H3C Fixed Port Campus Switches Configuration Examples-6W103
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W103
Table of Contents
Related Documents
72-DRNI and EVPN Configuration Examples
72-DRNI and EVPN Configuration Examples 413.39 KB
Introduction· 1
Prerequisites· 1
General restrictions and guidelines· 1
Example: Configuring DRNI using an Ethernet aggregate link as the IPL on EVPN VTEPs· 2
Network configuration· 2
Analysis· 2
Applicable hardware and software versions· 3
Restrictions and guidelines· 4
Procedures· 5
Configuring the system operating mode· 5
Configuring routed (Layer 3) interfaces· 5
Configuring OSPF· 6
Disabling spanning tree· 7
Configuring EVPN· 7
Configuring DRNI 9
Configuring BGP to advertise BGP EVPN routes· 11
Mapping Ethernet service instances to VSIs· 12
Verifying the configuration· 13
Verifying the configuration on a DR member device· 13
Verifying the network connectivity of the VMs· 15
Configuration files· 15
Example: Configuring DRNI using a VXLAN tunnel as the IPL on EVPN VTEPs  22
Network configuration· 22
Analysis· 22
Applicable hardware and software versions· 23
Restrictions and guidelines· 24
Procedures· 25
Configuring the system operating mode· 25
Configuring Layer 3 interfaces· 25
Configuring OSPF· 26
Configuring EVPN· 27
Configuring DRNI 28
Configuring BGP to advertise BGP EVPN routes· 31
Mapping Ethernet service instances to VSIs· 32
Configuring Monitor Link· 33
Verifying the configuration· 33
Verifying the configuration on a DR member device· 33
Verifying the network connectivity of the VMs· 35
Configuration files· 35
Example: Configuring DRNI using an Ethernet aggregate link as the IPL on EVPN gateways· 42
Network configuration· 42
Analysis· 42
Applicable hardware and software versions· 43
Restrictions and guidelines· 44
Procedures· 45
Configuring the system operating mode· 45
Configuring Layer 3 interfaces· 45
Configuring OSPF· 46
Disabling spanning tree· 47
Configuring EVPN· 47
Configuring distributed EVPN gateways· 49
Configuring DRNI 52
Configuring BGP to advertise BGP EVPN routes· 54
Mapping Ethernet service instances to VSIs· 55
Verifying the configuration· 56
Verifying the configuration on a DR member device· 56
Verifying the network connectivity of the VMs· 59
Configuration files· 59
Example: Configuring DRNI using a VXLAN tunnel as the IPL on EVPN gateways  68
Network configuration· 68
Analysis· 69
Applicable hardware and software versions· 69
Restrictions and guidelines· 71
Procedures· 72
Configuring the system operating mode· 72
Configuring Layer 3 interfaces· 72
Configuring OSPF· 72
Disabling spanning tree· 73
Configuring EVPN· 74
Configuring distributed EVPN gateways· 75
Configuring DRNI 78
Configuring BGP to advertise BGP EVPN routes· 80
Mapping Ethernet service instances to VSIs· 81
Configuring Monitor Link· 82
Verifying the configuration· 83
Verifying the configuration on a DR member device· 83
Verifying the network connectivity of the VMs· 86
Configuration files· 86
Introduction
This document provides configuration examples for using Distributed Resilient Network Interconnect (DRNI) on an Ethernet Virtual Private Network (EVPN) network.
DRNI virtualizes two physical devices into one system through multichassis link aggregation. You can use DRNI to virtualize two VTEPs or EVPN gateways into one distributed-relay (DR) system to avoid single points of failure.
The following information is provided based on the assumption that you have basic knowledge of DRNI and EVPN.
Link aggregation group membership is mutually exclusive with Ethernet service instance-to-VSI mappings on a Layer 2 interface. Do not associate a VSI with an Ethernet service instance on a Layer 2 interface if the interface is in an aggregation group. Do not assign a Layer 2 interface to an aggregation group if the interface is configured with Ethernet service instances of VSIs.
Ethernet service instance bindings of VSIs are mutually exclusive with QinQ and VLAN mapping on a Layer 2 Ethernet interface or Layer 2 aggregate interface. Do not configure these features simultaneously on the same interface. Otherwise, the features cannot take effect.
Do not configure VLAN mapping, QinQ, or MAC-based VLAN on a Layer 2 Ethernet interface or Layer 2 aggregate interface that acts as the traffic outgoing interface of a VXLAN tunnel. Otherwise, the features cannot take effect.
If a manually created VXLAN tunnel and an automatically created VXLAN tunnel have the same destination IP address, do not assign the tunnels to the same VXLAN. For more information about manual VXLAN tunnel setup, see VXLAN Configuration Guide.
The VTEPs or EVPN gateways to form a DR system must have the same configuration, including the following:
·     ACs.
·     VSI and VXLAN mappings.
·     Router MAC address, which is the EVPN global MAC address configured by using the evpn global-mac command or the MAC address assigned to L3VNI-associated VSI interfaces by using the mac-address command.
As shown in Figure 1, perform the following tasks to make sure the VMs can communicate with one another:
·     Configure VXLAN 10 on Switch A, Switch B, and Switch D.
·     Configure DRNI on Switch A and Switch B to virtualize them into one VTEP. Configure an Ethernet aggregate link as the IPL between the switches.
·     Configure Switch C as a route reflector (RR).
Figure 1 Network diagram
Analysis
To make sure the overlay network has connectivity, configure a routing protocol on the switches to advertise routes for reaching their interfaces, including the loopback interfaces. In this example, OSPF is used.
