- H3C Data Center Switches M-LAG Configuration Guide-6W100
- 00-M-LAG network planning
- 01-M-LAG+IPv4 and IPv6 Dual-Active VLAN Gateway Configuration Example
- 02-Multi-Layer M-LAG+STP+Dual-Active VLAN Gateway Configuration Examples
- 03-Multi-Layer M-LAG+Dual-Active VLAN Gateway+OSPF Configuration Examples
- 04-Multi-tier M-LAG+Spine Gateways+ECMP Paths to External Network Configuration Example
- 05-M-LAG and VRRP Configuration Example
- 06-M-LAG+RDMA Configuration Example
- 07-M-LAG and EVPN Distributed Gateway (IS-IS for underlay routing) Configuration Example
- 08-M-LAG and EVPN Distributed Gateway (BGP for Underlay Routing) Configuration Example
- 09-M-LAG+EVPN Distributed Gateway (OSPF on Underlay Network)+DHCP Relay+Microsegmentation+Service Chain Configuration Example
- 10-M-LAG+EVPN Centralized Gateway Configuration Example
- 11-Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example
- 12-M-LAG+EVPN+Monitor Link Configuration Examples
- 13-M-LAG and MVXLAN Configuration Example
- 14-M-LAG and DCI Configuration Example
- 15-M-LAG+EVPN DC Switchover Upon Border Failure Configuration Examples
07-M-LAG and EVPN Distributed Gateway (IS-IS for underlay routing) Configuration Example | 721.28 KB |
Example: Configuring M-LAG and EVPN distributed gateways (IS-IS for underlay routing)
Configuring S6800 or S6812 switches as leaf devices
Configuring the resource mode (only on S6800 switches)
Configuring the links towards the spine tier
Configuring the links towards the virtualization servers
Configuring the links towards the bare metal servers
Configuring the overlay network
Configuring S6850 switches as leaf devices
Configuring S12508X-AF or S12500G-AF switches as border devices
Configuring the M-LAG interfaces connected to the external network
Configuring the M-LAG interfaces connected to the external network firewalls
Configuring S12508X-AF or S12500G-AF switches as spine devices
Configuring the links between the spine and leaf tiers
Configuring the links between the spine and border tiers
Overlay traffic forwarding models
Overlay traffic characteristics
As shown in Figure 1:
· Deploy an M-LAG system at the border tier, and deploy two M-LAG systems at the leaf tier. Configure the M-LAG systems as follows:
¡ Configure direct physical links as peer links.
¡ Set up one border M-LAG system with two S12500X-AF or S12500G-AF switches. Configure SDN gateways on the border M-LAG system to forward traffic between the data center and external network, and between PODs.
¡ Set up one leaf M-LAG system with two S6800 or S6812 switches. Configure them as SDN ToR switches and distributed EVPN gateways for network overlay.
¡ Set up another leaf M-LAG system with two S6850 switches. Configure them as SDN ToR switches and distributed EVPN gateways for network overlay.
· Configure two S12500X-AF or S12500G-AF switches as spine devices. Configure them as route reflectors to reflect BGP EVPN routes among border and leaf devices.
· Configure the firewalls as follows:
¡ Configure them to operate in primary/secondary mode.
¡ Attach the firewalls to the border M-LAG system by using four aggregation links of M-LAG groups.
¡ Assign the firewalls to the same VLAN as the border M-LAG system.
· Configure static routes on the border M-LAG system to direct the following traffic to the firewall for security policy-based filtering or NAT:
¡ South-to-north traffic sent from the bare metal servers and VMs to the external network.
¡ Inter-VPC east-west traffic sent between the bare metal servers and VMs.
· Configure the C-spine device to provide access to other data centers and forward Layer 3 traffic on the underlay network.
· Configure the public device to provide access to the external network.
