- H3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-Ethernet Link Aggregation Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-Spanning Tree Configuration Examples
- 07-VLAN Configuration Examples
- 08-VLAN Tagging Configuration Examples
- 09-DHCP Snooping Configuration Examples
- 10-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 12-GRE Tunnel Configuration Examples
- 13-GRE with OSPF Configuration Examples
- 14-OSPF Configuration Examples
- 15-IS-IS Configuration Examples
- 16-BGP Configuration Examples
- 17-Policy-Based Routing Configuration Examples
- 18-OSPFv3 Configuration Examples
- 19-IPv6 IS-IS Configuration Examples
- 20-Routing Policy Configuration Examples
- 21-IGMP Snooping Configuration Examples
- 22-IGMP Configuration Examples
- 23-MLD Snooping Configuration Examples
- 24-Basic MPLS Configuration Examples
- 25-MPLS L3VPN Configuration Examples
- 26-ACL Configuration Examples
- 27-Control Plane-Based QoS Policy Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Priority Mapping and Queue Scheduling Configuration Examples
- 31-Traffic Filtering Configuration Examples
- 32-AAA Configuration Examples
- 33-SSH Configuration Examples
- 34-IP Source Guard Configuration Examples
- 35-Ethernet OAM Configuration Examples
- 36-CFD Configuration Examples
- 37-DLDP Configuration Examples
- 38-VRRP Configuration Examples
- 39-BFD Configuration Examples
- 40-NTP Configuration Examples
- 41-SNMP Configuration Examples
- 42-NQA Configuration Examples
- 43-Mirroring Configuration Examples
- 44-sFlow Configuration Examples
- 45-OpenFlow Configuration Examples
- 46-MAC Address Table Configuration Examples
- 47-Static Multicast MAC Address Entry Configuration Examples
- 48-IP Unnumbered Configuration Examples
- 49-Congestion Avoidance and Queue Scheduling Configuration Examples
- 50-Attack Protection Configuration Examples
- 51-Smart Link Configuration Examples
- 52-RRPP Configuration Examples
- 53-BGP Route Selection Configuration Examples
- 54-IS-IS Route Summarization Configuration Examples
- 55-MPLS OAM Configuration Examples
- 56-MPLS TE Configuration Examples
- 57-VXLAN Configuration Examples
- 58-NetStream Configuration Examples
- 59-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-MPLS SR Configuration Examples
- 63-Puppet Configuration Examples
57-VXLAN Configuration Examples | 250.52 KB |
H3C S12500R Switch Router Series |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Example: Configuring VXLAN Layer 2 forwarding
Configuring IP addresses for interfaces
Configuring a routing protocol on the transport network
Example: Configuring a centralized VXLAN IP gateway
Configuring basic VXLAN settings
Configuring the centralized VXLAN IP gateway
Example: Configuring a centralized VXLAN IP gateway group
Configuring centralized VXLAN IP gateway settings
Specifying the VTEP group as the gateway for access layer VTEPs
Introduction
This document provides Virtual eXtensible LAN (VXLAN) configuration examples. VXLAN is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network. VXLAN is typically used in data centers for multitenant services.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of VXLAN.
Before you can configure VXLANs, you must perform the following tasks:
1. Set the system operating mode to standard by using the system-working-mode standard command. For more information about setting the system operating mode, see device management in Fundamentals Configuration Guide.
2. Save the configuration.
3. Reboot the device.
As shown in Figure 1:
· Configure VXLAN 10 as a unicast-mode VXLAN on Router A, Router B, and Router C to provide Layer 2 connectivity for the VMs across the network sites.
· Manually establish VXLAN tunnels and assign the tunnels to VXLAN 10.
Analysis
To ensure that the routers in the transport network can reach one another, configure a routing protocol on the routers to advertise routes for interfaces, including the loopback interfaces. In this example, OSPF is used.
To assign Router A, Router B, and Router C to a VXLAN network, create VXLAN tunnels on the routers and assign the tunnels to the VXLAN.
To assign customer traffic to a VXLAN, map the interface that receives the customer traffic to the VSI of the VXLAN.
Software versions used
This configuration example was created and verified on Release 3606.
