switch A as a C-RP.
·     To use the BSR mechanism to dynamically elect the RP, configure VLAN-interface 12 on Switch A as a C-BSR.
·     To avoid multicast forwarding interruption when the RP fails, specify the unused IP address 10.13.1.4/24 as the static RP. In this way, the link on the subnet 10.13.1.0/24 becomes the RPL. Switch A and Switch C on the link function as the RPs.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S6550XE-HI switch series
Release 6008 and later
S6525XE-HI switch series
S5850 switch series
Release 8005 and later
S5570S-EI switch series
Not supported
S5560X-EI switch series
Release 65xx, Release 66xx
S5560X-HI switch series
S5500V2-EI switch series
ES5500 switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S
MS4520V2-24TP
Not supported
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
Not supported
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI
S5500V3-48P-SI
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C
E152C
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC
IE4300-12P-PWR
IE4300-M switch series
IE4320 switch series
Not supported
When you configure BIDIR-PIM, follow these restrictions and guidelines:
·     Enable the same PIM mode on the interfaces that belong to the same VPN instance on each switch.
·     Configure the same static RP on all the switches in the BIDIR-PIM domain.
·     Enable PIM-SM for all interfaces on the switches in the BIDIR-PIM domain.
·     Enable IGMP for the interfaces that connect to the stub networks on all the switches in the BIDIR-PIM domain.
Procedures
Configure Switch A
1.     Enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
2.     Configure each interface and enable PIM-SM.
# Create VLAN 100, and assign GigabitEthernet 1/0/1 to this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 1/0/1
[SwitchA-vlan100] quit
# Assign an IP address to VLAN-interface 100, and enable PIM-SM on the interface.
[SwitchA-Vlan-interface100] ip address 10.10.1.1 24
# Create VLAN 12, and assign GigabitEthernet 1/0/2 to the VLAN.
[SwitchA] vlan 12
[SwitchA-vlan12] port gigabitethernet 1/0/2
[SwitchA-vlan12] quit
# Assign an IP address to VLAN-interface 12, enable PIM-SM on the interface.
[SwitchA-vlan12] interface vlan-interface 12
[SwitchA-Vlan-interface12] ip address 10.12.1.1 24
[SwitchA-Vlan-interface12] pim sm
[SwitchA-Vlan-interface12] quit
# Create VLAN 13, and assign GigabitEthernet 1/0/3 to the VLAN.
[SwitchA] vlan 13
[SwitchA-vlan13] port gigabitethernet 1/0/3
[SwitchA-vlan13] quit
# Assign an IP address to VLAN-interface 13, enable PIM-SM on the interface.
[SwitchA] interface vlan-interface 13
[SwitchA-Vlan-interface13] ip address 10.13.1.1 24
[SwitchA-Vlan-interface13] pim sm
[SwitchA-Vlan-interface13] quit
3.     Configure a C-RP, a C-BSR, and the static RP.
# Configure VLAN-interface 12 as a C-BSR and a C-RP.
[SwitchA] pim
[SwitchA-pim] c-bsr 10.12.1.1
[SwitchA-pim] c-rp 10.12.1.1 bidir
# Specify the unused IP address 10.13.1.4 as a static RP.
[SwitchA-pim] static-rp 10.13.1.4 bidir
4.     Enable BIDIR-PIM.
[SwitchA-pim] bidir-pim enable
[SwitchA-pim] quit
5.     Configure OSPF.
[SwitchA] ospf 1
[SwitchA-ospf-1] import-route direct
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchA-ospf-1] quit
Configure Switch B
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Create VLAN 12, and assign GigabitEthernet 1/0/2 to this VLAN.
