H3C Fixed Port Campus Switches Configuration Examples-6W103
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W103
Table of Contents
Related Documents
40-BFD Configuration Examples
40-BFD Configuration Examples 439.83 KB
Introduction· 1
Prerequisites· 1
Example: Configuring VRRP-BFD-Track collaboration· 1
Network configuration· 1
Analysis· 2
Applicable hardware and software versions· 2
Restrictions and guidelines· 4
Procedures· 5
Configuring interface IP addresses· 5
Configuring the interfaces that connect the gateways· 5
Disabling the spanning tree feature on uplink interfaces· 5
Configuring static routes from Device E and Device F to the virtual IP addresses of the VRRP groups  6
Configuring VRRP groups· 6
Configuring BFD·· 6
Configuring Track· 7
Configuring MSTP· 7
Verifying the configuration· 8
Configuration files· 12
Example: Configuring BFD for static routing· 16
Network configuration· 16
Applicable hardware and software versions· 17
Restrictions and guidelines· 19
Procedures· 19
Configuring interface IP addresses· 19
Configuring static routes· 19
Configuring BFD parameters on Device A· 20
Verifying the configuration· 20
Configuration files· 21
Example: Configuring BFD for RIP·· 23
Network configuration· 23
Applicable hardware and software versions· 24
Restrictions and guidelines· 25
Procedures· 26
Configuring interface IP addresses· 26
Configuring RIP· 26
Configuring BFD parameters on Device A· 27
Verifying the configuration· 27
Configuration files· 30
Example: Configuring BFD for OSPF· 32
Network configuration· 32
Applicable hardware and software versions· 33
Restrictions and guidelines· 35
Procedures· 35
Configuring interface IP addresses· 35
Configuring OSPF· 35
Configuring BFD parameters· 36
Verifying the configuration· 36
Configuration files· 40
Example: Configuring BFD for IS-IS·· 42
Network configuration· 42
Applicable hardware and software versions· 43
Restrictions and guidelines· 45
Procedures· 45
Configuring interface IP addresses· 45
Configuring IS-IS· 45
Configuring BFD parameters· 46
Verifying the configuration· 47
Configuration files· 50
Example: Configuring BFD for BGP·· 53
Network configuration· 53
Analysis· 54
Applicable hardware and software versions· 54
Restrictions and guidelines· 55
Procedures· 55
Configuring interface IP addresses· 55
Configuring OSPF in AS 100· 55
Configuring BGP· 56
Configuring routing policies· 58
Configuring BFD·· 59
Verifying the configuration· 59
Configuration files· 65
Example: Configuring BFD for PBR·· 69
Network configuration· 69
Applicable hardware and software versions· 70
Restrictions and guidelines· 72
Procedures· 72
Configuring interface IP addresses· 72
Configuring static routes· 72
Configuring routing policies on Device A· 72
Configuring BFD parameters on Device A· 73
Verifying the configuration· 73
Configuration files· 74
Introduction
This document provides BFD configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BFD, VRRP, Track, OSPF, and IS-IS.
As shown in Figure 1:
·     Two distribution layer devices, Device A and Device B, are deployed at the egress of area A and area B.
·     Device A and Device B belong to VRRP group 1 and VRRP group 2.
·     Device A is the master in VRRP group 1. Device B is the master in VRRP group 2.
·     The default gateway is VRRP group 1 for users in area A and VRRP group 2 for users in area B.
Configure VRRP-Track-BFD collaboration to meet the following requirements:
When Device A and Device B are operating correctly, they forward traffic for users in area A and area B, respectively.
·     When one gateway device or the uplink of the device fails, BFD can detect the failure and the other device takes over to implement link switchover.
·     When the downlink of a gateway device fails, L2 Switch A or L2 Switch B forwards user traffic to the gateway through interface GigabitEthernet 1/0/2. When the fault is cleared, L2 Switch A or L2 Switch B forwards user traffic to the gateway through interface GigabitEthernet 1/0/1.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     For Device A to become the master in VRRP group 1, configure a higher priority (110) for Device A in VRRP group 1 (Device B uses the default priority 100). For Device B to become the master in VRRP group 2, configure a higher priority (110) for Device B in VRRP group 2 (Device A uses the default priority 100).
·     To enable the failed master to forward traffic when it recovers, configure both VRRP groups to operate in preemptive mode.
·     To enable Device A to communicate with Device B by using VRRP advertisement packets and BFD packets of different VLANs, configure the ports connecting Device A and Device B to allow packets from VLAN 2 and VLAN 3 to pass through.
·     To eliminate Layer 2 loops, configure MSTP. Map VLAN 2 to MSTI 1 and map VLAN 3 to MSTI 2. The configuration traffic in MSTI 1 and MSTI 2 is forwarded through GigabitEthernet 1/0/1 of L2 Switch A and GigabitEthernet 1/0/1 of L2 Switch B, respectively.
·     To prevent MSTP from blocking uplink interface GigabitEthernet 1/0/1 of Device A and Device B, disable the spanning tree feature on the interfaces.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S6550XE-HI switch series
Release 6008 and later
S6525XE-HI switch series
S5850 switch series
Release 8005 and later
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 66xx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
S5500V3-SI switch series (excluding S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V3-EI switch series
Not supported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Not supported
S5120V3-SI switch series (excluding S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
When you configure VRRP-BFD-Track collaboration, follow these restrictions and guidelines:
·     Make sure the VRRP versions on all devices of the VRRP group are the same.
·     The source IP address for BFD echo packets cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
·     The virtual IP address of an IPv4 VRRP group and the downlink interface IP address of the VRRP group must be in the same subnet. Otherwise, the hosts in the subnet might fail to access external networks.
Procedures
1.     Configure Device A:
[DeviceA] vlan 101
[DeviceA-vlan101] port gigabitethernet 1/0/1
[DeviceA-vlan101] quit
[DeviceA] interface vlan-interface 101
[DeviceA-Vlan-interface101] ip address 1.1.1.1 24
[DeviceA-Vlan-interface101] quit
2.     Configure other devices in the same way Device A is configured. (Details not shown.)
# Configure GigabitEthernet 1/0/4 as a trunk port, remove the interface from VLAN 1, and assign it to VLAN 2 and VLAN 3.
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4] port link-type trunk
[DeviceA-GigabitEthernet1/0/4] undo port trunk permit vlan 1
[DeviceA-GigabitEthernet1/0/4] port trunk permit vlan 2 to 3
[DeviceA-GigabitEthernet1/0/4] port trunk pvid vlan 2
[DeviceA-GigabitEthernet1/0/4] quit
2.     Configure Device B:
[DeviceB] interface gigabitethernet 1/0/4
[DeviceB-GigabitEthernet1/0/4] port link-type trunk
[DeviceB-GigabitEthernet1/0/4] undo port trunk permit vlan 1
[DeviceB-GigabitEthernet1/0/4] port trunk permit vlan 2 to 3
[DeviceB-GigabitEthernet1/0/4] port trunk pvid vlan 2
[DeviceB-GigabitEthernet1/0/4] quit
1.     Disable the spanning tree feature on GigabitEthernet 1/0/1 of Device A:
[DeviceA-GigabitEthernet1/0/1] undo stp enable
2.     Disable the spanning tree feature on GigabitEthernet 1/0/1 of Device B:
[DeviceB-GigabitEthernet1/0/1] undo stp enable
1.     Configure Device E:
Configure static routes to the virtual IP addresses of VRRP group 1 and VRRP group 2.
