- H3C Data Center Switches M-LAG Configuration Guide-6W100
- 00-M-LAG network planning
- 01-M-LAG+IPv4 and IPv6 Dual-Active VLAN Gateway Configuration Example
- 02-Multi-Layer M-LAG+STP+Dual-Active VLAN Gateway Configuration Examples
- 03-Multi-Layer M-LAG+Dual-Active VLAN Gateway+OSPF Configuration Examples
- 04-Multi-tier M-LAG+Spine Gateways+ECMP Paths to External Network Configuration Example
- 05-M-LAG and VRRP Configuration Example
- 06-M-LAG+RDMA Configuration Example
- 07-M-LAG and EVPN Distributed Gateway (IS-IS for underlay routing) Configuration Example
- 08-M-LAG and EVPN Distributed Gateway (BGP for Underlay Routing) Configuration Example
- 09-M-LAG+EVPN Distributed Gateway (OSPF on Underlay Network)+DHCP Relay+Microsegmentation+Service Chain Configuration Example
- 10-M-LAG+EVPN Centralized Gateway Configuration Example
- 11-Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example
- 12-M-LAG+EVPN+Monitor Link Configuration Examples
- 13-M-LAG and MVXLAN Configuration Example
- 14-M-LAG and DCI Configuration Example
- 15-M-LAG+EVPN DC Switchover Upon Border Failure Configuration Examples
11-Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example | 373.14 KB |
Example: Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example
As shown in Figure 1:
· Leaf 1 and Leaf 2 are distributed EVPN gateways that are virtualized into one M-LAG system. The peer link is an Ethernet aggregate link.
· Spine 1 and Spine 2 act as RRs to reflect routes between the leaf devices and between the leaf and border devices.
· Switch A and Switch B each is dual-homed to Leaf 1 and Leaf 2 through an Ethernet aggregate link. To avoid single points of failure, a Layer 2 Ethernet interface that contains member ports across devices is configured for the links connected to each VM.
· Standalone device Leaf 3 is connected to Switch C through a Layer 2 aggregate link.
· Switch D and Switch E each is single-homed to Leaf 1 and Leaf 2 through a physical link.
· To forward VXLAN traffic from one M-LAG member to the other M-LAG member for single-homed ACs, the M-LAG member devices create VXLAN tunnels over the peer link.
· For Layer 3 communication, enable a routing protocol for route advertisement between Leaf 1 and Leaf 2 and the user network. The underlay network is an IPv4 network and the overlay network is an IPv4 and IPv6 network.
Table 1 Topology and IP assignment
Device |
IP address |
Remarks |
Leaf 1 |
Loopback 0 |
1.1.1.1/32 |
VTEP address Used to establish BGP EVPN peer relationship |
Loopback 1 |
1.2.3.4/32 |
Virtual VTEP address |
VLAN-interface 4094 |
100.0.1.1/24 |
Attached to the link that forwards east-west traffic |
HGE 1/0/25 |
N/A |
Attached to the peer link Connected to HGE 1/0/25 on Leaf 2 |
HGE 1/0/26 |
100.0.0.1/24 100::1/64 |
Attached to the keepalive link Connected to HGE 1/0/26 on Leaf 2. |
HGE 1/0/27 |
Borrowed from Loopback 0 |
Connected to HGE 1/0/4 on Spine 1. |
HGE 1/0/28 |
Connected to HGE 1/0/4 on Spine 2. |
HGE 1/0/32 |
N/A |
AC interface Connected to HGE 1/0/1 on Switch D |
WGE 1/0/1 |
N/A |
M-LAG group member port Connected to Server A |
WGE 1/0/2 |
N/A |
M-LAG group member port Connected to Server B |
VSI-interface 10 |
20.1.1.1/24 20:1:1:1::1/64 Virtual IP: 20.1.1.5/24 IPv6 virtual IP: 20:1:1:1::5/64 |
Gateway interface for VXLAN 100 |
VSI-interface 20 |
20.2.1.1/24 20:2:1:1::1/64 Virtual IP: 20.2.1.5/24 IPv6 virtual IP: 20:2:1:1::5/64 |
Gateway interface for VXLAN 101 |
VSI-interface 100 |
N/A |
Associated with a L3 VXLAN ID |
Leaf 2 |
Loopback 0 |
2.2.2.2/32 |
Loopback 1 |
1.2.3.4/32 |
100.0.1.2/24 |
HGE 1/0/25 |
N/A |
Attached to the peer link Connected to HGE 1/0/25 on Leaf 1 |
HGE 1/0/26 |
100.0.0.2/24 100::2/64 |
Attached to the keepalive link Connected to HGE 1/0/26 on Leaf 1 |
HGE 1/0/27 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/5 on Spine 1 |
HGE 1/0/28 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/5 on Spine 2 |
HGE 1/0/30 |
N/A |
Single-homed AC interface Connected to HGE 1/1/3 on Switch E |
XGE 1/0/1 |
N/A |
XGE 1/0/2 |
N/A |
VSI-interface 10 |
20.1.1.1/24 20:1:1:1::1/64 Virtual IP: 20.1.1.6/24 IPv6 virtual IP: 20:1:1:1::6/64 |
VSI-interface 20 |
20.2.1.1/24 20:2:1:1::1/64 Virtual IP: 20.2.1.6/24 IPv6 virtual IP: 20:2:1:1::6/64 |
VSI-interface 100 |
N/A |
Leaf 3 |
Loopback 0 |
3.3.3.3/32 |
HGE 1/0/27 |
Connected to HGE 1/0/6 on Spine 1 |
HGE 1/0/28 |
Connected to HGE 1/0/6 on Spine 2 |
XGE 1/0/1 |
N/A |
Member port of a Layer 2 aggregate interface Connected to Server 3 |
Spine 1 |
Loopback 0 |
4.4.4.4/32 |
HGE 1/0/4 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/27 on Leaf 1 |
HGE 1/0/5 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/27 on Leaf 2 |
HGE 1/0/6 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/27 on Leaf 3 |
HGE 1/0/9 |
30.0.0.1/24 |
Connected to HGE 1/0/25 on the border device |
Spine 2 |
Loopback 0 |
5.5.5.5/32 |
HGE 1/0/4 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/28 on Leaf 1 |
HGE 1/0/5 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/28 on Leaf 2 |
HGE 1/0/6 |
N/A |
Borrowed from Loopback 0 Connected to HGE 1/0/28 on Leaf 3 |
HGE 1/0/9 |
31.0.0.1/24 |
Connected to HGE 1/0/26 on the border device |
Border |
Loopback 0 |
6.6.6.6/32 |
HGE 1/0/25 |
30.0.0.2/24 |
Connected to HGE 1/0/9 on Spine 1 |
HGE 1/0/26 |
31.0.0.2/24 |
Connected to HGE 1/0/9 on Spine 2 |
HGE 1/0/30 |
50.0.0.1/24 |
Connected to the external network |
VSI-interface 100 |
N/A |
Applicable product matrix
IMPORTANT: In addition to running an applicable software version, you must also install the most recent patch, if any. |
Role |
Device |
Software version |
Spine |
S12500X-AF |
R2825 |
S12500G-AF |
R7625 |
Leaf or border |
S12500G-AF (only border, not leaf) |
R7625 |
S6800 and S6860 |
R6710 |
S6805, S6825, S6850, and S9850 |
R6710 |
S6890 |
R2825 |
S9820-64H (EVPN gateway not supported) |
Not supported for EVPN gateway deployment |
S9820-8C (EVPN not supported) |
Not supported for EVPN deployment |
S6812 and S6813 |
Not supported |
SDN controller |
N/A |
Contact H3C support to verify version compatibility |
Analysis
Leaf 1 and Leaf 2 form an M-LAG system and the same VSI interface on the leaf devices is assigned the same IP address and MAC address. As a result, the leaf devices cannot separately establish EBGP peer relationship with Switch A and Switch B. For Leaf 1 and Leaf 2 to separately establish EBGP peer relationship with the switches, you must assign different M-LAG virtual IP addresses to the same VSI interface on the leaf devices. Then, Leaf 1 and Leaf 2 each can use its own M-LAG virtual IP address to establish EBGP peer relationship with the switches. To configure an M-LAG virtual IP address on a VSI interface, use the port m-lag virtual-ip command.
