H3C Data Center Switches M-LAG Configuration Guide-6W100
HomeSupportResource CenterConfigure & DeployConfiguration GuidesH3C Data Center Switches M-LAG Configuration Guide-6W100
14-M-LAG and DCI Configuration Example
14-M-LAG and DCI Configuration Example 210.11 KB
Example: Configuring M-LAG and DCI
As shown in Figure 1:
·     The two EDs in each data center (DC) form an M-LAG system. The interfaces connected the EDs in different DCs operate in Layer 3 mode.
·     Run a dynamic routing protocol on the EDs. In this example, OSPF is used.
·     All the EDs are connected to spine devices.
In this example, the same tenant uses the same VXLAN ID and L3 VXLAN ID for inter-DC communication.
Figure 1 Network diagram
Device
IP address
Spine 1
Loopback 0
100.1.1.37/32
HGE 1/1/1
Borrowed from Loopback 0
HGE 1/1/2
Spine 2
Loopback 0
101.1.1.17/32
HGE 1/1/1
HGE 1/1/2
ED 1
Loopback 0
100.1.1.47/32
Loopback 2
100.1.1.19/32
HGE 1/0/25
HGE 1/0/27
9.1.1.1/24
ED 2
Loopback 0
100.1.1.48/32
Loopback 2
100.1.1.19/32
HGE 1/0/25
HGE 1/0/27
9.1.2.1/24
ED 3
Loopback 0
101.1.1.26/32
Loopback 2
101.1.1.19/32
HGE 1/0/25
HGE 1/0/27
9.1.1.2/24
ED 4
Loopback 0
101.1.1.27/32
Loopback 2
101.1.1.19/32
HGE 1/0/25
HGE 1/0/27
9.1.2.2/24
Applicable product matrix
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Role
Device
Software version
ED
S6805, S6825, S6850, and S9850
R6710
S6800 and S6860
R6710
S12500X-AF and S6890
R2825
S12500G-AF
R7625
S9820-64H and S9820-8C
Not supported
S6812 and S6813
Not supported
SDN controller
N/A
E6103 or higher versions
Before you use a higher version than E6103, contact H3C support to verify version compatibility.
·     You must configure the same M-LAG system MAC address for the M-LAG member devices in an M-LAG system and configure different M-LAG system MAC addresses for the M-LAG member devices in different M-LAG systems. Make sure each M-LAG system has a unique M-LAG system MAC address in the network.
·     This example covers the settings on the EDs. For more information about configuring the spine and leaf devices, see the configuration guides for the devices.
·     Before you perform the tasks in this example, perform the following tasks:
a.     Configure IP addresses and masks for interfaces.
b.     Configure routing protocols on the transport network to ensure that the devices have routes to reach one another.
·     The spine in each DC establishes IBGP peer relationship with the ED and leaf devices in the local DC. The EDs in one DC establish EBGP peer relationship with the EDs in the other DC.
Configuring EDs
Procedure summary
·     Configuring EDs in data center 1
·     Configuring EDs in data center 2
ED 1 (S6850)
ED 2 (S6850)
Configuration method
Remarks
m-lag system-mac 2-2-2
Manual or controller-based
Configure the M-LAG system MAC address.
For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on them.
m-lag system-number 1
m-lag system-number 2
Set the M-LAG system number.
You must assign different M-LAG system numbers to the M-LAG member devices in an M-LAG system.
m-lag system-priority 123
Set the M-LAG system priority.
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system.
m-lag keepalive ip destination 1.0.2.2 source 1.0.2.1
m-lag keepalive ip destination 1.0.2.1 source 1.0.2.2
Specify the destination and source IP addresses of keepalive packets.
N/A
interface twenty-fivegige 1/0/56
Enter the view of Twenty-FiveGigE 1/0/56. The interface is attached to the keepalive link.
N/A
port link-mode route
Set the link mode of the keepalive interface to Layer 3.
N/A
ip address 1.0.2.1 24
ip address 1.0.2.2 24
Assign an IP address to Twenty-FiveGigE 1/0/56. This IP address is the source IP address of keepalive packets.
N/A
N/A
N/A
N/A
m-lag mad exclude interface twenty-fivegige 1/0/56
Exclude Twenty-FiveGigE 1/0/56 from the M-LAG MAD shutdown action.
N/A
vlan 4094
vlan 4094
Create VLAN 4094.
N/A
interface bridge-aggregation 1
Create Layer 2 aggregate interface Bridge-Aggregation 1. This interface will be used as the peer-link interface.