To conserve resources, configure Switch C to reflect routes for Switch A, Switch B, and Switch D.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S6550XE-HI switch series
Not supported
S6525XE-HI switch series
Not supported
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Release 66xx
S5560X-HI switch series
Release 66xx
S5500V2-EI switch series
Release 66xx
MS4520V2-30F switch
Release 66xx
MS4520V2-30C switch
MS4520V2-54C switch
Release 66xx
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
Release 66xx
S6520X-SI switch series
S6520-SI switch series
Release 66xx
S5000-EI switch series
Release 66xx
MS4600 switch series
Release 66xx
ES5500 switch series
Release 66xx
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
Make sure the following settings are consistent on the DR member devices:
·     Ethernet service instances and their match criterion on the DR interfaces in the same DR group or single-homed site-facing interfaces.
·     VXLAN IDs of VSIs.
In addition, the Ethernet service instances must be created manually.
As a best practice, do not redistribute external routes on the DR member devices.
Use the drni mad exclude interface command to exclude all interfaces used by EVPN from the shutdown action by DRNI MAD. The interfaces include VSI interfaces, interfaces that provide BGP peer addresses, interfaces used for setting up the keepalive link, and transport-facing outgoing interfaces of VXLAN tunnels.
For EVPN to run correctly on a DR system, you must execute the undo mac-address static source-check enable command to disable static source check on the following interfaces:
·     Layer 2 aggregate interfaces or Layer 2 Ethernet interfaces acting as the IPPs.
·     Transport-facing physical interfaces.
As a best practice, use the IP address of a loopback interface as the virtual VTEP address.
You must disable spanning tree on the Layer 2 Ethernet interface that acts as the physical traffic outgoing interface of a VXLAN tunnel. If you enable spanning tree on that interface, the upstream device will falsely block the interfaces connected to the DR member devices.
Configure backup routes for directing traffic from one DR member device to the other DR member device upon uplink failure.
You can configure only the encapsulation s-vid vlan-id and encapsulation untagged frame match criteria and VLAN access mode for Ethernet service instances
Procedures
# Set the system operating mode to VXLAN on Switch A, and reboot the switch for the mode change to take effect.
[SwitchA] switch-mode 1
Reboot device to make the configuration take effect.
[SwitchA] quit
<SwitchA> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
# Set the system operating mode of Switch B and Switch D to VXLAN. The method is the same as Switch A. (Details not shown.)
# Configure the Layer 3 interfaces on Switch A.
[SwitchA-Loopback0] ip address 1.1.1.1 32
[SwitchA-Loopback0] quit
[SwitchA] interface loopback 1
[SwitchA-Loopback1] ip address 1.2.3.4 32
[SwitchA-Loopback1] quit
[SwitchA] vlan 11
[SwitchA-vlan11] port gigabitethernet 1/0/5
[SwitchA-vlan11] quit
[SwitchA-Vlan-interface11] ip address 11.1.1.1 24
[SwitchA] interface gigabitethernet 1/0/4
[SwitchA-GigabitEthernet1/0/4] port link-mode route
[SwitchA-GigabitEthernet1/0/4] ip address 60.1.1.1 24
[SwitchA-GigabitEthernet1/0/4] quit
# Configure the Layer 3 interfaces on other switches. (Details not shown.)
Configuring OSPF
Configuring Switch A
# Configure OSPF to advertise the networks attached to the Layer 3 interfaces.
[SwitchA] ospf 1 router-id 1.1.1.1
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 1.2.3.4 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchA-ospf-1] quit
# Configure OSPF on VLAN-interface 100 for traffic to be redirected to an available DR member device when an uplink fails.
[SwitchA] vlan 100
[SwitchA-vlan100] quit
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ip address 100.1.1.1 255.255.255.0
[SwitchA-Vlan-interface100] ospf 1 area 0.0.0.0
Configuring Switch B
[SwitchB] ospf 1 router-id 2.2.2.2
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 1.2.3.4 0.0.0.0
[SwitchB-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
[SwitchB] vlan 100
[SwitchB-vlan100] quit
[SwitchB] interface Vlan-interface 100
[SwitchB-Vlan-interface100] ip address 100.1.1.2 255.255.255.0
[SwitchB-Vlan-interface100] ospf 1 area 0.0.0.0
Configuring Switch C
[SwitchC] ospf 1 router-id 3.3.3.3
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
Configuring Switch D
<SwitchD> system-view
[SwitchD] ospf 1 router-id 4.4.4.4
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
# Disable spanning tree on transport-facing physical interface GigabitEthernet 1/0/5.
[SwitchA] interface gigabitethernet 1/0/5
[SwitchA-GigabitEthernet1/0/5] undo stp enable
[SwitchA-GigabitEthernet1/0/5] quit
[SwitchB] interface gigabitethernet 1/0/5
[SwitchB-GigabitEthernet1/0/5] undo stp enable
[SwitchB-GigabitEthernet1/0/5] quit
Configuring EVPN
# Enable L2VPN.
[SwitchA] l2vpn enable
# Enable Layer 2 forwarding for VXLANs.
[SwitchA] undo vxlan ip-forwarding
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] arp suppression enable
[SwitchA-vsi-vpna] evpn encapsulation vxlan
# Configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] undo vxlan ip-forwarding
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] arp suppression enable
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
# Enable L2VPN.
[SwitchD] l2vpn enable
[SwitchD] undo vxlan ip-forwarding
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vxlan tunnel arp-learning disable
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] arp suppression enable
[SwitchD-vsi-vpna] evpn encapsulation vxlan
[SwitchD-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchD-vsi-vpna] vxlan 10
[SwitchD-vsi-vpna-vxlan-10] quit
[SwitchD-vsi-vpna] quit
Configuring DRNI
# Specify the virtual VTEP address as 1.2.3.4.
[SwitchA] evpn drni group 1.2.3.4
# Configure DR system parameters.
[SwitchA] drni system-mac 0001-0001-0001
[SwitchA] drni system-number 1
[SwitchA] drni system-priority 10
[SwitchA] drni restore-delay 180
[SwitchA] drni keepalive ip destination 60.1.1.2 source 60.1.1.1
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 3.