<DeviceE> system-view
[DeviceE] ip route-static 10.1.1.0 255.255.255.0 1.1.1.1
[DeviceE] ip route-static 10.1.2.0 255.255.255.0 1.1.1.1
2.     Configure Device F:
[DeviceF] ip route-static 10.1.1.0 255.255.255.0 1.1.2.1
[DeviceF] ip route-static 10.1.2.0 255.255.255.0 1.1.2.1
# Configure the virtual IP address for VRRP group 1, set the preemption delay, and configure the priority of Device A in VRRP group 1.
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[DeviceA-Vlan-interface2] vrrp vrid 1 priority 110
[DeviceA-Vlan-interface2] vrrp vrid 1 preempt-mode delay 500
[DeviceA-Vlan-interface2] quit
# Configure the virtual IP address for VRRP group 2, and set the preemption delay.
[DeviceA] interface vlan-interface 3
[DeviceA-Vlan-interface3] vrrp vrid 2 virtual-ip 10.1.2.1
[DeviceA-Vlan-interface3] vrrp vrid 2 preempt-mode delay 500
[DeviceA–Vlan-interface3] quit
# Configure the virtual IP address for VRRP group 1, and set the preemption delay.
[DeviceB] interface vlan-interface 2
[DeviceB-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[DeviceB-Vlan-interface2] vrrp vrid 1 preempt-mode delay 500
[DeviceB-Vlan-interface2] quit
# Configure the virtual IP address for VRRP group 2, set the preemption delay, and configure the priority of Device B in VRRP group 2.
[DeviceB] interface vlan-interface 3
[DeviceB-Vlan-interface3] vrrp vrid 2 virtual-ip 10.1.2.1
[DeviceB-Vlan-interface3] vrrp vrid 2 priority 110
[DeviceB-Vlan-interface3] vrrp vrid 2 preempt-mode delay 500
[DeviceB–Vlan-interface3] quit
Configuring BFD
# Configure the source IP address for BFD echo packets.
[DeviceA] bfd echo-source-ip 10.10.10.10
[DeviceB] bfd echo-source-ip 11.11.11.11
Configuring Track
# Create track entry 1, and associate it with the BFD session to verify the reachability of Device E.
[DeviceA] track 1 bfd echo interface vlan-interface 101 remote ip 1.1.1.2 local ip 1.1.1.1
[DeviceA-track-1] quit
# Associate VRRP group 1 with track entry 1 and decrease the router priority by 20 when the state of track entry 1 changes to negative.
[DeviceA-Vlan-interface2] vrrp vrid 1 track 1 priority reduced 20
# Create track entry 1, and associate it with the BFD session to verify the reachability of Device F.
[DeviceB] track 1 bfd echo interface vlan-interface 101 remote ip 1.1.2.2 local ip 1.1.2.1
[DeviceB-track-1] quit
# Associate VRRP group 2 with track entry 1 and decrease the router priority by 20 when the state of track entry 1 changes to negative.
[DeviceB-Vlan-interface3] vrrp vrid 2 track 1 priority reduced 20
[DeviceB-Vlan-interface3] quit
Configuring MSTP
[DeviceA] stp region-configuration
[DeviceA-mst-region] region-name vrrp
[DeviceA-mst-region] instance 1 vlan 2
[DeviceA-mst-region] instance 2 vlan 3
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
[DeviceA] stp instance 1 root primary
[DeviceA] stp instance 2 root secondary
[DeviceA] stp global enable
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name vrrp
[DeviceB-mst-region] instance 1 vlan 2
[DeviceB-mst-region] instance 2 vlan 3
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
[DeviceB] stp instance 2 root primary
[DeviceB] stp instance 1 root secondary
[DeviceB] stp global enable
3.     Configure L2 Switch A:
[SwitchA] stp region-configuration
[SwitchA-mst-region] region-name vrrp
[SwitchA-mst-region] instance 1 vlan 2
[SwitchA-mst-region] active region-configuration
[SwitchA-mst-region] quit
[SwitchA] stp global enable
4.     Configure L2 Switch B:
[SwitchB] stp region-configuration
[SwitchB-mst-region] region-name vrrp
[SwitchB-mst-region] instance 2 vlan 3
[SwitchB-mst-region] active region-configuration
[SwitchB-mst-region] quit
[SwitchB] stp global enable
1.     Verify that the hosts in the LAN can access the external network when Device A and Device B are operating correctly:
# Ping 1.1.1.2 from host A in area A.
<host A> ping 1.1.1.2
PING 1.1.1.2 (1.1.1.2): 56 data bytes
56 bytes from 1.1.1.2: seq=0 ttl=128 time=22.43 ms
56 bytes from 1.1.1.2: seq=1 ttl=128 time=7.17 ms
56 bytes from 1.1.1.2: seq=2 ttl=128 time=8.91 ms
56 bytes from 1.1.1.2: seq=3 ttl=128 time=7.45 ms
56 bytes from 1.1.1.2: seq=4 ttl=128 time=9.11 ms
--- 1.1.1.2 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 7.17/11.01/22.43 ms
# Ping 1.1.2.2 from host C in area B.
<host C> ping 1.1.2.2
PING 1.1.2.2 (1.1.2.2): 56 data bytes
56 bytes from 1.1.2.2: seq=0 ttl=128 time=22.43 ms
56 bytes from 1.1.2.2: seq=1 ttl=128 time=7.17 ms
56 bytes from 1.1.2.2: seq=2 ttl=128 time=8.91 ms
56 bytes from 1.1.2.2: seq=3 ttl=128 time=7.45 ms
56 bytes from 1.1.2.2: seq=4 ttl=128 time=9.11 ms
--- 1.1.2.2 ping statistics ---
The output shows that the hosts in area A and area B can access the external network.
# Display BFD session information on Device A.
[DeviceA] display bfd session
 IPv4 session working in echo mode:
 LD             SourceAddr      DestAddr        State    Holdtime    Interface
 129            1.1.1.1         1.1.1.2         Up       500ms       Vlan101
The output shows that a BFD session has been established.
# Display detailed VRRP group information on Device A.
[DeviceA] display vrrp verbose
 Running mode      : Standard
   Interface Vlan-interface2
     VRID           : 1                    Adver Timer  : 100
     Admin Status   : Up                   State        : Master
     Config Pri     : 110                  Running Pri  : 110
     Preempt Mode   : Yes                  Delay Time   : 500
     Auth Type      : None
     Virtual IP     : 10.1.1.1
     Virtual MAC    : 0000-5e00-0101
     Master IP      : 10.1.1.101
   VRRP Track Information:
     Track Object   : 1                    State : Positive   Pri Reduced : 20
   Interface Vlan-interface3
     VRID           : 2                    Adver Timer  : 100
     Admin Status   : Up                   State        : Backup
     Config Pri     : 100                  Running Pri  : 100
     Become Master  : 3600ms left
     Auth Type      : None
     Virtual IP     : 10.1.2.1
     Virtual MAC    : 0000-5e00-0102
     Master IP      : 10.1.2.102
# Display detailed VRRP group information on Device B.
[DeviceB] display vrrp verbose
     Become Master  : 3100ms left
     Auth Type      : None
     Auth Type      : None
¡     In VRRP group 1, Device A is the master, and Device B is the backup. Hosts that use default gateway 10.1.1.1/24 access the Internet through Device A.
¡     In VRRP group 2, Device B is the master, and Device A is the backup. Hosts that use default gateway 10.1.2.1/24 access the Internet through Device B.