For the servers to reach one another, configure Switch A through Switch E to import direct routes to EBGP.
M-LAG configuration
· When Leaf 1 and Leaf 2 create VXLAN tunnels over the peer link, the tunnel source IP address is the virtual VTEP address of the M-LAG system. The tunnel destination IP address is the VTEP address of the local leaf device. When traffic from a single-homed server is forwarded from one M-LAG member to the other M-LAG member through a VXLAN tunnel created on the peer link, the latter M-LAG member cannot decapsulate the traffic. To resolve this issue, use the vxlan default-decapsulation source interface loopback 0 command on the latter M-LAG member so that the M-LAG member can decapsulate the traffic.
· In this example, Leaf 1 is the primary device and Leaf 2 is the secondary device in the M-LAG system. When the peer link is disconnected, the links connecting Leaf 1 to Sever A and Sever B are also disconnected. However, the EBGP connections to Sever A and Sever B go down only when the BGP peer relationship expires. The convergence time is up to dozens seconds and even more than 100 seconds. To resolve this issue, use the m-lag mad include interface command on Leaf 1 to add the interfaces connected to Server A and Server B to the user-configured list of included ports. The interfaces will be shut down by M-LAG MAD when the M-LAG system splits.
· When GIR is configured on an M-LAG member device and the M-LAG member device is isolated, traffic from single-homed interfaces on the M-LAG member device still can be forwarded to a leaf device.
· In an EVPN distributed relay network, AC interfaces and VSI interfaces support QoS rate limit.
· To avoid packet loss or other forwarding issues when the secondary device that has a large number of entries or is being upgraded joins the M-LAG system, use the m-lag restore-delay command to increase the data restoration interval.
Routing configuration
· You can configure a router ID for an OSPF process or BGP instance. If you do not configure a router ID, the OSPF process or BGP instance uses the global router ID. Make sure the router ID for each device is unique in the network.
· For the remote leaf and border devices to establish tunnels only with the M-LAG system (represented by the virtual VTEP address), use the nexthop evpn-m-lag group-address command in BGP EVPN address family view on the M-LAG member devices. When this command is used, the VXLAN tunnels established between the M-LAG member devices go down. To resolve this issue, configure a routing policy for each M-LAG member device to use its local VTEP address as the next hop of BGP EVPN routes advertised to the other M-LAG member device. The following information shows the settings:
route-policy 1 permit node 1
if-match route-type bgp-evpn-ip-prefix
apply ip-address next-hop 1.1.1.1
route-policy 1 deny node 10
bgp 20
address-family l2vpn evpn
peer 2.2.2.2 route-policy 1 export
· As a best practice, use the nexthop evpn-m-lag group-address command. If you do not use this command, OSPF advertises the IP address of Loopback 0. When the peer link recovers from a failure or an M-LAG member device finishes reboot, the following issues exist:
¡ Traffic detour—When the peer link recovers from a failure or an M-LAG member device finishes reboot, the peer link comes up earlier than other links. The VLAN interfaces used to forward east-west traffic also come up. As a result, the tunnels between the failed M-LAG member and remote VTEPs come up before the failed M-LAG member recovers. Downstream traffic from the remote VTEPs to the failed M-LAG member is forwarded to the failed M-LAG member. Because the failed M-LAG member has not recovered, the failed M-LAG member forwards the traffic to the other M-LAG member through the peer link. In this process, detour exists for the traffic.
¡ Two traffic convergences—The first traffic convergence occurs when the peer link recovers and the second traffic convergence occurs when M-LAG MAD brings up the interfaces that were shut down when the M-LAG system split.
Procedures
Configuring leaf devices
Procedure summary
· Configuring the links connected to the spine devices
· Configuring the overlay network
· Configuring links for dual-homed servers
· Configuring links for single-homed servers
Configuring M-LAG settings
Leaf 1 (S6850) |
Leaf 2 (S6805) |
Configuration method |
Remarks |
m-lag system-mac cda-8037-1324 |
Manual or controller-based |
Configure the M-LAG system MAC address. |
For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on them. |
m-lag system-number 1 |
m-lag system-number 2 |
Set the M-LAG system number. |
You must assign different M-LAG system numbers to the M-LAG member devices in an M-LAG system. |
m-lag system-priority 100 |
Set the M-LAG system priority. |
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system. |
m-lag keepalive ip destination 100.0.0.2 source 100.0.0.1 |
m-lag keepalive ip destination 100.0.0.1 source 100.0.0.2 |
Specify the destination and source IP addresses of keepalive packets. |
N/A |
interface hundredgige 1/0/26 |
Enter the view of HundredGigE 1/0/26. The interface is attached to the keepalive link. |
N/A |
port link-mode route |
Set the link mode of the keepalive interface to Layer 3. |
N/A |
ip address 100.0.0.1 24 |
ip address 100.0.0.2 24 |
Assign an IP address to HundredGigE 1/0/26. This IP address is the source IP address of keepalive packets. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
m-lag mad default-action none |
Configure M-LAG MAD to not shut down any network interfaces when the M-LAG system splits, except the interfaces configured manually or by the system to be shut down by M-LAG MAD. |
N/A |
m-lag restore-delay 300 |
Set the data restoration interval to 300 seconds. |
N/A |
m-lag mad include interface hundredgige 1/0/27 |
Add HundredGigE 1/0/27 to the user-configured list of included ports, which will be shut down by M-LAG MAD when the M-LAG system splits |
N/A |
m-lag mad include interface hundredgige 1/0/28 |
Add HundredGigE 1/0/28 to the user-configured list of included ports, which will be shut down by M-LAG MAD when the M-LAG system splits |
N/A |
vlan all |
vlan all |
Create all VLANs. |
N/A |
interface vlan-interface 4094 |
Create VLAN-interface 4094 and enter its view. |
VLAN-interface 4094 is used to forward east-west traffic. The VLAN interface cannot borrow IP addresses from loopback interfaces. |
ip address 100.0.1.1 24 |
ip address 100.0.1.2 24 |
Assign an IP address to the interface. |
N/A |
ospf 1 area 0 |
ospf 1 area 0 |
Enable OSPF process 1 on the interface. |
N/A |
quit |
quit |
N/A |
N/A |
interface bridge-aggregation 1 |
