H3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration ExamplesH3C S12500R Ethernet Switch Router Series Config Examples-Release 36xx-6W100
Table of Contents
Related Documents
61-S-MLAG Configuration Examples
61-S-MLAG Configuration Examples 110.37 KB
H3C S12500R Switch Router Series
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples for using simple multichassis link aggregation (S-MLAG).
S-MLAG enhances dynamic link aggregation to establish an aggregation that spans multiple standalone devices to a remote device.
The following information is provided based on the assumption that you have basic knowledge of S-MLAG.
Example: Configuring S-MLAG
Device B, Device C, and Device D are standalone devices. As shown in Figure 1, configure Device B, Device C, and Device D as S-MLAG devices to establish a multidevice aggregate link with Device A.
Figure 1 Network diagram
Analysis
To establish a multidevice aggregate link with Device A, you must perform the following tasks on Device B, Device C, and Device D:
1.     Create a Layer 2 dynamic aggregate interface and assign HundredGigE 1/0/1 to its aggregation group.
2.     Assign the aggregate interfaces to the same DR group.
Software versions used
This configuration example was created and verified on Release 3606.
Before you assign an interface to an aggregation group, use the display this command in interface view to identify whether attribute settings exist, including port isolation, VLAN, and VLAN mapping settings. If attribute settings exist, use the corresponding undo commands to remove them.
Configure the link aggregation settings other than S-MLAG settings on each S-MLAG device. Make sure the settings are consistent across the S-MLAG devices.
As a best practice, maintain consistency across S-MLAG devices in service feature configuration.
Procedures
Configuring Device A
# Create Layer 2 aggregate interface Bridge-Aggregation 10, and set the link aggregation mode to dynamic.
[DeviceA] interface bridge-aggregation 10
[DeviceA-Bridge-Aggregation10] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation10] quit
# Assign HundredGigE 1/0/1 through HundredGigE 1/0/3 to aggregation group 10.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] port link-aggregation group 10
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port link-aggregation group 10
[DeviceA-HundredGigE1/0/2] quit
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] port link-aggregation group 10
[DeviceA-HundredGigE1/0/3] quit
Configuring Device B
# Set the LACP system MAC address to 0001-0001-0001.
[DeviceB] lacp system-mac 1-1-1
# Set the LACP system priority to 123.
[DeviceB] lacp system-priority 123
# Set the LACP system number to 1.
[DeviceB] lacp system-number 1
# Create Layer 2 aggregate interface Bridge-Aggregation 2, and set the link aggregation mode to dynamic.
[DeviceB] interface bridge-aggregation 2
[DeviceB-Bridge-Aggregation2] link-aggregation mode dynamic
# Assign Bridge-Aggregation 2 to S-MLAG group 100.
[DeviceB-Bridge-Aggregation2] port s-mlag group 100
[DeviceB-Bridge-Aggregation2] quit
# Assign HundredGigE 1/0/1 to aggregation group 2.
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port link-aggregation group 2
[DeviceB-HundredGigE1/0/1] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] lacp system-mac 1-1-1
[DeviceC] lacp system-priority 123
# Set the LACP system number to 2.
[DeviceC] lacp system-number 2
# Create Layer 2 aggregate interface Bridge-Aggregation 3, and set the link aggregation mode to dynamic.
[DeviceC] interface bridge-aggregation 3
[DeviceC-Bridge-Aggregation3] link-aggregation mode dynamic
# Assign Bridge-Aggregation 3 to S-MLAG group 100.
[DeviceC-Bridge-Aggregation3] port s-mlag group 100
# Assign HundredGigE 1/0/1 to aggregation group 3.
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] port link-aggregation group 3