2.     Verify that the hosts in the LAN can access the external network when the uplink monitored by Device A fails:
 Total Session Num: 1     Up Session Num: 0     Init Mode: Active
 129            1.1.1.1         1.1.1.2         Down        /        Vlan101
The output shows that the BFD session has been terminated.
     Auth Type      : None
     Master IP      : 10.1.1.102
     Auth Type      : None
The output shows that Device B becomes the master in VRRP group 1. Hosts in area A access the external network through Device B.
# When the fault is cleared, display BFD session information on Device A.
 129            1.1.1.1         1.1.1.2         Up       1000ms      Vlan101
The output shows that the BFD session is resumed.
     Auth Type      : None
     Become Master  : 3550ms left
     Auth Type      : None
The output shows that Device A resumes its priority and becomes the master in VRRP group 1 again. Hosts in area B access the external network through Device A.
Configuration files
Support for the port link-mode bridge command depends on the device model.
·     Device A:
vlan 2 to 3
vlan 101
 region-name vrrp
 instance 1 vlan 2
 instance 2 vlan 3
 stp global enable
interface Vlan-interface2
 ip address 10.1.1.101 255.255.255.0
interface Vlan-interface3
 ip address 10.1.2.101 255.255.255.0
interface Vlan-interface101
 ip address 1.1.1.1 255.255.255.0
 port access vlan 101
 undo stp enable
 port access vlan 2
 port access vlan 3
interface GigabitEthernet1/0/4
 track 1 bfd echo interface Vlan-interface101 remote ip 1.1.1.2 local ip 1.1.1.1
·     Device B:
vlan 2 to 3
vlan 101
 region-name vrrp
 instance 1 vlan 2
 instance 2 vlan 3
 stp global enable
 ip address 10.1.1.102 255.255.255.0
 ip address 10.1.2.102 255.255.255.0
 ip address 1.1.2.1 255.255.255.0
 undo stp enable
 port access vlan 2
 port access vlan 3
 track 1 bfd echo interface Vlan-interface101 remote ip 1.1.2.2 local ip 1.1.2.1
·     L2 Switch A:
vlan 2
 region-name vrrp
 instance 1 vlan 2
 stp global enable
 port access vlan 2
 port access vlan 2
·     L2 Switch B:
vlan 3
 region-name vrrp
 instance 2 vlan 3
 stp global enable
 port access vlan 3
 port access vlan 3
·     Device E:
vlan 101
 ip address 1.1.1.2 255.255.255.0
·     Device F:
vlan 101
 ip address 1.1.2.2 255.255.255.0
As shown in Figure 2:
·     Device A has two paths to reach Device B: one over a Layer 2 switch, and the other over Device C.
·     A Layer 2 switch connects Device A and Device B.
Because Device B does not support BFD, enable BFD echo packet mode on Device A. When the link between Device B and the Layer 2 switch fails, Device A switches the path over Device C to reach Device B.
Figure 2 Network diagram
Device
IP address
Device A
Vlan-int10
192.168.10.101/24
Device A
Vlan-int20
192.168.20.101/24
Device A
Vlan-int40
192.168.40.101/24
Device B
Vlan-int10
192.168.10.102/24
Device B
Vlan-int30
192.168.30.101/24
Device B
Vlan-int50
192.168.50.101/24
Device C
Vlan-int20
192.168.20.102/24
Device C
Vlan-int30
192.168.30.102/24
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Release 11xx
Not supported
Not supported
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Not supported
Not supported
Release 11xx
Release 11xx
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
Release 63xx
E500C switch series
E500D switch series
Not supported
Not supported
Release 63xx
Not supported
Release 63xx
Release 63xx
Procedures
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 192.168.10.101 24
# Configure two static routes with the same destination network 192.168.50.0/24 and different preferences. Configure the BFD echo packet mode for the preferred static route (Device A –> L2 Switch–> Device B).
[DeviceA] ip route-static 192.168.50.0 24 vlan-interface 10 192.168.10.102 bfd echo-packet
[DeviceA] ip route-static 192.168.50.0 24 vlan-interface 20 192.168.20.102 preference 65
# Configure two static routes with the same destination network 192.168.40.0/24 and different preferences. Configure the BFD echo packet mode for the preferred static route (Device B –> L2 Switch–> Device A).
[DeviceB] ip route-static 192.168.40.0 24 vlan-interface 10 192.168.10.101
[DeviceB] ip route-static 192.168.40.0 24 vlan-interface 30 192.168.30.102 preference 65
3.     Configure Device C:
# Configure static routes with destination networks 192.168.40.0/24 and 192.168.50.0/24.
[DeviceC] ip route-static 192.168.40.0 24 vlan-interface 20 192.168.20.101
[DeviceC] ip route-static 192.168.50.0 24 vlan-interface 30 192.168.30.101
# Configure the minimum interval for receiving BFD echo packets and the single-hop detection time multiplier.
[DeviceA-Vlan-interface10] bfd min-echo-receive-interval 100
[DeviceA-Vlan-interface10] bfd detect-multiplier 3
1.     Verify the configuration when Device A and Device B and the link between them are operating correctly:
# Display static route information on Device A.
[DeviceA] display ip routing-table protocol static
Summary Count : 1
Static Routing table Status : <Active>
Summary Count : 1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
192.168.50.0/24     Static 60   0            192.168.10.102  Vlan10
Static Routing table Status : <Inactive>
Summary Count : 0
The output shows that Device A communicates with Device B through the Layer 2 switch.
 67          192.168.10.101  192.168.10.102  Up       300ms       Vlan10
2.     Verify the configuration when the link between Device B and the Layer 2 switch is faulty:
Summary Count : 1
Summary Count : 1
192.168.50.0/24     Static 65   0            192.168.20.102  Vlan20
Summary Count : 0
The output shows that Device A communicates with Device B through Device C.
Configuration files
·     Device A:
vlan 10
vlan 20
vlan 40
 ip address 192.168.10.101 255.255.255.0
interface Vlan-interface20
 ip address 192.168.20.101 255.255.255.0
interface Vlan-interface40
 ip address 192.168.40.101 255.255.255.0
 port access vlan 10
 port access vlan 20
 port access vlan 40
 ip route-static 192.168.50.0 24 Vlan-interface10 192.168.10.102 bfd echo-packet
 ip route-static 192.168.50.0 24 Vlan-interface20 192.168.20.102 preference 65
·     Device B:
vlan 10
vlan 30
vlan 50
 ip address 192.168.10.102 255.255.255.0
interface Vlan-interface30
 ip address 192.168.30.101 255.255.255.0
interface Vlan-interface50
 ip address 192.168.50.101 255.255.255.0
 port access vlan 10
 port access vlan 30
 port access vlan 50
 ip route-static 192.168.40.0 24 Vlan-interface10 192.168.10.101
 ip route-static 192.168.40.0 24 Vlan-interface30 192.168.30.102 preference 65
·     Device C:
vlan 20
vlan 30
 ip address 192.168.20.102 255.255.255.0
 ip address 192.168.30.102 255.255.255.0
 port access vlan 20
 port access vlan 30
 ip route-static 192.168.40.0 24 Vlan-interface20 192.168.20.101
 ip route-static 192.168.50.0 24 Vlan-interface30 192.168.30.101
As shown in Figure 3, Device A, Device B, and Device C run RIP. Device A and Device C are connected through a Layer 2 switch.