Create Layer 2 aggregate interface Bridge-Aggregation 1. This aggregate interface will be used as the peer-link interface. |
N/A |
quit |
quit |
N/A |
N/A |
interface hundredgige 1/0/25 |
Enter the view of the physical interface that will be assigned to the peer-link interface. |
N/A |
port link-aggregation group 1 |
Assign the physical interface to Bridge-Aggregation 1. Bridge-Aggregation 1 will be configured as the peer-link interface. |
N/A |
quit |
quit |
N/A |
N/A |
Enter the view of Bridge-Aggregation 1. |
N/A |
link-aggregation mode dynamic |
Configure the aggregate interface to operate in dynamic aggregation mode |
N/A |
port m-lag peer-link 1 |
Specify the aggregate interface as the peer-link interface. |
N/A |
port link-type trunk |
Set the link type of the aggregate interface to trunk. |
N/A |
port trunk permit vlan all |
Assign the aggregate interface to all VLANs. |
N/A |
port trunk pvid vlan 4094 |
Set the PVID of the aggregate interface to 4094. |
VLAN 4094 is a VLAN used to provide services when all services become unavailable. |
undo mac-address static source-check enable |
Enable the static source check feature. |
N/A |
flow-interval 5 |
flow-interval 5 |
Set the statistics polling interval to 5 seconds on the aggregate interface. |
N/A |
quit |
quit |
N/A |
N/A |
Leaf 1 (S6850) |
Leaf 2 (S6805) |
Leaf 3 (S6805) |
Remarks |
interface loopback 0 |
Create interface Loopback 0 and enter its view. |
N/A |
ip address 1.1.1.1 32 |
ip address 2.2.2.2 32 |
ip address 3.3.3.3 32 |
This IP address will be used as the VTEP address. Make sure each device is assigned a unique VTEP address. |
quit |
quit |
quit |
N/A |
N/A |
interface loopback 1 |
N/A |
Create interface Loopback 1 and enter its view. |
N/A |
ip address 1.2.3.4 32 |
N/A |
Specify this IP address as the virtual VTEP address when you enable EVPN distributed relay. |
quit |
quit |
N/A |
N/A |
N/A |
ospf 1 router-id 1.1.1.1 |
ospf 1 router-id 2.2.2.2 |
ospf 1 router-id 3.3.3.3 |
Enable OSPF process 1 and enter OSPF process view. |
N/A |
non-stop-routing |
non-stop-routing |
non-stop-routing |
Enable NSR for the OSPF process. |
N/A |
stub-router include-stub on-startup 900 |
Configure the router as a stub router during reboot and specify the timeout time to 900 seconds to accelerate network convergence. |
N/A |
area 0.0.0.0 |
area 0.0.0.0 |
area 0.0.0.0 |
Create an OSPF area and enter OSPF area view or OSPF IPv4 unicast topology area view. |
N/A |
network 1.1.1.1 0.0.0.0 |
network 2.2.2.2 0.0.0.0 |
network 3.3.3.3 0.0.0.0 |
Enable OSPF on the interface attached to the specified network in the area. |
N/A |
network 1.2.3.4 0.0.0.0 |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
interface range hundredgige 1/0/27 hundredgige 1/0/28 |
Enter the interface range view of the interfaces connected to the spine devices. |
N/A |
Set the link mode of the interfaces to Layer 3. |
N/A |
flow-interval 5 |
flow-interval 5 |
flow-interval 5 |
Set the statistics polling interval to 5 seconds on the interfaces. |
N/A |
ip address unnumbered interface loopback 0 |
Configure the interfaces to borrow the IP address of interface Loopback 0. |
N/A |
ospf network-type p2p |
Set the OSPF network type to P2P on the interfaces. |
N/A |
ospf 1 area 0.0.0.0 |
Enable OSPF process 1 on the interfaces. |
N/A |
ospf peer hold-max-cost duration 20000 |
Enable OSPF to advertise the maximum link cost to neighbors within 20000 milliseconds. |
Route convergence optimization. |
lldp management-address arp-learning |
Configure the interfaces to generate an ARP entry after receiving an LLDP frame that carries a management address TLV. |
N/A |
lldp tlv-enable basic-tlv management-address-tlv interface loopback 0 |
Configure the types of advertisable TLVs on the interfaces. |
N/A |
Disable the static source check feature. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
bgp 20 |
bgp 20 |
bgp 20 |
Create BGP instance 20 and enter its view. |
N/A |
router-id 1.1.1.1 |
router-id 2.2.2.2 |
router-id 3.3.3.3 |
Specify a router ID for the BGP instance. |
N/A |
peer 4.4.4.4 as-number 20 |
Create BGP peer 4.4.4.4 and specify AS number 20 for the peer. |
N/A |
peer 4.4.4.4 connect-interface loopback 0 |
Specify Loopback 0 as the source interface for establishing TCP connections to peer 4.4.4.4. |
N/A |
peer 5.5.5.5 as-number 20 |
Create BGP peer 5.5.5.5 and specify AS number 20 for the peer. |
N/A |
peer 5.5.5.5 connect-interface loopback 0 |
Specify Loopback 0 as the source interface for establishing TCP connections to peer 5.5.5.5. |
N/A |
address-family l2vpn evpn |
Enter BGP EVPN address family view. |
N/A |
nexthop evpn-m-lag group-address |
Enable the device to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address. |
N/A |
peer 4.4.4.4 enable |
Enable the local router to exchange unicast routing information with peer 4.4.4.4. |
N/A |
peer 5.5.5.5 enable |
Enable the local router to exchange unicast routing information with peer 5.5.5.5. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
Leaf 1 (S6850) |
Leaf 2 (S6805) |
Leaf 3 (S6805) |
Remarks |
ip vpn-instance vpn1 |
Create VPN instance vpn1 and enter its view, or directly enter the view of the VPN instance if the VPN instance already exists. |
N/A |
route-distinguisher 1:100 |
route-distinguisher 1:101 |
route-distinguisher 1:102 |
Configure an RD for the VPN instance. |
N/A |
address-family ipv4 |
Enter VPN instance IPv4 address family view. |
N/A |
vpn-target 1:100 |
vpn-target 1:100 |
vpn-target 1:100 |
Configure a route target for the VPN instance. |
N/A |
address-family ipv6 |
Enter VPN instance IPv6 address family view. |
N/A |
vpn-target 1:100 |
vpn-target 1:100 |
vpn-target 1:100 |
N/A |
address-family evpn |
Enter VPN instance EVPN view. |
N/A |
vpn-target 1:100 |
vpn-target 1:100 |
vpn-target 1:100 |
Configure a route target for EVPN. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
l2vpn enable |
l2vpn enable |
l2vpn enable |
Enable L2VPN. |
N/A |
l2vpn m-lag peer-link ac-match-rule vxlan-mapping |
N/A |
Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the Ethernet aggregate link peer link. |
N/A |
vxlan tunnel mac-learning disable |
Disable remote-MAC address learning. |
N/A |
vxlan tunnel arp-learning disable |
Disable remote ARP learning for VXLANs. |
N/A |
vxlan tunnel nd-learning disable |
Disable remote ND learning for VXLANs. |
N/A |
evpn m-lag group 1.2.3.4 |
N/A |
Enable EVPN distributed relay and specify the virtual VTEP address. |
N/A |
evpn global-mac 1-1-1 |
evpn global-mac 2-2-2 |
Configure the EVPN global MAC address. |
N/A |
vxlan default-decapsulation source interface loopback 0 |
Enable default IPv4 VXLAN decapsulation. |
N/A |