Execute the undo vxlan ip-forwarding command on each VTEP to enable Layer 2 forwarding for VXLANs on the VTEPs.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# Configure IP addresses for interfaces on Router A.
[RouterA] interface hundredgige 1/0/2
[RouterA-HundredGigE1/0/2] ip address 11.1.1.1 24
[RouterA-HundredGigE1/0/2] quit
[RouterA-LoopBack0] ip address 1.1.1.1 32
# Configure IP addresses for interfaces on other routers in the same way the IP addresses are configured on Router A. (Details not shown.)
# Configure OSPF to advertise routes for Router A.
[RouterA] ospf 1 router-id 1.1.1.1
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[RouterA-ospf-1] quit
# Configure OSPF to advertise routes for Router B.
[RouterB] ospf 1 router-id 2.2.2.2
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure OSPF to advertise routes for Router C.
[RouterC] ospf 1 router-id 3.3.3.3
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
# Configure OSPF to advertise routes for Router D.
[RouterD] ospf 1 router-id 4.4.4.4
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
Configuring VXLAN settings
Configuring Router A
# Enable L2VPN.
[RouterA] l2vpn enable
# Enable Layer 2 forwarding for VXLANs.
[RouterA] undo vxlan ip-forwarding
# Create VSI vpna and VXLAN 10.
[RouterA] vsi vpna
[RouterA-vsi-vpna] vxlan 10
[RouterA-vsi-vpna-vxlan10] quit
[RouterA-vsi-vpna] quit
# Create a VXLAN tunnel to Router B. The tunnel interface name is Tunnel 1.
[RouterA] interface tunnel 1 mode vxlan
[RouterA-Tunnel1] source 1.1.1.1
[RouterA-Tunnel1] destination 2.2.2.2
[RouterA-Tunnel1] quit
# Create a VXLAN tunnel to Router C. The tunnel interface name is Tunnel 2.
[RouterA] interface tunnel 2 mode vxlan
[RouterA-Tunnel2] source 1.1.1.1
[RouterA-Tunnel2] destination 3.3.3.3
[RouterA-Tunnel2] quit
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[RouterA] vsi vpna
[RouterA-vsi-vpna-vxlan10] tunnel 1
[RouterA-vsi-vpna-vxlan10] tunnel 2
# Map HundredGigE 1/0/1 to VSI vpna.
[RouterA] interface hundredgige 1/0/1
[RouterA-HundredGigE1/0/1] xconnect vsi vpna
[RouterA-HundredGigE1/0/1] quit
Configuring Router B
# Enable L2VPN.
[RouterB] l2vpn enable
[RouterB] undo vxlan ip-forwarding
[RouterB] vsi vpna
[RouterB-vsi-vpna] vxlan 10
[RouterB-vsi-vpna-vxlan10] quit
[RouterB-vsi-vpna] quit
# Create a VXLAN tunnel to Router A. The tunnel interface name is Tunnel 1.
[RouterB] interface tunnel 1 mode vxlan
[RouterB-Tunnel1] source 2.2.2.2
[RouterB-Tunnel1] destination 1.1.1.1
[RouterB-Tunnel1] quit
[RouterB] interface tunnel 2 mode vxlan
[RouterB-Tunnel2] source 2.2.2.2
[RouterB-Tunnel2] destination 3.3.3.3
[RouterB-Tunnel2] quit
[RouterB] vsi vpna
[RouterB-vsi-vpna-vxlan10] tunnel 1
[RouterB-vsi-vpna-vxlan10] tunnel 2
[RouterB] interface hundredgige 1/0/1
[RouterB-HundredGigE1/0/1] xconnect vsi vpna
[RouterB-HundredGigE1/0/1] quit
Configuring Router C
# Enable L2VPN.
[RouterC] l2vpn enable
[RouterC] undo vxlan ip-forwarding
[RouterC] vsi vpna
[RouterC-vsi-vpna] vxlan 10
[RouterC-vsi-vpna-vxlan10] quit
[RouterC-vsi-vpna] quit
[RouterC] interface tunnel 1 mode vxlan
[RouterC-Tunnel1] source 3.3.3.3
[RouterC-Tunnel1] destination 1.1.1.1
[RouterC-Tunnel1] quit
# Create a VXLAN tunnel to Router B. The tunnel interface name is Tunnel 2.
[RouterC] interface tunnel 2 mode vxlan
[RouterC-Tunnel2] source 3.3.3.3
[RouterC-Tunnel2] destination 2.2.2.2
[RouterC-Tunnel2] quit
[RouterC] vsi vpna
[RouterC-vsi-vpna-vxlan10] tunnel 1
