H3C Fixed Port Campus Switches Configuration Examples-6W103
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W103
Table of Contents
Related Documents
79-IRF Member Replacement Configuration Examples
79-IRF Member Replacement Configuration Examples 105.22 KB
Introduction
This document provides examples for replacing an IRF member device with a new device.
This document assumes that you have basic knowledge of IRF.
Example: Replacing an IRF member device with a new device
In this example, the IRF fabric does not split. Because the standby device fails, you need to replace the standby device with a new device. During the replacement, the IRF fabric will split. The procedures in this example are also applicable to master device replacement in scenarios where the master device fails when the IRF fabric is integrated.
As shown in Figure 1, Device A and Device B have set up an IRF fabric. Device A is the master device and its member ID is 1, and Device B is the standby device and its member ID is 2. BFD MAD is used for multi-active collision detection.
Device B fails when the IRF fabric is integrated. Replace Device B with a new device.
Figure 1 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S6550XE-HI switch series
Release 6008 and later
S6525XE-HI switch series
S5850 switch series
Release 8005 and later
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 66xx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Release 63xx
S5500V3-SI switch series (except the S5500V3-24P-SI and S5500V3-48P-SI switches)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Release 11xx
S5120V3-SI switch series (except the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI switches)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
Change the IRF member ID of the new device in advance and reboot the device for the change to take effect.
Prepare scripts in advance for shutting down or bringing up the uplink and downlink service interfaces on Device B. To prevent omission of service interfaces from resulting in exceptions in the replacement process, make sure the scripts contain all service interfaces on Device B.
To avoid configuration loss, do not save the running configuration on any IRF member device when the IRF fabric splits.
After the IRF fabric recovers, make sure all member devices are running correctly. Use the display interface brief command to verify that all interfaces are displayed, and then wait for 2 minutes before you move to the next step.
As a best practice to discover, locate, and analyze issues in time, record all operations during the whole replacement process. Login software, for example, HyperTerminal and PuTTY, supports session recording.  The software can automatically record all user operations and save the operations to a .txt file. If the login software does not support session recording, you must manually record all operations.
1.     Configure NSR settings on the IRF fabric:
During the replacement, process-level active/standby switchover might occur for routing protocols such as BGP and OSPF. This issue causes routing neighbor flapping and affects packet forwarding. For high availability, configure NSR for routing protocols. Before replacing Device B, configure NSR settings and save the configuration. In this example, OSPF NSR and BGP NSR are configured for illustration.
# Enable NSR for OSPF process 100.
<IRF> system-view
[IRF] ospf 100
[IRF-ospf-100] non-stop-routing
[IRF-ospf-100] display ospf non-stop-routing status
         OSPF Process 100 with Router ID 1.1.1.1
                  Non Stop Routing information
 Non Stop Routing capability : Enabled
 Upgrade phase : Normal
[IRF-ospf-100] quit
[IRF] quit
# Enable NSR for BGP process 100.
[IRF] bgp 100
[IRF-bgp-default] non-stop-routing
[IRF-bgp-default] display bgp non-stop-routing status
 BGP NSR status: Ready
 Location of preferred standby process: Slot 2
 TCP NSR status: Ready
[IRF-bgp-default] quit
[IRF-bgp] quit
[IRF] quit
2.     Examine whether Device B has single-armed service links.
Single-armed service links refer to links connected only to one IRF member device in an IRF fabric. They do not connect to other IRF member devices in the IRF fabric. If single-armed service links exist, traffic interruption will occur during the replacement process. To avoid traffic interruption, add backup links for the single-armed links.
3.     Check IRF status and collect information:
Before the replacement, you must check the device status, HA status, IRF status, and MAD status.
IMPORTANT
IMPORTANT:
Make sure all member devices except Device B are in stable state. If a member device is not in stable state, identify the reason. Do not replace Device B with a new device unless other member devices are all in stable state.
# Display device information.
<IRF> display device
Slot Type              State    Subslot  Soft Ver             Patch Ver
1    S5560X-30C-PWR-EI Master   0        S5560X-6530P01       None
2    S5560X-30C-PWR-EI Standby  0        S5560X-6530P01       None
# Display system stable status.
<IRF> display system stable state
System state     : Stable
Redundancy state : Stable
  Slot    CPU    Role       State
  1       0      Active     Stable
  2       0      Standby    Stable
# Display brief information about system stability and status, including CPU running status, redundancy status, and NSR status.