[SwitchA] interface bridge-aggregation 3
[SwitchA-Bridge-Aggregation3] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation3] quit
# Assign GigabitEthernet 1/0/3 to aggregation group 3.
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] port link-aggregation group 3
[SwitchA-GigabitEthernet1/0/3] quit
# Specify Bridge-Aggregation 3 as the IPP.
[SwitchA-Bridge-Aggregation3] port drni intra-portal-port 1
[SwitchA-Bridge-Aggregation3] undo mac-address static source-check enable
# Disable the static source check feature on GigabitEthernet 1/0/5.
[SwitchA-GigabitEthernet1/0/5] undo mac-address static source-check enable
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 4.
[SwitchA] interface bridge-aggregation 4
[SwitchA-Bridge-Aggregation4] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation4] quit
# Assign GigabitEthernet 1/0/1 to aggregation group 4.
[SwitchA-GigabitEthernet1/0/1] port link-aggregation group 4
[SwitchA-GigabitEthernet1/0/1] quit
# Assign Bridge-Aggregation 4 to DR group 4.
[SwitchA-Bridge-Aggregation4] port drni group 4
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 5.
[SwitchA] interface bridge-aggregation 5
[SwitchA-Bridge-Aggregation5] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation5] quit
# Assign GigabitEthernet 1/0/2 to aggregation group 5.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port link-aggregation group 5
[SwitchA-GigabitEthernet1/0/2] quit
# Assign Bridge-Aggregation 5 to DR group 5.
[SwitchA-Bridge-Aggregation5] port drni group 5
# Exclude all interfaces used by EVPN from the shutdown action by DRNI MAD.
[SwitchA] drni mad exclude interface loopback 0
[SwitchA] drni mad exclude interface gigabitethernet 1/0/4
[SwitchA] drni mad exclude interface gigabitethernet 1/0/5
[SwitchA] drni mad exclude interface vlan-interface 11
[SwitchB] evpn drni group 1.2.3.4
[SwitchB] drni system-mac 0001-0001-0001
[SwitchB] drni system-number 2
[SwitchB] drni system-priority 10
[SwitchB] drni restore-delay 180
[SwitchB] drni keepalive ip destination 60.1.1.1 source 60.1.1.2
[SwitchB] interface bridge-aggregation 3
[SwitchB-Bridge-Aggregation3] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation3] quit
[SwitchB] interface gigabitethernet 1/0/3
[SwitchB-GigabitEthernet1/0/3] port link-aggregation group 3
[SwitchB-GigabitEthernet1/0/3] quit
[SwitchB-Bridge-Aggregation3] port drni intra-portal-port 1
[SwitchB-Bridge-Aggregation3] undo mac-address static source-check enable
[SwitchB-GigabitEthernet1/0/5] undo mac-address static source-check enable
[SwitchB] interface bridge-aggregation 4
[SwitchB-Bridge-Aggregation4] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation4] quit
[SwitchB-GigabitEthernet1/0/1] port link-aggregation group 4
[SwitchB-Bridge-Aggregation4] port drni group 4
[SwitchB] interface bridge-aggregation 5
[SwitchB-Bridge-Aggregation5] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation5] quit
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port link-aggregation group 5
[SwitchB-Bridge-Aggregation5] port drni group 5
[SwitchB] drni mad exclude interface loopback 0
[SwitchB] drni mad exclude interface gigabitethernet 1/0/4
[SwitchB] drni mad exclude interface gigabitethernet 1/0/5
[SwitchA] drni mad exclude interface vlan-interface 12
# Configure BGP to advertise BGP EVPN routes.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 3.3.3.3 as-number 200
[SwitchA-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 3.3.3.3 as-number 200
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
# Configure BGP to advertise BGP EVPN routes and configure the switch as an RR.
[SwitchC] bgp 200
[SwitchC-bgp-default] group evpn
[SwitchC-bgp-default] peer 1.1.1.1 group evpn
[SwitchC-bgp-default] peer 2.2.2.2 group evpn
[SwitchC-bgp-default] peer 4.4.4.4 group evpn
[SwitchC-bgp-default] peer evpn as-number 200
[SwitchC-bgp-default] peer evpn connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer evpn enable
[SwitchC-bgp-default-evpn] undo policy vpn-target
[SwitchC-bgp-default-evpn] peer evpn reflect-client
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 3.3.3.3 as-number 200
[SwitchD-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
# On Bridge-Aggregation 4, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA-Bridge-Aggregation4] port link-type trunk
[SwitchA-Bridge-Aggregation4] port trunk permit vlan 2
[SwitchA-Bridge-Aggregation4] service-instance 1000
[SwitchA-Bridge-Aggregation4-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-Bridge-Aggregation4-srv1000] xconnect vsi vpna
