- 05-Web configuration examples (AC+fit AP)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
14-Static IPv6 Address Configuration Example | 76.46 KB |
H3C Access Controllers |
Comware 7 Static IPv6 Address |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following information provides an example for configuring a static IPv6 address to a VLAN interface to support IPv6 communication between the clients and the AC.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of IPv6 basics and WLAN access features.
Example: Configuring a static IPv6 address
As shown in Figure 1, assign the AP and the AC to VLAN 10 and configure a global unicast IPv6 address 2001::1/64 for VLAN-interface 10 of the AC. Install IPv6 on the client to enable the client to generate an IPv6 address through stateless address autoconfiguration.
Procedures
1. Configure basic wireless functions on the AC, including WLAN access services and radio functions. (Details not shown.)
2. Assign IPv6 address 2001::1/64 to VLAN-interface 10:
a. Click the System View tab at the bottom of the page.
b. From the navigation pane, select Network Configuration > Network Interfaces.
c. Click the Edit button for
VLAN-interface 10.
d. Set the IPv6 address to 2001::1 and set the prefix length to 64.
Figure 2 Assigning an IPv6 address to VLAN-interface 10
e. Click Apply.
3. Configure VLAN-interface 10 to advertise RA messages.
b. From the navigation pane, select Network Configuration > Network Services > ND.
c. Click the Advanced settings
button .
d. Click the Expand icon for
RA settings.
e. Enable RA message advertisement for VLAN-interface 10.
f. Click Apply.
4. Install IPv6 on the client. The client automatically generates an IPv6 address based on the address prefix information contained in the RA message.
Verify that the client and the AC can ping each other. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