<IRF> display system stable state summary
NSR     state     : Ready
# Display IRF information.
<IRF> display irf
MemberID    Role    Priority  CPU-Mac         Description
*+1         Master  1         f010-90db-7402  ---
  2         Standby 1         f010-90db-8100  ---
 The bridge MAC of the IRF is: ae05-0607-eaaa
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
# Display IRF configuration on all IRF member devices.
<IRF> display irf configuration
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        Ten-GigabitEthernet1/0/25     disable
                   Ten-GigabitEthernet1/0/26
 2        2        disable                       Ten-GigabitEthernet2/0/25
                                                 Ten-GigabitEthernet2/0/26
# Display IRF link information.
<IRF> display irf link
Member 1
 IRF Port  Interface                             Status
 1         Ten-GigabitEthernet1/0/25             UP
           Ten-GigabitEthernet1/0/26             UP
 2         disable                               --
Member 2
 1         disable                               --
 2         Ten-GigabitEthernet2/0/25             UP
           Ten-GigabitEthernet2/0/26             UP
# Display IRF topology information.
<IRF> display irf topology
                              Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 2           DIS        ---           UP         1           f010-90db-7402
 1           UP         2             DIS        ---         f010-90db-7402
# Display detailed MAD information.
<IRF> display mad verbose
Multi-active recovery state: No
Excluded ports (user-configured):
Excluded ports (system-configured):
  IRF physical interfaces:
  BFD MAD interfaces:
    Vlan-interface2
MAD ARP disabled.
MAD ND disabled.
MAD LACP disabled.
MAD BFD enabled interface: Vlan-interface2
  MAD status                 : Normal
  Member ID   MAD IP address       Neighbor   MAD status
  1           192.168.2.1/24       2          Normal
  2           192.168.2.2/24       1          Normal
# Display BFD session information.
<IRF> display bfd session
 Total Sessions: 1     Up Sessions: 0     Init mode: Active
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 32833/0        192.168.2.1     192.168.2.2     Down        /        Vlan2
4.     Examine licensing state on the IRF fabric. If Device B has been installed with formal licenses, you must transfer the licenses on Device B to the new device before the replacement process. Alternatively, you can apply for and install new licenses of the same specification for the new device. For more information about license transfer and installation, see the licensing guide for the product. You cannot transfer trial licenses.
<IRF> display license
Slot 1:
flash:/license/210235A1XE00000000012020062314252639903.ak
Feature: OPENXCVR
Product Description: H3C Open Optical Transceiver Module Support License for 40G/10G(or Lower) Fixed-Port Campus Switches
Registered at: 2021-12-10 06:03:27
License Type: Permanent
Current State: In use
Slot 2:
flash:/license/210235A1XE00000000012020062314252631110.ak
Feature: OPENXCVR
5.     Verify that the IRF fabric is running correctly, and collect status information, including status information for protocols, ports, and table entries, for comparing the information with the information collected after the replacement:
# Display system version information.
<IRF> display version
# Display the running configuration.
<IRF> display current-configuration
# Display brief interface information.
<IRF> display interface brief
# Display ARP entries.
<IRF> display arp
# Display MAC address table information.
<IRF> display mac-address
# Display information about OSPF neighbors.
<IRF> display ospf peer
# Display routing table information.
<IRF> display ip routing-table
# Display detailed information about aggregation groups.
<IRF> display link-aggregation verbose
# Display traffic rate statistics for interfaces in up state within the most recent statistics polling interval.
<IRF> display counters rate inbound interface
6.     Back up the main next-startup configuration file:
# Save the running configuration to the main next-startup configuration file.
<IRF> save
The startup.cfg file already exists.
Compared with the startup.cfg file, The current configuration adds 0 commands and deletes 0 commands.
If you want to see the configuration differences, please cancel this operation, and then use the display diff command to show the details.
If you continue the save operation, the file will be overwritten.
Are you sure you want to continue the save operation? [Y/N]:y
Saving the current configuration to the file. Please wait...
Slot 2:
Save next configuration file successfully.
# Display the names of the current startup configuration file and the next-startup configuration files.
<IRF> display startup
MainBoard:
 Current startup saved-configuration file: NULL
 Next main startup saved-configuration file: flash:/startup.cfg
 Next backup startup saved-configuration file: NULL
Slot 2:
# Back up next-startup configuration file startup.cfg.
<IRF> tftp 2.2.2.3 put startup.cfg
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  8128    0     0  100  8128      0   170k --:--:-- --:--:-- --:--:--  233k
<IRF>
7.     Prepare the new device:
a.     Verify that the new device has the same model as the old device and runs the same version of software as the IRF fabric. If the new device runs a version of software different than the IRF fabric, upgrade the software on the new device.
<newDeviceB> display version
H3C Comware Software, Version 7.1.070, Release 6530P01
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.
