H3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
Table of Contents
Related Documents
47-Static Multicast MAC Address Entry Configuration Examples
H3C S12500R Switch Router Series
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples of static multicast MAC address entries.
This document assumes that you have basic knowledge of multicast MAC addresses.
Example: Configuring static multicast MAC address entries
As shown in Figure 1, Router A runs IGMP and acts as the IGMP querier. Switch A does not run a Layer 2 multicast protocol.
Configure a static multicast MAC address entry on Switch A so that only Host A and Host C can receive multicast data for multicast group 224.1.1.1.
Figure 1 Network diagram
Analysis
Multicast MAC address entries guide Layer 2 multicast forwarding. They can be dynamically created through Layer 2 multicast protocols or manually configured by binding multicast MAC addresses and ports.
In this example, Switch A does not run a Layer 2 multicast protocol. To control destination ports of Layer 2 multicast data, configure a static multicast MAC address entry on Switch A.
Software versions used
This example was created and verified on Release 3606.
You must specify an unused multicast MAC address in a manually configured multicast MAC address entry.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# On Switch A, create VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure HundredGigE 1/0/1 through HundredGigE 1/0/4 to operate in Layer 2 mode, and assign the ports to VLAN 100.
[SwitchA] interface range hundredgige 1/0/1 to hundredgige 1/0/4
[SwitchA-if-range] port access vlan 100
[SwitchA-if-range] quit
# Translate the multicast IP address 224.1.1.1 to a multicast MAC address (0100-5e01-0101). (Details not shown.)
# Create a static entry for the multicast MAC address 0100-5e01-0101 with HundredGigE 1/0/2 and HundredGigE 1/0/4 in VLAN 100 as outgoing ports.
[SwitchA] mac-address multicast 0100-5e01-0101 interface hundredgige 1/0/2 hundredgige 1/0/4 vlan 100
# Display static multicast MAC address entries for VLAN 100 on Switch A.
[SwitchA] display mac-address multicast vlan 100
MAC Address      VLAN ID    State            Port/NickName            Aging
0100-5e01-0101   100        Multicast        HGE1/0/2                 N
                                             HGE1/0/4
The output shows that HundredGigE 1/0/2 and HundredGigE 1/0/4 have become outgoing ports of the multicast MAC group 0100-5e01-0101.
Configuration files
vlan 100
interface HundredGigE1/0/1
 port link-mode bridge
interface HundredGigE1/0/2
interface HundredGigE1/0/3
interface HundredGigE1/0/4
mac-address multicast 0100-5e01-0101 interface HundredGigE1/0/2 HundredGigE1/0/4 vlan 100
Related documentation
·     H3C S12500R Switch Router Series IP Multicast Command Reference-R3606
·     H3C S12500R Switch Router Series IP Multicast Configuration Guide-R3606