[RouterC-vsi-vpna-vxlan10] tunnel 2
[RouterC] interface hundredgige 1/0/1
[RouterC-HundredGigE1/0/1] xconnect vsi vpna
[RouterC-HundredGigE1/0/1] quit
1. Verify the VXLAN settings on the VTEPs. This example uses Router A.
# Verify that the VXLAN tunnel interfaces on the VTEP are in up state.
[RouterA] display interface tunnel
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel2
Current state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 3.3.3.3
# Verify that the VXLAN tunnels have been assigned to the VXLAN, and the VXLAN tunnels and Ethernet service instances are in up state.
[RouterA] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : Unlimited
Broadcast Restrain : 4294967295 kbps
Multicast Restrain : 4294967295 kbps
Unknown Unicast Restrain: 4294967295 kbps
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Local MAC aging time : 300 sec
Remote MAC aging time : 300 sec
Drop Unknown : -
PW Redundancy Mode : Slave
Flooding : Enabled
Statistics : Disabled
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel1 0x5000001 Up Manual Disabled
Tunnel2 0x5000002 Up Manual Disabled
ACs:
AC Link ID State Type
HGE1/0/1 0 Up Manual
# Verify that the VTEP has learned the MAC addresses of remote VMs.
[RouterA] display l2vpn mac-address
MAC Address State VSI Name Link ID/Name Aging
cc3e-5f9c-6cdb Dynamic vpna Tunnel1 Aging
cc3e-5f9c-23dc Dynamic vpna Tunnel2 Aging
--- 2 mac address(es) found ---
2. Verify that VM 1, VM 2, and VM 3 can ping each other. (Details not shown.)
Configuration files
· Router A:
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
interface HundredGigE1/0/1
xconnect vsi vpna
interface HundredGigE1/0/2
ip address 11.1.1.1 255.255.255.0
interface Tunnel1 mode vxlan
source 1.1.1.1
destination 2.2.2.2
interface Tunnel2 mode vxlan
source 1.1.1.1
destination 3.3.3.3
return
· Router B:
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
xconnect vsi vpna
ip address 12.1.1.2 255.255.255.0
source 2.2.2.2
destination 1.1.1.1
source 2.2.2.2
destination 3.3.3.3
return
· Router C:
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
xconnect vsi vpna
ip address 13.1.1.3 255.255.255.0
source 3.3.3.3
destination 1.1.1.1
source 3.3.3.3
destination 2.2.2.2
return
· Router D:
area 0.0.0.0
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 11.1.1.4 255.255.255.0
ip address 13.1.1.4 255.255.255.0
interface HundredGigE1/0/3
ip address 12.1.1.4 255.255.255.0
return
As shown in Figure 2:
· Configure VXLAN 10 and VXLAN 20 as unicast-mode VXLANs on Router A, Router B, and Router C.
· Manually establish VXLAN tunnels and assign the tunnels to VXLAN 10 or VXLAN 20. Make sure VM 1 and VM 3 belong to VXLAN 10 and VM 2 and VM 4 belong to VXLAN 20.
· Configure a centralized VXLAN IP gateway on Router C to provide gateway services for VXLAN 10 and VXLAN 20.
Analysis
To assign Router A, Router B, and Router C to VXLANs, create VXLAN tunnels on the routers and assign the tunnels to the VXLANs.
For Router C to provide centralized VXLAN IP gateway services for VXLANs, you must perform the following tasks:
· Create a VSI interface for each VXLAN on the router.
· Assign an IP address to each VSI interface.
· Specify the VSI interfaces as the gateway interfaces for VXLANs.
For Layer 3 nodes in the transport network to reach the VMs, configure a routing protocol on Router C to advertise routes for VSI interfaces and HundredGigE 1/0/1. In this example, OSPF is used.