NOTE: This example uses IS-IS as the underlay routing protocol. Alternatively, you can use OSPF or other protocols for routing on the underlay network. |
Device |
IP address |
Remarks |
Leaf 1 |
XGE1/0/21 |
N/A |
Member port of an underlay M-LAG interface. Connected to a virtualization server. |
XGE1/0/47 |
N/A |
Member port of an M-LAG interface, interface with ACs configured. Connected to a bare metal server. |
FGE1/0/53 |
N/A |
Member port of the peer-link interface. Connected to FGE1/0/53 on Leaf 2. |
FGE1/0/54 |
N/A |
Member port of the peer-link interface. Connected to FGE1/0/54 on Leaf 2. |
FGE1/0/51 |
6.1.1.1/30 |
Connected to FGE3/0/16 on Spine 1. |
FGE1/0/49 |
6.1.1.5/30 |
Connected to FGE3/0/4 on Spine 2. |
Loopback0 |
5.1.1.1/32 |
VTEP IP address. |
Loopback1 |
5.1.1.101/32 |
Virtual VTEP IP address. |
Vlan-interface2 |
10.10.10.3/24 VRRP virtual IP: 10.10.10.254 |
The VRRP virtual IP address is the gateway address for virtualization servers. |
Vlan-interface10 |
10.1.1.1/24 |
Peer link. |
Leaf 2 |
XGE1/0/21 |
N/A |
XGE1/0/47 |
N/A |
FGE1/0/53 |
N/A |
Member port of the peer-link interface. Connected to FGE1/0/53 on Leaf 1. |
FGE1/0/54 |
N/A |
Member port of the peer-link interface. Connected to FGE1/0/54 on Leaf 1. |
FGE1/0/51 |
6.1.1.9/30 |
Connected to FGE3/0/13 on Spine 1. |
FGE1/0/49 |
6.1.1.13/30 |
Connected to FGE3/0/1 on Spine 2. |
LoopBack0 |
5.1.1.2/32 |
VTEP IP address. |
LoopBack1 |
5.1.1.101/32 |
Vlan-interface2 |
10.10.10.4/24 VRRP virtual IP: 10.10.10.254 |
Vlan-interface10 |
10.1.1.2/24 |
Peer link. |
Leaf 3 |
WGE1/0/21 |
N/A |
WGE1/0/55 |
N/A |
HGE1/0/31 |
N/A |
Member port of the peer-link interface. Connected to HGE1/0/31 on Leaf 4. |
HGE1/0/32 |
N/A |
Member port of the peer-link interface. Connected to HGE1/0/32 on Leaf 4. |
HGE1/0/29 |
6.1.1.17/30 |
Connected to HGE2/0/3 on Spine 1. |
HGE1/0/25 |
6.1.1.29/30 |
Connected to HGE2/0/12 on Spine 2. |
LoopBack0 |
5.1.1.3/32 |
VTEP IP address. |
LoopBack1 |
5.1.1.102/32 |
Vlan-interface2 |
50.50.50.2/24 VRRP virtual IP: 50.50.50.254 |
Vlan-interface10 |
10.2.1.1/24 |
Peer link. |
Leaf 4 |
WGE1/0/21 |
N/A |
WGE1/0/55 |
N/A |
HGE1/0/31 |
N/A |
Member port of the peer-link interface. Connected to HGE1/0/31 on Leaf 3. |
HGE1/0/32 |
N/A |
Member port of the peer-link interface. Connected to HGE1/0/32 on Leaf 3. |
HGE1/0/29 |
6.1.1.25/30 |
Connected to HGE2/0/1 on Spine 1. |
HGE1/0/25 |
6.1.1.21/30 |
Connected to HGE2/0/11 on Spine 2. |
LoopBack0 |
5.1.1.4/32 |
VTEP IP address. |
LoopBack1 |
5.1.1.102/32 |
Vlan-interface2 |
50.50.50.3/24 VRRP virtual IP: 50.50.50.254 |
Vlan-interface10 |
10.2.1.2/24 |
Peer link. |
Spine 1 |
FGE3/0/16 |
6.1.1.2/30 |
Connected to FGE1/0/51 on Leaf 1. |
FGE3/0/13 |
6.1.1.10/30 |
Connected to FGE1/0/51 on Leaf 2. |
HGE2/0/3 |
6.1.1.18/30 |
Connected to HGE1/0/29 on Leaf 3. |
HGE2/0/1 |
6.1.1.26/30 |
Connected to HGE1/0/29 on Leaf 4. |
HGE2/0/5 |
6.1.1.33/30 |
Connected to HGE3/0/16 on Border 1. |
HGE2/0/7 |
6.1.1.37/30 |
Connected to HGE2/0/13 on Border 2. |
LoopBack0 |
5.1.1.6/32 |
N/A |
Spine 2 |
FGE3/0/4 |
6.1.1.6/30 |
Connected to FGE1/0/49 on Leaf 1. |
FGE3/0/1 |
6.1.1.14/30 |
Connected to FGE1/0/49 on Leaf 2. |
HGE2/0/12 |
6.1.1.30/30 |
