H3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
Table of Contents
Related Documents
58-NetStream Configuration Examples
58-NetStream Configuration Examples 1.22 MB
H3C S12500R Switch Router Series
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides NetStream statistics analysis configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of NetStream.
Example: Configuring NetStream statistics analysis
As shown in Figure 1, configure NetStream on the device to collect and export traffic statistics as follows:
·     Randomly capture one packet out of every 256 packets (both inbound and outbound) for NetStream traffic statistics collection on HundredGigE 1/0/1.
·     Export the collected traffic statistics to the IMC server with IP address 12.110.2.2/16 and UDP port 6343.
Figure 1 Network diagram
Analysis
To ensure that the device and the IMC server can communicate with each other, add the device to IMC NTA with the correct SNMP community string and port number.
To collect bidirectional traffic statistics on HundredGigE 1/0/1 of the device, enable NetStream for both the inbound and outbound traffic on HundredGigE 1/0/1. Specify a sampler to implement sampled-NetStream as required.
For the device to send NetStream statistics to the IMC server, specify the IMC server with IP address 12.110.2.2/16 and UDP port 6343 as the destination host for NetStream data export.
For the IMC server to analyze the NetStream statistics and generate reports based on the statistics, configure a traffic analysis task in IMC NTA.
Software versions used
This configuration example was created and verified on R3606.
The IMC platform version running on the IMC server is PLAT 7.3 (E0504).
NetStream supports only random sampling. The packets are randomly selected out of a group of packets.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring the device
1.     Configure SNMP:
# Enable the SNMP agent.
[Device] snmp-agent
# Set the read-only community name to public.
[Device] snmp-agent community read public
# Specify the UDP port number for receiving SNMP packets as 161.
[Device] snmp-agent port 161
2.     Create sampler 256 in random sampling mode. Set the sampling rate to 8, which indicates that one packet will be randomly selected out of every 256 packets.
[Device] sampler 256 mode random packet-interval n-power 8
3.     Configure NetStream:
# Enable NetStream sampling for both incoming and outgoing traffic on HundredGigE1/0/1 with sampler 256.
[Device] interface HundredGigE1/0/1
[Device-HundredGigE1/0/1] ip netstream inbound
[Device-HundredGigE1/0/1] ip netstream outbound
[Device-HundredGigE1/0/1] ip netstream inbound sampler 256
[Device-HundredGigE1/0/1] ip netstream outbound sampler 256
[Device-HundredGigE1/0/1] quit
# Specify the IMC server as the NetStream data export destination.
[Device] ip netstream export host 12.110.2.2 6343
Configuring IMC
Adding the device to IMC NTA
1.     Log in to IMC.
2.     Click the Service tab.
3.     From the left navigation pane, select Traffic Analysis and Audit > Settings.
4.     On the Settings page that opens, click Device Management.
The Device Management page opens.
5.     Click Add.
6.     On the Add Device page shown in Figure 2, perform the following steps:
a.     Enter the device IP address (12.110.2.1) in the Device IP field.
b.     Specify the device name, SNMP community name, SNMP port number, and other parameters as needed.
c.     Click OK.
Figure 2 Adding the device to IMC NTA
Deploying NTA server configuration to the device
1.     On the Settings page, click Server Management.
The Server List page opens.
2.     Click the Modify icon icon_modify_16x16.png for the NTA server.
3.     On the Server Configuration page shown in Figure 3, configure the following parameters:
a.     Set port 6343 as the listening port for the server.
b.     Select the device (12.110.2.1) in the Traffic Analysis area.
c.     Use the default settings for other parameters.
d.     Click Deploy.
Figure 3 Server Configuration
Adding a traffic analysis task
1.     On the Settings page, click Traffic Analysis Task Management.
The Traffic Analysis Task Management page opens.
2.     Click Add.
The Select Task Type page opens.
3.     Select Interface and click Next.
The Add Traffic Analysis Task page opens.
4.     In the Basic Information area, configure the following settings:
¡     Task Name—Enter a task name. This example uses Interface.
¡     ServerSelect 127.0.0.1 from the list.
¡     Reader—Click Select next to the Reader field, select the operator groups that have access to the analysis and reports provided by the task, and click OK.
¡     Vlan Analysis—Select Disable from the list.
¡     Baseline Analysis—Select Enable from the list.
The Enable Automatic Anomaly Detection Based On The Baseline parameter and the Baseline Threshold Setting area are displayed.
¡     Enable Automatic Anomaly Detection Based On The Baseline—Select Disable from the list.
¡     Threshold Alarm—Select Enable from the list.
The Threshold Alarm Settings area is displayed.
5.     In the Baseline Threshold Settings area, set the In Threshold to 40% and the Out Threshold to 30%.
6.     In the Threshold Alarm Settings area, set the In Threshold to 50 Mbps and the Out Threshold to 30 Mbps.
7.     In the Interface Information area, click Select and select interface.
8.     Use the default settings for other parameters.
9.     Click OK.
Figure 4 Adding an interface traffic analysis task
Verifying the configuration on the device
# Display NetStream data export information.
[Device] display ip netstream export
IP export information:
  Flow source interface                           : HundredGigE 1/0/1
  Flow destination VPN instance                   : Not specified
  Flow destination IP address (UDP)               : 12.110.2.2 (6343)
  Version 5 exported flow number                  : 0
  Version 5 exported UDP datagram number (failed) : 0 (0)
  Version 9 exported flow number                  : 10
  Version 9 exported UDP datagram number (failed) : 10 (0)
Verifying the configuration on IMC
1.     View the interface traffic analysis task summary reports.
a.     Click the Service tab.
b.     From the left navigation pane, select Traffic Analysis and Audit > Interface Traffic Analysis Task.
The interface traffic analysis task summary reports are displayed, as shown in Figure 5.
Figure 5 Summary reports for interface traffic analysis tasks
2.     View detailed reports for the interface traffic analysis task named Interface:
b.     From the left navigation tree, select Traffic Analysis and Audit > Interface Traffic Analysis Task.
c.     Use either of the following methods to access the report page of interface traffic analysis task Interface:
-     In the Summary List area, click the name of interface traffic analysis task.
-     On the left navigation pane, move your mouse pointer to the shortcut menu icon  next to imc_nta_icon_interface_trafficInterface Traffic Analysis Task, and then select Interface from the menu.
The Traffic tab displays the traffic analysis reports of the task.
Figure 6 Viewing the traffic analysis reports of the task
3.     To view the application usage reports of the task, click the Application tab.
Figure 7 Viewing the application usage reports of the task
4.     To view the source host-based traffic analysis reports of the task, click the Source tab.
Figure 8 Viewing source host-based traffic analysis reports of the task
5.     To view the destination host-based traffic analysis reports of the task, click the Destination tab.
Figure 9 Viewing destination host-based traffic analysis reports of the task
6.     To view the session-based traffic analysis reports of the task, click the Session tab.
Figure 10 Viewing session-based traffic analysis reports of the task
Configuration files
snmp-agent
snmp-agent port 161
interface HundredGigE 1/0/1
 port link-mode route
 ip address 11.110.2.1 255.255.0.0
interface HundredGigE 1/0/2
 ip address 12.110.2.1 255.255.0.0
Related documentation
·     H3C S12500R Switch Router Series Network Management and Monitoring Command Reference-R3606
·     H3C S12500R Switch Router Series Network Management and Monitoring Configuration Guide-R3606