Procedures
[RouterA-HundredGigE1/0/2] ip address 20.1.1.1 24
# Configure IP addresses for interfaces on other devices in the same way the IP addresses are configured on Router A. (Details not shown.)
[RouterA-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
# Enable L2VPN.
[RouterA] vsi vpna
# Create VSI vpnb and VXLAN 20.
[RouterA] vsi vpnb
[RouterA-vsi-vpnb] vxlan 20
[RouterA-vsi-vpnb-vxlan10] quit
[RouterA-vsi-vpnb] quit
[RouterA] vsi vpna
# Assign Tunnel 1 and Tunnel 2 to VXLAN 20.
[RouterA] vsi vpnb
[RouterA-vsi-vpnb-vxlan20] tunnel 1
[RouterA-vsi-vpnb-vxlan20] tunnel 2
[RouterA-vsi-vpnb-vxlan20] quit
# Map HundredGigE 1/0/3 to VSI vpnb.
[RouterA] interface hundredgige 1/0/3
[RouterA-HundredGigE1/0/3] xconnect vsi vpnb
[RouterA-HundredGigE1/0/3] quit
# Enable L2VPN.
[RouterB] vsi vpna
[RouterB] vsi vpnb
[RouterB-vsi-vpnb] vxlan 20
[RouterB-vsi-vpnb-vxlan10] quit
[RouterB-vsi-vpnb] quit
[RouterB] vsi vpna
[RouterB] vsi vpnb
[RouterB-vsi-vpnb-vxlan20] tunnel 1
[RouterB-vsi-vpnb-vxlan20] tunnel 2
[RouterB-vsi-vpnb-vxlan20] quit
[RouterB] interface hundredgige 1/0/3
[RouterB-HundredGigE1/0/3] xconnect vsi vpnb
[RouterB-HundredGigE1/0/3] quit
# Enable L2VPN.
[RouterC] vsi vpna
[RouterC] vsi vpnb
[RouterC-vsi-vpnb] vxlan 20
[RouterC-vsi-vpnb-vxlan10] quit
[RouterC-vsi-vpnb] quit
[RouterC] vsi vpna
[RouterC] vsi vpnb
[RouterC-vsi-vpnb-vxlan20] tunnel 1
[RouterC-vsi-vpnb-vxlan20] tunnel 2
[RouterC-vsi-vpnb-vxlan20] quit
# Create VSI-interface 1 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 10.
[RouterC] interface vsi-interface 1
[RouterC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterC-Vsi-interface1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[RouterC] vsi vpna
[RouterC-vsi-vpna] gateway vsi-interface 1
# Create VSI-interface 2 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 20.
[RouterC] interface vsi-interface 2
[RouterC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterC-Vsi-interface2] quit
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[RouterC] vsi vpnb
[RouterC-vsi-vpnb] gateway vsi-interface 2
# Configure OSPF to advertise routes for the VSI interfaces and HundredGigE 1/0/1.
[RouterC] ospf 2 router-id 3.3.3.3
[RouterC-ospf-2] area 0
[RouterC-ospf-2-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterC-ospf-2-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[RouterC-ospf-2-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[RouterC-ospf-2-area-0.0.0.0] quit
[RouterC-ospf-2] quit
# Verify that the VXLAN tunnel interfaces are in up state.
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel2
Current state: UP
Bandwidth: 64 kbps
# Verify that the VXLAN tunnels have been assigned to their respective VXLANs, and the VXLAN tunnels and Ethernet service instances are in up state.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
ACs:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
HGE1/0/3 0 Up Manual
2. Verify the configuration on the VXLAN IP gateway:
[RouterC] display interface tunnel
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 1.1.1.1
Tunnel2
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 2.2.2.2
# Verify that the VSI interfaces are in up state.
[RouterC] display interface vsi-interface
Vsi-interface1
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
Internet Address: 10.1.1.1/24 (primary)
IP packet frame type: Ethernet II, hardware address: 0000-fc00-458d
IPv6 packet frame type: Ethernet II, hardware address: 0000-fc00-458d
Vsi-interface2
Current state: UP
Description: Vsi-interface2 Interface
Internet Address: 10.1.2.1/24 (primary)
# Verify that the VXLAN tunnels have been assigned to VXLANs 10 and 20, VSI-interface 1 is the gateway interface of VSI vpna, and VSI-interface 2 is the gateway interface of VSI vpnb.
