H3C Data Center Switches M-LAG Configuration Guide-6W100
HomeSupportResource CenterConfigure & DeployConfiguration GuidesH3C Data Center Switches M-LAG Configuration Guide-6W100
01-M-LAG+IPv4 and IPv6 Dual-Active VLAN Gateway Configuration Example
Example: Configuring IPv4 and IPv6 dual-active VLAN gateways on an M-LAG network  1
Network configuration· 1
Applicable product matrix· 4
Analysis· 5
Restrictions and guidelines· 5
Configuring the M-LAG system·· 5
Procedure summary· 5
Configuring the interconnect links between the M-LAG system and the downlink device Device D·· 5
Configuring the dual-active gateways· 9
Configuring Layer 3 communication between M-LAG member devices· 11
Configuring the interconnect links between the M-LAG system and the uplink device Device C· 12
Configuring the single-homed interface of the M-LAG system·· 13
Configuring a dynamic routing protocol used for communication with Device D·· 13
Configuring uplink device Device C· 14
Procedure summary· 14
Configuring the interconnect links to the M-LAG member devices· 14
Configuring the interconnect links between the uplink device Device C and the network· 16
Configuring downlink device Device D·· 17
Procedure summary· 17
Configuring the interconnect links to the M-LAG member devices· 17
Setting up OSPF and OSPFv3 peer relationships with the M-LAG member devices· 18
Traffic forwarding models· 19
Underlay traffic characteristics· 19
Forwarding models· 19
Testing network convergence upon single points of failure· 20
Verifying the configuration· 21
Upgrading the devices· 25
Upgrading the M-LAG member devices· 25
Expanding the network· 25
Adding an M-LAG member device· 26
Replacing hardware· 27
Replacing a service module· 27
Replacing a switching fabric module· 27
Replacing a device· 28
As shown in Figure 1:
·     Device A and Device B form an M-LAG system. Device D accesses the M-LAG system through M-LAG interfaces.
·     Device A and Device B are connected to uplink device Device C through equal-cost routes.
Configure the network as follows to meet the server access requirements of users:
·     The two M-LAG member devices Device A and Device B both act as the IPv4 gateway and IPv6 gateway for the servers.
·     If the link between Device A or Device B and uplink device Device C fails, packets can be transmitted along the other M-LAG member device to Device C to avoid interrupting the servers’ communication with the external network.
In some scenarios, the devices or servers attached to the M-LAG interfaces are required to establish routing peer relationships with the M-LAG member devices.
Figure 1 Network diagram
Table 1 Topology and IP assignment
Device
IP address
Peer device and interface
Device A
HGE1/0/1
N/A
Device D: HGE1/0/1
HGE1/0/2
N/A
Device D: HGE1/0/2
HGE1/0/3
N/A
Device B: HGE1/0/3
HGE1/0/4
N/A
Device B: HGE1/0/4
HGE1/0/5
IPv4: 21.1.1.1/24
IPv6: 21::1/64
Device B: HGE1/0/5
HGE1/0/6
N/A
Device C: HGE1/0/1
HGE1/0/7
N/A
N/A
Vlan-int100
IPv4: 100.1.1.100/24
M-LAG virtual IPv4 address: 100.1.1.101/24
IPv6: 100::100/64
M-LAG virtual IPv6 address: 100::101
N/A
Vlan-int101
IPv4: 101.1.1.1/24
IPv6: 101::1/64
Device B: Vlan-int101
·     IPv4: 101.1.1.2/24
·     IPv6: 101::2/64
Vlan-int32
IPv4: 32.1.1.1/24
IPv6: 32::1/64
Device C: Vlan-int32
·     IPv4: 32.1.1.2/24
·     IPv6: 32::2/64
Device B
HGE1/0/1
N/A
Device D: HGE1/0/3
HGE1/0/2
N/A
Device D: HGE1/0/4
HGE1/0/3
N/A
Device A: HGE1/0/3
HGE1/0/4
N/A