Enable BFD echo packet mode on Device A (Device C does not support BFD) to monitor the path over the Layer 2 switch. When BFD detects a link failure, it notifies RIP to switch to the path over Device B.
Figure 3 Network diagram
Device
IP address
Device A
Vlan-int10
10.1.0.101/24
Device A
Vlan-int20
192.168.0.101/24
Device A
Vlan-int100
120.1.1.1/24
Device B
Vlan-int20
192.168.0.102/24
Device B
Vlan-int30
13.1.1.101/24
Device C
Vlan-int10
10.1.0.102/24
Device C
Vlan-int30
13.1.1.102/24
Device C
Vlan-int100
121.1.1.1/24
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Release 11xx
Not supported
Not supported
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Not supported
Not supported
Release 11xx
Release 11xx
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
Release 63xx
E500C switch series
E500D switch series
Not supported
Not supported
Release 63xx
Not supported
Release 63xx
Release 63xx
Procedures
[DeviceA] vlan 10
[DeviceA] interface vlan-interface10
[DeviceA-Vlan-interface10] ip address 10.1.0.101 24
Configuring RIP
# Configure basic RIP functions, import direct routes, and enable BFD for RIP.
[DeviceA] rip 1
[DeviceA-rip-1] version 2
[DeviceA-rip-1] undo summary
[DeviceA-rip-1] network 10.1.0.0
[DeviceA-rip-1] network 192.168.0.0
[DeviceA-rip-1] import-route direct
[DeviceA-rip-1] quit
[DeviceA-Vlan-interface10] rip bfd enable
# Configure basic RIP functions, and import direct routes.
[DeviceB] rip 1
[DeviceB-rip-1] version 2
[DeviceB-rip-1] undo summary
[DeviceB-rip-1] network 192.168.0.0
[DeviceB-rip-1] network 13.1.1.0
[DeviceB-rip-1] import-route direct
[DeviceB-rip-1] quit
<DeviceC> system-view
[DeviceC] rip 1
[DeviceC-rip-1] version 2
[DeviceC-rip-1] undo summary
[DeviceC-rip-1] network 10.1.0.0
[DeviceC-rip-1] network 13.1.1.0
[DeviceC-rip-1] import-route direct
[DeviceC-rip-1] quit
[DeviceA] bfd echo-source-ip 11.11.11.11
[DeviceA] display bfd session verbose
       Local Discr: 2049
         Source IP: 10.1.0.101         Destination IP: 10.1.0.102
     Session State: Up                      Interface: Vlan-interface10
         Hold Time: 300ms                Act Tx Inter: 100ms
      Min Rx Inter: 100ms                Detect Inter: 300ms
          Rx Count: 0                        Tx Count: 910
      Connect Type: Direct             Running Up for: 00:00:46
       Detect Mode: Async                        Slot: 1
          Protocol: RIP
           Version: 1
         Diag Info: No Diagnostic
The output shows that a BFD session has been established and is up.
# (Release 63xx) Display information about the routes to network 121.1.1.0/24 on Device A.
<DeviceA> display ip routing-table 121.1.1.0 24 verbose
Summary Count : 1
Destination: 121.1.1.0/24
   Protocol: RIP
 Process ID: 1
  SubProtID: 0x1                    Age: 04h20m37s
       Cost: 1               Preference: 100
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x26000002          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 10.1.0.102
      Flags: 0x1008c        OrigNextHop: 10.1.0.102
      Label: NULL           RealNextHop: 10.1.0.102
    BkLabel: NULL             BkNextHop: N/A
    SRLabel: NULL             BkSRLabel: NULL
  Tunnel ID: Invalid          Interface: Vlan-interface10
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
# (Release 65xx, 6008 and later, and 8005 and later) Display information about the routes to network 121.1.1.0/24 on Device A.
Summary Count : 1
   Protocol: RIP
 Process ID: 1
   SIDIndex: NULL               InLabel: NULL
   LinkCost: 0               MicroSegID: 0
The output shows that Device A communicates with Device C through the Layer 2 switch.
# When the link between Device C and the Layer 2 switch fails, view BFD log information.
%Oct  9 18:42:17:650 2013 Device A BFD/5/BFD_CHANGE_FSM: Sess[10.1.0.101/10.1.0.102, LD/RD:2049/2049, Interface:Vlan10, SessType:Echo, LinkType:INET], Ver:1, Sta: UP-> DOWN, Diag:1 (Control Detection Time Expired)
The output shows that BFD can quickly detect the failure and notify RIP.
Summary Count : 1
   Protocol: RIP
 Process ID: 2
       Cost: 2               Preference: 100
     AttrID: 0xffffffff        Neighbor: 192.168.0.102
      Flags: 0x1008c        OrigNextHop: 192.168.0.102
      Label: NULL           RealNextHop: 192.168.0.102
  Tunnel ID: Invalid          Interface: Vlan-interface20
# (Release 63xx, 6008 and later, and 8005 and later) Display information about the routes to network 121.1.1.0/24 on Device A.
Summary Count : 1
   Protocol: RIP
 Process ID: 2
The output shows that Device A communicates with Device C through Device B.
Configuration files
·     Device A:
rip 1
 undo summary
 version 2
 network 10.0.0.0
 network 192.168.0.0
 import-route direct
vlan 10
vlan 20
vlan 100
 ip address 10.1.0.101 255.255.255.0
 rip bfd enable
 bfd min-transmit-interval 100
 bfd min-receive-interval 100
 ip address 192.168.0.101 255.255.255.0
interface Vlan-interface100
 ip address 120.1.1.1 255.255.255.0
 port access vlan 10
 port access vlan 20
 port access vlan 100
·     Device B:
rip 1
 undo summary
 version 2
 network 192.168.0.0
network 13.1.1.0
 import-route direct
vlan 20
vlan 30
 ip address 192.168.0.102 255.255.255.0
 ip address 13.1.1.101 255.255.255.0
 port access vlan 20
 port access vlan 30
·     Device C:
rip 1
 undo summary
 version 2
 network 10.1.0.0
network 13.1.1.0
 import-route direct
vlan 10
vlan 30
vlan 100
 ip address 10.1.0.102 255.255.255.0
 ip address 13.1.1.102 255.255.255.0
 ip address 121.1.1.1 255.255.255.0
 port access vlan 10
 port access vlan 30
As shown in Figure 4, Device A, Device B, and Device C run OSPF. Device A and Device C are connected through a Layer 2 switch.
Enable BFD control packet mode on Device A and Device C to monitor the path over the Layer 2 switch. When BFD detects a link failure, it notifies OSPF to switch to the path over Device B.
Figure 4 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device A
Vlan-int10
10.1.0.101/24
Device A
Vlan-int20
192.168.0.101/24
Device A
Vlan-int100
120.1.1.1/24
Device B
Vlan-int20
192.168.0.102/24
Device B
Vlan-int30
13.1.1.101/24
Device C
Vlan-int10
10.1.0.102/24
Device C
Vlan-int30
13.1.1.102/24
Device C
Vlan-int100
121.1.1.1/24
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Not supported
Release 63xx
Release 63xx
Not supported
Not supported
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
In BFD control packet mode, a minimum of one end must operate in active mode for a BFD session to be established.