[RouterC] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway interface : VSI-interface 1
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flooding proxy
Tunnel1 0x5000002 Up Manual Disabled
Tunnel2 0x5000003 Up Manual Disabled
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway interface : VSI-interface 2
VXLAN ID : 20
Tunnels:
# Verify that Router C has created ARP entries for the VMs.
[RouterC] display arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI name Interface Aging Type
10.1.1.11 0000-1234-0001 N/A Tunnel1 20 D
10.1.1.12 0000-1234-0002 N/A Tunnel2 19 D
# Verify that Router C has created FIB entries for the VMs.
[RouterC] display fib 10.1.1.11
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
10.1.1.11/32 10.1.1.11 UH Vsi1 Null
3. Verify the network connectivity for VMs:
# Verify that VM 1, VM 2, VM 3, and VM 4 can ping each other. (Details not shown.)
# Verify that VM 1, VM 2, VM 3, VM 4, and HundredGigE 1/0/1 (100.1.1.1) on Router C can ping each other. (Details not shown.)
Configuration files
· Router A:
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
xconnect vsi vpna
ip address 20.1.1.1 255.255.255.0
xconnect vsi vpnb
source 1.1.1.1
destination 2.2.2.2
source 1.1.1.1
destination 3.3.3.3
· Router B:
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
xconnect vsi vpna
ip address 30.1.1.2 255.255.255.0
xconnect vsi vpnb
source 2.2.2.2
destination 1.1.1.1
source 2.2.2.2
destination 3.3.3.3
· Router C:
area 0.0.0.0
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
ip address 100.1.1.1 255.255.255.0
ip address 40.1.1.3 255.255.255.0
interface Vsi-interface1
interface Vsi-interface2
source 3.3.3.3
destination 1.1.1.1
source 3.3.3.3
destination 2.2.2.2
return
· Router D:
area 0.0.0.0
interface LoopBack0
ip address 20.1.1.4 255.255.255.0
ip address 30.1.1.4 255.255.255.0
ip address 40.1.1.4 255.255.255.0
return
As shown in Figure 3:
· Configure VXLAN 10 and VXLAN 20 as unicast-mode VXLANs on Router A, Router B, Router C, and Router D.
· Assign Router C and Router D to a VTEP group to provide gateway services for VXLAN 10 and VXLAN 20.
Analysis
To assign Router A, Router B, Router C, and Router D to VXLANs, create VXLAN tunnels on the routers and assign the tunnels to the VXLANs.
For Router C and Router D to act as centralized VXLAN IP gateways, you must perform the following tasks:
· Create a VSI interface for each VXLAN on the routers.
For Layer 3 nodes in the transport network to reach the VMs, configure a routing protocol on Router C and Router D to advertise routes for VSI interfaces and HundredGigE 1/0/1. In this example, OSPF is used.
Make sure all VTEPs in the VTEP group have consistent VXLAN configuration.
Procedures
[RouterC-ospf-1-area-0.0.0.0] network 8.8.8.8 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] network 8.8.8.8 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
# Configure OSPF to advertise routes for Router E.
[RouterE] ospf 1 router-id 5.5.5.5
[RouterE-ospf-1] area 0
[RouterE-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[RouterE-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] quit
[RouterE-ospf-1] quit
# Enable L2VPN.
[RouterA] vsi vpna
[RouterA] vsi vpnb
# Create a VXLAN tunnel to the VTEP group. The tunnel interface name is Tunnel 1.
[RouterA-Tunnel1] destination 8.8.8.8
[RouterA-Tunnel2] destination 2.2.2.2
[RouterA] vsi vpna
[RouterA] vsi vpnb
# Enable L2VPN.
[RouterB] vsi vpna
[RouterB] vsi vpnb
[RouterB-Tunnel1] destination 8.8.8.8
# Create a VXLAN tunnel to Router A. The tunnel interface name is Tunnel 2.
[RouterB-Tunnel2] destination 1.1.1.1
[RouterB] vsi vpna
[RouterB] vsi vpnb
# Enable L2VPN.
[RouterC] vsi vpna
[RouterC] vsi vpnb
# Create a VXLAN tunnel for the VTEP group to Router A. The tunnel source IP address is 8.8.8.8, and the tunnel interface name is Tunnel 1.