Connected to HGE1/0/25 on Leaf 3. |
HGE2/0/11 |
6.1.1.22/30 |
Connected to HGE1/0/25 on Leaf 4. |
HGE2/0/9 |
6.1.1.41/30 |
Connected to HGE2/0/12 on Border 1. |
HGE2/0/10 |
6.1.1.45/30 |
Connected to HGE2/0/1 on Border 2. |
LoopBack0 |
5.1.1.8/32 |
N/A |
Border 1 |
HGE1/0/16 |
6.1.1.34/30 |
Connected to HGE2/0/5 on Spine 1. |
HGE1/0/12 |
6.1.1.42/30 |
Connected to HGE2/0/9 on Spine 2. |
HGE2/0/21 |
N/A |
Member port of the peer-link interface. Connected to HGE2/0/7 on Border 2. |
HGE3/0/36 |
N/A |
Member port of the peer-link interface. Connected to HGE3/0/36 on Border 2. |
HGE2/0/5 |
5.58.1.1/30 |
Connected to the C-spine device. |
FGE3/0/24 |
N/A |
Member port of an M-LAG interface. Connected to the public device. |
HGE2/0/27 |
N/A |
Member port of an M-LAG interface. Upstream traffic forwarding to the firewalls. |
HGE2/0/11 |
N/A |
Member port of an M-LAG interface. Downstream traffic forwarding to the firewalls. |
LoopBack0 |
5.1.1.7/32 |
ED IP address. |
LoopBack100 |
100.100.100.100/32 |
Virtual ED IP address. |
Vlan-interface1000 |
100.1.1.1/24 |
Peer link. |
Border 2 |
HGE1/0/13 |
6.1.1.38/30 |
Connected to HGE2/0/7 on Spine 1. |
HGE1/0/1 |
6.1.1.46/30 |
Connected to HGE2/0/10 on Spine 2. |
HGE2/0/7 |
N/A |
Member port of the peer-link interface. Connected to HGE2/0/21 on Border 1. |
HGE3/0/36 |
N/A |
HGE2/0/5 |
5.58.1.5/30 |
FGE3/0/24 |
N/A |
HGE2/0/27 |
N/A |
HGE2/0/29 |
N/A |
LoopBack0 |
5.1.1.9/32 |
ED IP address. |
LoopBack100 |
100.1.1.2/24 |
Peer link. |
Traffic forwarding models
A VM is in a host overlay network, and a bare metal host is called a BM in network overlay. The following traffic forwarding models are available:
· Intra-VPC forwarding in the same POD (leaf > spine > leaf):
¡ VM-to-VM and VM-to-BM Layer 2 and Layer 3 communication through the same M-LAG system at the leaf tier.
¡ BM-to-VM and BM-to-BM Layer 2 and Layer 3 communication through the same M-LAG system at the leaf tier.
¡ VM-to-VM and VM-to-BM Layer 2 and Layer 3 communication across M-LAG systems at the leaf tier.
¡ BM-to-VM and BM-to-BM Layer 2 and Layer 3 communication across M-LAG systems at the leaf tier.
· Inter-VPC forwarding in the same POD (leaf > spine > border > firewall > border > spine > leaf):
¡ VM-to-VM and VM-to-BM Layer 3 communication through the same M-LAG system at the leaf tier.
¡ BM-to-VM and BM-to-BM Layer 3 communication through the same M-LAG system at the leaf tier.
¡ VM-to-VM and VM-to-BM Layer 3 communication across M-LAG systems at the leaf tier.
¡ BM-to-VM and BM-to-BM Layer 3 communication across M-LAG systems at the leaf tier.
· Inter-POD forwarding (leaf > spine > border > C-spine > border > spine > leaf):
¡ VM-remote host and BM-remote host Layer 2 communication across PODs.
¡ VM-remote host and BM-remote host Layer 3 communication across PODs.
· Forwarding between the data center and the external network (leaf > spine > border > firewall > border > public device):
¡ Layer 3 communication between BMs and the external network.
¡ Layer 3 communication between VMs and the external network.
¡ SSH, FTP, and fping operations from the external network to the data center (leaf > spine > border > LB > border > public device).