[SwitchB] vlan 12
[SwitchB-vlan12] port gigabitethernet 1/0/2
[SwitchB-vlan12] quit
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ip address 10.12.1.2 24
[SwitchB-Vlan-interface12] pim sm
[SwitchB-Vlan-interface12] quit
# Create VLAN 23, and assign GigabitEthernet 1/0/3 to this VLAN.
[SwitchB] vlan 23
[SwitchB-vlan23] port gigabitethernet 1/0/3
[SwitchB-vlan23] quit
# Assign an IP address to VLAN-interface 23, enable PIM-SM on the interface.
[SwitchB] interface vlan-interface 23
[SwitchB-Vlan-interface23] ip address 10.23.1.2 24
[SwitchB-Vlan-interface23] pim sm
[SwitchB-Vlan-interface23] quit
# Create VLAN 101, and assign GigabitEthernet 1/0/1 to this VLAN.
[SwitchB] vlan 101
[SwitchB-vlan101] port gigabitethernet 1/0/1
[SwitchB-vlan101] quit
# Assign an IP address to VLAN-interface 101, enable PIM-SM and IGMP on the interface.
[SwitchB-Vlan-interface101] ip address 10.101.1.1 24
[SwitchB-Vlan-interface101] igmp enable
3.     Specify the unused IP address 10.13.1.4 as a static RP.
[SwitchB] pim
[SwitchB-pim] static-rp 10.13.1.4 bidir
[SwitchB-pim] bidir-pim enable
[SwitchB-pim] quit
5.     Configure OSPF.
[SwitchB] ospf 1
[SwitchB-ospf-1] import-route direct
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchB-ospf-1] quit
Configure Switch C
[SwitchC] multicast routing
[SwitchC-mrib] quit
# Create VLAN 33, and assign GigabitEthernet 1/0/4 to this VLAN.
[SwitchC] vlan 33
[SwitchC-vlan33] port gigabitethernet 1/0/4
[SwitchC-vlan33] quit
# Assign an IP address to VLAN-interface 33, enable PIM-SM on the interface.
[SwitchC] interface vlan-interface 33
[SwitchC-Vlan-interface33] ip address 10.33.1.3 24
[SwitchC-Vlan-interface33] pim sm
[SwitchC-Vlan-interface33] quit
# Create VLAN 13, and assign GigabitEthernet 1/0/3 to this VLAN.
[SwitchC] vlan 13
[SwitchC-vlan13] port gigabitethernet 1/0/3
[SwitchC-vlan13] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] ip address 10.13.1.3 24
[SwitchC-Vlan-interface13] pim sm
[SwitchC-Vlan-interface13] quit
# Create VLAN 23, and assign GigabitEthernet 1/0/2 to this VLAN.
[SwitchC] vlan 23
[SwitchC-vlan23] port gigabitethernet 1/0/2
[SwitchC-vlan23] quit
[SwitchC] interface vlan-interface 23
[SwitchC-Vlan-interface23] ip address 10.23.1.3 24
[SwitchC-Vlan-interface23] pim sm
[SwitchC-Vlan-interface23] quit
# Create VLAN 102, and assign GigabitEthernet 1/0/1 to this VLAN.
[SwitchC] vlan 102
[SwitchC-vlan102] port gigabitethernet 1/0/1
[SwitchC-vlan102] quit
# Assign an IP address to VLAN-interface 102, enable PIM-SM and IGMP on the interface.
[SwitchC-Vlan-interface102] ip address 10.102.1.1 24
[SwitchC-Vlan-interface102] igmp enable
[SwitchC] pim
[SwitchC-pim] static-rp 10.13.1.4 bidir
4.     Enable BIDIR-PIM
[SwitchC-pim] bidir-pim enable
[SwitchC-pim] quit
5.     Configure OSPF.
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchC-ospf-1] quit
1.     Verify that Switch A, Switch B, and Switch C have established PIM neighbor relationships.
# Display PIM neighbor information on Switch A.
[SwitchA] display pim neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime   Expires  DR-Priority Mode