[SwitchA-Bridge-Aggregation4-srv1000] quit
# On Bridge-Aggregation 5, create Ethernet service instance 1000 to match VLAN 3.
[SwitchA-Bridge-Aggregation5] port link-type trunk
[SwitchA-Bridge-Aggregation5] port trunk permit vlan 3
[SwitchA-Bridge-Aggregation5] service-instance 1000
[SwitchA-Bridge-Aggregation5-srv1000] encapsulation s-vid 3
[SwitchA-Bridge-Aggregation5-srv1000] xconnect vsi vpna
[SwitchA-Bridge-Aggregation5-srv1000] quit
[SwitchB-Bridge-Aggregation4] port link-type trunk
[SwitchB-Bridge-Aggregation4] port trunk permit vlan 2
[SwitchB-Bridge-Aggregation4] service-instance 1000
[SwitchB-Bridge-Aggregation4-srv1000] encapsulation s-vid 2
[SwitchB-Bridge-Aggregation4-srv1000] xconnect vsi vpna
[SwitchB-Bridge-Aggregation4-srv1000] quit
[SwitchB-Bridge-Aggregation5] port link-type trunk
[SwitchB-Bridge-Aggregation5] port trunk permit vlan 3
[SwitchB-Bridge-Aggregation5] service-instance 1000
[SwitchB-Bridge-Aggregation5-srv1000] encapsulation s-vid 3
[SwitchB-Bridge-Aggregation5-srv1000] xconnect vsi vpna
[SwitchB-Bridge-Aggregation5-srv1000] quit
# On GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchD] interface gigabitethernet 1/0/1
[SwitchD-GigabitEthernet1/0/1] port link-type trunk
[SwitchD-GigabitEthernet1/0/1] port trunk permit vlan 2
[SwitchD-GigabitEthernet1/0/1] service-instance 1000
[SwitchD-GigabitEthernet1/0/1] encapsulation s-vid 2
[SwitchD-GigabitEthernet1/0/1] xconnect vsi vpna
[SwitchD-GigabitEthernet1/0/1] quit
The verification procedure uses Switch A as an example.
# Verify that Switch A has BGP EVPN routes.
[Switch A]display bgp l2vpn evpn
 BGP local router ID is 1.2.3.4
 Status codes: * - valid, > - best, d - dampened, h - history
               a - additional-path
 Total number of routes from all PEs: 1
 Route distinguisher: 1:10
 Total number of routes: 2
* >  [3][0][32][1.2.3.4]/80
                        1.2.3.4         0          100        32768   i
* >i [3][0][32][4.4.4.4]/80
                        4.4.4.4         0          100        0       i
# Verify that the VXLAN tunnel to Switch D is up, and the source address of the tunnel is the virtual VTEP address.
[SwitchA] display interface tunnel
Tunnel0
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 4.4.4.4
# Verify that ACs have been created on the IPP and mapped to VXLAN 10.
[SwitchA] display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Statistics              : Disabled
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State    Type        Flood proxy
    Tunnel0              0x5000000  UP       Auto        Disabled
  ACs:
    AC                               Link ID  State       Type
    BAGG4 srv1000                    0        Up          Manual
    BAGG3 srv2                       1        Up          Dynamic (DRNI)
    BAGG5 srv1000                    2        Up          Manual
    BAGG3 srv3                       3        Up          Dynamic (DRNI)
# Verify that VM 1, VM 2, and VM 3 can communicate when both Switch A and Switch B are operating correctly. (Details not shown.)
# Verify that VM 1, VM 2, and VM 3 can communicate when Switch A's or Switch B's links to the local site are disconnected. (Details not shown.)
Configuration files
·     Switch A:
 area 0.0.0.0
vlan 2
vlan 3
vlan 11
vlan 100
l2vpn enable
vsi vpna
 vxlan 10
  vpn-target auto export-extcommunity
  vpn-target auto import-extcommunity
interface Bridge-Aggregation3
interface Bridge-Aggregation4
 port trunk permit vlan 1 to 2
 port drni group 4
  xconnect vsi vpna
interface Bridge-Aggregation5
 port trunk permit vlan 1 3
 port drni group 5
  xconnect vsi vpna
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface LoopBack0
 ip address 1.2.3.4 255.255.255.255
interface Vlan-interface11
 ip address 11.1.1.1 255.255.255.0
interface Vlan-interface100
 ospf 1 area 0.0.0.0
interface GigabitEthernet1/0/4
 ip address 60.1.1.1 255.255.255.0
 port link-mode bridge
interface GigabitEthernet1/0/5
 port access vlan 11
 undo stp enable
bgp 200
 peer 3.3.3.3 connect-interface LoopBack0
  peer 3.3.3.3 enable
 drni mad exclude interface LoopBack0
 drni mad exclude interface GigabitEthernet1/0/4
 drni mad exclude interface GigabitEthernet1/0/5
 drni mad exclude interface Vlan-interface11
return
·     Switch B:
 area 0.0.0.0
vlan 2
vlan 3
vlan 12
vlan 100
l2vpn enable
vsi vpna
 vxlan 10
 port drni group 4
  xconnect vsi vpna
 port drni group 5
  xconnect vsi vpna
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
interface LoopBack1
interface Vlan-interface12
 ip address 12.1.1.2 255.255.255.0
 ospf 1 area 0.0.0.0
 ip address 60.1.1.2 255.255.255.0
 port access vlan 12
 undo stp enable
bgp 200
  peer 3.3.3.3 enable
 drni mad exclude interface Vlan-interface12
return
·     Switch C:
 area 0.0.0.0
vlan 11 to 13
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 11.1.1.3 255.255.255.0
 ip address 12.1.1.3 255.255.255.0
interface Vlan-interface13
 ip address 13.1.1.3 255.255.255.0
 port access vlan 11
 port access vlan 12
 port access vlan 13
bgp 200
 group evpn internal
 peer evpn connect-interface LoopBack0
  peer evpn enable
return
·     Switch D:
 area 0.0.0.0
vlan 2
vlan 13
l2vpn enable
vsi vpna
 vxlan 10
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 13.1.1.4 255.255.255.0
  xconnect vsi vpna
 port access vlan 13
bgp 200
  peer 3.3.3.3 enable
As shown in Figure 2, perform the following tasks to make sure the VMs can communicate with one another:
·     Configure DRNI on Switch A and Switch B to virtualize them into one VTEP. Manually set up a VXLAN tunnel as the IPL between the switches.