Applicable product matrix
IMPORTANT: In addition to running an applicable software version, you must also install the most recent patch, if any. |
Device |
Software version |
Border or spine |
S12500X-AF S12500X-AF switches are used in this example. |
R2825 |
S12500G-AF |
R7625 |
Leaf |
S6800, S6860 S6800 switches are used in this configuration example. |
R6710 |
S6812, S6813 S6812 switches are used in this configuration example. |
F6628P22 and later |
S6805, S6825, S6850, and S9850 S6850 switches are used in this configuration example. |
R6710 |
S6890 |
R2825 |
S9820-64H (EVPN gateway not supported) S9820-8C (EVPN not supported) |
Not supported |
SDN controller |
N/A |
SeerEngine-DC E3610 or higher versions NOTE: Before you use a higher version than E3610, contact H3C support to verify version compatibility. |
Procedure summary
· Configuring the resource mode (only on S6800 switches)
· Configuring the links towards the spine tier
· Configuring the links towards the virtualization servers
· Configuring the links towards the bare metal servers
· Configuring the overlay network
Leaf 1 |
Leaf 2 |
Configuration method |
Purpose |
Remarks |
hardware-resource switch-mode 4 |
Manual |
Set the hardware resource mode for the MAC address table, ARP/ND table, and routing tables. |
Adjust the capacities of the MAC address table, ARP/ND table, and routing tables. |
Reboot the device for this setting to take effect. |
hardware-resource routing-mode ipv6-128 |
Manual |
Enable support for IPv6 routes with prefixes longer than 64 bits. |
N/A |
hardware-resource vxlan l3gw40k |
Manual |
Set the VXLAN hardware resource mode to Layer 3 gateway mode that supports 40 K of overlay adjacency table |
N/A |
openflow flow-table ipv6-enhanced |
Manual |
Enable support for bidirectional security groups. |
N/A |
N/A |
openflow permit-flag ignore |
Manual |
Ignore the permit flag added by OpenFlow. |
Enable support for bidirectional security groups and port rate limiting. |
N/A |
Creating VRRP groups
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
vlan 2 |
vlan 2 |
Manual |
Configure the VLAN used to communicate with a virtualization server. |
The switch is an underlay device to a virtualization server. |
N/A |
interface Vlan-interface 2 |
Manual |
Create a VLAN interface. |
N/A |
N/A |
ip address 10.10.10.3 255.255.255.0 |
ip address 10.10.10.4 255.255.255.0 |
Manual |
Assign an IP address to the interface. |
N/A |
N/A |
vrrp vrid 1 virtual-ip 10.10.10.254 |
Manual |
Configure the virtual IP address of a VRRP group. |
N/A |
N/A |
vrrp vrid 1 priority 100 |
vrrp vrid 1 priority 101 |
Manual |
Configure the priority of the device in the VRRP group. |
VRRP determines the role (master or backup) of each router in a VRRP group by priority. A router with higher priority is more likely to become the master. |
The larger the priority value, the higher the priority. |
undo vrrp vrid 1 preempt-mode |
Manual |
Configure the device to work in non-preemptive mode in the VRRP group. |
Ensure consistency between the VRRP role and M-LAG role. |
This command is optional. Inconsistency between the VRRP role and M-LAG role does not affect traffic forwarding. |
quit |
quit |
Manual |
N/A |
N/A |
N/A |
ip prefix-list 1 index 10 permit 10.10.10.0 24 |
Manual |
Configure an IPv4 prefix list or an item for the list. |
Create an IPv4 prefix list for the virtual IP address of the VRRP group. |
N/A |
route-policy 1 permit node 0 |
Manual |
Configure a routing policy. |
Create the routing policy used in IS-IS IPv4 unicast address family view. |
N/A |
if-match ip address prefix-list 1 |
Manual |
Match IPv4 routes with an IPv4 prefix list. |
N/A |
N/A |
quit |
quit |
Manual |
Exit routing policy view. |
N/A |
N/A |
Configuring IS-IS
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
router id 5.1.1.1 |
router id 5.1.1.2 |
Manual |
Configure the IP address of Loopback 0 as the router ID. |
Configure the global router ID. |
N/A |
isis 1 |
isis 1 |
Manual |
Enter IS-IS view. |
N/A |
N/A |
is-level level-2 |
is-level level-2 |
Manual |
Specify the IS level. |
If the only area is an IP network, configure all the routers as Level-2 for scalability. |
cost-style wide |
cost-style wide |
Manual |
Set the cost style to wide. |
Enable the device to receive wide cost style packets. |
N/A |
timer spf 1 10 10 |
timer spf 1 10 10 |
Manual |
Set the maximum SPF calculation interval to 1 second, minimum SPF calculation interval to 10 milliseconds, and incremental SPF calculation interval to 10 milliseconds. |
Reduce the interval between two SPF calculations and speed up convergence. |
N/A |
timer lsp-max-age 65535 |
Manual |
Set the LSP maximum age in the LSDB to 65535 seconds. |
A large LSP maximum age reduces LSP floods. Any LSP with an age of 0 is deleted from the LSDB. |
N/A |
timer lsp-refresh 65000 |
Manual |
Set the LSP refresh interval to 65000 seconds. |