[RouterC-Tunnel1] source 8.8.8.8
# Create a VXLAN tunnel for the VTEP group to Router B. The tunnel source IP address is 8.8.8.8, and the tunnel interface name is Tunnel 2.
[RouterC-Tunnel2] source 8.8.8.8
[RouterC] vsi vpna
[RouterC] vsi vpnb
Configuring Router D
# Enable L2VPN.
[RouterD] l2vpn enable
[RouterD] vsi vpna
[RouterD-vsi-vpna] vxlan 10
[RouterD-vsi-vpna-vxlan10] quit
[RouterD-vsi-vpna] quit
[RouterD] vsi vpnb
[RouterD-vsi-vpnb] vxlan 20
[RouterD-vsi-vpnb-vxlan10] quit
[RouterD-vsi-vpnb] quit
[RouterD] interface tunnel 1 mode vxlan
[RouterD-Tunnel1] source 8.8.8.8
[RouterD-Tunnel1] destination 1.1.1.1
[RouterD-Tunnel1] quit
[RouterD] interface tunnel 2 mode vxlan
[RouterD-Tunnel2] source 8.8.8.8
[RouterD-Tunnel2] destination 2.2.2.2
[RouterD-Tunnel2] quit
[RouterD] vsi vpna
[RouterD-vsi-vpna-vxlan10] tunnel 1
[RouterD-vsi-vpna-vxlan10] tunnel 2
[RouterD] vsi vpnb
[RouterD-vsi-vpnb-vxlan20] tunnel 1
[RouterD-vsi-vpnb-vxlan20] tunnel 2
[RouterD-vsi-vpnb-vxlan20] quit
# Create VSI-interface 1 and assign the interface an IP address and a MAC address. The IP address will be used as the gateway address for VXLAN 10.
[RouterC-Vsi-interface1] mac-address 1-1-1
# Enable periodic sending of gratuitous ARP packets on VSI-interface 1.
[RouterC-Vsi-interface1] arp send-gratuitous-arp interval 200000
[RouterC] vsi vpna
# Create VSI-interface 2 and assign the interface an IP address and a MAC address. The IP address will be used as the gateway address for VXLAN 20.
[RouterC-Vsi-interface2] mac-address 2-2-2
# Enable periodic sending of gratuitous ARP packets on VSI-interface 2.
[RouterC-Vsi-interface2] arp send-gratuitous-arp interval 200000
[RouterC] vsi vpnb
[RouterD] interface vsi-interface 1
[RouterD-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[RouterD-Vsi-interface1] mac-address 1-1-1
[RouterD-Vsi-interface1] arp send-gratuitous-arp interval 200000
[RouterD-Vsi-interface1] quit
[RouterD] vsi vpna
[RouterD-vsi-vpna] gateway vsi-interface 1
[RouterD] interface vsi-interface 2
[RouterD-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[RouterD-Vsi-interface2] mac-address 2-2-2
[RouterD-Vsi-interface2] arp send-gratuitous-arp interval 200000
[RouterD-Vsi-interface2] quit
[RouterD] vsi vpnb
[RouterD-vsi-vpnb] gateway vsi-interface 2
[RouterD] ospf 2 router-id 4.4.4.4
[RouterD-ospf-2] area 0
[RouterD-ospf-2-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterD-ospf-2-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[RouterD-ospf-2-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[RouterD-ospf-2-area-0.0.0.0] quit