N/A
link-aggregation mode dynamic
Configure Bridge-Aggregation 1 to operate in dynamic aggregation mode.
N/A
N/A
N/A
N/A
interface range hundredgige 1/0/31 hundredgige 1/0/32
Enter the interface range view of physical interfaces that will be assigned to Bridge-Aggregation 1.
N/A
port link-aggregation group 1
Assign the physical interfaces to Bridge-Aggregation 1.
N/A
N/A
N/A
N/A
Enter the view of Bridge-Aggregation 1.
N/A
port m-lag peer-link 1
Specify Bridge-Aggregation 1 as the peer-link interface.
N/A
port trunk pvid vlan 4094
Set the PVID of the peer-link interface to 4094.
N/A
N/A
N/A
N/A
interface loopback 0
Create Loopback 0 and enter its view.
N/A
ip address 100.1.1.47 32
ip address 100.1.1.48 32
Assign an IP address to the interface.
The IP address must be a local IP address.
interface loopback 2
Create Loopback 2 and enter its view.
N/A
ip address 100.1.1.19 32
Specify the virtual VTEP address.
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
Disable remote-MAC address learning.
N/A
vxlan tunnel arp-learning disable
Disable remote ARP learning for VXLANs.
N/A
vxlan tunnel nd-learning disable
Disable remote ND learning for VXLANs.
N/A
vxlan default-decapsulation source interface loopback 0
Enable default IPv4 VXLAN decapsulation and specify source interface Loopback 0.
N/A
l2vpn m-lag peer-link ac-match-rule vxlan-mapping
Enable the switch to create frame match criteria based on VXLAN IDs for the dynamic ACs on the directly connected peer link.
N/A
ospf 65530 router-id 172.10.1.47
ospf 65530 router-id 172.10.1.48
Enable OSPF process 65530 on the underlay network.
N/A
stub-router include-stub on-startup 900
Configure the router as a stub router during reboot and specify the timeout time to 900 seconds.
N/A
area 0.0.0.0
area 0.0.0.0
Create an OSPF area.
N/A
N/A
N/A
N/A
interface range loopback 0 loopback 2
Manual
Enter the interface range view of Loopback 0 and Loopback 2.
N/A
ospf 65530 area 0.0.0.0
Manual
Enable OSPF process 65530 on the loopback interfaces.
N/A
N/A
N/A
N/A
hundredgige 1/0/27
interface
hundredgige 1/0/27
Manual
Enter the view of the DCI interface. A DCI interface is connected to an ED in another DC.
N/A
port link-type route
Manual
Set the link type of the DCI interface to Layer 3.
N/A
ip address 9.1.1.1 255.255.255.0
ip address 9.1.2.1 255.255.255.0
Manual
Assign an IP address to the DCI interface.
N/A
Manual
Enable OSPF process 65530 on the DCI interface.
N/A
ospf peer hold-max-cost duration 60000
Manual
On the DCI interface, enable OSPF to advertise the maximum link cost to neighbors within 60 seconds.
N/A
N/A
N/A
N/A
evpn m-lag group 100.1.1.19
Enable EVPN distributed relay and specify the virtual VTEP address.
N/A
ip vpn-instance USERVRF
Create VPN instance USERVRF for the service network and enter its view.
N/A
router-distinguisher 9:10001
router-distinguisher 10:10001
Configure an RD for the VPN instance.
Do not configure the same RD on both the EDs for the VPN instance.
address-family ipv4
address-family ipv4
Enter VPN instance IPv4 address family view.
N/A
vpn-target 0:10001 1:10001 import-extcommunity
Configure the import route targets in VPN instance IPv4 address family view.
Make sure the same import route targets are configured for the VPN instance on the EDs.
vpn-target 1:10001 export-extcommunity
Configure the export route targets in VPN instance IPv4 address family view.
Make sure the same export route targets are configured for the VPN instance on the EDs.
address-family ipv6
address-family ipv6
Enter VPN instance IPv6 address family view.
N/A
Configure the import route targets in VPN instance IPv6 address family view.
Configure the export route targets in VPN instance IPv6 address family view.
address-family evpn
address-family evpn
Enter VPN instance EVPN view.
N/A
Configure the import route targets for EVPN.
Make sure the same import route targets are configured for EVPN on the EDs.
Configure the export route targets for EVPN.
Make sure the same export route targets are configured for EVPN on the EDs.
N/A
N/A
N/A
N/A
N/A
N/A
bgp 65530
bgp 65530
Create BGP instance 65530.