interface vsi-interface 10 |
interface vsi-interface 30 |
Create VSI-interface 10 and enter its view. |
N/A |
ip binding vpn-instance vpn1 |
Associate VPN instance vpn1 with the VSI interface. |
N/A |
ip address 20.1.1.1 24 |
ip address 20.3.1.1 24 |
Assign an IP address to the VSI interface. |
N/A |
mac-address 0001-0001-0002 |
mac-address 0001-0001-0004 |
Assign a MAC address to the VSI interface. |
N/A |
local-proxy-arp enable |
Enable local proxy ARP. |
N/A |
ipv6 address 20:1:1:1::1/64 |
ipv6 address 20:3:1:1::1/64 |
Assign an IPv6 global unicast address to the VSI interface. |
N/A |
distributed-gateway local |
Specify the VSI interface as a distributed gateway. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
interface vsi-interface 20 |
N/A |
Create VSI-interface 20 and enter its view. |
N/A |
N/A |
N/A |
ip address 20.2.1.1 24 |
N/A |
N/A |
mac-address 0001-0001-0003 |
N/A |
N/A |
N/A |
N/A |
ipv6 address 20:2:1:1::1/64 |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
interface vsi-interface 100 |
Create VSI-interface 100 and enter its view. |
N/A |
description L3_vni |
Configure a description for the VSI interface. |
N/A |
N/A |
l3-vni 1000 |
l3-vni 1000 |
l3-vni 1000 |
Associate Layer 3 VXLAN ID 1000 with the VSI interface. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
vsi vni_100 |
vsi vni_100 |
vsi vni_102 |
Create a VSI and enter its view, or directly enter the view of the VSI if the VPN instance already exists. |
N/A |
gateway vsi-interface 10 |
gateway vsi-interface 30 |
Specify a gateway for the VSI. |
N/A |
vxlan 100 |
vxlan 100 |
vxlan 102 |
Create a VXLAN and enter its view, or enter the view of the VXLAN if the VXLAN already exists. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
evpn encapsulation vxlan |
Create an EVPN instance on the VSI. |
N/A |
Configure an RD for the EVPN instance. |
N/A |
vpn-target 1:100 both |
vpn-target 1:102 both |
Configure route targets for the EVPN instance. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
vsi vni_101 |
vsi vni_101 |
N/A |
N/A |
gateway vsi-interface 20 |
N/A |
N/A |
vxlan 101 |
vxlan 101 |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
vpn-target 1:101 both |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
Leaf 1 (S6850) |
Leaf 2 (S6805) |
Leaf 3 (S6805) |
Remarks |
interface bridge-aggregation 2 |
Create a Layer 2 aggregate interface and enter its view. The Layer 2 aggregate interface on each device is connected to a server. |
N/A |
Configure the Layer 2 aggregation group to operate in dynamic aggregation mode. |
N/A |
port m-lag group 1 |
N/A |
Assign Bridge-Aggregation 2 to M-LAG group 1. |
N/A |
stp edged-port |
stp edged-port |
stp edged-port |
Configure the Layer 2 aggregate interface as an edge port for the spanning tree feature. |
N/A |
Set the link type of the Layer 2 aggregate interface to trunk. |
N/A |
undo port trunk permit vlan 1 |
Remove the Layer 2 aggregate interface from VLAN 1. |
N/A |
port trunk permit vlan 10 20 |
port trunk permit vlan 30 |
Assign the Layer 2 aggregate interface to the specified VLANs. |
N/A |
service-instance 10 |
service-instance 30 |
Create an Ethernet service instance. |
N/A |
encapsulation s-vid 10 |
encapsulation s-vid 30 |
Configure a frame match criterion for the Ethernet service instance. |
N/A |
xconnect vsi vni_100 |
xconnect vsi vni_102 |
Map the Ethernet service instance to a VSI. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
service-instance 20 |
N/A |
N/A |
encapsulation s-vid 20 |
N/A |
N/A |
xconnect vsi vni_101 |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
interface twenty-fivegige 1/0/1 |
interface ten-gigabitethernet 1/0/2 |
interface ten-gigabitethernet 1/0/1 |
Enter the view of a physical interface connected to a server. |
N/A |
speed 10000 |
N/A |
N/A |
Set the interface speed to 10 Gbps. |
N/A |
flow-interval 5 |
flow-interval 5 |
flow-interval 5 |
Set the statistics polling interval to 5 seconds on the interface. |
N/A |
Set the link type of the interface to trunk. |
N/A |
Remove the interface from VLAN 1. |
N/A |
Assign the interface to the specified VLANs. |
N/A |
port link-aggregation group 2 |
Assign the interface to the Layer 2 aggregate interface created for server connection. |
N/A |
quit |
quit |
quit |
N/A |
N/A |
interface bridge-aggregation 3 |
N/A |
Create Bridge-Aggregation 3. The aggregate interface is connected to a server. |
N/A |
interface twenty-fivegige 1/0/2 |
N/A |
N/A |
speed 10000 |
N/A |
N/A |
N/A |
flow-interval 5 |
flow-interval 5 |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
port link-aggregation group 3 |
N/A |
Assign the interface to a Layer 2 aggregate interface. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
Enter the view of VSI-interface 10. |
N/A |
port m-lag virtual-ip 20.1.1.5 24 active |
port m-lag virtual-ip 20.1.1.6 24 active |
N/A |
Assign an M-LAG virtual IPv4 address to the VSI interface. |
Make sure you assign different M-LAG virtual IPv4 addresses to the same VSI interface on the M-LAG member devices in one M-LAG system. |
port m-lag ipv6 virtual-ip 20:1:1:1::5 64 active |
port m-lag ipv6 virtual-ip 20:1:1:1::6 64 active |
N/A |
Assign an M-LAG virtual IPv6 address to the VSI interface. |
Make sure you assign different M-LAG virtual IPv6 addresses to the same VSI interface on the M-LAG member devices in one M-LAG system. |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
Enter the view of VSI-interface 20. |
N/A |
port m-lag virtual-ip 20.2.1.5 24 active |
port m-lag virtual-ip 20.2.1.6 24 active |
N/A |
port m-lag ipv6 virtual-ip 20:2:1:1::5 64 active |
port m-lag ipv6 virtual-ip 20:2:1:1::6 64 active |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
bgp 20 |
bgp 20 |
bgp 20 |
Enter BGP instance view. |
N/A |
Create BGP-VPN instance vpn1 and enter BGP-VPN instance view. |
N/A |
peer 20.1.1.10 as-number 10 |
peer 20.3.1.10 as-number 10 |
Create a BGP peer and specify its AS number. |
Leaf 3 does not form an M-LAG system with any device. Leaf 3 uses the primary IP address of the VSI interface to establish BGP peer relationship with other devices. |
peer 20.1.1.10 source-address 20.1.1.5 |
peer 20.1.1.10 source-address 20.1.1.6 |
peer 20:3:1:1::10 as-number 10 |
Specify a source IPv4 address for establishing TCP connections to a peer. |
N/A |
peer 20.2.1.10 as-number 10 |
N/A |
Create a BGP peer for the server at 20.2.1.10 and specify its AS number. |
N/A |
peer 20.2.1.10 source-address 20.2.1.5 |
peer 20.2.1.10 source-address 20.2.1.6 |
N/A |
Specify a source IPv4 address for establishing TCP connections to peer 20.2.1.10. |
N/A |
peer 20:1:1:1::10 as-number 10 |
N/A |
Create a BGP peer for the server at 20:1:1:1::10 and specify its AS number. |
