H3C Data Center Switches M-LAG Configuration Guide-6W100
HomeSupportResource CenterConfigure & DeployConfiguration GuidesH3C Data Center Switches M-LAG Configuration Guide-6W100
03-Multi-Layer M-LAG+Dual-Active VLAN Gateway+OSPF Configuration Examples
Example: Configuring multi-layer M-LAG+dual-active VLAN gateway+OSPF
As shown in Figure 1, the user network uses a three-layer architecture: core-aggregation-access. To improve network availability, deploy two devices separately on the core layer, aggregation layer, and access layer. Two devices on each layer form an M-LAG system.
·     Device A and Device B form M-LAG system 1, which acts as the access device and connects to VM.
·     Device C and Device D form M-LAG system 2, which acts as an aggregation device.
·     Device E and Device F form M-LAG system 3, which acts as the core device and connects to Server.
To meet the network access requirements of VM and Server, make sure the M-LAG member devices on the aggregation layer act as both the IPv4 gateway and IPv6 gateway of VM and the M-LAG member devices on the core layer act as both the IPv4 gateway and IPv6 gateway of Server. Run OSPF between the M-LAG member devices on the aggregation layer and M-LAG member devices on the core layer to ensure that they can reach each other at Layer 3.
Figure 1 Network diagram
Device
IP address
Peer device and interface
Device A
XGE1/0/24
IPv4:  220.1.1.1/24
Device B: XGE2/0/24
Device B
XGE2/0/24
IPv4: 220.1.1.2/24
Device A: XGE1/0/24
Device C
WGE1/0/11
IPv4: 220.1.1.3/24
Device D: WGE2/0/11
Vlan-int10
IPv4: 10.1.1.1/24
IPv6: 10:1::1/64
N/A
Vlan-int20
IPv4: 20.1.1.1/24
IPv6: 20:1::1/64
Device E: Vlan-int20
Device F: Vlan-int20
Device D
WGE2/0/11
IPv4: 220.1.1.4/24
Device C: WGE1/0/11
Vlan-int10
IPv4: 10.1.1.1/24
IPv6: 10:1::1/64
N/A
Vlan-int20
IPv4: 20.1.1.1/24
IPv6: 20:1::1/64
Device E
XGE1/4/5
IPv4: 220.1.1.5/24
Device F: XGE2/4/5
Vlan-int20
IPv4: 20.1.1.2/24
IPv6: 20:1::2/64
Device C: Vlan-int20
Device D: Vlan-int20
Vlan-int30
IPv4: 30.1.1.1/24
IPv6: 30:1::1/64
Device G: Vlan-int30
Device F
XGE2/4/5
IPv4: 220.1.1.6/24
Device E: XGE1/4/5
Vlan-int20
IPv4: 20.1.1.2/24
IPv6: 20:1::2/64
Vlan-int30
IPv4: 30.1.1.1/24
IPv6: 30:1::1/64
Applicable product matrix
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Device
Software version
S6805, S6825, S6850, S9850, S9820-64H, S9820-8C
R6710
S6800/S6860
R6710
S12500X-AF, S6890
R2825
S12500G-AF
Under verification. To obtain the latest images, contact Technical Support.
S6812, S6813
F6628P22 and later
Analysis
Device A and Device B are on the access layer. Device C and Device D are on the aggregation layer. Device E and Device F are on the core layer.
On Device C and Device D, configure an IPv4 address and an IPv6 address for VLAN-interface 10, which will act as the IPv4 gateway address and IPv6 gateway address of VM, respectively. Configure an IPv4 address and an IPv6 address for VLAN-interface 20, which will act as the interconnect interface to devices on the core layer.
On Device E and Device F, configure an IPv4 address and an IPv6 address for VLAN-interface 30, which will act as the IPv4 gateway address and IPv6 gateway address of Server, respectively. Configure an IPv4 address and an IPv6 address for VLAN-interface 20, which will act as the interconnect interface to devices on the aggregation layer.
On Device C, Device D, Device E, and Device F, assign an M-LAG virtual IP address to VLAN-interface 20, and enable OSPF to use the secondary IP addresses of interfaces to establish neighbor relationships. On Device C and Device D, enable OSPF and OSPFv3 on VLAN-interface 10 and VLAN-interface 20. On Device E and Device F, enable OSPF and OSPFv3 on VLAN-interface 20 and VLAN-interface 30. Configure Device C to use the M-LAG virtual IP address of VLAN-interface 20 to establish OSPF/OSPFv3 neighbor relationships with Device D, Device E, and Device F. Configure Device D, Device E, and Device F in the same way. Each device uses the M-LAG virtual IP address to establish OSPF/OSPFv3 neighbor relationships with the other three devices.