·     Configure Switch C as an RR.
Figure 2 Network diagram
Analysis
To make sure the overlay network has connectivity,, configure a routing protocol on these switches to advertise routes for reaching their interfaces, including the loopback interfaces. In this example, OSPF is used.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
Not supported
Not supported
S5850 switch series
Not supported
Not supported
Release 66xx
Release 66xx
Release 66xx
MS4520V2-30F switch
Release 66xx
MS4520V2-30C switch
MS4520V2-54C switch
Release 66xx
MS4520V2-28S switch
Not supported
Release 66xx
Release 66xx
Release 66xx
Release 66xx
Release 66xx
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Use the drni mad exclude interface command to exclude VXLAN tunnel interfaces and their traffic outgoing interfaces from the MAD shutdown action by DRNI before you configure them as IPPs. If you have configured the VXLAN tunnel interfaces as IPPs before excluding them and their traffic outgoing interfaces from the MAD shutdown action, you must first remove the IPP configuration. After the VXLAN tunnel interfaces and their traffic outgoing interfaces come up, exclude the interfaces from the MAD shutdown action by DRNI. Then, configure the VXLAN tunnel interfaces as IPPs.
Procedures
[SwitchA] quit
<SwitchA> reboot
.......DONE!
[Y/N]:y
[SwitchA] vlan 11
Configuring OSPF
Configuring EVPN
# Enable L2VPN.
# Specify the reserved VXLAN as VXLAN 1234.
[SwitchA] reserved vxlan 1234
[SwitchA] vsi vpna
# Create VXLAN 10.
# Enable L2VPN.
[SwitchB] reserved vxlan 1234
[SwitchB] vsi vpna
# Create VXLAN 10.
# Enable L2VPN.
[SwitchD] vsi vpna
# Create VXLAN 10.
Configuring DRNI
# Create a tunnel to Switch B, and set the ToS of tunneled packets to 100.
[SwitchA-Tunnel1] tunnel tos 100
[SwitchA-Tunnel1] quit
# Exclude Tunnel 1 from the shutdown action by DRNI MAD.
[SwitchA] drni mad exclude interface tunnel 1
# Specify Tunnel 1 as the IPP
[SwitchA-Tunnel1] port drni intra-portal-port 1
# Disable the static source check feature on GigabitEthernet 1/0/4.
[SwitchA-GigabitEthernet1/0/4] undo mac-address static source-check enable
# Create a tunnel to Switch A, and set the ToS of tunneled packets to 100.
[SwitchB] interface tunnel 1 mode vxlan
[SwitchB-Tunnel1] source 2.2.2.2
[SwitchB-Tunnel1] destination 1.1.1.1
[SwitchB-Tunnel1] tunnel tos 100
[SwitchB-Tunnel1] quit
[SwitchB] drni mad exclude interface tunnel 1
[SwitchB-Tunnel1] port drni intra-portal-port 1
[SwitchB] interface gigabitethernet 1/0/4
[SwitchB-GigabitEthernet1/0/4] undo mac-address static source-check enable
[SwitchB-GigabitEthernet1/0/4] quit
[SwitchB] drni mad exclude interface vlan-interface 12
[SwitchA] bgp 200
[SwitchB] bgp 200
[SwitchC] bgp 200
[SwitchD] bgp 200
# Create monitor link group 1 and assign the uplink and downlink interfaces to it.
[SwitchA] monitor-link group 1
[SwitchA-mtlk-group1] port gigabitethernet 1/0/1 downlink
[SwitchA-mtlk-group1] port gigabitethernet 1/0/2 downlink
[SwitchA-mtlk-group1] port gigabitethernet 1/0/4 uplink
[SwitchA-mtlk-group1] quit
[SwitchB] monitor-link group 1
[SwitchB-mtlk-group1] port gigabitethernet 1/0/1 downlink
[SwitchB-mtlk-group1] port gigabitethernet 1/0/2 downlink
[SwitchB-mtlk-group1] port gigabitethernet 1/0/4 uplink
[SwitchB-mtlk-group1] quit
               a - additional-path
 Total number of routes from all PEs: 2
 Total number of routes: 4
* >  [3][0][32][1.1.1.1]/80
                        1.1.1.1         0          100        32768   i
* >i [3][0][32][2.2.2.2]/80
                        2.2.2.2         0          100        0       i
                        4.4.4.4         0          100        0       i