N/A |
peer 20:1:1:1::10 source-address 20:1:1:1::5 |
peer 20:1:1:1::10 source-address 20:1:1:1::6 |
N/A |
Specify a source IPv6 address for establishing TCP connections to peer 20:1:1:1::10. |
N/A |
peer 20:2:1:1:: 10 as-number 10 |
N/A |
Create a BGP peer for the server at 20:2:1:1:: 10 and specify its AS number. |
N/A |
peer 20:2:1:1::10 source-address 20:2:1:1::5 |
peer 20:2:1:1::10 source-address 20:2:1:1::6 |
N/A |
Specify a source IPv6 address for establishing TCP connections to peer 20:2:1:1::10. |
N/A |
address-family ipv4 unicast |
Create the BGP-VPN IPv4 unicast address family view and enter its view. |
N/A |
balance 4 |
balance 4 |
balance 4 |
Enable load balancing and set the maximum number of BGP ECMP routes used for load balancing to 4. |
This step is optional for Leaf 3. |
peer 20.1.1.10 enable |
peer 20.3.1.10 enable |
Enable the local router to exchange unicast routing information with a peer. |
N/A |
peer 20.2.1.10 enable |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
address-family ipv6 unicast |
Create the BGP-VPN IPv6 unicast address family and enter its view. |
N/A |
balance 4 |
balance 4 |
balance 4 |
peer 20:1:1:1::10 enable |
peer 20:3:1:1::10 enable |
N/A |
peer 20:2:1:1::10 enable |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
quit |
quit |
quit |
N/A |
N/A |
Leaf 1 (S6850) |
Leaf 2 (S6805) |
Remarks |
interface hundredgige 1/0/32 |
Interface hundredgige 1/0/30 |
Enter the view of the interface connected to Switch. |
N/A |
flow-interval 5 |
flow-interval 5 |
N/A |
stp edged-port |
stp edged-port |
Configure the interface as an edge port for the spanning tree feature. |
N/A |
N/A |
N/A |
port trunk permit vlan 10 |
Assign the interface to VLAN 10. |
N/A |
Create Ethernet service instance 10. |
N/A |
Configure the Ethernet service instance to match traffic in VLAN 10. |
N/A |
Map the Ethernet service instance to VSI vni_100. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
interface hundredgige 1/0/30 |
Enter the view of the interface connected to a server. |
N/A |
port trunk permit vlan 20 |
Assign the interface to VLAN 20. |
N/A |
Create Ethernet service instance 20. |
N/A |
Configure the Ethernet service instance to match traffic in VLAN 20. |
N/A |
Map the Ethernet service instance to VSI vni_101. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
route-policy 1 permit node 1 |
Create a routing policy and enter its view, and specify the permit match mode for the routing policy node. |
N/A |
if-match route-type bgp-evpn-ip-prefix |
Configure the node to match IP prefix advertisement routes of BGP EVPN. |
Permit the subnet of the single-homed server. |
apply ip-address next-hop 1.1.1.1 |
apply ip-address next-hop 2.2.2.2 |
Set a next hop for the matching IPv4 routes. |
Specify the VTEP address of each leaf device as the next hop for the leaf devices to establish tunnels between them. |
quit |
quit |
N/A |
N/A |
N/A |
route-policy 1 deny node 10 |
Create a routing policy and enter its view, and specify the deny match mode for the routing policy node. |
Deny addresses in other subnets except the subnet of the single-homed server. |
quit |
quit |
N/A |
N/A |
N/A |
bgp 20 |
bgp 20 |
N/A |
peer 2.2.2.2 as-number 20 |
peer 1.1.1.1 as-number 20 |
Configure EVPN settings between the leaf devices. |
peer 2.2.2.2 connect-interface loopback 0 |
peer 1.1.1.1 connect-interface loopback 0 |
Specify a source interface for establishing TCP connections to a peer or peer group. |
Specify Loopback 0 as the source interface for establishing TCP connection between the leaf devices. |
N/A |
peer 2.2.2.2 enable |
peer 1.1.1.1 enable |
N/A |
peer 2.2.2.2 route-policy 1 export |
peer 1.1.1.1 route-policy 1 export |
Apply a routing policy to routes outgoing to a peer in order to filter the routes and modify the route attributes. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
Enter BGP-VPN instance view. |
N/A |
peer 20.1.1.11 as-number 10 |
Create BGP peer 20.1.1.11 and specify AS number 10 for the peer. |
N/A |
peer 20.1.1.11 source-address 20.1.1.5 |
peer 20.1.1.11 source-address 20.1.1.6 |
Specify a source IPv4 address for establishing TCP connections to peer 20.1.1.11. |
Specify the M-LAG virtual IPv4 address on each leaf device as the source IPv4 address for establishing TCP connections to a peer single-homed to the M-LAG system. |
peer 20.2.1.11 as-number 10 |
Create BGP peer 20.2.1.11 and specify AS number 10 for the peer. |
N/A |
peer 20.2.1.11 source-address 20.2.1.5 |
peer 20.2.1.11 source-address 20.2.1.6 |
Specify a source IPv4 address for establishing TCP connections to peer 20.2.1.11. |
peer 20:1:1:1::11 as-number 10 |
Create BGP peer 20:1:1:1::11 and specify AS number 10 for the peer. |
N/A |
peer 20:1:1:1::11 source-address 20:1:1:1::5 |
peer 20:1:1:1::11 source-address 20:1:1:1::6 |
Specify a source IPv6 address for establishing TCP connections to peer 20:1:1:1::11. |
Specify the M-LAG virtual IPv6 address on each leaf device as the source IPv6 address for establishing TCP connections to a peer single-homed to the M-LAG system. |
peer 20:2:1:1::11 as-number 10 |
Create BGP peer 20:2:1:1::11 and specify AS number 10 for the peer. |
N/A |
peer 20:2:1:1::11 source-address 20:2:1:1::5 |
peer 20:2:1:1::11 source-address 20:2:1:1::6 |
Specify a source IPv6 address for establishing TCP connections to peer 20:2:1:1::11. |
Enter BGP-VPN IPv4 unicast address family view. |
N/A |
peer 20.1.1.11 enable |
Enable the local router to exchange unicast routing information with peer 20.1.1.11. |
N/A |
peer 20.2.1.11 enable |
Enable the local router to exchange unicast routing information with peer 20.2.1.11. |
N/A |
Enter BGP-VPN IPv6 unicast address family view. |
N/A |
peer 20:1:1:1::11 enable |
Enable the local router to exchange unicast routing information with peer 20:1:1:1::11. |
N/A |
peer 20:2:1:1::11 enable |
Enable the local router to exchange unicast routing information with peer 20:2:1:1::11. |
N/A |
Configuring spine devices
Procedure summary
· Configuring the links connected to the leaf devices
· Configuring the link connected to the border device
Spine 1 |
Spine 2 |
Remarks |
ospf 1 router-id 4.4.4.4 |
ospf 1 router-id 5.5.5.5 |
N/A |
non-stop-routing |
non-stop-routing |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
Create interface Loopback 0 and enter loopback interface view. |
N/A |
ip address 4.4.4.4 32 |
ip address 5.5.5.5 32 |
This IP address will be used as the VTEP address for each spine device. Make sure the VTEP address of each spine device is unique in the network. |
ospf 1 area 0 |
ospf 1 area 0 |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