Procedures
[DeviceA] vlan 10
Configuring OSPF
# Configure basic OSPF functions, and enable BFD for OSPF.
[DeviceA] ospf
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 120.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
[DeviceA-Vlan-interface10] ospf bfd enable
# Configure basic OSPF functions.
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
[DeviceC] ospf
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 121.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ospf bfd enable
[DeviceC-Vlan-interface10] quit
# Configure the session establishment mode as active (this is the default mode).
[DeviceA] bfd session init-mode active
# Configure the minimum interval for sending and receiving single-hop BFD control packets and the single-hop detection time multiplier.
[DeviceA-Vlan-interface10] bfd min-transmit-interval 100
[DeviceA-Vlan-interface10] bfd min-receive-interval 100
2.     Configure Device C:
[DeviceC] bfd session init-mode active
[DeviceC-Vlan-interface10] bfd min-transmit-interval 100
[DeviceC-Vlan-interface10] bfd min-receive-interval 100
[DeviceC-Vlan-interface10] bfd detect-multiplier 3
# Ping host C (connected to Device C) from host A (connected to Device A) to verify the connectivity.
<host A> ping 121.1.1.2
PING 121.1.1.2 (121.1.1.2): 56 data bytes
56 bytes from 121.1.1.2: seq=0 ttl=128 time=22.43 ms
56 bytes from 121.1.1.2: seq=1 ttl=128 time=7.17 ms
56 bytes from 121.1.1.2: seq=2 ttl=128 time=8.91 ms
56 bytes from 121.1.1.2: seq=3 ttl=128 time=7.45 ms
56 bytes from 121.1.1.2: seq=4 ttl=128 time=9.11 ms
--- 121.1.1.2 ping statistics ---
round-trip min/avg/max/std-dev = 7.17/11.01/22.43 ms
The output shows that host C can be pinged successfully.
# Display detailed OSPF neighbor information on Device A.
[DeviceA] display ospf peer verbose
                  Neighbors
 Area 0.0.0.0 interface 10.1.0.101(Vlan-interface10)'s neighbors
 Router ID: 1.1.1.1          Address: 10.1.0.102       GR State: Normal
   State: Full  Mode: Nbr is Slave  Priority: 1
   DR: 10.1.0.101  BDR: 10.1.0.102  MTU: 0
   Options is 0x42 (-|O|-|-|-|-|E|-)
   Dead timer due in 39  sec
   Neighbor is up for 00:09:01
   Neighbor state change count: 5
   BFD status: Enabled(Control mode)
The output shows that Device A has established OSPF neighbor relationship with Device C.
# Display BFD session information on Device A and Device C.
       Local Discr: 2049                 Remote Discr: 2049
      Min Tx Inter: 100ms                Act Tx Inter: 100ms
      Rx Count: 536                      Tx Count: 536
      Connect Type: Direct             Running Up for: 00:04:48
         Hold Time: 300ms                   Auth mode: None
          Protocol: OSPF
           Version: 1
[DeviceC] display bfd session verbose
         Source IP: 10.1.0.102         Destination IP: 10.1.0.101
          Rx Count: 3971                     Tx Count: 3776
      Connect Type: Direct             Running Up for: 00:06:52
          Protocol: OSPF
           Version: 1
The output shows that BFD sessions have been established and are up.
<DeviceA> display ip routing-table 121.1.1.0 verbose
Summary Count : 1
   Protocol: OSPF
 Process ID: 1
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
# (Release 65xx, 6008 and later, 8005 and later, 1106 and later, and 66xx) Display information about the routes to network 121.1.1.0/24 on Device A.
Summary Count : 1
   Protocol: OSPF
 Process ID: 1
%Oct  9 15:22:23:154 2013 DeviceC BFD/5/BFD_CHANGE_FSM: Sess[10.1.0.102/10.1.0.101, LD/RD:2049/2049, Interface:Vlan10, SessType:Ctrl, LinkType:INET], Ver:1, Sta: UP-> DOWN, Diag: 1 (Control Detection Time Expired)
%Oct  9 15:22:23:155 2013 DeviceC OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 10.1.0.101(Vlan-interface10) from FULL to DOWN.
The output shows that BFD can quickly detect the failure and notify OSPF.
Summary Count : 1
   Protocol: OSPF
 Process ID: 1
Summary Count : 1
   Protocol: OSPF
 Process ID: 1
Configuration files
·     Device A:
ospf 1
 area 0.0.0.0
vlan 10
vlan 20
vlan 100
 ospf bfd enable
 port access vlan 10
 port access vlan 20
·     Device B:
ospf 1
 area 0.0.0.0
vlan 20
vlan 30
 port access vlan 20
 port access vlan 30
·     Device C:
ospf 1
 area 0.0.0.0
vlan 10
vlan 30
vlan 100
 ospf bfd enable
 port access vlan 10
 port access vlan 30
As shown in Figure 5, Device A, Device B, and Device C run IS-IS. Device A and Device C are connected through a Layer 2 switch.
Enable BFD control packet mode on Device A and Device C to monitor the path over the Layer 2 switch. When BFD detects a link failure, it notifies IS-IS to switch to the path over Device B.
Figure 5 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device A
Vlan-int10
10.1.0.101/24
Device A
Vlan-int20
192.168.0.101/24
Device A
Vlan-int100
120.1.1.1/24
Device B
Vlan-int20
192.168.0.102/24
Device B
Vlan-int30
13.1.1.101/24
Device C
Vlan-int10
10.1.0.102/24
Device C
Vlan-int30
13.1.1.102/24
Device C
Vlan-int100
121.1.1.1/24
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Not supported
Not supported
Not supported
Not supported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Not supported
Not supported
Not supported
Release 11xx
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Release 63xx
Not supported
Not supported
Not supported
Procedures
[DeviceA] vlan 10
Configuring IS-IS
# Configure basic IS-IS functions, and enable BFD for IS-IS.
[DeviceA] isis
[DeviceA-isis-1] network-entity 10.0000.0000.0001.00
[DeviceA-isis-1] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] isis enable
[DeviceA-Vlan-interface20] quit
[DeviceA-Vlan-interface10] isis enable
[DeviceA-Vlan-interface10] isis bfd enable
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] isis enable
[DeviceA-Vlan-interface100] isis bfd enable
[DeviceA-Vlan-interface100] quit
# Configure basic IS-IS functions.
[DeviceB] isis
[DeviceB-isis-1] network-entity 10.0000.0000.0003.00
[DeviceB-isis-1] quit
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] isis enable
[DeviceB-Vlan-interface20] quit
[DeviceB] interface vlan-interface 30
[DeviceB-Vlan-interface30] isis enable
[DeviceB-Vlan-interface30] quit
[DeviceC] isis
[DeviceC-isis-1] network-entity 10.0000.0000.0002.00
[DeviceC-isis-1] quit
[DeviceC-Vlan-interface10] isis enable
[DeviceC-Vlan-interface10] isis bfd enable
[DeviceC] interface vlan 30
[DeviceC-Vlan-interface30] isis enable
[DeviceC-Vlan-interface30] quit
[DeviceC] interface vlan-interface 100
[DeviceC-Vlan-interface100] isis enable
[DeviceC-Vlan-interface100] isis bfd enable
[DeviceC-Vlan-interface100] quit
[DeviceC] interface vlan 10
# Display detailed IS-IS neighbor information on Device A.
[DeviceA] display isis peer verbose
                         Peer information for IS-IS(1)
 System ID: 0000.0000.0002
 Interface: Vlan10                  Circuit Id:  0000.0000.0002.01
 State: Up     HoldTime: 6s         Type: L1(L1L2)     PRI: 64
 Area address(es): 00
 Peer IP address(es): 10.1.0.102
 Peer local circuit ID: 1
 Peer circuit SNPA address: ce9d-d91d-d100
 Uptime: 00:01:19
 Adj protocol:  IPv4
 Graceful Restart capable
   Restarting signal: No
   Suppress adjacency advertisement: No
 Local topology:
   0
 Remote topology:
   0
The output shows that Device A has established IS-IS neighbor relationship with Device C.
