H3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
Table of Contents
Related Documents
19-IPv6 IS-IS Configuration Examples
19-IPv6 IS-IS Configuration Examples 89.32 KB
H3C S12500R Switch Router Series
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides IPv6 IS-IS configuration examples.
This document assumes that you have basic knowledge of IPv6 IS-IS.
Example: Configuring IPv6 IS-IS
As shown in Figure 1, the company's headquarters and the branch run IPv6 IS-IS. The partner runs OSPFv3.
Configure the switches to meet the following requirements:
·     The Marketing department can reach the Finance department, the branch, and the partner.
·     The Finance department and the branch cannot reach each other, and the branch does not have a route to the Finance department.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     Configure Router A and Router B in Area 10 as Level-1 routers to allow communication between the Marketing department and the Finance department.
·     Configure route redistribution between IPv6 IS-IS and OSPFv3 on Router D to allow communication between the Marketing department and the partner.
·     Configure Router C to use a prefix list to advertise only network 3001:1::/64 to Level-2. So that the branch does not have a route to the Finance department.
Software versions used
This configuration example was created and verified on Release 3606.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Router A
# Configure an IPv6 address for HundredGigE 1/0/1.
[RouterA] interface hundredgige 1/0/1
[RouterA-HundredGigE1/0/1] ipv6 address 2001:1::1 64
[RouterA-HundredGigE1/0/1] undo shutdown
[RouterA-HundredGigE1/0/1] quit
# Configure IPv6 addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IPv6 IS-IS.
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] network-entity 10.3001.0001.0001.00
[RouterA-isis-1] address-family ipv6
[RouterA-isis-1-ipv6] quit
[RouterA-isis-1] quit
[RouterA–HundredGigE1/0/1] isis ipv6 enable 1
[RouterA–HundredGigE1/0/1] quit
[RouterA] interface hundredgige 1/0/2
[RouterA–HundredGigE1/0/2] isis ipv6 enable 1
[RouterA–HundredGigE1/0/2] quit
Configuring Router B
<RouterB> system-view
[RouterB] interface hundredgige 1/0/1
[RouterB-HundredGigE1/0/1] ipv6 address 2001:2::1 64
[RouterB-HundredGigE1/0/1] undo shutdown
[RouterB-HundredGigE1/0/1] quit
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] network-entity 10.3001.0002.0001.00
[RouterB-isis-1] address-family ipv6
[RouterB-isis-1-ipv6] quit
[RouterB-isis-1] quit
[RouterB–HundredGigE1/0/1] isis ipv6 enable 1
[RouterB–HundredGigE1/0/1] quit
[RouterB] interface hundredgige 1/0/2
[RouterB–HundredGigE1/0/2] isis ipv6 enable 1
[RouterB–HundredGigE1/0/2] quit
Configuring Router C
# Configure an IPv6 address for HundredGigE1/0/1.
<RouterC> system-view
[RouterC] interface hundredgige 1/0/1
[RouterC-HundredGigE1/0/1] ipv6 address 2001:1::2 64
[RouterC-HundredGigE1/0/1] undo shutdown
[RouterC-HundredGigE1/0/1] quit
[RouterC] isis 1
[RouterC-isis-1] is-level level-1
[RouterC-isis-1] network-entity 10.2001.0010.0001.00
[RouterC-isis-1] address-family ipv6
[RouterC-isis-1-ipv6] quit
[RouterC-isis-1] quit
[RouterC–HundredGigE1/0/1] isis ipv6 enable 1
[RouterC–HundredGigE1/0/1] quit
[RouterC] interface hundredgige 1/0/2
[RouterC–HundredGigE1/0/2] isis ipv6 enable 1
[RouterC–HundredGigE1/0/2] quit
[RouterC] interface hundredgige 1/0/3
[RouterC–HundredGigE1/0/3] isis ipv6 enable 1
[RouterC–HundredGigE1/0/3] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 3001:1::/64 to Level-2.
[RouterC] ipv6 prefix-list 1 permit 3001:1:: 64
[RouterC] isis 1
[RouterC] address-family ipv6
[RouterC-isis-1-ipv6] import-route isisv6 level-1 into level-2 filter-policy prefix-list 1