Device A: HGE1/0/4
HGE1/0/5
IPv4: 21.1.1.2/24
IPv6: 21::2/64
Device A: HGE1/0/5
HGE1/0/6
N/A
Device C: HGE1/0/2
Vlan-int100
M-LAG virtual IPv4 address: 100.1.1.102/24
IPv6: 100::100/64
M-LAG virtual IPv6 address: 100::102
N/A
Vlan-int101
IPv4: 101.1.1.2/24
IPv6: 101::2/64
Device A: Vlan-int101
·     IPv4: 101.1.1.1/24
·     IPv6: 101::1/64
Vlan-int33
IPv4: 33.1.1.1/24
IPv6: 33::1/64
Device C: Vlan-int33
·     IPv4: 33.1.1.2/24
·     IPv6: 33::2/64
Device C
HGE1/0/1
N/A
Device A: HGE1/0/6
HGE1/0/2
N/A
Device B: HGE1/0/6
HGE1/0/3
N/A
Network
Vlan-int22
IPv4: 22.1.1.1/24
IPv6: 22::1/64
Network
Vlan-int32
IPv4: 32.1.1.2/24
IPv6: 32::2/64
Device A: Vlan-int32
·     IPv4: 32.1.1.1/24
·     IPv6: 32::1/64
Vlan-int33
IPv4: 33.1.1.2/24
IPv6: 33::2/64
Device B: Vlan-int33
·     IPv4: 33.1.1.1/24
·     IPv6: 33::1/64
Device D
HGE1/0/1
N/A
Device A: HGE1/0/1
HGE1/0/2
N/A
Device A: HGE1/0/2
HGE1/0/3
N/A
Device B: HGE1/0/1
HGE1/0/4
N/A
Device B: HGE1/0/2
Vlan-int100
IPv4: 100.1.1.110/24
IPv6: 100::110
Routing peers to the M-LAG virtual IP addresses assigned to VLAN-interface 100 on the M-LAG member devices
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Device
Software version
S6805, S6825, S6850, S9850, S9820-64H, S9820-8C
R6710
S6800, S6860
R6710
S12500X-AF, S6890
R2825
S12500G-AF
R7625
S6812, S6813
F6628P22 and higher
Analysis
·     Configure VLAN-interface 100 on Device A and Device B to act as the IPv4 and IPv6 dual-active gateways. To enable IPv4 and IPv6 users to access the external network through the gateways, configure the same IPv4 address, MAC address, IPv6 address, and IPv6 link-local address for VLAN-interface 100 on Device A and Device B.
·     Enable Device A and Device B to communicate at Layer 3 through VLAN-interface 101. Then, packets can be routed to the other M-LAG member device when the link between Device A or Device B and uplink device Device C fails.
All the devices were started with the factory default configuration. When you are working on a live network, make sure the existing configuration does not conflict with the following configuration.
The M-LAG system MAC address must be the same for devices in the same M-LAG system. The M-LAG system MAC addresses must be different for devices in different M-LAG systems.
For how to set the MAC addresses for dual-active gateways on S12500X-AF series switches, see S12500X-AF MAC address configuration guide in the recommended M-LAG networking solutions.
Procedure summary
·     Configuring the interconnect links between the M-LAG system and the downlink device Device D
·     Configuring the dual-active gateways
·     Configuring Layer 3 communication between M-LAG member devices
·     Configuring the interconnect links between the M-LAG system and the uplink device Device C
·     Configuring the single-homed interface of the M-LAG system
·     Configuring a dynamic routing protocol used for communication with Device D
Device A
Device B
Remarks
m-lag system-mac 2-2-2
Set the M-LAG system MAC address.
You must set the same M-LAG system MAC address for devices in the same M-LAG system.
m-lag system-number 1
m-lag system-number 2
Set the M-LAG system number.
You must set different M-LAG system numbers for devices in the same M-LAG system.
m-lag system-priority 123
Set the M-LAG system priority.
You must set the same M-LAG system priority for devices in the same M-LAG system.
m-lag standalone enable
Enable M-LAG standalone mode.