A large refresh interval reduces LSP refreshes and saves bandwidth. |
N/A |
timer lsp-generation 1 10 10 |
Manual |
Set the maximum interval to 1 second, minimum interval to 10 milliseconds, and incremental interval to 10 milliseconds for LSP generation. |
Speed up LSP generation and routing convergence upon network topology changes. |
N/A |
set-overload on-startup 360 |
Manual |
Set the overload bit for 360 seconds upon system startup. |
Delay VRRP address advertisement after system startup to reduce traffic loss during fallback. |
N/A |
network-entity 51.0000.0005.0001.00 |
network-entity 51.0000.0005.0002.00 |
Manual |
Configure the NET for an IS-IS process. |
N/A |
N/A |
address-family ipv4 unicast |
Manual |
Enter IS-IS IPv4 address family view. |
N/A |
N/A |
fast-reroute lfa |
fast-reroute lfa |
Manual |
Configure IS-IS FRR. |
Enable IS-IS to calculate backup next hops for all Level-2 routes to reduce traffic interruption upon link or device failure. |
N/A |
import-route direct route-policy 1 |
Manual |
Redistribute direct VRRP routes. |
Use this command together with the set-overload command to delay VRRP route advertisement after system startup to optimize route convergence upon fallback. |
N/A |
quit |
quit |
Manual |
Exit address family view. |
N/A |
N/A |
quit |
quit |
Manual |
Exit IS-IS view. |
N/A |
N/A |
interface LoopBack0 |
Manual |
Create Loopback 0 and enter its view. |
N/A |
N/A |
ip address 5.1.1.1 255.255.255.255 |
ip address 5.1.1.2 255.255.255.255 |
Manual |
Configure the VTEP IP address. |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
Enable IS-IS on the interface. |
N/A |
N/A |
isis circuit-level level-2 |
Manual |
Set the circuit level for the interface to Level-2. |
N/A |
For the Level-2 device, the circuit level can only be Level-2. |
quit |
quit |
Manual |
Exit the view of Loopback 0. |
N/A |
N/A |
interface LoopBack1 |
Manual |
Create Loopback 1 and enter its view. |
N/A |
N/A |
ip address 5.1.1.101 255.255.255.255 |
Manual |
Configure the virtual VTEP IP address. |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
Exit the view of Loopback 1. |
N/A |
N/A |
vlan 10 |
vlan 10 |
Manual |
Create a VLAN. |
Create the VLAN for communicating with the M-LAG peer. |
N/A |
interface Vlan-interface10 |
Manual |
Create VLAN-interface 10. |
Create the VLAN interface for the VLAN used for communicating with the M-LAG peer. When the uplink interface fails, the device forwards the packets received on the M-LAG interfaces to the M-LAG peer for Layer 3 forwarding. |
N/A |
ip address 10.1.1.1 255.255.255.0 |
ip address 10.1.1.2 255.255.255.0 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
isis circuit-type p2p |
Manual |
Set the network type of the interface to P2P. |
If only two routers exist on a broadcast network, set the network type of attached interfaces to P2P to avoid DIS election and CSNP flooding. This saves network bandwidth and speeds up network convergence. |
N/A |
isis peer hold-max-cost duration 20000 |
Manual |
Enable IS-IS to advertise the maximum link cost to neighbors within 20000 milliseconds. |
N/A |
Execute this command at both ends of a link. |
quit |
quit |
Manual |
Exit the view of VLAN-interface 10. |
N/A |
N/A |
NOTE: On an IS-IS network, when a link recovers from failures or the state of an interface changes, IS-IS will re-establish neighbor relationships and perform route convergence. During the route convergence process, routing loops and traffic loss might occur because the convergence speeds of the nodes are different. To address this issue, enable IS-IS to advertise the maximum link cost to neighbors within the specified period, so the traffic forwarding path remains unchanged. After the specified period, IS-IS advertises the original link cost to neighbors and performs optimal route selection again. |
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
interface FortyGigE1/0/49 |
interface FortyGigE 1/0/49 |
Manual |
Configure the interface connected to Spine 2. |
N/A |
N/A |
port link-mode route |
Manual |
Configure the Ethernet interface to work in Layer 3 mode. |
N/A |
N/A |
ip address 6.1.1.5 255.255.255.252 |
ip address 6.1.1.13 255.255.255.252 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
undo mac-address static source-check enable |
Manual |
Disable static source check. |
To correctly forward traffic sourced from the MAC address of a VLAN interface, you must disable the static source check feature on the Layer 2 interfaces in the VLAN. |
N/A |
interface FortyGigE1/0/51 |
interface FortyGigE 1/0/51 |
Manual |
Configure the interface connected to Spine 1. |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 6.1.1.1 255.255.255.252 |
ip address 6.1.1.9 255.255.255.252 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
Configuring L2VPN
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