Configuring the M-LAG systems
Procedure summary
·     Configuring M-LAG
·     Configuring the dual-active gateways
·     Configuring OSPF between M-LAG member devices
Configuring M-LAG
Configuring Device A and Device B
Device A
Device B
Remarks
m-lag system-mac 2-2-2
Configure the M-LAG system MAC address.
You must configure the same M-LAG system MAC address for devices in the same M-LAG system.
m-lag system-number 1
m-lag system-number 2
Set the M-LAG system number.
You must set different M-LAG system numbers for devices in the same M-LAG system.
m-lag system-priority 123
Set the M-LAG system priority.
You must set the same M-LAG system priority for devices in the same M-LAG system.
m-lag standalone enable
Enable M-LAG standalone mode.
N/A
m-lag keepalive ip destination 220.1.1.2 source 220.1.1.1
m-lag keepalive ip destination 220.1.1.1 source 220.1.1.2
Configure the destination and source IP addresses of keepalive packets.
N/A
interface Ten-GigabitEthernet 1/0/24
interface Ten-GigabitEthernet 2/0/24
Enter the interface view for the keepalive link.
N/A
port link-mode route
Configure the interface for the keepalive link to operate in route mode as a Layer 3 interface.
N/A
ip address 220.1.1.1 24
ip address 220.1.1.2 24
Assign an IP address to the interface for the keepalive link.
N/A
Return to system view.
N/A
m-lag mad exclude interface Ten-GigabitEthernet 1/0/24
m-lag mad exclude interface Ten-GigabitEthernet 2/0/24
Exclude the interface used for M-LAG keepalive detection from the shutdown action by M-LAG MAD.
N/A
interface bridge-aggregation 1
Create the aggregate interface to be used as the peer-link interface and enter interface view.
N/A
N/A
Interface HundredGigE 1/0/28
interface HundredGigE 2/0/28
Enter the view of the peer-link interface.
N/A
port link-aggregation group 1
Assign the peer-link interface to the aggregation group for the peer link.
N/A
N/A
Enter the view of the aggregation group for the peer link.
N/A
undo mac-address static source-check enable
Disable source MAC check on an interface.
N/A
link-aggregation mode dynamic
Configure the peer-link aggregate interface to operate in dynamic mode.
N/A
port m-lag peer-link 1
Specify the aggregate interface (Bridge-Aggregation 1) as the peer-link interface.
N/A
N/A
interface bridge-aggregation 2
Create an aggregate interface connecting to VM.
N/A
Configure the aggregate interface connecting to VM to operate in dynamic mode.
N/A
port m-lag group 2
port m-lag group 2
Assign the aggregate interface (Bridge-Aggregation 2) to M-LAG group 2.
N/A
N/A
interface bridge-aggregation 3
Create an aggregate interface connecting to Device C and Device D.
N/A
Configure the aggregate interface connecting to Device C and Device D to operate in dynamic mode.
N/A
port m-lag group 3
port m-lag group 3
Assign the aggregate interface (Bridge-Aggregation 3) to M-LAG group 3.
N/A
N/A
interface HundredGigE 1/0/27
interface HundredGigE 2/0/27
Enter the view of the physical interfaces connecting the M-LAG system to VM.
N/A
port link-aggregation group 2
Assign the interfaces to an M-LAG group.
N/A
N/A
interface range HundredGigE 1/0/25 HundredGigE 1/0/26
interface range HundredGigE 2/0/25 HundredGigE 2/0/26
Enter the view of the physical interfaces connecting the M-LAG system to Device C and Device D.
N/A
port link-aggregation group 3
N/A
N/A
link-aggregation global load-sharing algorithm 7
Configure a link aggregation load sharing algorithm.
To identify whether traffic is load-shared among aggregation member ports, use the display counters command to view the traffic on each aggregation group member port. If traffic is not well load-shared, you can use this command to specify a proper link aggregation load sharing algorithm.
This command is not supported on the S6812 and S6813 switches.