N/A
m-lag keepalive ip destination 21.1.1.2 source 21.1.1.1
m-lag keepalive ip destination 21.1.1.1 source 21.1.1.2
Configure the destination and source IP addresses of keepalive packets.
N/A
stp instance 0 root primary
stp instance 0 root primary-
Configure the M-LAG member device as the root STP bridge.
N/A
stp global enable
stp global enable
Enable spanning tree globally.
N/A
stp tc-protection
stp tc-protection
Enable the TC-BPDU guard feature.
To prevent the device from frequently deleting MAC address entries and ARP entries and thus protect the device, enable this feature.
stp bpdu-protection
stp bpdu-protection
Enable BPDU guard globally.
N/A
interface HundredGigE1/0/5
Enter the interface view for the keepalive link.
N/A
port link-mode route
Configure the interface for the keepalive link to operate in route mode as a Layer 3 interface.
N/A
ip address 21.1.1.1 24
ip address 21.1.1.2 24
Configure the source IPv4 address of keepalive packets.
N/A
N/A
N/A
m-lag mad exclude interface HundredGigE1/0/5
Exclude the interface used for M-LAG keepalive detection from the shutdown action by M-LAG MAD.
N/A
interface bridge-aggregation 1
Create the Layer 2 aggregate interface to be used as the peer-link interface and enter interface view.
N/A
link-aggregation mode dynamic
Configure the aggregate interface to operate in dynamic mode.
N/A
N/A
N/A
interface range HundredGigE 1/0/3 HundredGigE 1/0/4
Enter the view of physical interfaces on the peer link.
N/A
port link-aggregation group 1
Assign the physical interfaces on the peer link to the aggregation group for the peer link (aggregation group 1).
N/A
N/A
N/A
port m-lag peer-link 1
Specify the aggregate interface (Bridge-Aggregation 1) as the peer-link interface.
N/A
undo mac-address static source-check enable
Disable the static source check feature to avoid inter-peer link Layer 3 traffic forwarding failures.
You do not need to execute this command on an S12500X-AF, S12500G-AF, or S6890 switch, because inter-peer link Layer 3 traffic forwarding failures do not exist on these switches.
N/A
N/A
interface bridge-aggregation 3
Create an aggregate interface connecting to Device D.
N/A
Configure the aggregate interface connecting to Device D to operate in dynamic mode.
N/A
port m-lag group 1
port m-lag group 1
Assign the Layer 2 aggregate interface (Bridge-Aggregation 3) to M-LAG group 1.
N/A
N/A
N/A
interface range HundredGigE 1/0/1 HundredGigE 1/0/2
Enter the view of the physical interfaces connecting the M-LAG system to Device D.
N/A
port link-aggregation group 3
Assign the interfaces to an M-LAG group.
N/A
N/A
N/A
m-lag restore-delay 300
Set the data restoration interval.
The data restoration interval specifies the maximum amount of time for the secondary M-LAG member device to synchronize data with the primary M-LAG member device during M-LAG system setup.
Device A
Device B
vlan 100 101
vlan 100 101
Create VLAN 100 and VLAN 101.
N/A
port link-type trunk
Set the link type of the Layer 2 aggregate interface (Bridge-Aggregation 3) to trunk.
port trunk permit vlan 100
Assign the interface to VLAN 100.
port lacp system-priority 100
port lacp system-priority 101
Set the LACP system priority, so that only member ports with higher priority are selected when both peer link and keepalive link fail.
N/A
N/A
Set the link type of the Layer 2 aggregate interface (Bridge-Aggregation 1) to trunk.
port trunk permit vlan all
Assign the interface to all VLANs.