l2vpn enable |
l2vpn enable |
Manual |
Enable L2VPN. |
N/A |
N/A |
l2vpn statistics interval 30 |
Manual |
Set the interval for collecting L2VPN statistics to 30 seconds. |
Configure this setting according to the gRPC report interval. |
N/A |
vxlan default-decapsulation source interface LoopBack0 |
Manual |
Enable default VXLAN decapsulation on the packets destined for the VTEP IP address. |
N/A |
This command takes effect only when the specified interface has an IP address. |
vxlan tunnel mac-learning disable |
Manual |
Disable remote-MAC address learning. |
Execute this command if a controller issues forwarding entries to the device. |
N/A |
vxlan tunnel arp-learning disable |
Manual |
Disable remote ARP learning. |
N/A |
vxlan tunnel nd-learning disable |
Manual |
Disable remote ND learning. |
N/A |
mac-address timer aging 3600 |
Manual |
Set the aging time to 3600 seconds for dynamic MAC address entries. |
Increase this timer to ensure forwarding entry synchronization is finished in time after the M-LAG peer restarts. |
This setting must be consistent on the M-LAG member devices in the same M-LAG system. |
mac-address mac-move fast-update |
Manual |
Enable ARP fast update for MAC address moves. |
Use this command together with gRPC. |
N/A |
NOTE: If you use two border devices to set up an M-LAG system and BMs in bond1 mode need to communicate with the external network, unidirectional tunnels exist between the ToR switches and SDN gateway. Typically, unidirectional tunnels are set up when a ToR switch is disconnected from the controller or new BMs come online. In this scenario, an online ToR switch advertises routes that contain its real IP address. The SDN will set up a tunnel to that real IP address, while the ToR switch uses the virtual VTEP IP address for tunnel setup. For the ToR switches to decapsulate the packets sent by the SDN gateway, enable default VXLAN decapsulation on the ToR switches. |
Configuring M-LAG
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
ip vpn-instance management |
Manual |
Create a VPN for the management Ethernet interface. |
N/A |
This command is optional. |
interface M-GigabitEthernet0/0/0 |
Manual |
Enter the view of the management Ethernet interface. |
N/A |
N/A |
ip binding vpn-instance management |
Manual |
Assign the management Ethernet interface to the VPN. |
N/A |
Assign the management Ethernet interface to a VPN as needed. |
ip address 192.1.2.66 255.255.255.0 |
ip address 192.1.2.67 255.255.255.0 |
Manual |
Configure a management IP address. |
N/A |
N/A |
quit |
quit |
Manual |
Exit the view of the management Ethernet interface. |
N/A |
N/A |
l2vpn m-lag peer-link ac-match-rule vxlan-mapping |
Manual |
Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link. Perform this task when the M-LAG system uses a direct physical link as the peer link. |
N/A |
N/A |
evpn m-lag group 5.1.1.101 |
Manual |
Enable EVPN M-LAG and specify the virtual VTEP address. |
N/A |
You must specify the same virtual VTEP address on both VTEPs in the same M-LAG system. |
evpn m-lag local 5.1.1.1 remote 5.1.1.2 |
evpn m-lag local 5.1.1.2 remote 5.1.1.1 |
Manual |
Specify the IP addresses of the VTEPs in an M-LAG system. |
After you configure this command, each VTEP in an M-LAG system changes the next hop of the routes for single-armed ACs to its local VTEP IP address when advertising the routes. This ensures that the traffic of a single-armed AC is forwarded to its attached VTEP. |
When you execute this command, make sure the IP address of the local VTEP belongs to a local interface. Make sure the local VTEP IP address and peer VTEP IP address are reversed on the VTEPs in an M-LAG system. |
evpn global-mac 00e0-fc00-580a |
Manual |
Configure the EVPN global MAC address. |
N/A |
You must specify the same EVPN global MAC address on the devices in the same M-LAG system. Do not use a reserved MAC address as the EVPN global MAC address. |
m-lag system-mac 00e0-fc00-5800 |
Manual |
Configure the M-LAG system MAC address. |
Configure the settings required for establishing the M-LAG system. |
The M-LAG system MAC address uniquely identifies the M-LAG system on the network. For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on them. |
m-lag system-number 1 |
m-lag system-number 2 |
Manual |
Set the M-LAG system number. |
You must assign different M-LAG system numbers to the M-LAG member devices in an M-LAG system. |
m-lag system-priority 123 |
Manual |
Set the M-LAG system priority. |
N/A |
This command is optional. You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system. The default M-LAG system priority is 32768. The smaller the priority value, the higher the priority. |
m-lag keepalive ip destination 192.1.2.67 source 192.1.2.66 vpn-instance management |
m-lag keepalive ip destination 192.1.2.66 source 192.1.2.67 vpn-instance management |
