- 05-Web configuration examples (AC+fit AP)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
29-Dynamic IPv6 DNS Configuration Example | 103.16 KB |
H3C Access Controllers |
Comware 7 Dynamic IPv6 DNS |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring dynamic IPv6 DNS to allow users to access a host.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of DNS.
Example: Configuring dynamic IPv6 DNS
As shown in Figure 1, configure the DNS server to store the mapping between the host's domain name host and IPv6 address 1::1/64 in the com domain. Configure dynamic IPv6 domain name resolution and specify the DNS suffix as com on the AC so that the client can use domain name host to access the host.
Configure static routes or a dynamic routing protocol on all devices to make sure the network connections are available.
Procedures
Configuring the DNS server
On the DNS server, configure the mapping between the host's domain name host and IPv6 address 1::1/64 in the com domain. (Details not shown.)
Configuring the DNS client
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Network Services > DHCP/DNS.
3. Click the IPv6 DNS tab.
4. Specify 2::2 as the IPv6 DNS server IP address.
Figure 2 Specifying the IPv6 DNS server IP address
5. Click the Add icon .
6. Click the Advanced settings button .
7. Enter domain name suffix com.
Figure 3 Configuring the DNS suffix
8. Click the Add icon .
# Verify that the AC can use the dynamic domain name resolution to resolve domain name host.com into IPv6 address 1::1.
<AC> ping host
Ping6(56 data bytes) 2::1 --> 1::1, press CTRL_C to break
56 bytes from 1::1, icmp_seq=0 hlim=128 time=1.653 ms
56 bytes from 1::1, icmp_seq=1 hlim=128 time=0.529 ms
56 bytes from 1::1, icmp_seq=2 hlim=128 time=0.452 ms
56 bytes from 1::1, icmp_seq=3 hlim=128 time=0.460 ms
56 bytes from 1::1, icmp_seq=4 hlim=128 time=0.422 ms
--- Ping6 statistics for host.com ---
round-trip min/avg/max/std-dev = 0.422/0.703/1.653/0.476 ms
Related documentation
H3C Access Controllers Web-Based Configuration Guide