N/A
interface vlan-interface 100
Create VLAN-interface 100.
ip address 100.1.1.100 24
Assign an IPv4 address to VLAN-interface 100, which is to act as an IPv4 dual-active gateway.
mac-address 0000-0010-0010
Assign a MAC address to VLAN-interface 100, which is to act as an IPv4 dual-active gateway.
ipv6 address 100::100 64
Assign an IPv6 address to VLAN-interface 100, which is to act as an IPv6 dual-active gateway.
ipv6 address FE80::80 link-local
Assign a link-local address to VLAN-interface 100, which is to act as an IPv6 dual-active gateway.
ipv6 nd unsolicited-na-learning enable
Enable unsolicited NA learning.
For ND entries to be synchronous on M-LAG member devices, enable this feature.
N/A
m-lag mad exclude interface Vlan-interface100
Exclude VLAN-interface100 from the shutdown action by M-LAG MAD.
interface vlan-interface 101
Create VLAN-interface 101.
ip address 101.1.1.1 24
ip address 101.1.1.2 24
Assign an IPv4 address to VLAN-interface 101, which is used for Layer 3 communication between M-LAG member devices.
ipv6 address 101::1 64
ipv6 address 101::2 64
Assign an IPv6 address to VLAN-interface 101, which is used for Layer 3 communication between M-LAG member devices.
N/A
m-lag mad exclude interface Vlan-interface101
Exclude VLAN-interface101 from the shutdown action by M-LAG MAD.
Device A
Device B
router id 3.3.3.3
router id 4.4.4.4
Configure a router ID.
ospf 1
ospf 1
Configure OSPF to enable M-LAG member devices to communicate through an IPv4 network.
stub-router include-stub on-startup 900
Specify the cost of the stub links (link type 3) in Router LSAs to the maximum value 65535 to accelerate network convergence.
silent-interface Vlan-interface 100
Disable VLAN-interface 100 from receiving and sending OSPF packets.
area 0
area 0
N/A
N/A
N/A
ospf 1 area 0
ospf 1 area 0
Enable OSPF on an interface.
N/A
N/A
ospf 1 area 0
ospf 1 area 0
N/A
ospfv3 1
ospfv3 1
Configure OSPFv3 to enable M-LAG member devices to communicate through an IPv6 network.
router-id 3.3.3.3
router-id 4.4.4.4
stub-router max-metric on-startup 900
Specify the cost of the links in Type-1 LSAs to the maximum value 65535 and specify the router as a stub router during reboot.
area 0
area 0
N/A
N/A
N/A
ospfv3 1 area 0
ospfv3 1 area 0
Enable OSPFv3 on an interface.
N/A
N/A
ospfv3 1 area 0
ospfv3 1 area 0
N/A
Device A
Device B
vlan 32
vlan 33
Create a VLAN.
N/A
interface HundredGigE 1/0/6
N/A
Set the link type of the interface to trunk.
port trunk permit vlan 32
port trunk permit vlan 33
Assign the interface to the specified VLANs.
undo port trunk permit vlan 1
Remove the interface from VLAN 1.
undo stp enable
undo stp enable
Disable STP on the uplink interface to speed up topology convergence.
N/A
interface vlan-interface 32
interface vlan-interface 33
Create a VLAN interface.
ip address 32.1.1.1 24
ip address 33.1.1.1 24
Assign an IPv4 address to a VLAN-interface.
ipv6 address 32::1 64
ipv6 address 33::1 64
Assign an IPv6 address to a VLAN-interface.
ospf 1 area 0
ospf 1 area 0
ospfv3 1 area 0
ospfv3 1 area 0
N/A
Device A
vlan 100
Create a VLAN.
N/A
interface HundredGigE 1/0/7
Configure the single-homed interface.
port link-mode bridge
Configure the interface to operate in bridge mode as a Layer 2 interface.
port link-type access
Set the link type of the interface to access.
port access vlan 100
Assign the interface to the specified VLAN.
Perform this task if the devices or servers attached to the M-LAG member devices are required to establish routing peer relationships with the M-LAG member devices.
