H3C Fixed Port Campus Switches Configuration Examples-6W103
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W103
Table of Contents
Related Documents
59-IRF 3.1 Configuration Examples
59-IRF 3.1 Configuration Examples 133.01 KB
Introduction
This document provides examples for setting up an IRF 3.1 system.
IRF 3.1 integrates multiple lower-layer devices with a higher-layer IRF fabric to provide high-density, low-cost connectivity at the access layer. IRF 3.1 is implemented based on IEEE 802.1BR.
In an IRF 3.1 system, the higher-layer IRF fabric is called the parent fabric and the lower-layer devices are called bridge port extenders (PEXs). You manage and configure the PEXs from the parent fabric as if they were interface modules on the parent fabric.
This document assumes that you have basic knowledge of IRF 3.1.
Example: Setting up an IRF 3.1 system
As shown in Figure 1:
·     Use Member 1 and Member 2 to set up an IRF fabric at the distribution layer.
·     Use the IRF fabric as the parent fabric and attach PEXs to the parent fabric to set up an IRF 3.1 system.
·     The IRF 3.1 system acts as the gateway for users in VLANs 10 and 30.
Figure 1 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Not supported
S6550XE-HI switch series
Not supported
S6525XE-HI switch series
Not supported
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Supported: Release 63xx, Release 65xx
Not supported: Release 66xx
S5560X-HI switch series
S5500V2-EI switch series
Not supported
MS4520V2-30F switch
Not supported
MS4520V2-30C switch
MS4520V2-54C switch
Not supported
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except the S5500V3-24P-SI and S5500V3-48P-SI switches)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Not supported
S5120V3-SI switch series (except the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI switches)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
Parent IRF fabric and PEX hardware compatibility
Parent IRF fabric
PEX
·     S5560X-EI switch series
·     FS4100 Switch Series
FS4100 switch series
ES4100 switch series
To assign extended ports on multiple PEXs to the same Layer 2 extended-link aggregation group, make sure the PEXs meet the following requirements:
·     The PEXs belong to the same switch series.
·     The PEXs are in the same PEX group.
·     The PEXs are at the same tier.
The FS4100 switch series and ES4100 switch series do not support Layer 2 extended-link aggregate interfaces. You can connect a downstream access device to an FS4100 or ES4100 PEX only through a single link.
On PEXs, only some high-speed ports can act as member interfaces of upstream ports. Before you set up an IRF 3.1 system, use either of the following methods to identify these ports and select upstream member interfaces from among them as needed:
·     If you have not placed the switch in PEX mode, use the virtual technologies configuration guide (or IRF configuration guide) for the switch to identify candidate upstream member interfaces.
·     If the switch has been placed in PEX mode, identify the candidate upstream member interfaces from the CLI:
a.     Execute the probe command to enter probe view.
b.     Execute the display system internal pex upstreamport command.
Table 1 lists the candidate upstream member interfaces on the PEXs to which this example is applicable:
Table 1 Candidate upstream member interfaces on the PEXs
PEX
The two highest numbered ports on the front panel
The two highest numbered 10/100/1000BASE-T autosensing Ethernet ports and the two highest numbered SFP ports.
Make sure the upstream member interfaces belong to the same type.
Procedures
Setting up the parent fabric
1.     Configure Member 1:
# Place the device in 802.1BR mode.
[Sysname] switch-mode 2
# Set the device operating mode to switch mode. This step is required only for setting up an S5560X-EI parent IRF fabric.