# Verify that the IPL Tunnel 1 is up, and Tunnel 0 to Switch D uses the virtual VTEP address as the source address.
[SwitchA] display interface Tunnel
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Last 300 seconds input rate: 13 bytes/sec, 104 bits/sec, 0 packets/sec
Last 300 seconds output rate: 13 bytes/sec, 104 bits/sec, 0 packets/sec
Input: 332 packets, 36377 bytes, 0 drops
Output: 583 packets, 59132 bytes, 0 drops
# Verify that the VXLAN tunnels have been assigned to VXLAN 10.
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 10
  Tunnels:
    Tunnel1              0x5000001  UP       Manual      Disabled
  ACs:
Configuration files
·     Switch A:
 area 0.0.0.0
vlan 2
vlan 3
vlan 11
 l2vpn enable
 reserved vxlan 1234
vsi vpna
 vxlan 10
 port drni group 4
  xconnect vsi vpna
 port drni group 5
  xconnect vsi vpna
interface LoopBack0
interface LoopBack1
 port monitor-link group 1 downlink
 port access vlan 11
 undo stp enable
 port monitor-link group 1 uplink
interface Tunnel1 mode vxlan
 source 1.1.1.1
 destination 2.2.2.2
 tunnel tos 100
bgp 200
  peer 3.3.3.3 enable
 drni mad exclude interface Tunnel1
 drni mad exclude interface Vlan-interface 11
return
·     Switch B:
 area 0.0.0.0
vlan 2
vlan 3
vlan 12
 l2vpn enable
 reserved vxlan 1234
vsi vpna
 vxlan 10
 port drni group 4
  xconnect vsi vpna
 port drni group 5
  xconnect vsi vpna
interface LoopBack0
interface LoopBack1
 port access vlan 12
 source 2.2.2.2
 destination 1.1.1.1
 tunnel tos 100
bgp 200
  peer 3.3.3.3 enable
 drni mad exclude interface Vlan-interface 12
return
·     Switch C:
 area 0.0.0.0
vlan 11 to 13
interface LoopBack0
 port access vlan 11
 port access vlan 12
 port access vlan 13
bgp 200
 group evpn internal
  peer evpn enable
return
·     Switch D:
 area 0.0.0.0
vlan 2
vlan 13
 l2vpn enable
vsi vpna
 vxlan 10
interface LoopBack0
  xconnect vsi vpna
 port access vlan 13
bgp 200
  peer 3.3.3.3 enable
return
As shown in Figure 3, perform the following tasks to make sure the VMs can communicate with one another:
·     Configure VXLAN 10 on Switch A, Switch B, and Switch D, and configure VXLAN 20 on Switch A and Switch B.
·     Configure Switch A, Switch B, and Switch D as distributed EVPN gateways to provide Layer 3 forwarding service for the VMs.
Figure 3 Network diagram
Analysis
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
Not supported
Not supported
S5850 switch series
Not supported
Not supported
Release 66xx
Release 66xx
Release 66xx
MS4520V2-30F switch
Release 66xx
MS4520V2-30C switch
MS4520V2-54C switch
Release 66xx
MS4520V2-28S switch
Not supported
Release 66xx
Release 66xx
Release 66xx
Release 66xx
Release 66xx
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Procedures
[SwitchA] quit
<SwitchA> reboot
.......DONE!
[Y/N]:y
[SwitchA] vlan 11
# On VM 1, VM 3, and VM 5, specify 10.1.1.1 as the gateway address. On VM 2 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
Configuring OSPF
[SwitchA] vlan 100
[SwitchB] vlan 100
Configuring EVPN
# Enable L2VPN.
# Configure the EVPN global MAC address as 0002-0003-0004.
[SwitchA] evpn global-mac 2-3-4
[SwitchA] vsi vpna
# Create VXLAN 10.
# Create an EVPN instance on VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] evpn encapsulation vxlan
[SwitchA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchA-vsi-vpnb] vxlan 20
[SwitchA-vsi-vpnb-vxlan-20] quit
[SwitchA-vsi-vpnb] quit
# Enable L2VPN.
[SwitchB] evpn global-mac 2-3-4
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] evpn encapsulation vxlan
[SwitchB-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchB-vsi-vpnb] vxlan 20