N/A
Configure a router ID for the BGP instance.
N/A
group evpn internal
group evpn internal
Create an IBGP peer group named evpn.
N/A
peer evpn connect-interface loopback 0
Specify source interface Loopback 0 for establishing TCP connections to the peer group.
N/A
peer 100.1.1.37 group evpn
Add the spine to peer group evpn.
N/A
peer 101.1.1.26 as-number 65531
Establish EBGP peer relationship with peer ED 3.
N/A
peer 101.1.1.26 ebgp-max-hop 64
Enable BGP to establish EBGP sessions to indirectly connected EBGP peer ED 3, and set the maximum hop count to 64.
N/A
peer 101.1.1.26 source-address 100.1.1.47
peer 101.1.1.26 source-address 100.1.1.48
Specify a source IP address for establishing TCP connections to peer ED 3.
N/A
peer 101.1.1.27 as-number 65531
Establish EBGP peer relationship with peer ED 4.
N/A
peer 101.1.1.27 ebgp-mac-hop 64
Enable BGP to establish EBGP sessions to indirectly connected EBGP peer ED 4, and set the maximum hop count to 64.
N/A
peer 101.1.1.27 source-address 100.1.1.47
peer 101.1.1.27 source-address 100.1.1.48
Specify a source IP address for establishing TCP connections to peer ED 4.
N/A
address-family l2vpn evpn
Enter BGP EVPN address family view.
N/A
nexthop evpn-m-lag group-address
Enable the switch to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address.
N/A
peer evpn enable
peer evpn enable
Enable BGP to exchange unicast routing information with peer group evpn.
N/A
peer 100.1.1.37 next-hop-local
Set the local router as the next hop for routes sent to peer 100.1.1.37.
N/A
peer 101.1.1.26 enable
Enable BGP to exchange unicast routing information with peer 101.1.1.26.
N/A
peer 101.1.1.26 router-mac-local dci
Enable the switch to use its router MAC address to replace the router MAC address of routes received from and advertised to peer 101.1.1.26 and establish VXLAN-DCI tunnels with the peer.
N/A
peer 101.1.1.27 enable
Enable BGP to exchange unicast routing information with peer 101.1.1.27.
N/A
peer 101.1.1.27 router-mac-local dci
Enable the switch to use its router MAC address to replace the router MAC address of routes received from and advertised to peer 101.1.1.27 and establish VXLAN-DCI tunnels with the peer.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
interface vlan-interface 4094
Create VLAN-interface 4094.
N/A
ip address 100.1.1.70 255.255.255.252
ip address 100.1.1.69 255.255.255.252
Assign an IP address to the VLAN interface.
N/A
Enable OSPF process 65530.
N/A
Manual
On the VLAN interface, enable OSPF to advertise the maximum link cost to neighbors within 60 seconds.
N/A
N/A
N/A
N/A
ED 3 (S6850)
ED 4 (S6850)
Remarks
m-lag system-mac 3-3-3
m-lag keepalive ip destination 1.0.3.2 source 1.0.3.1
m-lag keepalive ip destination 1.0.3.1 source 1.0.3.2
N/A
N/A
N/A
ip address 1.0.3.1 24
ip address 1.0.3.2 24
N/A
N/A
N/A
N/A
N/A
vlan 4094
vlan 4094
Create VLAN 4094.
N/A
N/A
N/A
N/A
N/A
N/A
Enter the interface range view of the physical interfaces that will be assigned to Bridge-Aggregation 1.
N/A
N/A
N/A
N/A
N/A
Enter the view of Bridge-Aggregation 1..
N/A
N/A
N/A
N/A
N/A
N/A
N/A
ip address 101.1.1.26 32
ip address 101.1.1.27 32
N/A
ip address 101.1.1.19 32
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
N/A
N/A
N/A
N/A
N/A
ospf 65531 router-id 172.10.2.27
ospf 65531 router-id 172.10.2.26
Enable OSPF process 65531 on the underlay network.
N/A
Manual
N/A
area 0.0.0.0
area 0.0.0.0
N/A
N/A
N/A
N/A
Manual
Enter the interface range of Loopback 0 and Loopback 2.
N/A
ospf 65531 area 0.0.0.0
Manual
Enable OSPF process 65531 on the interfaces.
N/A
N/A
N/A
N/A
hundredgige 1/0/27
interface
hundredgige 1/0/27
Manual
N/A
Manual
N/A
ip address 9.1.1.2 255.255.255.0
ip address 9.1.2.2 255.255.255.0
Manual
N/A
Manual
Enable OSPF process 65531 on the DCI interface.