Manual |
Configure M-LAG keepalive packet parameters. |
Use the management Ethernet interface to set up the keepalive link. This interface is excluded from the M-LAG MAD DOWN action. |
You do not need to specify a VPN instance if the interface does not belong to any VPN instance. If the interface that owns the source IP address is not excluded from the M-LAG MAD DOWN action, exclude it from that action. |
m-lag mad default-action none |
Manual |
Set the default M-LAG MAD action to NONE. |
N/A |
N/A |
m-lag mad include interface FortyGigE1/0/49 |
m-lag mad include interface FortyGigE 1/0/49 |
Manual |
Enable M-LAG to shut down an interface when the M-LAG system splits. |
Shut down the interface upon an M-LAG system split to reduce the fallback duration after a device restart. |
Execute this command on the uplink interface attached to a spine device. |
m-lag mad include interface FortyGigE1/0/51 |
m-lag mad include interface FortyGigE 1/0/51 |
Manual |
m-lag restore-delay 300 |
Manual |
Set the data restoration interval. |
Ensure that entry synchronization is finished before interfaces are brought up. |
N/A |
interface Bridge-Aggregation1 |
Manual |
Create Bridge-Aggregation 1 which will be the peer-link interface. |
N/A |
N/A |
port link-type trunk |
Manual |
Set the link type of the interface to trunk. |
N/A |
N/A |
port trunk permit vlan all |
Manual |
Configure the trunk interface to permit all VLANs. |
N/A |
N/A |
link-aggregation mode dynamic |
Manual |
Configure the aggregate interface to operate in dynamic mode and enable LACP. |
N/A |
N/A |
port m-lag peer-link 1 |
Manual |
Configure the interface as the peer-link interface. |
N/A |
N/A |
Manual |
You do not need to execute this command on S12500X-AF switches. Disable static source check on all peer-link interfaces and the uplink interfaces attached to spine devices. |
interface FortyGigE1/0/53 |
Manual |
Configure the interface as a member port of the peer-link interface. |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
port link-aggregation group 1 |
Manual |
Assign the interface to link aggregation group 1. |
N/A |
N/A |
interface FortyGigE1/0/54 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
N/A |
NOTE: By default, if an M-LAG system uses a direct physical link as the peer link, each M-LAG member device creates a dynamic AC on the peer link when an AC is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, enable the M-LAG member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link. If you use a VXLAN tunnel as the peer link in an EVPN environment, you must retain a large number of logical interfaces (for example, tunnel and loopback interfaces) in up state. To reduce configuration steps, set the default M-LAG MAD action to NONE and execute the m-lag mad include interface command to specify interfaces that must be shut down by M-LAG MAD in addition to those already automatically specified by the system. |
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
interface Bridge-Aggregation101 |
Manual |
Create an aggregate interface to be configured as an M-LAG interface. |
Create the interface to connect to the host overlay servers. |
N/A |
port access vlan 2 |
Manual |
Configure the interface as an access interface and assign it to VLAN 2. |
Assign the interface to the VLAN of the VRRP group. |
N/A |
Manual |
N/A |
N/A |
port m-lag group 101 |
Manual |
Assign the interface to an M-LAG group. |
N/A |
N/A |
interface Ten-GigabitEthernet1/0/21 |
interface Ten-GigabitEthernet 1/0/21 |
Manual |
Enter the view of a member port to be assigned to the M-LAG interface. |
N/A |
N/A |
Manual |
N/A |
port link-aggregation group 101 |
Manual |
Assign the interface to the aggregation group of the M-LAG interface. |
N/A |
N/A |
quit |
quit |
Manual |
Exit the current view. |
N/A |
N/A |
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
interface Bridge-Aggregation1024 |
Manual |
Create the aggregate interface to connect to the bare metal servers. |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
port m-lag group 1024 |
Manual |
Assign the aggregate interface to an M-LAG group. |
N/A |
N/A |
interface Ten-GigabitEthernet1/0/47 |
interface Ten-GigabitEthernet 1/0/47 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
port link-aggregation group 1024 |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Configuring spanning tree
Leaf 1 |
Leaf 2 |
Purpose |
stp global enable |
stp global enable |
Manual |
Enable spanning tree globally. |
N/A |
Manual |
Enter the view of the M-LAG interface connected to the virtualization servers. |
N/A |
stp edged-port |
stp edged-port |
Manual |
Configure the interface as an edge port. |
Exclude the interface from spanning tree calculation. |
interface Bridge-Aggregation 1024 |
Manual |
Enter the view of the M-LAG interface connected to the bare metal servers. |
N/A |