Device A
Device B
N/A
port m-lag virtual-ip 100.1.1.101 255.255.255.0 active
port m-lag virtual-ip 100.1.1.102 255.255.255.0 active
Assign an M-LAG virtual IPv4 address to this VLAN interface.
port m-lag ipv6 virtual-ip FE80::81 link-local
port m-lag ipv6 virtual-ip FE80::82 link-local
Assign an M-LAG link-local virtual IPv6 address to this VLAN interface.
port m-lag ipv6 virtual-ip 100::101 64 active
port m-lag ipv6 virtual-ip 100::102 64 active
Assign an M-LAG virtual IPv6 address to this VLAN interface, and set the state of the address to active.
ospf peer sub-address enable 100.1.1.101
ospf peer sub-address enable 100.1.1.102
Enable OSPF to use secondary IP addresses to set up peer relationships.
N/A
Procedure summary
·     Configuring the interconnect links to the M-LAG member devices
·     Configuring the interconnect links between the uplink device Device C and the network
Device C
vlan 32
Create VLAN 32.
N/A
interface HundredGigE 1/0/1
N/A
Assign HundredGigE 1/0/1 (which connects Device C to Device A) to VLAN 32.
undo stp enable
Disable the spanning tree protocol to speed up topology convergence.
N/A
Create VLAN-interface 32.
ip address 32.1.1.2 24
Assign an IPv4 address to the VLAN-interface.
ipv6 address 32::2 64
Assign an IPv6 address to the VLAN-interface.
N/A
vlan 33
Create VLAN 33.
N/A
interface HundredGigE 1/0/2
N/A
Assign HundredGigE 1/0/2 (which connects Device C to Device B) to VLAN 33.
undo stp enable
N/A
Create VLAN-interface 33.
ip address 33.1.1.2 24
ipv6 address 33::2 64
N/A
router id 5.5.5.5
ospf 1
area 0
N/A
N/A
N/A
ospf 1 area 0
Enable OSPF on the interface.
N/A
N/A
ospf 1 area 0
N/A
ospfv3 1
router id 5.5.5.5
Configure a Router ID.
area 0
N/A
N/A
N/A
ospfv3 1 area 0
Enable OSPFv3 on the interface.
N/A
N/A
ospfv3 1 area 0
N/A
Device C
vlan 22
Create VLAN 22.
N/A
interface HundredGigE 1/0/3
N/A
port trunk permit vlan 22
Assign HundredGigE 1/0/3 (which connects Device C to the network) to VLAN 22.
undo stp enable
N/A
interface vlan-interface 22
Create VLAN-interface 22.
ip address 22.1.1.1 24
ipv6 address 22::1 64
N/A
Procedure summary
·     Setting up OSPF and OSPFv3 peer relationships with the M-LAG member devices
Device D
Create Layer 2 aggregate interface Bridge-Aggregation 3, and enter its view.
Configure the aggregate interface connecting to the M-LAG system to operate in dynamic mode.
N/A
interface range HundredGigE 1/0/1 to HundredGigE 1/0/4
Enter the view of the physical interfaces connecting Device D to the M-LAG system.
Assign interfaces to an aggregation group.
N/A
vlan 100
Create VLAN 100.
N/A
N/A
N/A
Device D
router id 6.6.6.6
Configure the router ID.
ospf 1
Configure OSPF to set up IPv4 connectivity to the M-LAG member devices.
area 0
Create an OSPF area and enter its view.
N/A
N/A
ip address 100.1.1.110 255.255.255.0
Assign an IPv4 address to this VLAN interface.
ipv6 address FE80::83 link-local
Assign an IPv6 link-local address to this VLAN interface.
ipv6 address 100::110 64
Assign an IPv6 address to this VLAN interface.
ospf 1 area 0.0.0.0
Enable OSPF on VLAN-interface 100.
ospfv3 1 area 0.0.0.0
Enable OSPFv3 on VLAN-interface 100.
N/A
The forwarding model matrix provides the following characteristics of underlay traffic:
·     No.—Traffic number in the U-X-XXX format:
¡     UUnderlay traffic.
¡     X—Protocol number, which can be 4 (IPv4) or 6 (IPv6).
¡     XXX—Traffic sequence number.