[Sysname] pex system-working-mode switch
# Shut down Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Sysname] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[Sysname-if-range] shutdown
[Sysname-if-range] quit
# Bind Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to IRF-port 1/1.
[Sysname] irf-port 1/1
[Sysname-irf-port1/1] port group interface ten-gigabitethernet 1/0/1
[Sysname-irf-port1/1] port group interface ten-gigabitethernet 1/0/2
[Sysname-irf-port1/1] quit
# Bring up Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 and save the configuration.
[Sysname-if-range] undo shutdown
[Sysname] save
# Activate the IRF port configuration.
[Sysname] irf-port-configuration active
2.     Configure Member 2:
# Change the IRF member ID to 2 and reboot the device for the new member ID to take effect.
[Sysname] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[Sysname] quit
<Sysname> reboot
# Log in to the device and shut down Ten-GigabitEthernet 2/0/1 and Ten-GigabitEthernet 2/0/2.
[Sysname] interface range ten-gigabitethernet 2/0/1 to ten-gigabitethernet 2/0/2
# Bind Ten-GigabitEthernet 2/0/1 and Ten-GigabitEthernet 2/0/2 to IRF-port 2/2.
[Sysname] irf-port 2/2
[Sysname-irf-port2/2] port group interface ten-gigabitethernet 2/0/1
[Sysname-irf-port2/2] port group interface ten-gigabitethernet 2/0/2
[Sysname-irf-port2/2] quit
# Bring up Ten-GigabitEthernet 2/0/1 and Ten-GigabitEthernet 2/0/2 and save the configuration.
[Sysname] save
# Connect the IRF physical interfaces on Member 2 to the IRF physical interfaces on Member 1. (Details not shown.)
# Activate the IRF port configuration on Member 2.
Member 1 and Member 2 perform master election. The device that fails the election will reboot automatically to form an IRF fabric with the other device.
Configuring cascade ports for PEXs on the parent fabric
# Enter system view.
# Enable LLDP globally.
[Sysname] lldp global enable
# Create PEX group 1.
[Sysname] pex group 1
[Sysname-pex-group-1] quit
# Create Layer 2 aggregate interface Bridge-Aggregation 100. The aggregate interface will act as the cascade port connecting to the PEX in slot 100. For easy maintenance, this example assigns the aggregate interface the same number as the PEX virtual slot.
[Sysname] interface bridge-aggregation 100
# Enable PEX connection capability on Bridge-Aggregation 100 and assign Bridge-Aggregation 100 to PEX group 1.
[Sysname-Bridge-Aggregation100] pex-capability enable group 1
The aggregate interface was automatically set to dynamic aggregation mode and configured as an STP edge port.
# Assign virtual slot number 100 to the PEX.
[Sysname-Bridge-Aggregation100] pex associate slot 100
[Sysname-Bridge-Aggregation100] quit
# Enable LLDP on Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 2/0/3 in interface range view. By default, LLDP is enabled on a port.
[Sysname] interface range ten-gigabitethernet 1/0/3 ten-gigabitethernet 2/0/3
[Sysname-if-range] lldp enable
# Assign Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 2/0/3 to aggregation group 100. The ports will act as the cascade member interfaces.
[Sysname-if-range] port link-aggregation group 100
# Create Layer 2 aggregate interface Bridge-Aggregation 101. The aggregate interface will act as the cascade port connecting to the PEX in slot 101.
[Sysname] interface bridge-aggregation 101
# Enable PEX connection capability on Bridge-Aggregation 101 and assign the interface to PEX group 1.
[Sysname-Bridge-Aggregation101] pex-capability enable group 1
# Assign virtual slot number 101 to the PEX.
[Sysname-Bridge-Aggregation101] pex associate slot 101
[Sysname-Bridge-Aggregation101] quit
# Enable LLDP on Ten-GigabitEthernet 1/0/4 and Ten-GigabitEthernet 2/0/4 in interface range view. By default, LLDP is enabled on a port.
[Sysname] interface range ten-gigabitethernet 1/0/4 ten-gigabitethernet 2/0/4
# Assign Ten-GigabitEthernet 1/0/4 and Ten-GigabitEthernet 2/0/4 to aggregation group 101. The ports will act as the cascade member interfaces.