Configuring Device C and Device D
Device C
Device D
Remarks
m-lag system-mac 1-1-1
m-lag system-priority 124
N/A
m-lag keepalive ip destination 220.1.1.4 source 220.1.1.3
m-lag keepalive ip destination 220.1.1.3 source 220.1.1.4
N/A
interface Twenty-FiveGigE 1/0/11
interface Twenty-FiveGigE 2/0/11
N/A
N/A
ip address 220.1.1.3 24
ip address 220.1.1.4 24
N/A
N/A
m-lag mad exclude interface Twenty-FiveGigE 1/0/11
m-lag mad exclude interface Twenty-FiveGigE 2/0/11
N/A
N/A
N/A
interface HundredGigE 1/0/26
interface HundredGigE 2/0/26
N/A
N/A
N/A
N/A
N/A
Configure the aggregate interface to operate in dynamic mode.
N/A
N/A
N/A
Create an aggregate interface connecting to Device E and Device F.
N/A
Configure the aggregate interface connecting to Device E and Device F to operate in dynamic mode.
N/A
port m-lag group 2
port m-lag group 2
N/A
N/A
Create an aggregate interface connecting to Device A and Device B.
N/A
Configure the aggregate interface connecting to Device A and Device B to operate in dynamic mode.
N/A
port m-lag group 3
port m-lag group 3
N/A
N/A
interface range HundredGigE 1/0/28 HundredGigE 1/0/29
interface range HundredGigE 2/0/28 HundredGigE 2/0/29
Enter the view of the physical interfaces connecting the M-LAG system to Device E and Device F.
N/A
N/A
N/A
interface range HundredGigE 1/0/30 HundredGigE 1/0/31
interface range HundredGigE 2/0/30 HundredGigE 2/0/31
Enter the view of the physical interfaces connecting the M-LAG system to Device A and Device B.
N/A
N/A
N/A
Configuring Device E and Device F
Device E
Device F
Remarks
m-lag system-mac 1-2-3
m-lag system-priority 122
N/A
m-lag keepalive ip destination 220.1.1.6 source 220.1.1.5
m-lag keepalive ip destination 220.1.1.5 source 220.1.1.6
N/A
interface Ten-GigabitEthernet 1/4/5
interface Ten-GigabitEthernet 2/4/5
N/A
N/A
ip address 220.1.1.5 24
ip address 220.1.1.6 24
N/A
N/A
m-lag mad exclude  interface Ten-GigabitEthernet 1/4/5
m-lag mad exclude interface Ten-GigabitEthernet 2/4/5
N/A
N/A
N/A
interface HundredGigE 1/1/8
interface HundredGigE 2/1/8
N/A
N/A
N/A
N/A
N/A
N/A
Specify the aggregate interface (Bridge-Aggregation 1) as the peer link.
N/A
N/A
N/A
N/A
port m-lag group 2
port m-lag group 2
N/A
N/A
Create an aggregate interface connecting to Device G.
N/A
Configure the aggregate interface connecting to Device G to operate in dynamic mode.
N/A
port m-lag group 3
port m-lag group 3
N/A
N/A
interface range HundredGigE 1/0/4 HundredGigE 1/0/5
interface range HundredGigE 2/0/4 HundredGigE 2/0/5
N/A
N/A
N/A
interface HundredGigE1/0/6
interface HundredGigE2/0/6
Enter the view of the physical interface connecting the M-LAG system to Device G.
N/A
N/A
N/A
Device A
Device B
Remarks
vlan 10
vlan 10
Create VLAN 10.
N/A
Enter the view of the aggregate interface connecting to VM.
N/A
port link-type trunk
Set the link type of the Layer 2 aggregate interface to trunk.
N/A
port trunk permit vlan 10
Assign the interface to VLAN 10.
N/A
undo port trunk permit vlan 1
Remove the interface from VLAN 1.
N/A
port lacp system-priority 101
port lacp system-priority 100
Set the LACP priority.
Set different LACP priorities for different M-LAG member devices, so that only member ports with a higher priority are selected upon brain split.
N/A
Enter the view of the aggregate interface connecting to Device C and Device D.
N/A
Set the link type of the Layer 2 aggregate interface (Bridge-Aggregation 3) to trunk.
N/A
N/A
N/A
Device C
Device D
Remarks
vlan 10 20
vlan 10 20
Create VLANs 10 and 20.
N/A
Enter the view of the aggregate interface connecting to Device E and Device F.
N/A
Set the link type of the Layer 2 aggregate interface (Bridge-Aggregation 2) to trunk.
N/A
port trunk permit vlan 20
Assign the interface to VLAN 20.
N/A
N/A
N/A
Enter the view of the aggregate interface connecting to Device A and Device B.