·     Traffic type—Type of underlay traffic, which can be IPv4 known unicast or IPv6 known unicast.
·     Direction—Direction of underlay traffic.
·     Forwarding path—Nodes that underlay traffic traverses.
·     Traffic simulation—Traffic simulation method. Typically a tester is used to simulate server traffic.
·     Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
·     Traffic direction to firewalls/LB—Configuration used to direct traffic to firewalls and load balancers, other than PBR, M-LAG, VRRP, static routes.
Forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
U-4-101
IPv4 known unicast
South to north
Network > DeviceC > DeviceA&B > DeviceD > Server
Tester
Light
N/A
U-6-101
IPv6 known unicast
South to north
Tester
Light
N/A
Table 2 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time
M-LAG
Single point of failure on M-LAG member links
< 500 ms
Single point of failure restored on M-LAG member links
< 500 ms
Single point of failure on uplink ECMP links
< 500 ms
Single point of failure restored on uplink ECMP links
< 500 ms
Peer link failure
< 500 ms
Peer link failure restored
< 500 ms
Keepalive link failure
0 ms
Keepalive link failure restored
0 ms
Keepalive link and peer link failure
< 5000 ms
Keepalive link and peer link restored
< 1000 ms
< 500 ms (per-device upgrade)
N/A
Replacing hardware
Fixed-port device: < 500 ms
Modular device:
·     Device replacement: < 1000 ms
·     Switching fabric module replacement: 0 ms
·     Service module replacement: < 500 ms
Verifying the status of the M-LAG system
Verify that the peer-link interface and the M-LAG interface are working correctly on Device A and Device B. Use Device A as an example.
# Display summary information about the peer-link interface and M-LAG interface.
[DeviceA] display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG IF    M-LAG group  Local state (cause)  Peer state  Remaining down time (s)
BAGG3       1            UP                   UP          -
# Verify that keepalive link is working correctly.
[DeviceA] display m-lag keepalive
Neighbor keepalive link status: Up
Neighbor is alive for: 64765 s 28 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 21.1.1.2
  Time: 2021/01/17 17:10:52
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 21.1.1.2
Source IP address: 21.1.1.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Display the M-LAG system settings.
<DeviceA> display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: 0002-0002-0002            Peer system MAC: 0002-0002-0002
Local system priority: 123                  Peer system priority: 123
Local bridge MAC: 3cd4-3ce1-0200            Peer bridge MAC: 3cd4-437d-0300
Local effective role: Primary               Peer effective role: Secondary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: No
                     System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    300          -
Consistency-check delay    Disabled    150          -
Standalone delay           Disabled    -            -
Role to None delay         Disabled    60           -
# Display detailed information about the peer-link interface and M-LAG interfaces.
[DeviceA] display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE1/0/3 (27), HGE1/0/4 (32)
Peer Selected ports indexes: 125, 130
M-LAG interface/M-LAG group ID: BAGG3/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=0002-0002-0002, Effective=0002-0002-0002
Peer M-LAG interface LACP MAC: Config=0002-0002-0002, Effective=0002-0002-0002
Local M-LAG interface LACP priority: Config=123, Effective=123
Peer M-LAG interface LACP priority: Config=123, Effective=123
Local Selected ports (index): HGE1/0/1 (12), HGE1/0/2 (13)
Peer Selected ports indexes: 56, 57
Verifying the routing protocols
# Display the OSPF neighbors of Device A.
[DeviceA] display ospf peer
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 4.4.4.4         101.1.1.2       1   36         Full/DR           Vlan101