[SwitchB-vsi-vpnb-vxlan-20] quit
[SwitchB-vsi-vpnb] quit
# Enable L2VPN.
[SwitchD] vsi vpna
# Create VXLAN 10.
# Configure RD and route target settings for VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] address-family ipv4
[SwitchA-vpn-ipv4-vpna] vpn-target 2:2
[SwitchA-vpn-ipv4-vpna] quit
[SwitchA-vpn-instance-vpna] address-family evpn
[SwitchA-vpn-evpn-vpna] vpn-target 1:1
[SwitchA-vpn-evpn-vpna] quit
[SwitchA-vpn-instance-vpna] quit
# Configure VSI-interface 1 as a distributed gateway.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 1-1-1
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] quit
# Configure VSI-interface 2 as a distributed gateway.
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface2] ip binding vpn-instance vpna
[SwitchA-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchA-Vsi-interface2] mac-address 2-2-2
[SwitchA-Vsi-interface2] distributed-gateway local
[SwitchA-Vsi-interface2] local-proxy-arp enable
[SwitchA-Vsi-interface2] quit
# Create VSI-interface 3. Associate VSI-interface 3 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 3
[SwitchA-Vsi-interface3] ip binding vpn-instance vpna
[SwitchA-Vsi-interface3] l3-vni 1000
[SwitchA-Vsi-interface3] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] gateway vsi-interface 2
[SwitchB] ip vpn-instance vpna
[SwitchB-vpn-instance-vpna] route-distinguisher 1:1
[SwitchB-vpn-instance-vpna] address-family ipv4
[SwitchB-vpn-ipv4-vpna] vpn-target 2:2
[SwitchB-vpn-ipv4-vpna] quit
[SwitchB-vpn-instance-vpna] address-family evpn
[SwitchB-vpn-evpn-vpna] vpn-target 1:1
[SwitchB-vpn-evpn-vpna] quit
[SwitchB-vpn-instance-vpna] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpna
[SwitchB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 1-1-1
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] local-proxy-arp enable
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] ip binding vpn-instance vpna
[SwitchB-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchB-Vsi-interface2] mac-address 2-2-2
[SwitchB-Vsi-interface2] distributed-gateway local
[SwitchB-Vsi-interface2] local-proxy-arp enable
[SwitchB-Vsi-interface2] quit
[SwitchB] interface vsi-interface 3
[SwitchB-Vsi-interface3] ip binding vpn-instance vpna
[SwitchB-Vsi-interface3] l3-vni 1000
[SwitchB-Vsi-interface3] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] gateway vsi-interface 2
[SwitchD] ip vpn-instance vpna
[SwitchD-vpn-instance-vpna] route-distinguisher 1:1
[SwitchD-vpn-instance-vpna] address-family ipv4
[SwitchD-vpn-ipv4-vpna] vpn-target 2:2
[SwitchD-vpn-ipv4-vpna] quit
[SwitchD-vpn-instance-vpna] address-family evpn
[SwitchD-vpn-evpn-vpna] vpn-target 1:1
[SwitchD-vpn-evpn-vpna] quit
[SwitchD-vpn-instance-vpna] quit
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpna
[SwitchD-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchD-Vsi-interface1] mac-address 1-1-1
[SwitchD-Vsi-interface1] distributed-gateway local
[SwitchD-Vsi-interface1] local-proxy-arp enable
[SwitchD-Vsi-interface1] quit
# Create VSI-interface 3. Associate VSI-interface 3 with VPN instance vpna and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance vpna
[SwitchD-Vsi-interface3] l3-vni 1000
[SwitchD-Vsi-interface3] quit
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] gateway vsi-interface 1
Configuring DRNI
[SwitchA] drni system-mac 0001-0002-0003
[SwitchA] drni mad exclude interface loopback 1
[SwitchA] drni mad exclude interface vsi-interface 1
[SwitchA] drni mad exclude interface vsi-interface 2
[SwitchB] drni system-mac 0001-0002-0003
[SwitchB] drni mad exclude interface loopback 1
[SwitchB] drni mad exclude interface vsi-interface 1
[SwitchB] drni mad exclude interface vsi-interface 2
[SwitchA] bgp 200
[SwitchB] bgp 200
[SwitchC] bgp 200
[SwitchD] bgp 200
# Map Ethernet service instance 1000 to VSI vpnb.
[SwitchA-Bridge-Aggregation5-srv1000] xconnect vsi vpnb
[SwitchB-Bridge-Aggregation5-srv1000] xconnect vsi vpnb
[SwitchD-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchD-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchD-GigabitEthernet1/0/1-srv1000] quit
               a - additional-path
 Route distinguisher: 1:1(vpna)
* >  [5][0][24][10.1.1.0]/80
* >  [5][0][24][10.1.2.0]/80
                        4.4.4.4         0          100        0       i
 Route distinguisher: 1:20
                        4.4.4.4         0          100        0       i
Tunnel0
Current state: UP
Bandwidth: 64 kbps
# Verify that ACs have been created on the IPP and mapped to VXLAN 10 and VXLAN 20.
VSI Name: Auto_L3VNI1000_3
  VSI Index               : 1
  VSI State               : Down
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Gateway Interface       : VSI-interface 3
  VXLAN ID                : 1000
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Gateway Interface       : VSI-interface 1
  VXLAN ID                : 10
  Tunnels:
  ACs:
VSI Name: vpnb
  VSI Index               : 2
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  Gateway Interface       : VSI-interface 2
  VXLAN ID                : 20
  Tunnels:
  ACs:
    BAGG5 srv1000                    0        Up          Manual
    BAGG3 srv3                       1        Up          Dynamic (DRNI)
# Verify that the VMs can communicate when both Switch A and Switch B are operating correctly. (Details not shown.)
# Verify that VM 1 and VM 5 can communicate when Switch A's or Switch B's links to the local site are disconnected. (Details not shown.)
Configuration files
·     Switch A:
 address-family ipv4
  vpn-target 2:2 import-extcommunity
  vpn-target 2:2 export-extcommunity
 address-family evpn
  vpn-target 1:1 import-extcommunity
  vpn-target 1:1 export-extcommunity
 area 0.0.0.0
vlan 2
vlan 3
vlan 11
vlan 100
 l2vpn enable
 evpn global-mac 0002-0003-0004
vsi vpna
 vxlan 10
vsi vpnb
 vxlan 20
 port drni group 4
  xconnect vsi vpna
 port drni group 5
  xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
 ospf 1 area 0.0.0.0
 port access vlan 11
 undo stp enable
interface Vsi-interface1
 mac-address 0001-0001-0001
interface Vsi-interface2
 mac-address 0002-0002-0002
interface Vsi-interface3
 l3-vni 1000
bgp 200
  peer 3.3.3.3 enable
 drni mad exclude interface Vsi-interface1
 drni mad exclude interface Vsi-interface2
return
·     Switch B:
 address-family ipv4
 address-family evpn
 area 0.0.0.0
vlan 2
vlan 3
vlan 12
vlan 100
 l2vpn enable
vsi vpna
 vxlan 10
vsi vpnb
 vxlan 20
 port drni group 4
  xconnect vsi vpna
 port drni group 5
  xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
 ospf 1 area 0.0.0.0
 port access vlan 12
 undo stp enable
 l3-vni 1000
bgp 200
  peer 3.3.3.3 enable
return
·     Switch C:
 area 0.0.0.0
vlan 2
vlan 3
vlan 11 to 13
interface LoopBack0
 port access vlan 11
 port access vlan 12
 port access vlan 13
bgp 200
 group evpn internal
  peer evpn enable
return
·     Switch D:
 address-family ipv4
 address-family evpn
 area 0.0.0.0
vlan 2
vlan 13
l2vpn enable
vsi vpna
 vxlan 10
interface LoopBack0
  xconnect vsi vpna
 port access vlan 13
 l3-vni 1000
bgp 200
  peer 3.3.3.3 enable
return
As shown in Figure 4, perform the following tasks to make sure the VMs can communicate with one another:
·     Configure VXLAN 10 on Switch A, Switch B, and Switch D, and configure VXLAN 20 on Switch A, and Switch B.