N/A
N/A
N/A
N/A
N/A
interface vlan-interface 10
Create VLAN-interface 10.
N/A
Assign an IPv4 address to VLAN-interface 10, which is to act as an IPv4 dual-active gateway.
N/A
mac-address 0010-0010-0010
Assign a MAC address to VLAN-interface 10.
N/A
ipv6 address 10:1::1 64
Assign an IPv6 address to VLAN-interface 10, which is to act as an IPv6 dual-active gateway.
N/A
N/A
m-lag mad exclude  interface Vlan-interface10
Exclude VLAN-interface 10 from the shutdown action by M-LAG MAD.
N/A
interface vlan-interface 20
Create VLAN-interface 20.
N/A
ip address 20.1.1.1 255.255.255.0
Assign an IPv4 address to VLAN-interface 20.
The address is the address of the interface connecting to core devices.
mac-address 0020-0020-0020
Assign a MAC address to VLAN-interface 20.
N/A
ipv6 address 20:1::1 64
Assign an IPv6 address to VLAN-interface 20.
N/A
m-lag mad exclude  interface Vlan-interface20
Exclude VLAN-interface 20 from the shutdown action by M-LAG MAD.
N/A
Device E
Device F
Remarks
vlan 20 30
vlan 20 30
Create VLANs 20 and 30.
N/A
N/A
N/A
N/A
N/A
N/A
Enter the view of the aggregate interface connecting to Device G.
N/A
N/A
port trunk permit vlan 30
Assign the interface to VLAN 30.
N/A
N/A
N/A
interface vlan-interface 30
Create VLAN-interface 30.
N/A
ip address 30.1.1.1 255.255.255.0
Assign an IPv4 address to VLAN-interface 30.
The address acts as the IPv4 dual-active gateway.
mac-address 0030-0030-0030
Assign a MAC address to VLAN-interface 30.
N/A
ipv6 address 30:1::1 64
Assign an IPv6 address to VLAN-interface 30.
The address acts as the IPv6 dual-active gateway.
N/A
m-lag mad exclude  interface Vlan-interface30
Exclude VLAN-interface 30 from the shutdown action by M-LAG MAD.
N/A
N/A
ip address 20.1.1.2 255.255.255.0
The address is the address of the interface connecting to aggregation devices.
mac-address 0020-0020-0021
N/A
ipv6 address 20:1::2 64
N/A
N/A
Device C
Device D
Remarks
router id 3.3.3.3
router id 4.4.4.4
Configure a router ID.
N/A
ospf 1
ospf 1
Configure an OSPF process.
N/A
area 0
area 0
Configure an OSPF area.
N/A
N/A
Enter VLAN interface view.
N/A
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
Enable OSPF on an interface.
N/A
N/A
N/A
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
N/A
N/A
ospfv3 1
ospfv3 1
Configure an OSPFv3 process.
N/A
router-id 3.3.3.3
router-id 4.4.4.4
N/A
area 0
area 0
Configure an OSFPv3 area.
N/A
N/A
N/A
ospfv3 1 area 0.0.0.0
Enable OSPFv3 on an interface.
N/A
N/A
N/A
N/A
port m-lag virtual-ip 20.1.1.103 255.255.255.0 active
port m-lag virtual-ip 20.1.1.104 255.255.255.0 active
Assign an M-LAG virtual IPv4 address to an interface.
The address is used to establish OSPF neighbor relationships between core devices and the peer M-LAG member devices.
port m-lag ipv6 virtual-ip FE80::6 link-local
port m-lag ipv6 virtual-ip FE80::8 link-local
Assign an M-LAG virtual IPv6 address to an interface.
The address is used to establish OSPFv3 neighbor relationships between core devices and the peer M-LAG member devices.
ospf peer sub-address enable 20.1.1.103
ospf peer sub-address enable 20.1.1.104
Enable OSPF to establish neighbor relationships through the secondary IP addresses of an interface.
The same gateway interface on different M-LAG member devices must be configured with the same IP address and MAC address. Therefore, the M-LAG member devices cannot use the primary address of the interface to establish neighbor relationships with other devices. Therefore, you must enable OSPF to establish neighbor relationships through the secondary IP addresses of an interface.