 5.5.5.5         32.1.1.2        1   38         Full/DR           Vlan32
 6.6.6.6         100.1.1.110     1   36         Full/DR           Vlan100
# Display the OSPFv3 neighbors of Device A.
[DeviceA] display ospfv3 peer
               OSPFv3 Process 1 with Router ID 3.3.3.3
 Area: 0.0.0.0
 Router ID       Pri State             Dead-Time InstID Interface
 4.4.4.4         1   Full/DR           00:00:36  0      Vlan101
 5.5.5.5         1   Full/DR           00:00:35  0      Vlan32
 6.6.6.6         1   Full/DR           00:00:35  0      Vlan100
# Display the OSPF neighbors of Device B.
[DeviceB] display ospf peer
         OSPF Process 1 with Router ID 4.4.4.4
 Area: 0.0.0.0
 3.3.3.3         101.1.1.1       1   32         Full/BDR          Vlan101
 5.5.5.5         33.1.1.2        1   33         Full/DR           Vlan33
# Display the OSPFv3 neighbors of Device B.
[DeviceB] display ospfv3 peer
               OSPFv3 Process 1 with Router ID 4.4.4.4
 Area: 0.0.0.0
 3.3.3.3         1   Full/BDR          00:00:35  0      Vlan101
 5.5.5.5         1   Full/DR           00:00:38  0      Vlan33
 6.6.6.6         1   Full/DR           00:00:36  0      Vlan100
# Display the OSPF neighbors of Device C.
[DeviceC] display ospf peer
         OSPF Process 1 with Router ID 5.5.5.5
 Area: 0.0.0.0
 3.3.3.3         32.1.1.1        1   32         Full/DR           Vlan32
 4.4.4.4         33.1.1.1        1   38         Full/DR           Vlan33
# Display the OSPFv3 neighbors of Device C.
[DeviceC] display ospfv3 peer
               OSPFv3 Process 1 with Router ID 5.5.5.5
 Area: 0.0.0.0
 3.3.3.3         1   Full/DR           00:00:37  0      Vlan32
 4.4.4.4         1   Full/DR           00:00:34  0      Vlan33
Verifying that Server 1 and Server 2 can communicate with Network
Server 1 and Server 2 can communicate with Network through both IPv4 and IPv6 addresses.
Verifying that Server 1 and Server 2 can still communicate with Network when the uplink interface of Device A or Device B fails
Disconnect the interface connecting Device A to Device C. Server 1 and Server 2 can still communicate with Network (transient packet loss occurs during the traffic switchover process).
Displaying the brief spanning tree status and statistics
<DeviceA> display stp brief
 MST ID      Port                         Role  STP State     Protection
 0           Bridge-Aggregation3 (M-LAG)     DESI  FORWARDING    NONE
<DeviceB> display stp brief
Verifying OSPF and OSPFv3 peer establishment with the M-LAG virtual IP addresses
[DeviceD]display ospf peer
         OSPF Process 1 with Router ID 6.6.6.6
 Area: 0.0.0.0
 3.3.3.3         100.1.1.101     1   38         Full/DR           Vlan100
 4.4.4.4         100.1.1.102     1   33         Full/DROther      Vlan100
[DeviceD]display ospfv3 peer
               OSPFv3 Process 1 with Router ID 6.6.6.6
 Area: 0.0.0.0
 3.3.3.3         1   Full/DROther      00:00:32  0      Vlan100
 4.4.4.4         1   Full/BDR          00:00:34  0      Vlan100
Checking the environment
Execute the commands in "Verifying the configuration" and the following commands to verify that the devices are available for an upgrade.
M-LAG 1
M-LAG 2
display device
display device
Displays device information
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the traffic interruption time is shorter than 500 ms during a switchover and shorter than 150 ms during fallback when the traffic load is light. For more information, see “Testing network convergence upon single points of failure.”
Verifying the upgrade result
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is upgraded successfully.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
An expansion operation adds two leaf devices.
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for an expansion.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Disconnect the device from network management systems.
2.     Upgrade the software of the device as needed.
3.     Preconfigure the device.
4.     Connect the device to network management systems.
5.     Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Execute the commands in "Verifying the configuration" and the following commands to verify that the target device is available for a replacement.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Switch service and management traffic on the target service module to other service modules.
2.     Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the replacement result
Execute the commands in "Checking the environment."
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
Replacing a device
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing a device
  • Become a Partner
  • Partner Resources