N/A
Manual
N/A
N/A
N/A
N/A
evpn m-lag group 101.1.1.19
N/A
N/A
router-distinguisher 11:10001
router-distinguisher 12:10001
Do not configure the same RD for the VPN instance on the EDs.
address-family ipv4
address-family ipv4
N/A
address-family ipv6
address-family ipv6
N/A
address-family evpn
address-family evpn
N/A
N/A
N/A
N/A
N/A
N/A
N/A
bgp 65531
bgp 65531
Create BGP instance 65531.
N/A
N/A
group evpn internal
group evpn internal
N/A
N/A
peer 101.1.1.17 group evpn
N/A
peer 100.1.1.47 as-number 65530
Establish EBGP peer relationship with peer ED 1.
N/A
peer 100.1.1.47 ebgp-max-hop 64
Enable BGP to establish EBGP sessions to indirectly connected EBGP peer ED 1, and set the maximum hop count to 64.
N/A
peer 100.1.1.47  source-address 101.1.1.26
peer 100.1.1.47 source-address 101.1.1.27
Specify a source IPv4 address for establishing TCP connections to peer ED 1.
N/A
peer 100.1.1.48 as-number 65530
Establish EBGP peer relationship with peer ED 2.
N/A
peer 100.1.1.48 ebgp-mac-hop 64
Enable BGP to establish EBGP sessions to indirectly connected EBGP peer ED 2, and set the maximum hop count to 64.
N/A
peer 100.1.1.48 source-address 101.1.1.26
peer  100.1.1.48 source-address 101.1.1.27
Specify a source IPv4 address for establishing TCP connections to peer ED 2.
N/A
N/A
N/A
peer evpn enable
peer evpn enable
N/A
peer 101.1.1.17 next-hop-local
Set the local router as the next hop for routes sent to peer 101.1.1.17.
N/A
peer 100.1.1.47 enable
Enable BGP to exchange unicast routing information with peer 100.1.1.47.
N/A
peer 100.1.1.47 router-mac-local dci
Enable the switch to use its router MAC address to replace the router MAC address of routes received from and advertised to peer 100.1.1.47 and establish VXLAN-DCI tunnels with the peer.
N/A
peer 100.1.1.48 enable
Enable BGP to exchange unicast routing information with peer 100.1.1.48.
N/A
peer 100.1.1.48 router-mac-local dci
Enable the switch to use its router MAC address to replace the router MAC address of routes received from and advertised to peer 100.1.1.48 and establish VXLAN-DCI tunnels with the peer.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
ip address 101.1.1.29 255.255.255.252
ip address 101.1.1.30 255.255.255.252
Assign an IP address to VLAN-interface 4094.
N/A
Enable OSPF process 65531.
N/A
Manual
N/A
N/A
N/A
N/A
Overlay traffic forwarding models
Overlay traffic characteristics
The following table describes overlay traffic characteristics:
Parameter
No.
Overlay traffic number in the format of xxx, starting from 001.
Traffic type
Traffic type, which is IPv4 or IPv6 known unicast.
Direction
Traffic direction.
Traffic can be forwarded from south to north across EDs or from north to south across EDs.
Forwarding path
List of nodes that the traffic passes through.
Traffic simulation
Simulation method used in the test. A tester is simulated as a server to transmit traffic.
The following types of traffic is injected:
·     Server A sends 10K ARP or ND request traffic to Server B.
·     Server B replies to the ARP or ND request traffic of Server A. The traffic amount is also 10K.
·     Traffic is sent between the servers and between the servers and the external network. The source port of each flow changes 100th times.
·     20K traffic is sent from each server to the external network through the border.
Load
Traffic load is light or heavy.
If the number of flows is less than 1000, the load is light.
If the number of flows is more than 1000, the load is heavy.
Traffic direction to  firewalls/LB
Enter the method used to direct traffic to firewalls or LBs. In this example, no firewalls or LBs are deployed.
Forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
001
Known unicast/IPv4
DC 1 to DC 2
Server 1 > Leaf 1 > Spine 1 > ED 1 & ED 2 > ED 3 & ED 4 > Spine 2 > Leaf 2 > Server 2
Tester
Light
N/A
002
Known unicast/IPv6
DC 1 to DC 2
Tester
Light
N/A
003
Known unicast/IPv4
DC 2 to DC 1
Server 2 > Leaf 2 > Spine 2 > ED 3 & ED 4 > ED 1 & ED 2 > Spine 1 > Leaf 1 > Server 1
Tester
Light
N/A
004
Known unicast/IPv6
DC 2 to DC 1
Tester
Light
N/A
Testing network convergence upon single points of failure
Table 2 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time
ED
Link failure when the traffic load is light.