Device E
Device F
Remarks
router id 1.1.1.1
router id 2.2.2.2
N/A
ospf 1
ospf 1
N/A
area 0
area 0
N/A
N/A
N/A
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
N/A
N/A
N/A
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
N/A
N/A
ospfv3 1
ospfv3 1
N/A
router-id 1.1.1.1
router-id 2.2.2.2
N/A
area 0
area 0
N/A
N/A
N/A
N/A
port m-lag virtual-ip 20.1.1.101 255.255.255.0 active
port m-lag virtual-ip 20.1.1.102 255.255.255.0 active
port m-lag ipv6 virtual-ip FE80::2 link-local
port m-lag ipv6 virtual-ip FE80::4 link-local
ospf peer sub-address enable 20.1.1.101
ospf peer sub-address enable 20.1.1.102
N/A
N/A
N/A
Configuring the uplink device
Device G
vlan 30
Create VLAN 30.
Interface range HundredGigE 2/0/1 HundredGigE 2/0/2
Enter the view of the physical interfaces connecting to Device E and Device F.
Assign physical interfaces to aggregation group 3.
Interface HundredGigE 2/0/64
Enter the view of the interface connecting to Server.
port access vlan 30
Traffic forwarding models
Underlay traffic characteristics
The forwarding model matrix provides the following characteristics of underlay traffic:
·     No.—Traffic number in the U-X-XXX format:
¡     U—Underlay traffic.
¡     X—Protocol number, which can be 4 (IPv4) or 6 (IPv6).
¡     XXX—Traffic sequence number.
·     Traffic type—Type of underlay traffic, which can be IPv4 known unicast or IPv6 known unicast.
·     Direction—Direction of underlay traffic. The value is south-north, which indicates traffic from the south to north.
·     Forwarding path—Nodes that underlay traffic traverses.
·     Traffic simulation—Traffic simulation method. Typically, a tester is used to simulate server traffic.
·     Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
·     Traffic direction to firewalls/LB—No firewalls or LBs are used in this example. This field is not involved.
Forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
U-4-101
IPv4 known unicast
South to north
VM > M-LAG system 1 > M-LAG system 2 > M-LAG system 3 > Server
Tester
Light
N/A
U-6-101
IPv6 known unicast
South to north
Tester
Light
N/A
Testing network convergence upon single points of failure
Table 1 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time
M-LAG
Single point of failure on M-LAG member links
≤ 500 ms
Single point of failure restored on M-LAG member links
0 ms
Peer link failure
≤ 500 ms
Peer link failure restored
≤ 10 ms
Keepalive link failure
0 ms
Keepalive link failure restored
0 ms
Keepalive link and Peer link failure
≤ 5000 ms
Keepalive link and Peer link restored
≤ 10000 ms
Upgrading the devices
≤ 500ms (legacy method, in which two M-LAG member devices are separately upgraded)
Expanding the network
0 ms
Replacing hardware
Fixed-port device: ≤ 500 ms
Modular device:
·     Device replacement: ≤ 1000 ms.
·     Switching fabric module replacement: 0 ms.
·     Service module replacement: ≤ 500 ms.
Verifying the status of the M-LAG system
Verify that the M-LAG system is working correctly on Device C and Device D. Use Device C as an example.
# Display summary information about the peer-link interface and M-LAG interface.
[DeviceC] display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG interface  M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG2         2         UP                   UP          -
BAGG3         3         UP                   UP          -
# Verify that keepalive link is working correctly.
[DeviceC] display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 92565 s 440 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 220.1.1.4
  Time: 2022/01/29 03:35:51
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 220.1.1.4
Source IP address: 220.1.1.3
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Display the M-LAG system settings.
[DeviceC] display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: 0001-0001-0001            Peer system MAC: 0001-0001-0001
Local system priority: 124                  Peer system priority: 124
Local bridge MAC: dcda-8037-2bc0            Peer bridge MAC: 9ce8-9573-aba2
Local effective role: Secondary             Peer effective role: Primary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: No
                     System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              disabled    -            -
Restore delay              disabled    180          -
Consistency-check delay    disabled    90           -
Standalone delay           disabled    0            -
Role to None delay         disabled    60           -
# Display detailed information about the peer-link interface and M-LAG interfaces.
[DeviceC] display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE1/0/26 (30)
Peer Selected ports indexes: 225
M-LAG interface/M-LAG group ID: BAGG2/2
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0001
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0001
Local M-LAG interface LACP priority: Config=32768, Effective=124
Peer M-LAG interface LACP priority: Config=32768, Effective=124
Local Selected ports (index): HGE1/0/28 (40), HGE1/0/29 (45)
Peer Selected ports indexes: 235, 240
M-LAG interface/M-LAG group ID: BAGG3/3
Local Selected ports (index): HGE1/0/30 (50), HGE1/0/31 (55)