[RouterD-ospf-2] quit
Configuring the VTEP group
Configuring member VTEP Router C
# Assign Router C to VTEP group 8.8.8.8, and specify the member IP address of Router C as 3.3.3.3.
[RouterC] vtep group 8.8.8.8 member local 3.3.3.3
# Specify the other member VTEP in the VTEP group.
[RouterC] vtep group 8.8.8.8 member remote 4.4.4.4
Configuring member VTEP Router D
# Assign Router D to VTEP group 8.8.8.8, and specify the member IP address of Router D as 4.4.4.4.
[RouterD] vtep group 8.8.8.8 member local 4.4.4.4
[RouterD] vtep group 8.8.8.8 member remote 3.3.3.3
Configuring access layer VTEP Router A
# Specify VTEP group 8.8.8.8 and its member VTEPs at 3.3.3.3 and 4.4.4.4.
[RouterA] vtep group 8.8.8.8 member remote 3.3.3.3 4.4.4.4
Configuring access layer VTEP Router B
[RouterB] vtep group 8.8.8.8 member remote 3.3.3.3 4.4.4.4
# Verify that the VXLAN tunnel interfaces are in up state. Tunnel 1 and Tunnel 2 are manual tunnels, and Tunnel 3 and Tunnel 4 are VXLAN tunnels automatically established between the VTEP and each VXLAN IP gateway.
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 8.8.8.8
Tunnel2
Current state: UP
Bandwidth: 64 kbps
Tunnel3
Current state: UP
Description: Tunnel3 Interface
Bandwidth: 64 kbps
Tunnel4
Current state: UP
Description: Tunnel4 Interface
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 4.4.4.4
# Verify that the VXLAN tunnels have been assigned to VXLAN 10 and VXLAN 20, and the Ethernet service instances have been mapped to VSIs vpna and vpnb.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
Tunnel3 0x5000003 Up Auto Disabled
Tunnel4 0x5000004 Up Auto Disabled
ACs:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
2. Verify the basic VXLAN settings and VXLAN IP gateway settings on VXLAN IP gateways. This example uses Router C.
# Verify that the VXLAN tunnel interfaces are in up state on Router C.
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 8.8.8.8, destination 1.1.1.1
Tunnel2
Current state: UP
Bandwidth: 64 kbps
Tunnel source 8.8.8.8, destination 2.2.2.2
# Verify that the VSI interfaces are in up state on Router C.
Vsi-interface1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 0001-0001-0001
IPv6 packet frame type: Ethernet II, hardware address: 0001-0001-0001
Vsi-interface2
Current state: UP
IP packet frame type: Ethernet II, hardware address: 0002-0002-0002
IPv6 packet frame type: Ethernet II, hardware address: 0002-0002-0002
# Verify that the VXLAN tunnels have been assigned to VXLANs 10 and 20, VSI-interface 1 is the gateway interface for VSI vpna, and VSI-interface 2 is the gateway interface for VSI vpnb.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
Flag:
R:Relay F:FRR
# Verify that Router D has created the same ARP entries and FIB entries for the VMs as Router C.
[RouterD] display arp
[RouterD] display fib 10.1.1.11
Flag:
R:Relay F:FRR
# Verify that VM 1, VM 2, VM 3, and VM 4 can ping HundredGigE 1/0/1 on Router C (100.1.1.3) and Router D (100.1.1.4). (Details not shown.)
Configuration files
· Router A:
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
xconnect vsi vpna
xconnect vsi vpnb
source 1.1.1.1
destination 8.8.8.8
source 1.1.1.1
destination 2.2.2.2
· Router B:
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
xconnect vsi vpna
xconnect vsi vpnb
source 2.2.2.2
destination 8.8.8.8
source 2.2.2.2
destination 1.1.1.1
· Router C:
area 0.0.0.0
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface LoopBack1
ip address 8.8.8.8 255.255.255.255
ip address 100.1.1.3 255.255.255.0
mac-address 0001-0001-0001
mac-address 0002-0002-0002
source 8.8.8.8
destination 1.1.1.1
source 8.8.8.8
destination 2.2.2.2
return
· Router D:
area 0.0.0.0
area 0.0.0.0
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface LoopBack1
ip address 100.1.1.4 255.255.255.0
ip address 50.1.1.4 255.255.255.0
source 8.8.8.8
destination 1.1.1.1
source 8.8.8.8
destination 2.2.2.2
return
· Router E:
area 0.0.0.0
interface LoopBack0
ip address 5.5.5.5 255.255.255.255
ip address 20.1.1.5 255.255.255.0
ip address 30.1.1.5 255.255.255.0
ip address 40.1.1.5 255.255.255.0
interface HundredGigE1/0/4
ip address 50.1.1.5 255.255.255.0
return
Related documentation
· H3C S12500R Switch Router Series VXLAN Command Reference-R3606
· H3C S12500R Switch Router Series VXLAN Configuration Guide-R3606