Configuring Router D
<RouterD> system-view
[RouterD] interface hundredgige 1/0/1
[RouterD-HundredGigE1/0/1] ipv6 address 2001:10::2 64
[RouterD-HundredGigE1/0/1] undo shutdown
[RouterD-HundredGigE1/0/1] quit
[RouterD] isis 1
[RouterD-isis-1] is-level level-2
[RouterD-isis-1] network-entity 20.2001.0020.0001.00
[RouterD-isis-1] address-family ipv6
[RouterD-isis-1-ipv6] quit
[RouterD-isis-1] quit
[RouterD–HundredGigE1/0/1] isis ipv6 enable 1
[RouterD–HundredGigE1/0/1] quit
[RouterD] interface hundredgige 1/0/2
[RouterD–HundredGigE1/0/2] isis ipv6 enable 1
[RouterD–HundredGigE1/0/2] quit
# Configure OSPFv3.
[RouterD] ospfv3
[RouterD-ospfv3-1] router-id 4.4.4.4
[RouterD-ospfv3-1] quit
[RouterD–HundredGigE1/0/2] ospfv3 1 area 0
# Redistribute OSPFv3 and direct routes into IPv6 IS-IS.
[RouterD] isis 1
[RouterD] address-family ipv6
[RouterD-isis-1-ipv6] import-route ospfv3
[RouterD-isis-1-ipv6] import-route direct
# Redistribute IPv6 IS-IS and direct routes into OSPFv3.
[RouterD] ospfv3 1
[RouterD-ospfv3-1] import-route isisv6 1
[RouterD-ospfv3-1] import-route direct
Configuring Router E
<RouterE> system-view
[RouterE] interface hundredgige 1/0/1
[RouterE-HundredGigE1/0/1] ipv6 address 2001:20::2 64
[RouterE-HundredGigE1/0/1] undo shutdown
[RouterE-HundredGigE1/0/1] quit
# Configure OSPFv3.
[RouterE] ospfv3
[RouterE-ospfv3-1] router-id 5.5.5.5
[RouterE-ospfv3-1] quit
[RouterE–HundredGigE1/0/1] ospfv3 1 area 0
[RouterE–HundredGigE1/0/1] quit
[RouterE] interface hundredgige 1/0/2
[RouterE–HundredGigE1/0/2] ospfv3 1 area 0
[RouterE–HundredGigE1/0/2] quit
# Verify that the branch can reach the Marketing department, but cannot reach the Finance department.
[RouterD] display isis route ipv6
                         Level-2 IPv6 Forwarding Table
 Destination : 2001:10::                               PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 10
 Next Hop    : Direct                                  Interface: HGE1/0/1
 Destination : 2001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 20
 Next Hop    : FE80::7625:8AFF:FE02:4D13               Interface: HGE1/0/1
 Destination : 2001:2::                                PrefixLen: 64
 Destination : 3001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 30
# Verify that the company can communicate with the partner.
·     Display the IPv6 IS-IS routing table on Router C.
[RouterC] display isis route ipv6 level-2
 Next Hop    : Direct                                  Interface: HGE1/0/3
 Next Hop    : Direct                                  Interface: HGE1/0/2
 Destination : 2001:20::                               PrefixLen: 64
 Flag        : R/L/-                                   Cost     : 20
 Next Hop    : FE80::BAAF:67FF:FE30:3304               Interface: HGE1/0/3
 Destination : 3001:200::                              PrefixLen: 64
·     Ping 3001:200::1 from Router A.
[RouterA] ping ipv6 –a 3001:1::1 3001:200::1
Ping6(56 data bytes) 3001:1::1 --> 3001:200::1, press CTRL+C to break
56 bytes from 3001:200::1, icmp_seq=0 hlim=63 time=7.230 ms
56 bytes from 3001:200::1, icmp_seq=1 hlim=63 time=3.449 ms
56 bytes from 3001:200::1, icmp_seq=2 hlim=63 time=2.779 ms
56 bytes from 3001:200::1, icmp_seq=3 hlim=63 time=2.652 ms
56 bytes from 3001:200::1, icmp_seq=4 hlim=63 time=2.558 ms
--- Ping6 statistics for 3001:200::1 ---
round-trip min/avg/max/std-dev = 2.558/3.734/7.230/1.776 ms
Configuration files
·     Router A:
isis 1
 is-level level-1
 address-family ipv6 unicast
 isis ipv6 enable 1
 ipv6 address 2001:1::1/64
 isis ipv6 enable 1
 ipv6 address 3001:1::1/64
·     Router B:
isis 1
 is-level level-1
 isis ipv6 enable 1
 ipv6 address 2001:2::1/64
 isis ipv6 enable 1
 ipv6 address 3001:2::1/64
·     Router C:
isis 1
 isis ipv6 enable 1
 ipv6 address 2001:1::2/64
 isis ipv6 enable 1
 ipv6 address 2001:2::2/64
 isis ipv6 enable 1
 ipv6 address 2001:10::1/64
 ipv6 prefix-list 1 index 10 permit 3001:1:: 64
·     Router D:
isis 1
 is-level level-2
 import-route direct
 import-route ospfv3 1
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.0
 import-route direct
 isis ipv6 enable 1
 ipv6 address 2001:10::2/64
 ospfv3 1 area 0.0.0.0
 ipv6 address 2001:20::1/64
·     Router E:
ospfv3 1
 router-id 5.5.5.5
 area 0.0.0.0
 ospfv3 1 area 0
 ipv6 address 2001:20::2/64
 ospfv3 1 area 0
 ipv6 address 3001:200::1/64
Related documentation
·     H3C S12500R Switch Router Series Layer 3—IP Routing Command Reference-R3606
·     H3C S12500R Switch Router Series Layer 3—IP Routing Configuration Guide-R3606