[Sysname-if-range] port link-aggregation group 101
Configuring PEXs
Configure the devices to be used as PEXs to operate in auto or PEX mode. This example uses PEX 100 to describe the configuration procedure. You configure PEX 101 in the same way PEX 100 is configured.
1.     Configure PEX 100 to operate in auto mode:
IMPORTANT
IMPORTANT:
Skip this step if the PEXs are FS4100 switches or ES4100 switches.
# Change the operating mode to auto mode. By default, the operating mode is auto.
[Sysname] pex system-working-mode auto
# Save the running configuration.
[Sysname] save
2.     Select upstream member interfaces.
In this example, Ten-GigabitEthernet 1/0/25 and Ten-GigabitEthernet 1/0/26 are used. For information about candidate upstream member interfaces, see the configuration and installation guides for the PEX. (Details not shown.)
3.     Connect the upstream member interfaces on PEX 100 to the cascade member interfaces on the parent fabric as shown in Figure 1. (Details not shown.)
Configuring the gateway settings on the IRF 3.1 system
# Create VLANs 10 and 30.
[Sysname] vlan 10 30
# Create VLAN-interface 10 and assign IP address 192.168.1.1/24 to the VLAN interface.
[Sysname-Vlan-interface10] ip address 192.168.1.1 24
[Sysname-Vlan-interface10] quit
# Create VLAN-interface 30 and assign IP address 192.168.3.1/24 to the VLAN interface.
[Sysname] interface vlan-interface 30
[Sysname-Vlan-interface30] ip address 192.168.3.1 24
[Sysname-Vlan-interface30] quit
# Assign GigabitEthernet 100/0/1 to VLAN 10.
[Sysname] interface gigabitethernet 100/0/1
[Sysname-GigabitEthernet100/0/1] port access vlan 10
[Sysname-GigabitEthernet100/0/1] quit
# Assign GigabitEthernet 101/0/1 to VLAN 30.
[Sysname] interface gigabitethernet 101/0/1
[Sysname-GigabitEthernet101/0/1] port access vlan 30
[Sysname-GigabitEthernet101/0/1] quit
Configuring access layer devices
1.     Configure Device A:
# Create VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3 to VLAN 10.
[Sysname] interface range gigabitethernet 1/0/1 gigabitethernet 1/0/3
[Sysname-if-range] port access vlan 10
2.     Configure Device B:
# Create VLAN 30.
[Sysname] vlan 30
[Sysname-vlan30] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3 to VLAN 30.
[Sysname-if-range] port access vlan 30
# Use the display device command to display device information on the parent fabric. If the IRF 3.1 system has been set up, the system displays information about both parent IRF member devices and PEXs. (Details not shown.)
# Test the gateway service of the IRF 3.1 system. Verify that hosts in VLANs 10 and 30 can ping each other. (Details not shown.)
Configuration files
·     IRF 3.1 system:
 pex group 1
 lldp global enable
vlan 10
vlan 30
irf-port 1/1
 port group interface Ten-GigabitEthernet1/0/1
 port group interface Ten-GigabitEthernet1/0/2
irf-port 2/2
 port group interface Ten-GigabitEthernet2/0/1
 port group interface Ten-GigabitEthernet2/0/2
interface Bridge-Aggregation100
 link-aggregation mode dynamic
 stp edged-port
interface Bridge-Aggregation101
 stp edged-port
interface Vlan-interface10
interface Vlan-interface30
 ip address 192.168.3.1 255.255.255.0
interface GigabitEthernet100/0/1
 port link-mode bridge
 port access vlan 10
interface GigabitEthernet101/0/1
 port access vlan 30
interface Ten-GigabitEthernet1/0/4
interface Ten-GigabitEthernet2/0/3
interface Ten-GigabitEthernet2/0/4
·     Device A:
vlan 10
 port access vlan 10
 port access vlan 10
·     Device B:
vlan 30
 port access vlan 30
 port access vlan 30