          Rx Count: 3                        Tx Count: 3
      Connect Type: Direct             Running Up for: 00:06:09
          Protocol: ISIS_BR_L1/ISIS_BR_L2
           Version: 1
      Connect Type: Direct             Running Up for: 00:07:10
           Version: 1
Summary Count : 1
   Protocol: IS_L1
 Process ID: 1
       Cost: 20              Preference: 15
  OrigTblID: 0x2                OrigVrf: default-vrf
Summary Count : 1
   Protocol: IS_L1
 Process ID: 1
%Oct  9 16:11:24:163 2013 DeviceC BFD/5/BFD_CHANGE_FSM: Sess[10.1.0.102/10.1.0.101, LD/RD:2049/2049, Interface:Vlan10, SessType:Ctrl, LinkType:INET], Ver:1, Sta: UP-> DOWN, Diag: 1 (Control Detection Time Expired)
%Oct  9 16:11:24:164 2013 DeviceC ISIS/5/ISIS_NBR_CHG: IS-IS 1, Level-1 adjacency 0000.0000.0001 (Vlan-interface10), state changed to DOWN, Reason: BFD session down.
%Oct  9 16:11:24:164 2013 DeviceC ISIS/5/ISIS_NBR_CHG: IS-IS 1, Level-2 adjacency 0000.0000.0001 (Vlan-interface10), state changed to DOWN, Reason: BFD session down.
The output shows that BFD can quickly detect the failure and notify IS-IS.
Summary Count : 1
   Protocol: IS_L1
 Process ID: 1
Summary Count : 1
   Protocol: IS_L1
 Process ID: 1
Configuration files
·     Device A:
isis 1
vlan 10
vlan 20
vlan 100
isis enable 1
 isis bfd enable
isis enable 1
 isis enable 1
 port access vlan 10
 port access vlan 20
·     Device B:
isis 1
vlan 20
vlan 30
isis enable 1
isis enable 1
 port access vlan 20
 port access vlan 30
·     Device C:
isis 1
vlan 10
vlan 30
vlan 100
isis enable 1
 isis bfd enable
isis enable 1
 isis enable 1
 port access vlan 10
 port access vlan 30
As shown in Figure 6, the devices in AS 100 run OSPF to reach each other. There are two paths between Device B and Device D:
·     Path A—Path over Device C.
·     Path B—Path over Device E.
When both paths are available, BGP uses the path over Device C to forward traffic between Device A and Device F.
Enable BFD control packet mode on Device B and Device D to monitor the path over Device C. When BFD detects a link failure, it notifies BGP to switch to the path over Device E.
Figure 6 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device A
Vlan-int100
120.1.0.1/24
Device B
Vlan-int10
10.1.0.101/24
Device B
Vlan-int30
192.168.0.101/24
Device B
Vlan-int100
120.1.0.2/24
Device C
Vlan-int10
10.1.0.102/24
Device C
Vlan-int20
10.2.0.102/24
Device D
Vlan-int20
10.2.0.101/24
Device D
Vlan-int40
13.1.1.101/24
Device D
Vlan-int100
120.2.0.2/24
Device E
Vlan-int30
192.168.0.102/24
Device E
Vlan-int40
13.1.1.102/24
Device F
Vlan-int100
120.2.0.1/24
Analysis
For Path A to become the primary path, use a routing policy to set a lower cost for Path A than Path B.
Hardware
Software version
S5850 switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
Release 65xx
MS4520V2-28S switch
Release 63xx
Release 63xx
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
Release 63xx
E500C switch series
E500D switch series
Not supported
Not supported
Release 63xx
Not supported
Release 63xx
Not supported
Procedures
# Configure IP addresses for the interfaces on the devices. (Details not shown.)
1.     Configure Device B:
[DeviceB] ospf
[DeviceB-ospf-1] import-route direct
[DeviceB-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceC] ospf
[DeviceC-ospf-1-area-0.0.0.0] network 10.2.0.0 0.0.0.255
3.     Configure Device D:
[DeviceD] ospf
[DeviceD-ospf-1] import-route direct
[DeviceD-ospf-1] area 0
[DeviceD-ospf-1-area-0.0.0.0] network 10.2.0.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] quit
[DeviceD-ospf-1] quit
4.     Configure Device E:
[DeviceE] ospf
[DeviceE-ospf-1] area 0
[DeviceE-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] quit
[DeviceE-ospf-1] quit
Configuring BGP
# Enable BGP and set the local AS number to 200.
[DeviceA] bgp 200
[DeviceA-bgp-default] router-id 1.1.1.1
# Establish an EBGP connection with Device B.
[DeviceA-bgp-default] peer 120.1.0.2 as-number 100
# Create the BGP IPv4 unicast address family and enter its view.
[DeviceA-bgp-default] address-family ipv4 unicast
# In BGP IPv4 unicast address family view, inject local network 120.1.0.0/24 to the BGP routing table.
[DeviceA-bgp-default-ipv4] network 120.1.0.0 255.255.255.0
# Enable BGP to exchange IPv4 unicast routing information with peer 120.1.0.2.
[DeviceA-bgp-default-ipv4] peer 120.1.0.2 enable
[DeviceA-bgp-default-ipv4] quit
# Enable BGP and set the local AS number to 100.
[DeviceB] bgp 100
[DeviceB-bgp-default] router-id 2.2.2.2
# Establish an EBGP connection with Device A.
[DeviceB-bgp-default] peer 120.1.0.1 as-number 200
# Establish IBGP connections with Device D.
[DeviceB-bgp-default] peer 10.2.0.101 as-number 100
[DeviceB-bgp-default] peer 13.1.1.101 as-number 100
[DeviceB-bgp-default] address-family ipv4 unicast
# Enable BGP to exchange IPv4 unicast routing information with peer 10.2.0.101.
[DeviceB-bgp-default-ipv4] peer 10.2.0.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 10.2.0.101.
[DeviceB-bgp-default-ipv4] peer 10.2.0.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 13.1.1.101.
[DeviceB-bgp-default-ipv4] peer 13.1.1.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 13.1.1.101.
[DeviceB-bgp-default-ipv4] peer 13.1.1.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 120.1.0.1.
[DeviceB-bgp-default-ipv4] peer 120.1.0.1 enable
[DeviceB-bgp-default-ipv4] quit
[DeviceD] bgp 100
[DeviceD-bgp-default] router-id 4.4.4.4
# Establish IBGP connections with Device B.
[DeviceD-bgp-default] peer 10.1.0.101 as-number 100
[DeviceD-bgp-default] peer 192.168.0.101 as-number 100
# Establish an EBGP connection with Device F.
[DeviceD-bgp-default] peer 120.2.0.1 as-number 300
[DeviceD-bgp-default] address-family ipv4 unicast
# Enable BGP to exchange IPv4 unicast routing information with peer 10.1.0.101.
[DeviceD-bgp-default-ipv4] peer 10.1.0.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 10.1.0.101.
[DeviceD-bgp-default-ipv4] peer 10.1.0.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 192.168.0.101.