·     Configure Switch A, Switch B, and Switch D as distributed EVPN gateways to provide Layer 3 forwarding service for VMs.
·     Create a monitor link group on Switch A and Switch B. Configure the transport-facing interfaces of Switch A and Switch B as uplink interfaces for the monitor link group, and member interfaces of DR interfaces as downlink interfaces.
Figure 4 Network diagram
Analysis
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
Not supported
Not supported
S5850 switch series
Not supported
Not supported
Release 66xx
Release 66xx
Release 66xx
MS4520V2-30F switch
Release 66xx
MS4520V2-30C switch
MS4520V2-54C switch
Release 66xx
MS4520V2-28S switch
Not supported
Release 66xx
Release 66xx
Release 66xx
Release 66xx
Release 66xx
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Procedures
[SwitchA] quit
<SwitchA> reboot
.......DONE!
[Y/N]:y
[SwitchA] vlan 11
Configuring OSPF
# Disable spanning tree on transport-facing physical interface GigabitEthernet 1/0/4.
[SwitchA-GigabitEthernet1/0/4] undo stp enable
[SwitchB-GigabitEthernet1/0/4] undo stp enable
Configuring EVPN
# Enable L2VPN.
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
# Enable L2VPN.
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
# Enable L2VPN.
[SwitchD] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchD] vsi vpna
Configuring DRNI
[SwitchA] drni mad exclude interface loopback0
[SwitchA] drni mad exclude interface gigabitethernet1/0/4
[SwitchB] drni mad exclude interface loopback0
[SwitchB] drni mad exclude interface gigabitethernet1/0/4
[SwitchA] bgp 200
[SwitchB] bgp 200
[SwitchC] bgp 200
[SwitchD] bgp 200
               a - additional-path
 Total number of routes from all PEs: 3
                        2.2.2.2         0          100        0       i
                        4.4.4.4         0          100        0       i
 Total number of routes: 3
                        2.2.2.2         0          100        0       i
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Last 300 seconds input rate: 149 bytes/sec, 1192 bits/sec, 1 packets/sec
Last 300 seconds output rate: 379 bytes/sec, 3032 bits/sec, 3 packets/sec
Input: 398 packets, 46446 bytes, 0 drops
Output: 3597 packets, 363591 bytes, 0 drops
# Verify that the VXLAN tunnels have been assigned to VXLAN 10 and VXLAN 20.
  VSI Index               : 1
  VSI State               : Down
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 1000
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 10
  Tunnels:
  ACs:
VSI Name: vpnb
  VSI Index               : 2
  VSI State               : Up
  Bandwidth               : -
  MAC Table Limit         : -
  Drop Unknown            : -
  VXLAN ID                : 20
  Tunnels:
  ACs:
Configuration files
·     Switch A:
 address-family ipv4
 address-family evpn
 area 0.0.0.0
vlan 2
vlan 3
vlan 11
 l2vpn enable
 reserved vxlan 1234
vsi vpna
 vxlan 10
vsi vpnb
 vxlan 20
 port drni group 4
  xconnect vsi vpna
 port drni group 5
  xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
 port access vlan 11
 undo stp enable
 l3-vni 1000
 source 1.1.1.1
 destination 2.2.2.2
 tunnel tos 100
bgp 200
  peer 3.3.3.3 enable
return
·     Switch B:
 address-family ipv4
 address-family evpn
 area 0.0.0.0
vlan 2
vlan 3
vlan 12
 l2vpn enable
 reserved vxlan 1234
vsi vpna
 vxlan 10
vsi vpnb
 vxlan 20
 port drni group 4
  xconnect vsi vpna
 port drni group 5
  xconnect vsi vpnb
interface LoopBack0
interface LoopBack1
 port access vlan 12
 undo stp enable
 l3-vni 1000
 source 2.2.2.2
 destination 1.1.1.1
 tunnel tos 100
bgp 200
  peer 3.3.3.3 enable
return
·     Switch C:
 area 0.0.0.0
vlan 11 to 13
interface LoopBack0
 port access vlan 11
 port access vlan 12
 port access vlan 13
bgp 200
 group evpn internal
  peer evpn enable
return
·     Switch D:
 address-family ipv4
 address-family evpn
 area 0.0.0.0
vlan 2
vlan 13
 l2vpn enable
vsi vpna
 vxlan 10
interface LoopBack0
  xconnect vsi vpna
 port access vlan 13
 l3-vni 1000
bgp 200
  peer 3.3.3.3 enable
return