interface range hundredgige 1/0/4 to hundredgige 1/0/6 |
Enter the interface range view of the interfaces connected to the leaf devices. |
N/A |
N/A |
flow-interval 5 |
flow-interval 5 |
N/A |
N/A |
Specify the OSPF network type for the interfaces as P2P. |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
bgp 20 |
bgp 20 |
Create BGP instance 20 and enter BGP instance view. |
N/A |
non-stop-routing |
non-stop-routing |
Enable NSR for the BGP instance. |
N/A |
router-id 4.4.4.4 |
router-id 5.5.5.5 |
Specify a unique router ID for the BGP instance on each spine device. This step is optional. |
group evpn internal |
Create IBGP peer group evpn. |
N/A |
peer evpn connect-interface loopback 0 |
Specify source interface Loopback 0 for establishing TCP connections to the peer group. |
N/A |
peer 1.1.1.1 group evpn |
Add peer 1.1.1.1 to peer group evpn. |
N/A |
peer 2.2.2.2 group evpn |
Add peer 2.2.2.2 to peer group evpn. |
N/A |
peer 3.3.3.3 group evpn |
Add peer 3.3.3.3 to peer group evpn. |
N/A |
N/A |
undo policy vpn-target |
Disable route target filtering for BGP EVPN routes. |
N/A |
peer evpn enable |
peer evpn enable |
Enable the local router to exchange unicast routing information with peer group evpn. |
N/A |
peer evpn reflect-client |
Configure the device as a route reflector and specify peer group evpn as a client. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
Spine 1 |
Spine 2 |
Remarks |
interface hundredgige 1/0/9 |
Enter the view of the interface connected to the border device. |
N/A |
flow-interval 5 |
flow-interval 5 |
N/A |
ip address 30.0.0.1 24 |
ip address 31.0.0.1 24 |
N/A |
ospf 1 area 0 |
ospf 1 area 0 |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
bgp 20 |
bgp 20 |
N/A |
peer 6.6.6.6 as-number 30 |
N/A |
peer 6.6.6.6 connect-interface loopback 0 |
Specify source interface Loopback 0 for establishing TCP connections to peer 6.6.6.6. |
N/A |
peer 6.6.6.6 ebgp-max-hop 64 |
Enable BGP to establish EBGP sessions to indirectly connected EBGP peer 6.6.6.6, and set the maximum hop count to 64. |
N/A |
N/A |
peer 6.6.6.6 enable |
Enable the local router to exchange unicast routing information with a peer or peer group. |
N/A |
peer 6.6.6.6 next-hop-invariable |
Configure the device to not change the next hop of routes advertised to an EBGP peer or peer group. |
The border and spine devices establish EBGP peer relationship. For the leaf devices to establish tunnels with the border devices, you must perform this task. |
quit |
quit |
N/A |
N/A |
N/A |
Configuring the border device
Procedure summary
· Configuring routing for communication with the external network
Border |
Remarks |
Create VPN instance vpn1 and enter VPN instance view. |
N/A |
route-distinguisher 1:106 |
N/A |
N/A |
Configure route targets for the VPN instance. |
N/A |
quit |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
N/A |
N/A |
N/A |
N/A |
Configure route targets for EVPN. |
N/A |
quit |
N/A |
N/A |
N/A |
quit |
N/A |
N/A |
N/A |
Create VSI-interface100 and enter VSI interface view. |
N/A |
N/A |
N/A |
l3-vni 1000 |
N/A |
quit |
N/A |
N/A |
N/A |
Border |
Remarks |
ospf 1 router-id 6.6.6.6 |
N/A |
non-stop-routing |
N/A |
N/A |
quit |
N/A |
N/A |
N/A |
N/A |
ip address 6.6.6.6 32 |
This IP address will be used as the VTEP address of the device. Make sure the VTEP address is unique in the network. |
ospf 1 area 0 |
N/A |
quit |
N/A |
N/A |
N/A |
Enter the view of the interface connected to Spine 1. |
N/A |
Set the link mode of the interface to Layer 3. |
N/A |
flow-interval 5 |
N/A |
ip address 30.0.0.2 24 |
N/A |
ospf 1 area 0 |
N/A |
quit |
N/A |
N/A |
N/A |
Enter the view of the interface connected to Spine 2. |
N/A |
N/A |
flow-interval 5 |
N/A |
ip address 31.0.0.2 24 |
N/A |
ospf 1 area 0 |
N/A |
quit |
N/A |
N/A |
N/A |
bgp 30 |
Create BGP instance 30 and enter its view. |
N/A |
non-stop-routing |
N/A |
router-id 6.6.6.6 |
N/A |
group spine external |
Create an EBGP peer group named spine. |
N/A |
peer spine as-number 20 |
Specify AS number 20 for the peer group. |
N/A |
peer spine connect-interface loopback 0 |
N/A |
peer spine ebgp-max-hop 64 |
Enable the local router to establish EBGP sessions to indirectly connected EBGP peers in peer group spine, and set the maximum hop count to 64. |
N/A |
peer 4.4.4.4 group spine |
Add peer 4.4.4.4 to peer group spine. |
N/A |
peer 5.5.5.5 group spine |
Add peer 5.5.5.5 to peer group spine. |
N/A |
N/A |
peer spine enable |
Enable the local router to exchange unicast routing information with peer group spine. |
N/A |
quit |
N/A |
N/A |
N/A |
quit |
N/A |
N/A |
N/A |
Border |
Remarks |
Enter the view of the interface connected to the external network. |
N/A |
N/A |
Associate VPN instance vpn1 with the interface. |
N/A |
ip address 50.0.0.1 24 |
Assign an IPv4 address to the interface. |
N/A |
ipv6 address 50::1/64 |
Assign an IPv6 address to the interface. |
N/A |
quit |
N/A |
N/A |
N/A |
ip route-static vpn-instance vpn1 50.0.0.0 16 50.0.0.2 |
Configure a static route. |
N/A |
ipv6 route-static vpn-instance vpn1 50:: 32 50::2 |
Configure an IPv6 static route. |
N/A |
bgp 30 |
N/A |
N/A |
Create the BGP-VPN IPv4 unicast address family and enter its view. |
N/A |
default-route imported |
Enable default route redistribution into the BGP routing table. |
N/A |
balance 4 |
N/A |
import-route static |
Import static routes to the BGP routing table for BGP to advertise the imported routes. |
N/A |
N/A |
N/A |
balance 4 |
N/A |
N/A |
quit |
N/A |
N/A |
N/A |
Overlay traffic forwarding models
Overlay traffic characteristics
The following table describes overlay traffic characteristics:
Parameter |
No. |
Overlay traffic number in the format of O-4-xxx or O-6-xxx. O represents overlay, 4 represents IPv4, 6 represents IPv6, and xxx represents a number. |
Traffic type |
Traffic types include broadcast, Layer 2 unicast, Layer 2 unknown unicast, Layer 2 multicast, Layer 2 unknown multicast, IPv4 known unicast, IPv6 known unicast, IPv4 multicast, IPv6 multicast, DHCP, and MPLS. |
Direction |
Traffic direction. Traffic can be forwarded from south to north, north to south, from east to west, or from east to west. The traffic can pass through one leaf device or multiple leaf devices or within a data center or across data centers. |
Forwarding path |
List of nodes that the traffic passes through, for example, Server A > Leaf 1 & 2 > Spine 2 > Leaf 2 > Server B. |
Traffic simulation |