[DeviceC-HundredGigE1/0/1] quit
Configuring Device D
<DeviceD> system-view
[DeviceD] lacp system-mac 1-1-1
[DeviceD] lacp system-priority 123
# Set the LACP system number to 3.
[DeviceD] lacp system-number 3
# Create Layer 2 aggregate interface Bridge-Aggregation 4, and set the link aggregation mode to dynamic.
[DeviceD] interface bridge-aggregation 4
[DeviceD-Bridge-Aggregation4] link-aggregation mode dynamic
# Assign Bridge-Aggregation 4 to S-MLAG group 100.
[DeviceD-Bridge-Aggregation4] port s-mlag group 100
# Assign HundredGigE 1/0/1 to aggregation group 4.
[DeviceD] interface hundredgige 1/0/1
[DeviceD-HundredGigE1/0/1] port link-aggregation group 4
[DeviceD-HundredGigE1/0/1] quit
# Verify that HundredGigE 1/0/1 through HundredGigE 1/0/3 on Device A are Selected ports.
[DeviceA] display link-aggregation verbose
Port: A -- Auto port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Role: P -- Primary, S – Secondary
Aggregate Interface: Bridge-Aggregation10
Aggregation Mode: Dynamic
System ID: 0x8000, a0c7-9afd-0100
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  HGE1/0/1            S        32768    1        1                      {ACDEF}
  HGE1/0/2            S        32768    2        1                      {ACDEF}
  HGE1/0/3            S        32768    3        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  HGE1/0/1            32768    16385    50100    0x7b  , 0001-0001-0001 {ACDEF}
  HGE1/0/2            32768    32769    50100    0x7b  , 0001-0001-0001 {ACDEF}
  HGE1/0/3            32768    49153    50100    0x7b  , 0001-0001-0001 {ACDEF}
Configuration files
·     Device A:
interface Bridge-Aggregation10
interface HundredGigE1/0/1
 port link-mode bridge
interface HundredGigE1/0/2
interface HundredGigE1/0/3
·     Device B:
 lacp system-mac 0001-0001-0001
interface Bridge-Aggregation2
·     Device C:
interface Bridge-Aggregation3
·     Device D:
interface Bridge-Aggregation4
Example: Establishing a multidevice aggregate link with a server
Device A, Device B, and Device C are standalone devices. As shown in Figure 2, configure Device A, Device B, and Device C as S-MLAG devices to establish a multidevice aggregate link with the server. On Device A, Device B, and Device C, configure the server-facing aggregate interfaces as edge aggregate interfaces.
Figure 2 Network diagram
Analysis
To establish a multidevice aggregate link with the server, you must perform the following tasks on Device A, Device B, and Device C:
Procedures
[DeviceA] lacp system-mac 1-1-1
[DeviceA] lacp system-priority 123
[DeviceA] lacp system-number 1
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and set the link aggregation mode to dynamic.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Configure Bridge-Aggregation 1 as an edge aggregate interface.
[DeviceA-Bridge-Aggregation1] lacp edge-port
# Assign Bridge-Aggregation 1 to S-MLAG group 100.
[DeviceA-Bridge-Aggregation1] port s-mlag group 100
[DeviceA-Bridge-Aggregation1] quit
# Assign HundredGigE 1/0/1 to aggregation group 1.
[DeviceB] lacp system-number 2
[DeviceC-Bridge-Aggregation2] link-aggregation mode dynamic
# Configure Bridge-Aggregation 2 as an edge aggregate interface.
[DeviceB-Bridge-Aggregation2] lacp edge-port
[DeviceC] lacp system-number 3
# Configure Bridge-Aggregation 3 as an edge aggregate interface.
[DeviceC-Bridge-Aggregation3] lacp edge-port
# Verify that the aggregation member ports on Device A, Device B, and Device C are working in Individual state when dynamic link aggregation is not configured on the server.
System ID: 0x7b, 0001-0001-0001
Local:
  HGE1/0/1            I        32768    16385    50100                  {AG}
Remote:
  HGE1/0/1            32768    0        0        0x8000, 0000-0000-0000 {DEF}
[DeviceB] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation2
Local:
  HGE1/0/1            I        32768    32769    50100                  {AG}
Remote:
[DeviceC] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation3
Local:
  HGE1/0/1            I        32768    49153    50100                  {AG}
Remote:
# Verify that the aggregation member ports on Device A, Device B, and Device C are working in Selected state after dynamic link aggregation is configured on the server.
Local:
  HGE1/0/1            S        32768    16385    50100                  {ACDEF}
Remote:
  HGE1/0/1            32768    1        1        0x8000, 5022-e533-0400 {ACDEF}
Local:
  HGE1/0/1            S        32768    32769    50100                  {ACDEF}
Remote:
  HGE1/0/1            32768    2        1        0x8000, 5022-e533-0400 {ACDEF}
Local:
  HGE1/0/1            S        32768    49153    50100                  {ACDEF}
Remote:
  HGE1/0/1            32768    3        1        0x8000, 5022-e533-0400 {ACDEF}
Configuration files
·     Device A:
 lacp edge-port
·     Device B:
 lacp edge-port
·     Device C:
 lacp edge-port
Related documentation
·     H3C S12500R Switch Router Series Layer 2—LAN Switching Command Reference-R3606
·     H3C S12500R Switch Router Series Layer 2—LAN Switching Configuration Guide-R3606