Peer Selected ports indexes: 245, 250
Verifying the routing protocols
# Display the OSPF neighbors of Device C.
[DeviceC] display ospf peer
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 1.1.1.1         20.1.1.101      1   36         2-Way/ -          Vlan20
 2.2.2.2         20.1.1.102      1   32         Full/BDR          Vlan20
 4.4.4.4         20.1.1.104      1   31         Full/DR           Vlan20
# Display the OSPFv3 neighbors of Device C.
[DeviceC] display ospfv3 peer
               OSPFv3 Process 1 with Router ID 3.3.3.3
 Area: 0.0.0.0
 Router ID       Pri State             Dead-Time InstID Interface
 1.1.1.1         1   2-Way/ -          00:00:32  0      Vlan20
 2.2.2.2         1   Full/BDR          00:00:40  0      Vlan20
 4.4.4.4         1   Full/DR           00:00:34  0      Vlan20
# Display the OSPF neighbors of Device D.
[DeviceD] display ospf peer
         OSPF Process 1 with Router ID 4.4.4.4
 Area: 0.0.0.0
 1.1.1.1         20.1.1.101      1   36         Full/DROther      Vlan20
 2.2.2.2         20.1.1.102      1   33         Full/BDR          Vlan20
 3.3.3.3         20.1.1.103      1   33         Full/DROther      Vlan20
# Display the OSPFv3 neighbors of Device D.
[DeviceD] display ospfv3 peer
OSPFv3 Process 1 with Router ID 4.4.4.4
Area: 0.0.0.0
1.1.1.1         1   Full/DROther      00:00:33  0      Vlan20
2.2.2.2         1   Full/BDR          00:00:32  0      Vlan20
3.3.3.3         1   Full/DROther      00:00:32  0      Vlan20
# Display the OSPF neighbors of Device E.
[DeviceE] display ospf peer
Area: 0.0.0.0
2.2.2.2         20.1.1.102      1   38         Full/BDR          Vlan20
3.3.3.3         20.1.1.103      1   38         2-Way/ -          Vlan20
4.4.4.4         20.1.1.104      1   37         Full/DR           Vlan20
# Display the OSPFv3 neighbors of Device E.
[DeviceE] display ospfv3 peer
 OSPFv3 Process 1 with Router ID 1.1.1.1
Area: 0.0.0.0
2.2.2.2         1   Full/BDR          00:00:38  0      Vlan20
3.3.3.3         1   2-Way/ -          00:00:38  0      Vlan20
4.4.4.4         1   Full/DR           00:00:32  0      Vlan20
# Display the OSPF neighbors of Device F.
[DeviceF] display ospf peer
Area: 0.0.0.0
1.1.1.1         20.1.1.101      1   30         Full/DROther      Vlan20
3.3.3.3         20.1.1.103      1   37         Full/DROther      Vlan20
4.4.4.4         20.1.1.104      1   36         Full/DR           Vlan20
# Display the OSPFv3 neighbors of Device F.
[DeviceF] display ospfv3 peer
OSPFv3 Process 1 with Router ID 2.2.2.2
Area: 0.0.0.0
1.1.1.1         1   Full/DROther      00:00:38  0      Vlan20
3.3.3.3         1   Full/DROther      00:00:37  0      Vlan20
4.4.4.4         1   Full/DR           00:00:31  0      Vlan20
Checking the environment
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for an upgrade.
Device E
Device F
display device
display device
Displays device information.
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the legacy upgrade method is used, in which the two M-LAG member devices are upgraded one by one. Verify that the traffic interruption time is shorter than 500 ms during a switchover and shorter than 150 ms during fallback when the traffic load is light. For more information, see “Testing network convergence upon single points of failure.”
Verifying the upgrade result
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is upgraded successfully.
Device E
Device F
display device
display device
display boot-loader
display boot-loader
display version
display version
An expansion operation adds two leaf devices.
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for an expansion.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Disconnect the device from network management systems.
2.     Upgrade the software of the device as needed.
3.     Preconfigure the device.
4.     Connect the device to network management systems.
5.     Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Replacing a service module
Execute the commands in “Verifying the configuration" and the following commands to verify that the target device is available for a replacement.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Switch service and management traffic on the target service module to other service modules.
Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the replacement result
Execute the commands in "Checking the environment."
Replacing a switching fabric module
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
Replace a device
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
  • Become a Partner
  • Partner Resources