Traffic simulation in the test. The name of IPv4 traffic is suffixed with V4_ and the name of IPv6 traffic is suffixed with V6_. Use a switch and a tester to simulate a server. The following types of traffic is injected: · Server A sends 10K ARP or ND request traffic to Server B. · Server B replies to the ARP or ND request traffic of Server A. The traffic amount is also 10K. · Traffic is sent between the servers and between the servers and the external network. The source port of each flow changes 100th times. · 20K traffic is sent from each server to the external network through the border. |
Load |
Traffic load is light or heavy. If the number of flows is less than 1000, the load is light. If the number of flows is more than 1000, the load is heavy. If the load is heavy, enter the actual load for the load parameter. |
Traffic direction to firewalls/LB |
Enter the method used to direct traffic to firewalls or LBs. The value can be N/A, PBR, M-LAG and VRRP, or static route. |
Overlay IPv4 traffic forwarding models
No. |
Traffic type |
Direction |
Forwarding path |
Load |
O-4-001 |
Broadcast |
N/A |
Server A > Leaf 1 |
Tester |
Light |
N/A |
O-4-002 |
IPv4 known unicast |
From a server dual-homed to one leaf device to the other server dual-homed to the same leaf device East to west |
Server A > Leaf 1 & 2 > Server B |
Tester |
Light |
N/A |
O-4-003 |
From a server dual-homed to one leaf device to a server single-homed to another leaf device East to west |
Server A > Leaf 1 & 2 > Spine > Leaf 3 > Server C |
Tester |
Light |
N/A |
O-4-004 |
From a server dual-homed to one leaf device to a server single-homed to the same leaf device East to west |
Server A > Leaf 1 & 2 > Leaf 1 > Server D |
Tester |
Light |
N/A |
O-4-005 |
South to north |
Server A > Leaf 1 & 2 > Spine > External network |
Tester |
Light |
N/A |
O-4-006 |
Server A > Leaf 1 & 2 > Leaf 2 > Server E |
Tester |
Light |
N/A |
O-4-007 |
Server B > Leaf 1 & 2 > Server A |
Tester |
Light |
N/A |
O-4-008 |
Server B > Leaf 1 & 2 > Spine > Leaf 3 > Server C |
Tester |
Light |
N/A |
O-4-009 |
Server B > Leaf 1 & 2 > Leaf 1 > Server D |
Tester |
Light |
N/A |
O-4-010 |
South to north |
Server B > Leaf 1 & 2 > Spine > External network |
Tester |
Light |
N/A |
O-4-011 |
Server B > Leaf 1 & 2 > Leaf 2 > Server E |
Tester |
Light |
N/A |
O-4-012 |
From a server single-homed to one leaf device to a server dual-homed to another leaf device East to west |
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Server A |
Tester |
Light |
N/A |
O-4-013 |
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Server B |
Tester |
Light |
N/A |
O-4-014 |
From a server single-homed to one leaf device to a server single-homed to another leaf device East to west |
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Leaf 1 > Server D |
Tester |
Light |
N/A |
O-4-015 |
South to north |
Server C > Leaf 3 > Spine > Border > External network |
Tester |
Light |
N/A |
O-4-016 |
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Leaf 2 > Server E |
Tester |
Light |
N/A |
O-4-017 |
From a server single-homed to one leaf device to a server dual-homed to the same leaf device East to west |
Server D > Leaf 1 > Server A |
Tester |
Light |
N/A |
O-4-018 |
Server D > Leaf 1 & 2 > Server B |
Tester |
Light |
N/A |
O-4-019 |
Server D > Leaf 1 > Spine > Leaf 3 > Server C |
Tester |
Light |
N/A |
O-4-020 |
South to north |
Server D > Leaf 1 > Spine > Border > External network |
Tester |
Light |
N/A |
O-4-021 |
From a server single-homed to one leaf device to a server single-homed to the same leaf device East to west |
Server D > Leaf 1 > Leaf 2 > Server E |
Tester |
Light |
N/A |
O-4-022 |
North to south |
External network > Border > Spine > Leaf 1 & 2 > Server A |
Tester |
Light |
N/A |
O-4-023 |
North to south |
External network > Border > Spine > Leaf 1 & 2 > Server B |
Tester |
Light |
N/A |
O-4-024 |
North to south |
External network > Border > Spine > Leaf 3 > Server C |
Tester |
Light |
N/A |
O-4-025 |
North to south |
External network > Border > Spine > Leaf 1 & 2 > Leaf 1 > Server D |
Tester |
Light |
N/A |
O-4-026 |
North to south |
External network > Border > Spine > Leaf 1 & 2 > Leaf 2 > Server E |
Tester |
Light |
N/A |
O-4-027 |
Server E > Leaf 2 > Server A |
Tester |
Light |
N/A |
O-4-028 |
Server E > Leaf 2 > Server B |
Tester |
Light |
N/A |
O-4-029 |
Server E > Leaf 2 > Spine > Leaf 3 > Server C |
Tester |
Light |
N/A |
O-4-030 |
Server E > Leaf 2 > Leaf 1 > Server D |
Tester |
Light |
N/A |
O-4-031 |
South to north |
Server E > Leaf 2 > Spine > Border > External network |
Tester |
Light |
N/A |
Overlay IPv6 traffic forwarding models
No. |
Traffic type |
Direction |
Forwarding path |
Load |
O-6-001 |
Broadcast |
N/A |
Server A > Leaf 1 |
Tester |
Light |
N/A |
O-6-002 |
IPv6 known unicast |
Tester |
Light |
N/A |
O-6-003 |
Tester |
Light |
N/A |
O-6-004 |
Tester |
Light |
N/A |
O-6-005 |
South to north |
Tester |
Light |
N/A |
O-6-006 |
Tester |
Light |
N/A |
O-6-007 |
Tester |
Light |
N/A |
O-6-008 |
Tester |
Light |
N/A |
O-6-009 |
Tester |
Light |
N/A |
O-6-010 |
South to north |
Tester |
Light |
N/A |
O-6-011 |
Tester |
Light |
N/A |
O-6-012 |
Tester |
Light |
N/A |
O-6-013 |
Tester |
Light |
N/A |
O-6-014 |
Tester |
Light |
N/A |
O-6-015 |
South to north |
Tester |
Light |
N/A |
O-6-016 |
Tester |
Light |
N/A |
O-6-017 |
Tester |
Light |
N/A |
O-6-018 |
Tester |
Light |
N/A |
O-6-019 |
Tester |
Light |
N/A |
O-6-020 |
South to north |
Tester |
Light |
N/A |
O-6-021 |
Tester |
Light |
N/A |
O-6-022 |
North to south |
Tester |
Light |
N/A |
O-6-023 |
North to south |
Tester |
Light |
N/A |
O-6-024 |
North to south |
Tester |
Light |
N/A |
O-6-025 |
North to south |
Tester |
Light |
N/A |
O-6-026 |
North to south |
Tester |
Light |
N/A |
O-6-027 |
Tester |
Light |
N/A |
O-6-028 |
Tester |
Light |
N/A |
O-6-029 |
Tester |
Light |
N/A |
O-6-030 |
Tester |
Light |
N/A |
O-6-031 |
South to north |
Tester |
Light |
N/A |
Testing network convergence
Overlay IPv4 network convergence
Device |
Failure type |
Traffic interruption time |
Recovery type |
Leaf |
Single point of failure for ECMP uplinks |
< 500 ms |
Recovery from single point of failure for ECMP uplinks |
< 150 ms |
Single point of failure for M-LAG member links |
< 500 ms |
Recovery from single point of failure for M-LAG member links |
< 150 ms |
Peer link failure |
< 500 ms |
Peer link failure recovery |
< 150 ms |
Keepalive link failure |
0 ms |
Keepalive link failure recovery |
0 ms |
Device rebooting |
< 500 ms |
Device reboot recovery |
< 150 ms |
Upgrading a device |
< 500 ms |
N/A |
N/A |
Expanding the network |
< 500 ms |
N/A |
N/A |
Replacing hardware |
< 500 ms |
N/A |
N/A |
Spine |
Device rebooting |
< 500 ms |
< 150 ms |
< 500 ms |
N/A |
N/A |
Overlay IPv6 network convergence
Device |
Failure type |
Recovery type |
Leaf |
< 500 ms |
< 150 ms |
< 500 ms |
< 150 ms |
Peer link failure |
< 500 ms |
< 150 ms |
0 ms |