500 ms
Link failure recovery when the traffic load is light.
150 ms
Node failure when the traffic load is light.
500 ms
Node failure recovery when the traffic load is light.
150 ms
IMPORTANT
IMPORTANT:
On EDs, use the ospf peer hold-max-cost duration 60000 command on the Layer 3 interfaces connected to spine devices. This configuration ensures fast network convergence upon single points of failure for nodes.
Verification commands
ED
display m-lag summary
Displays summary information about the peer-link interface and M-LAG interfaces.
display m-lag keepalive
Displays M-LAG keepalive packet statistics.
display m-lag role
Displays M-LAG role information.
display m-lag system
Displays the M-LAG system settings.
display bgp peer l2vpn evpn
Displays BGP EVPN peers or peer groups.
This following information uses ED 1 as an example to verify that the EDs have established M-LAG systems and the M-LAG systems are running correctly.
# Display summary information about the peer-link interface and M-LAG interfaces.
[ED1] display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
# Display M-LAG keepalive packet statistics.
[ED1] display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 1471174 s 136 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 100.1.1.53
  Time: 2021/10/28 11:42:21
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 100.1.1.53
Source IP address: 100.1.1.54
Keepalive UDP port : 6400
Keepalive VPN name : auto-online-mlag
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Display M-LAG role information.
[ED1] display m-lag role
                    Effective role information
Factors                  Local                    Peer
Effective role           Secondary                Primary
Initial role             None                     Primary
MAD DOWN state           No                       No
Health level             0                        0
Role priority            32768                    32768
Bridge MAC               5cc9-995f-cb8a           0440-a9b8-52c9
Effective role trigger: Peer link calculation
Effective role reason: Single None role
                    Configured role information
Factors                  Local                    Peer
Configured role          Secondary                Primary
# Display the M-LAG system settings.
[ED1] display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: 2-2-2                     Peer system MAC: 2-2-2
Local system priority: 123                  Peer system priority: 123
Local bridge MAC: 5cc9-995f-cb8a            Peer bridge MAC: 0440-a9b8-52c9
Local effective role: Secondary             Peer effective role: Primary
Health level: 0
Standalone mode on split: Disabled
In standalone mode: No
                     System timer information
Timer                       State      Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    180          -
Consistency-check delay    Disabled    90           -
Standalone delay           Disabled    0            -
Role to None delay         Disabled    60           -
# Verify that ED 1 has established EBGP peer relationship with ED 3, ED 4, and Spine 1.
[ED1] display bgp peer l2vpn evpn
 BGP local router ID: 172.10.1.47
 Local AS number: 65530
 Total number of peers: 3                 Peers in established state: 3
  * - Dynamically created peer
  ^ - Peer created through link-local address
  100.1.1.37           65530   801329  1038226    0     681 0410h40m Established
  101.1.1.26           65531      485      313    0     480 03:06:56 Established
  101.1.1.27           65531      465      301    0     456 03:05:35 Established
Upgrading the devices
Upgrading an ED
Checking the environment
Execute the commands in "Verification commands" and the following commands to verify that the ED is available for an upgrade.
ED
display device
Displays device information.
display boot-loader
Displays current software images and startup software images.
display version
Displays system version information.
Upgrading the ED
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the traffic interruption time is shorter than 500 ms during a switchover and shorter than 150 ms during fallback when the traffic load is light. For more information, see "Testing network convergence upon single points of failure."
Verifying the upgrade result
Execute the commands in "Verification commands" and the following commands to verify that the ED is upgraded successfully.
ED
display device
display boot-loader
display version
Replacing hardware
Replacing a service module
Execute the commands in "Verification commands" and the following commands to verify that the target ED is available for a replacement.
ED
display device
display boot-loader
display version
1.     Switch service and management traffic on the target service module to other service modules.
2.     Power off the ED and replace the service module, or replace the service module when the ED is running. For more information, see the installation guides for the service module.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the replacement result
Execute the commands in "Checking the environment."
Replacing a switching fabric module
ED
display device
display boot-loader
display version
Power off the ED and replace the switching fabric module, or replace the switching fabric module when the ED is running. For more information, see the installation guides for the switching fabric module.
Replacing an ED
ED
display device
display boot-loader
display version
Replacing an ED
  • Become a Partner
  • Partner Resources