[DeviceD-bgp-default-ipv4] peer 192.168.0.101 enable
# In BGP IPv4 unicast address family view, specify the device as the next hop for routes sent to peer 192.168.0.101.
[DeviceD-bgp-default-ipv4] peer 192.168.0.101 next-hop-local
# Enable BGP to exchange IPv4 unicast routing information with peer 120.2.0.1.
[DeviceD-bgp-default-ipv4] peer 120.2.0.1 enable
[DeviceD-bgp-default-ipv4] quit
4.     Configure Device F:
# Enable BGP and set the local AS number to 300.
[DeviceF] bgp 300
[DeviceF-bgp-default] router-id 6.6.6.6
# Establish an EBGP connection with Device D.
[DeviceF-bgp-default] peer 120.2.0.2 as-number 100
[DeviceF-bgp-default] address-family ipv4 unicast
# In BGP IPv4 unicast address family view, inject local network 120.2.0.0/24 to the BGP routing table.
[DeviceF-bgp-default-ipv4] network 120.2.0.0 255.255.255.0
# Enable BGP to exchange IPv4 unicast routing information with peer 120.2.0.2.
[DeviceF-bgp-default-ipv4] peer 120.2.0.2 enable
[DeviceF-bgp-default-ipv4] quit
# Create ACL 2000 to permit packets sourced from 120.1.0.0/24.
[DeviceB] acl basic 2000
[DeviceB-acl-ipv4-basic-2000] rule permit source 120.1.0.0 0.0.0.255
[DeviceB-acl-ipv4-basic-2000] quit
# Set a local preference of 200 for routes advertised to peer 10.2.0.101, and set the preference for IBGP routes to 100.
[DeviceB] route-policy local-pre permit node 10
[DeviceB-route-policy-local-pre] if-match ip address acl 2000
[DeviceB-route-policy-local-pre] apply local-preference 200
[DeviceB-route-policy-local-pre] quit
[DeviceB] bgp 100
[DeviceB-bgp-default-ipv4] peer 10.2.0.101 route-policy local-pre export
[DeviceB-bgp-default-ipv4] preference 255 100 130
2.     Configure Device D:
# Create ACL 2000 to permit packets sourced from 120.2.0.0/24.
[DeviceD] acl basic 2000
[DeviceD-acl-ipv4-basic-2000] rule permit source 120.2.0.0 0.0.0.255
[DeviceD-acl-ipv4-basic-2000] quit
# Set a local preference of 200 for routes learned from peer 10.1.0.101, and configure the preference for IBGP routes as 100.
[DeviceD] route-policy local-pre permit node 10
[DeviceD-route-policy-local-pre] if-match ip address acl 2000
[DeviceD-route-policy-local-pre] apply local-preference 200
[DeviceD-route-policy-local-pre] quit
[DeviceD] bgp 100
[DeviceD-bgp-default-ipv4] peer 10.1.0.101 route-policy local-pre export
[DeviceD-bgp-default-ipv4] preference 255 100 130
Configuring BFD
# Enable BFD for the link to BGP peer 10.2.0.101.
[DeviceB] bgp 100
[DeviceB-bgp-default] peer 10.2.0.101 bfd
[DeviceB-bgp-default] quit
# Enable BFD for the link to BGP peer 10.1.0.101.
[DeviceD] bgp 100
[DeviceD-bgp-default] peer 10.1.0.101 bfd
[DeviceD-bgp-default] quit
# Ping Device F from Device A to verify the connectivity.
[DeviceA] ping 120.2.0.1
Ping 120.2.0.1 (120.2.0.1): 56 data bytes, press CTRL+C to break
56 bytes from 120.2.0.1: icmp_seq=0 ttl=252 time=1.189 ms
56 bytes from 120.2.0.1: icmp_seq=1 ttl=252 time=1.095 ms
56 bytes from 120.2.0.1: icmp_seq=2 ttl=252 time=1.086 ms
56 bytes from 120.2.0.1: icmp_seq=3 ttl=252 time=1.097 ms
56 bytes from 120.2.0.1: icmp_seq=4 ttl=252 time=1.089 ms
--- Ping statistics for 120.2.0.1 ---
round-trip min/avg/max/std-dev = 1.086/1.111/1.189/0.039 ms
The output shows that Device F can be pinged successfully.
# Display BGP peer information on Device B.
[DeviceB] display bgp peer ipv4
 BGP local router ID: 2.2.2.2
 Local AS number: 100
 Total number of peers: 3                  Peers in established state: 3
  * - Dynamically created peer
  ^ - Peer created through link-local address
  10.2.0.101             100        6        4    0       1 00:00:56 Established
  13.1.1.101             100        6        5    0       1 00:00:56 Established
  120.1.0.1              200        6        5    0       1 00:00:56 Established
·     Two IBGP connections have been established between Device B and Device D.
·     An EBGP connection has been established between Device B and Device A.
# Display detailed BFD session information on Device B.
[DeviceB] display bfd session verbose
       Local Discr: 2049                 Remote Discr: 0
         Source IP: 10.1.0.101         Destination IP: 10.2.0.101
     Session State: UP                      Interface: N/A
         Hold Time: 0ms                  Act Tx Inter: 400ms
      Min Rx Inter: 400ms                Detect Inter: 2000ms
      Connect Type: Indirect           Running Up for: 00:00:00
          Protocol: BGP
           Version: 1
# (Release 63xx) Display information about the routes to network 120.2.0.0/24 on Device B.
[DeviceB] display ip routing-table 120.2.0.0 24 verbose
Summary Count : 3
Destination: 120.2.0.0/24
   Protocol: BGP instance default
 Process ID: 0
  SubProtID: 0x1                    Age: 00h24m48s
       Cost: 0               Preference: 100
    TableID: 0x2                 OrigAs: 300
      NibID: 0x15000001          LastAs: 300
     AttrID: 0x1               Neighbor: 10.2.0.101
      Flags: 0x10060        OrigNextHop: 10.2.0.101
   Protocol: O_ASE2
 Process ID: 1
  SubProtID: 0x8                    Age: 00h26m19s
       Cost: 1               Preference: 150
        Tag: 1                    State: Inactive Adv
      NibID: 0x13000005          LastAs: 0
      Flags: 0x41           OrigNextHop: 10.1.0.102
   Protocol: O_ASE2
 Process ID: 1
      NibID: 0x13000003          LastAs: 0
      Flags: 0x41           OrigNextHop: 192.168.0.102
  Tunnel ID: Invalid          Interface: Vlan-interface30
# (Release 65xx, 6008 and later, and 8005 and later) Display information about the routes to network 120.2.0.0/24 on Device B.
Summary Count : 3
 Process ID: 0
   Protocol: O_ASE2
 Process ID: 1
   Protocol: O_ASE2
 Process ID: 1
The output shows that Device B communicates with Device D through path over Device C.
# When the path over Device C fails, ping Device F from Device A.
Ping 120.1.0.1 (120.2.0.1): 56 data bytes, press CTRL+C to break
56 bytes from 120.2.0.1: icmp_seq=0 ttl=252 time=0.680 ms
56 bytes from 120.2.0.1: icmp_seq=1 ttl=252 time=0.295 ms
56 bytes from 120.2.0.1: icmp_seq=2 ttl=252 time=0.423 ms
56 bytes from 120.2.0.1: icmp_seq=3 ttl=252 time=0.464 ms
56 bytes from 120.2.0.1: icmp_seq=4 ttl=252 time=0.445 ms
round-trip min/avg/max/std-dev = 0.295/0.461/0.680/0.124 ms
Summary Count : 2
 Process ID: 0
  SubProtID: 0x1                    Age: 00h00m18s
     AttrID: 0x1               Neighbor: 13.1.1.101
      Flags: 0x10060        OrigNextHop: 13.1.1.101
   Protocol: O_ASE2
 Process ID: 1
  SubProtID: 0x8                    Age: 00h00m18s
      NibID: 0x13000001          LastAs: 0
Summary Count : 2
 Process ID: 0
   Protocol: O_ASE2
 Process ID: 1
The output shows that Device B communicates with Device D through path over Device E.