Recovery from keepalive link failure |
0 ms |
Device rebooting |
< 500 ms |
< 150 ms |
Spine |
Device rebooting |
< 500 ms |
< 150 ms |
Verification commands
Leaf 1 |
Leaf 2 |
display m-lag summary |
Displays summary information about the peer-link interface and M-LAG interfaces. |
display m-lag system |
Displays the M-LAG system settings. |
display m-lag keepalive |
Displays M-LAG keepalive packet statistics. |
display m-lag role |
Displays M-LAG role information. |
display m-lag consistency { type1 | type2 } |
Displays information about the configuration consistency check done by M-LAG. |
display m-lag consistency-check status |
Displays the configuration consistency check status. |
display interface Bridge-Aggregation [ brief ] |
Displays information about Layer 2 aggregate interfaces. |
display m-lag virtual-ip |
Displays M-LAG virtual IP addresses. |
display stp brief |
display stp brief |
Displays brief spanning tree status and statistics. |
# On Leaf 1, verify that Leaf 1 and Leaf 2 have formed an M-LAG system.
<Leaf 1> display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
M-LAG interface information
M-LAG interface M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG2 1 UP UP -
BAGG3 2 UP UP -
# On Leaf 1, display the M-LAG system settings.
<Leaf 1> display m-lag system
System information
Local system number: 1 Peer system number: 2
Local system MAC: dcda-8037-1324 Peer system MAC: dcda-8037-1324
Local system priority: 100 Peer system priority: 100
Local bridge MAC: dcda-8037-1324 Peer bridge MAC: 2019-1010-1000
Local effective role: Primary Peer effective role: Secondary
Health level: 0
Standalone mode on split: Disabled
In standalone mode: No
System timer information
Timer State Value (s) Remaining time (s)
Auto recovery Disabled - -
Restore delay Disabled 180 -
Consistency-check delay Disabled 90 -
Standalone delay Disabled - -
Role to None delay Disabled 60 -
# On Leaf 1, display M-LAG keepalive packet statistics..
<Leaf 1> display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 76743 s 787 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 100.0.0.2
Time: 2001/01/20 02:26:37
Action: Accept
M-LAG keepalive parameters:
Destination IP address: 100.0.0.2
Source IP address: 100.0.0.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
# On Leaf 1, display the configuration consistency check status.
<Leaf 1> display m-lag consistency-check status
Global Consistency Check Configuration
Local status : Enabled Peer status : Enabled
Local check mode : Strict Peer check mode : Strict
Consistency Check on Modules
Module Type1 Type2
LAGG Check Check
VLAN Check Check
STP Check Check
MAC Not Check Check
L2VPN Not Check Check
PORTSEC Not Check Not Check
DOT1X Not Check Not Check
MACA Not Check Not Check
WEBAUTH Not Check Not Check
NETANALYSIS Not Check Check
Type1 Consistency Check Result
Global consistency check result: SUCCESS
Inconsistent global modules: -
M-LAG interface M-LAG group ID Check Result Inconsistency modules
BAGG2 1 SUCCESS -
BAGG3 2 SUCCESS -
# On Leaf 1, display information about Layer 2 aggregate interfaces.
<Leaf 1> display interface Bridge-Aggregation brief
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
BAGG1 UP 100G(a) F(a) T 4094
BAGG2 UP 20G(a) F(a) A 1
BAGG3 UP 20G(a) F(a) A 1
# On Leaf 1, display M-LAG virtual IP addresses.
<Leaf 1> display m-lag virtual-ip
Interface IP address MAC address Effective state
Vsi10 20.1.1.5/24 N/A ACTIVE
20:1:1:1::5/64 N/A ACTIVE
Vsi20 20.2.1.5/24 N/A ACTIVE
20:2:1:1::5/64 N/A ACTIVE
# On Leaf 1, display brief spanning tree status and statistics.
<Leaf 1> display stp brief
MST ID Port Role STP State Protection
0 Bridge-Aggregation2 (DR) DESI FORWARDING NONE
0 Bridge-Aggregation3 (DR) DESI FORWARDING NONE
0 HundredGigE1/0/32 DESI FORWARDING NONE
Upgrading the devices
Upgrading the leaf devices
Checking the environment
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for an upgrade.
Leaf 1 |
Leaf 2 |
display device |
display device |
Displays device information. |
display boot-loader |
Displays current software images and startup software images. |
display version |
display version |
Displays system version information. |
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the traffic interruption time is shorter than 500 ms during the upgrade. For more information, see "Testing network convergence."
Verifying the upgrade result
Execute the commands in "Verification commands" and the following commands to verify that the device is upgraded successfully.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Upgrading the spine devices
Spine 1 |
Spine 2 |
display device |
display device |
display version |
display version |
1. Use the display version command to obtain the current BootWare image version and startup software version.
2. Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡ Software and hardware compatibility.
¡ Version and size of the upgrade software.
¡ Compatibility of the upgrade software with the current BootWare image and startup software image.
3. Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image.
4. Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command.
5. Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system.
6. Upgrade the device according to the configuration guides for the device.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Upgrading the border device
Border 1 |
Border 2 |
display device |
display device |
display version |
display version |
Verify that the south-north traffic is interrupted during the upgrade. Other traffic is not interrupted or is interrupted transiently.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
An expansion operation adds two leaf devices.
Adding a leaf device
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an expansion.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Adding the device to the leaf tier
1. Disconnect the device from network management systems.
2. Upgrade the software of the device as needed.
3. Preconfigure the device.
4. Connect the device to network management systems.
5. Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Replacing a leaf device
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for a replacement.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Replacing the device
Traffic interruption time is the same for replacing and upgrading operations. For more information, see the traffic interruption time for upgrading a leaf device in "Testing network convergence."
Verifying the replacement result
Execute the commands in "Verification commands" and the following commands to verify that the device is replaced successfully.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