H3C S5560X-30C-PWR-EI uptime is 0 weeks, 0 days, 17 hours, 19 minutes
Last reboot reason : User reboot
b.     Verify that the new device has the same settings for some parameters as Device A. The parameters include the system operating mode and the maximum number of ECMP routes. The parameter requirements vary by device model. For more information about the configuration restrictions and guidelines, see IRF in Virtual Technologies Configuration Guide for the device.
c.     Change the IRF member ID of the new device to 2, the same as the old device.
[newDeviceB] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]:y
[newDeviceB] quit
d.     Save the running configuration and reboot the new device for the member ID to take effect.
<newDeviceB> save
Compared with the startup.cfg file, The current configuration adds 20 commands and deletes 121 commands.
<newDeviceB> reboot
Now rebooting, please wait.......
e.     Configure IRF port bindings. Bind Ten-GigabitEthernet 2/0/25 and Ten-GigabitEthernet 2/0/26 to IRF-port 2/2.
<newDeviceB> system-view
[newDeviceB] interface ten-gigabitethernet 2/0/25
[newDeviceB-Ten-GigabitEthernet2/0/25] shutdown
[newDeviceB-Ten-GigabitEthernet2/0/25] quit
[newDeviceB] int ten-gigabitethernet 2/0/26
[newDeviceB-Ten-GigabitEthernet2/0/26] shutdown
[newDeviceB-Ten-GigabitEthernet2/0/26] quit
[newDeviceB] irf-port 2/2
[newDeviceB-irf-port2/2] port group interface ten-gigabitethernet 2/0/25
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the "irf-port-configuration active" command to activate the IRF ports.
[newDeviceB-irf-port2/2] port group interface ten-gigabitethernet 2/0/26
[newDeviceB-irf-port2/2] quit
[newDeviceB-Ten-GigabitEthernet2/0/25] undo shutdown
[newDeviceB-Ten-GigabitEthernet2/0/26] undo shutdown
[newDeviceB] irf-port-configuration active
[newDeviceB] save
f.     Power off the new device.
Procedures
1.     On Device B (the old device), shut down service interfaces and save the configuration:
# On Device B, shut down all uplink and downlink service interfaces. Do not shut down IRF physical interfaces Ten-GigabitEthernet 2/0/25 and Ten-GigabitEthernet 2/0/26 and BFD MAD interface GigabitEthernet 2/0/1.
[IRF] interface range name yewu interface gigabitethernet 2/0/2 to gigabitethernet 2/0/24 ten-gigabitethernet 2/0/27 to ten-gigabitethernet 2/0/28
[IRF-if-range-yewu] shutdown
[IRF-if-range-yewu] quit
# On Device D, ping Device C. On Device C, ping Device D. If the ping operations succeed, Device C and Device D are reachable. If the ping operations fail, first locate and resolve the communication failure issue. (Details not shown.)
2.     Verify that all services on Device B have been switched over to Device A. (Details not shown.)
3.     Save the running configuration.
[IRF] save
Slot 2:
4.     Power off Device B, and then remove cables for IRF physical interfaces and service interfaces.
CAUTION
CAUTION:
The IRF fabric splits after you power off Device B. To avoid configuration loss, do not execute the save command on Device A or Device B.
5.     Connect IRF physical interfaces to add the new device to the IRF fabric, and power on the new device:
# Connect IRF physical interfaces Ten-GigabitEthernet 1/0/25 and Ten-GigabitEthernet 1/0/26 and BFD MAD interface GigabitEthernet 2/0/1, and then power on the new device. The new device and Device A merge into an IRF fabric, and Device A is still the master device.
# After the new device starts up, execute the following display commands to verify that Device B and the IRF fabric are running correctly. The command outputs should be the same as those before the replacement. If the command outputs before and after the replacement are inconsistent, locate and resolve the issue.
[IRF] display system stable state
[IRF] display irf
[IRF] display irf configuration
[IRF] display irf link
[IRF] display irf topology
[IRF] display mad verbose
6.     After the new device runs stably, connect service interfaces on the new device to uplink and downlink devices and bring up all service interfaces:
# Verify that the new device is a standby device.
[IRF] display device
# Verify that all physical interfaces on the new device are displayed.
[IRF] display interface
# Wait for 2 minutes, and then connect the cables that were connected to service interfaces on the old device to the service interfaces on the new device.
# Bring up all service interfaces on the new device and verify that all services are running correctly.
[IRF-if-range-yewu] undo shutdown
7.     Save the configuration.
[IRF] save
Checking the environment after IRF member replacement
# Delete unused settings as needed and save the configuration.
[IRF] undo interface range yewu
[IRF] quit
<IRF> save
# Check the device status, collect device status information, and compare the device status with that before the replacement. If the device status information is inconsistent before and after replacement, locate and resolve the issue.
<IRF> display arp
# Display device information on the IRF fabric. Verify that Device A is the master device and Device B is the standby device.