Configuration files
·     Device A:
vlan 100
 ip address 120.1.0.1 255.255.255.0
bgp 200
 router-id 1.1.1.1
·     Device B:
ospf 1
import-route direct
 area 0.0.0.0
vlan 10
vlan 30
vlan 100
 ip address 120.1.0.2 255.255.255.0
 port access vlan 10
 port access vlan 30
bgp 100
 router-id 2.2.2.2
 peer 10.2.0.101 bfd
acl basic 2000
 rule 0 permit source 120.1.0.0 0.0.0.255
·     Device C:
ospf 1
 area 0.0.0.0
vlan 10
vlan 20
 ip address 10.2.0.102 255.255.255.0
 port access vlan 10
 port access vlan 20
·     Device D:
ospf 1
 import-route direct
 area 0.0.0.0
vlan 20
vlan 40
vlan 100
ip address 10.2.0.101 255.255.255.0
 port access vlan 20
 port access vlan 40
bgp 100
 router-id 4.4.4.4
 peer 10.1.0.101 bfd
acl basic 2000
 rule 0 permit source 120.2.0.0 0.0.0.255
·     Device E:
ospf 1
 area 0.0.0.0
vlan 30
vlan 40
 port access vlan 30
 port access vlan 40
·     Device F:
vlan 100
 ip address 120.2.0.1 255.255.255.0
bgp 300
 router-id 6.6.6.6
As shown in Figure 7, Device A has two paths to reach Device C:
·     Link A.
·     Link B.
Configure PBR to enable Device A to forward traffic with source IP address 40.0.0.2 over Link B.
Enable BFD echo packet mode on Device A (Device C does not support BFD) to monitor Link B. When BFD detects a link failure, Device A switches the path to Link A.
Figure 7 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Release 66xx
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Procedures
[DeviceA] vlan 40
[DeviceA-vlan40] port gigabitethernet 1/0/2
[DeviceA-vlan40] quit
[DeviceA] interface vlan-interface 40
[DeviceA-Vlan-interface40] ip address 40.0.0.1 24
[DeviceA-Vlan-interface40] quit
# Configure a static route to reach network 50.0.0.0.
[DeviceA] ip route-static 50.0.0.0 24 vlan-interface 200 13.13.13.2
[DeviceB] ip route-static 50.0.0.0 24 vlan-interface 101 24.24.24.4
# Create ACL 3010 to permit packets sourced from 40.0.0.2.
[DeviceA] acl number 3010
[DeviceA-acl-adv-3010] rule 0 permit ip source 40.0.0.2 0
[DeviceA-acl-adv-3010] quit
# Create routing policy aaa to set next hop 12.12.12.2 for packets matching ACL 3010, and associate the next hop with track entry 11.
[DeviceA] policy-based-route aaa permit node 5
[DeviceA-pbr-aaa-5] if-match acl 3010
[DeviceA-pbr-aaa-5] apply next-hop 12.12.12.2 track 11
[DeviceA-pbr-aaa-5] quit
# Apply routing policy aaa to VLAN-interface 40.
[DeviceA-Vlan-interface40] ip policy-based-route aaa
[DeviceA] bfd echo-source-ip 3.3.3.3
# Configure the minimum interval for receiving BFD echo packets and the single-hop detection time multiplier, and associate track entry 11 with BFD.
[DeviceA-Vlan-interface100] bfd min-echo-receive-interval 100
[DeviceA-Vlan-interface100] bfd detect-multiplier 3
[DeviceA] track 11 bfd echo interface vlan-interface100 remote ip 12.12.12.2 local ip 12.12.12.1
[DeviceA-track-11] quit
# Display outbound traffic statistics for all interfaces on Device A.
<DeviceA> reset counters interface
<DeviceA> display counters outbound interface
Interface         Total (pkts)   Broadcast (pkts)   Multicast (pkts)  Err (pkts)
GE1/0/1                     0                  0                  0           0
GE1/0/2                     0                  0                  0           0
GE1/0/3                585414                  0                  0           0
GE1/0/4                     0                  0                  0           0
GE1/0/5                     0                  0                  0           0
GE1/0/6                     0                  0                  0           0
The output shows that the traffic sourced from 40.0.0.0 is forwarded through VLAN-interface 100 (Link B).
       Local Discr: 2049
         Source IP: 12.12.12.1         Destination IP: 12.12.12.2
     Session State: Up                      Interface: Vlan-interface100
         Hold Time: 0ms                  Act Tx Inter: 100ms
          Rx Count: 128234                   Tx Count: 371950
      Connect Type: Direct             Running Up for: 00:01:04
          Protocol: TRACK
           Version: 1
# When the link between Device A and Device B fails, view BFD log information.
%Dec 10 16:39:46:210 2013 DeviceA BFD/5/BFD_CHANGE_FSM: Sess[12.12.12.1/12.12.12.2, LD/RD:2049/2049, Interface:Vlan100, SessType:Echo, LinkType:INET], Ver: 1, Sta: UP-> DOWN, Diag: 1 (Control Detection Time Expired)
%Dec 10 16:39:47:343 2013 DeviceA IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/3 is down.
%Dec 10 16:39:47:343 2013 DeviceA IFNET/3/PHY_UPDOWN: Vlan-interface100 link status is down.
The output shows that the BFD session is down.
# Clear the interface statistics, and display outbound traffic statistics for all interfaces on Device A again.
GE1/0/1                863764                  0                  0           0
GE1/0/2                     0                  0                  0           0
GE1/0/3                     0                  0                  0           0
GE1/0/4                     0                  0                  0           0
GE1/0/5                     0                  0                  0           0
GE1/0/6                     0                  0                  0           0
The output shows that the traffic sourced from 40.0.0.0 is forwarded through VLAN-interface 200 (Link A).
Configuration files
·     Device A:
vlan 40
vlan 100
vlan 200
 if-match acl 3010
 ip address 40.0.0.1 255.255.255.0
 ip address 12.12.12.1 255.255.255.0
interface Vlan-interface200
 ip address 13.13.13.1 255.255.255.0
 port access vlan 200
 port access vlan 40
 ip route-static 50.0.0.0 24 Vlan-interface200 13.13.13.2
 ip local policy-based-route aaa
acl number 3010
 track 11 bfd echo interface Vlan-interface100 remote ip 12.12.12.2 local ip 12.
12.12.1
·     Device B:
vlan 100 to 101
interface NULL0
 ip address 12.12.12.2 255.255.255.0
 ip address 24.24.24.2 255.255.255.0
 ip route-static 50.0.0.0 24 Vlan-interface101 24.24.24.4
·     Device C:
vlan 50
vlan 101
vlan 200
interface NULL0
 ip address 50.0.0.1 255.255.255.0
 ip address 24.24.24.4 255.255.255.0
 ip address 13.13.13.2 255.255.255.0
 port access vlan 50
