- 05-Web configuration examples (AC+fit AP)
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
- 09-Licensing Configuration Example
- 10-Automatic License Installation Configuration Example
- 11-Layer 2 Static Link Aggregation Configuration Example
- 12-Layer 2 Dynamic Link Aggregation Configuration Example
- 13-PPPoE Client Configuration Example
- 14-Static IPv6 Address Configuration Example
- 15-IPv6 Static Routing Configuration Example
- 16-Static IPv4 DNS Configuration Example
- 17-Static IPv6 DNS Configuration Example
- 18-IGMP Snooping Configuration Example
- 19-MLD Snooping Configuration Example
- 20-IPv4 DNS Proxy Configuration Example
- 21-IPv6 DNS Proxy Configuration Example
- 22-Static NAT Configuration Example
- 23-Dynamic NAT Configuration Example
- 24-IPv4 ACL-Based Packet Filter Configuration Example
- 25-IPv6 ACL-Based Packet Filter Configuration Example
- 26-ARP Attack Protection Configuration Example
- 27-ARP Proxy Configuration Example
- 28-Dynamic IPv4 DNS Configuration Example
- 29-Dynamic IPv6 DNS Configuration Example
- 30-WLAN Access Configuration Example
- 31-Different Wireless Services on Different Radios Configuration Example
- 32-CAPWAP Tunnel Establishment Through DHCP Configuration Example
- 33-CAPWAP Tunnel Establishment Through DHCPv6 Configuration Example
- 34-CAPWAP Tunnel Establishment Through DNS Configuration Example
- 35-CAPWAP Tunnel Establishment Through DNSv6 Configuration Example
- 36-Auto AP Configuration Example
- 37-AP Group Configuration Example
- 38-Radio Management Configuration Example
- 39-Load Balancing Group-Based Session-Mode Load Balancing Configuration Example
- 40-Radio-Based Session-Mode Load Balancing Configuration Example
- 41-A-MPDU and A-MSDU Configuration Example
- 42-Device Classification and Countermeasure Configuration Example
- 43-Malformed Packet Detection and Flood Attack Detection Configuration Example
- 44-Signature-Based Attack Detection Configuration Example
- 45-802.1X RADIUS-Based AAA Configuration Example
- 46-VLAN Interface-Based Direct Portal Authentication Configuration Example
- 47-Service Template-Based Direct Portal Authentication Configuration Example
- 48-Wireless Spectrum Analysis Configuration Example
- 49-Auto DFS Configuration Examples
- 50-Auto TPC Configuration Examples
- 51-Whitelist-Based Client Access Control Configuration Example
- 52-Blacklist-Based Client Access Control Configuration Example
- 53-CAC Configuration Example
- 54-WLAN Probe Configuration Example
- 55-Intra-AC Roaming Configuration Example
- 56-Bonjour Gateway Configuration Example
- 57-IPv4 Multicast Optimization Configuration Examples
- 58-IPv6 Multicast Optimization Configuration Examples
- 59-Ping Configuration Example
- 60-Local Packet Capture Configuration Example
- 61-Remote Packet Capture Configuration Example
11-Layer 2 Static Link Aggregation Configuration Example | 231.38 KB |
H3C Access Controllers |
Comware 7 Layer 2 Static Link Aggregation |
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring a Layer 2 static link aggregation group
Configuring an aggregation group on AC 1
Configuring an aggregation group on AC 2
Overview
The following information provides an example for configuring Layer 2 static link aggregation.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of Layer 2 static link aggregation.
As shown in Figure 1, set up a static aggregate link between AC 1 and AC 2.
Procedures
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Settings > Interfaces > Link Aggregation.
3. Click the Create button to create aggregation group 1.
Figure 2 Creating an aggregation group
4. Set the aggregation mode to static and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
Figure 3 Configuring an aggregation group
5. Click the System View tab at the bottom of the page.
6. From the navigation pane, select Network Settings > VLAN.
Figure 4 VLAN list
7. Click the Create VLANs
button to create VLAN 10.
Figure 5 Creating a VLAN
8. Click the Edit
button for VLAN 10 to assign GigabitEthernet 1/0/4 as an untagged member and GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 as tagged
members to the VLAN.
Figure 6 Adding physical interfaces
Configure AC 2 in the same way you configured AC 1. (Details not shown.)
1. Verify that GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 have been assigned to aggregation group 1 on the ACs. (Details not shown.)
2. Verify that Host A can ping Host B. (Details not shown.)
3. Verify that Host A can ping Host B when one of the links between the ACs fails. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