 10.12.1.2       Vlan12              00:02:27 00:01:45 1           B
 10.13.1.3       Vlan13              00:02:27 00:01:19 1           B
# Display PIM neighbor information on Switch B.
[SwitchB] display pim neighbor
 10.12.1.1       Vlan12              00:03:05 00:01:44 1           B
 10.23.1.3       Vlan23              00:13:49 00:01:29 1           B
# Display PIM neighbor information on Switch C.
[SwitchC] display pim neighbor
 10.13.1.1       Vlan13              00:03:28 00:01:39 1           B
 10.23.1.2       Vlan23              00:14:05 00:01:36 1           B
2.     Verify that VLAN-interface 12 on Switch A has been elected as the BSR on each switch.
# Display BSR information on Switch A.
[SwitchA] display pim bsr-info
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:01:18
     Elected BSR address: 10.12.1.1
       Priority: 64
       Hash mask length: 30
       Uptime: 00:04:01
     Candidate BSR address: 10.12.1.1
       Priority: 64
# Display BSR information on Switch B.
[SwitchB] display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:00:26
       Priority: 64
       Uptime: 00:10:41
# Display BSR information on Switch C.
[SwitchC] display pim bsr-info
 Scope: non-scoped
     Bootstrap timer: 00:02:08
       Priority: 64
       Uptime: 00:15:41
3.     Verify that VLAN-interface 12 on Switch A has been elected as the RP, and verify that the IP address of the static RP is 10.13.1.4 on each switch.
# Display RP information on Switch A.
[SwitchA] display pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4 [B]
       RP address               Priority  HoldTime  Uptime    Expires
       10.12.1.1 (local)        192       150       00:06:01  00:02:58
 Static RP information:
       RP address               ACL   Mode    Preferred
       10.13.1.4                ----  bidir   No
# Display RP information on Switch B.
[SwatchB] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.12.1.1                192       150       00:06:33  00:02:26
# Display RP information on Switch C.
[SwitchC] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.12.1.1                192       150       00:06:51  00:02:05
4.     Verify that the DFs have been elected for BIDIR-PIM on each switch.
# Display information about DFs for BIDIR-PIM on Switch A.
[SwitchA] display pim df-info
RP address: 10.12.1.1
  Interface: Vlan-interface100
    State     : Win        DF preference: 0
    DF metric : 0          DF uptime    : 00:01:09
    DF address: 10.10.1.1 (local)
  Interface: Vlan-interface12
    State     : -          DF preference: -
    DF metric : -          DF uptime    : -
    DF address: -
  Interface: Vlan-interface13
    DF metric : 0          DF uptime    : 00:01:10
    DF address: 10.13.1.1 (local)
RP address: 10.13.1.4
    DF metric : 0          DF uptime    : 00:00:07
    DF address: 10.12.1.1 (local)
    DF address: -
# Display information about DFs for BIDIR-PIM on Switch B.
[SwatchB] display pim df-info
    DF address: -
  Interface: Vlan-interface23
    DF metric : 0          DF uptime    : 00:01:46
    DF address: 10.23.1.2 (local)
  Interface: Vlan-interface101
    DF metric : 0          DF uptime    : 00:01:45
    DF address: 10.101.1.1 (local)
    State     : Lose       DF preference: 0
    DF metric : 0          DF uptime    : 00:00:44
    DF metric : 0          DF uptime    : 00:00:53
    DF address: 10.23.1.3
    State     : Win        DF preference: 10
    DF metric : 2          DF uptime    : 00:00:53
# Display information about DFs for BIDIR-PIM on Switch C.
[SwitchC] display pim df-info
  Interface: Vlan-interface102
    DF metric : 2          DF uptime    : 00:02:07
    DF address: 10.102.1.1 (local)
  Interface: Vlan-interface33
    DF metric : 2          DF uptime    : 00:02:06
    DF address: 10.33.1.3 (local)
    DF metric : 0          DF uptime    : 00:02:07
    DF metric : 0          DF uptime    : 00:01:24
    DF metric : 0          DF uptime    : 00:01:23
    DF address: -
5.     Verify that DFs for multicast forwarding are correct on each switch.
# Display information about DFs for multicast forwarding on Switch A.
[SwitchA] display multicast forwarding df-info
Total 2 RPs, 2 matched
00001. RP address: 10.12.1.1
     Flags: 0x0
     Uptime: 00:02:42
     RPF interface: Vlan-interface12
     List of 2 DF interfaces:
       1: Vlan-interface100
       2: Vlan-interface13
00002. RP address: 10.13.1.4
     Flags: 0x0
     Uptime: 00:01:41
     RPF interface: Vlan-interface13
       2: Vlan-interface12
# Display information about DFs for multicast forwarding on Switch B.
[SwitchB] display multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:03:18
       1: Vlan-interface23
       2: Vlan-interface101
     Flags: 0x0
     Uptime: 00:02:24
     RPF interface: Vlan-interface23
     List of 1 DF interfaces:
       1: Vlan-interface101
# Display information about DFs for multicast forwarding on Switch C.
[SwitchC] display multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:03:38
       1: Vlan-interface102
       2: Vlan-interface33
     Flags: 0x0
     Uptime: 00:02:41
     List of 3 DF interfaces:
       1: Vlan-interface33
       2: Vlan-interface23
       3: Vlan-interface102
6.     Send IGMP reports from Host A and Host B to join multicast group 225.1.1.1, and send multicast data from Source 1 and Source 2 to the group. (Details not shown.)
7.     Verify that PIM forwarding entries have been correctly established on each switch.
# Display information about PIM routing entries on Switch A.
[SwitchA] display pim routing-table
 Total 1 (*, G) entries; 0 (S, G) entries
 (*, 225.1.1.1)
     RP: 10.12.1.1 (local)
     Protocol: pim-bidir, Flag: WC LOC ACT
     UpTime: 00:21:59
     Upstream interface: Vlan-interface12
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Vlan-interface12
             Protocol: pim-bidir, UpTime: 00:21:59, Expires: -
         2: Vlan-interface13
             Protocol: pim-bidir, UpTime: 00:03:26, Expires: -
# Display information about PIM routing entries on Switch B.
[SwitchB] display pim routing-table
 (*, 225.1.1.1)
     RP: 10.12.1.1
     UpTime: 00:23:47
     Total number of downstreams: 3
         1: Vlan-interface12
             Protocol: pim-bidir, UpTime: 00:23:47, Expires: -
         2: Vlan-interface23
             Protocol: pim-bidir, UpTime: 00:21:56, Expires: -
         3: Vlan-interface101
             Protocol: igmp, UpTime: 00:23:47, Expires: -
# Display information about PIM routing entries on Switch C.
[SwitchC] display pim routing-table
 (*, 225.1.1.1)
     RP: 10.12.1.1
     Protocol: pim-bidir, Flag: WC ACT
     UpTime: 00:01:45
     Upstream interface: Vlan-interface23
         Upstream neighbor: 10.23.1.2
         RPF prime neighbor: 10.23.1.2
     Total number of downstreams: 2
             Protocol: igmp, UpTime: 00:01:05, Expires: -
         2: Vlan-interface23
             Protocol: pim-bidir, UpTime: 00:00:53, Expires: -
Configuration files
IMPORTANT
IMPORTANT:
Support for the port link-mode bridge command depends on the device model.
·     Switch A:
ospf 1
 area 0.0.0.0
vlan 12 to 13
vlan 100
interface Vlan-interface12
 ip address 10.12.1.1 255.255.255.0
 pim sm
interface Vlan-interface13
 ip address 10.13.1.1 255.255.255.0
 pim sm
interface Vlan-interface100
 ip address 10.10.1.1 255.255.255.0
 pim sm
 port access vlan 100
 port access vlan 12
 port access vlan 13
multicast routing
pim
 bidir-pim enable
 c-bsr 10.12.1.1
·     Switch B:
ospf 1
 area 0.0.0.0
vlan 12
Vlan 23
vlan 101
 ip address 10.12.1.2 255.255.255.0
 pim sm
interface Vlan-interface23
 ip address 10.23.1.2 255.255.255.0
 pim sm
interface Vlan-interface101
 ip address 10.101.1.1 255.255.255.0
 igmp enable
 port access vlan 101
 port access vlan 12
 port access vlan 23
multicast routing
pim
 bidir-pim enable
·     Switch C:
ospf 1
 area 0.0.0.0
vlan 13
vlan 23
vlan 33
vlan 102
 ip address 10.13.1.3 255.255.255.0
 pim sm
 ip address 10.23.1.3 255.255.255.0
 pim sm
interface Vlan-interface33
 ip address 10.33.1.3 255.255.255.0
 pim sm
interface Vlan-interface102
 ip address 10.102.1.1 255.255.255.0
 igmp enable
 port access vlan 102
 port access vlan 23
 port access vlan 13
interface GigabitEthernet1/0/4
 port access vlan 33
multicast routing
pim
 bidir-pim enable