stp edged-port |
stp edged-port |
Manual |
NOTE: Make sure the M-LAG member devices have the same spanning tree configuration, including: · Global spanning tree configuration. · Spanning tree configuration on the peer-link interface. · Spanning tree configuration on M-LAG interfaces. Violation of this rule might cause network flapping. Peer-link interfaces in the M-LAG system do not participate in spanning tree calculation. The M-LAG member devices still use the M-LAG system MAC address after the M-LAG system splits, which will cause spanning tree calculation issues. To avoid the issues, enable M-LAG standalone mode on the M-LAG member devices before the M-LAG system splits. |
Configuring a BGP instance
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
bgp 400 |
bgp 400 |
Manual |
Enable a BGP instance. |
N/A |
N/A |
bgp update-delay on-startup 40 |
Manual |
Configure BGP to delay sending route updates on reboot. |
Avoid forwarding issues during fallback after a ToR switch restarts. |
N/A |
router-id 5.1.1.1 |
router-id 5.1.1.2 |
Manual |
Configure a router ID for the BGP instance. |
To run BGP in a BGP instance, you must configure a router ID for the BGP instance. If you do not configure a router ID for the BGP instance, it uses the global router ID. |
N/A |
group evpn internal |
Manual |
Create an IBGP peer group. |
N/A |
N/A |
peer evpn connect-interface LoopBack0 |
Manual |
Specify a source interface for establishing TCP links towards the peer group. |
N/A |
N/A |
peer evpn route-update-interval 0 |
Manual |
Specify an interval for sending the same update to the peer group. |
Enable the device to fast send update to the peer group upon route changes to speed up route convergence after an M-LAG primary/secondary switchover occurs. |
Execute this command only for IBGP peers. |
peer 5.1.1.6 group evpn |
Manual |
Add a spine device to the peer group. |
N/A |
N/A |
peer 5.1.1.8 group evpn |
Manual |
N/A |
N/A |
address-family l2vpn evpn |
Manual |
Enter L2VPN EVPN address family view. |
N/A |
N/A |
peer evpn enable |
peer evpn enable |
Manual |
Enable the device to exchange routes with the peer group. |
N/A |
N/A |
quit |
quit |
Manual |
Exit L2VPN EVPN address family view. |
N/A |
N/A |
Leaf 1 |
Leaf 2 |
Remarks |
ip vpn-instance admin_route1_50034 |
Controller-based |
Create a VPN instance on the private network. |
N/A |
route-distinguisher 1:50034 |
Controller-based |
Configure the RD of the VPN instance. |
N/A |
address-family ipv4 |
Controller-based |
Enter IPv4 address family view of the VPN instance. |
N/A |
vpn-target 0:50034 1:50034 import-extcommunity |
Controller-based |
Configure import targets for the VPN instance. |
N/A |
vpn-target 1:50034 export-extcommunity |
Controller-based |
Configure export targets for the VPN instance. |
N/A |
address-family ipv6 |
Controller-based |
Enter IPv6 address family view of the VPN instance. |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
address-family evpn |
Controller-based |
Enter EVPN view of the VPN instance. |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
interface Vsi-interface22000 |
Controller-based |
Create a VSI interface and enter its view. |
N/A |
mtu 1450 |
mtu 1450 |
Controller-based |
Configure the MTU of the VSI interface. |
N/A |
ip binding vpn-instance admin_route1_50034 |
Controller-based |
Associate the VSI interface with the VPN instance. |
N/A |
ip address 121.1.0.1 255.255.0.0 sub |
Controller-based |
Assign an IPv4 address as a gateway address to the VSI interface. |
Make sure the VSI interface has the same setting for this command on all distributed gateways. |
mac-address 542b-de0c-02c9 |
Controller-based |
Assign a MAC address to the VSI interface. |
ipv6 nd ra prefix 121:1::/64 no-advertise |
Controller-based |
Disable the device from advertising the prefix of the IPv6 gateway through RA messages. |
ipv6 address 121:1::1/64 |
Controller-based |
Assign an IPv6 address as a gateway address to the VSI interface. |
distributed-gateway local |
Controller-based |
Specify the VSI interface as a distributed gateway to provide services for the local site. |
N/A |
quit |
quit |
Controller-based |
N/A |
interface Vsi-interface 22001 |
Controller-based |
N/A |
mtu 1450 |
mtu 1450 |
Controller-based |
N/A |
Controller-based |
Associate the VSI interface with a VPN instance. |
N/A |
ip address 121.2.0.1 255.255.0.0 sub |
Controller-based |
Controller-based |
ipv6 nd ra prefix 121:2::/64 no-advertise |
Controller-based |
ipv6 address 121:2::1/64 |
Controller-based |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
interface Vsi-interface50034 |
Controller-based |
N/A |
Controller-based |
N/A |
ipv6 address auto link-local |
Controller-based |
Automatically generate a link-local address for the VSI interface. |
N/A |
l3-vni 50034 |
l3-vni 50034 |
Controller-based |
Assign an L3VNI to the VSI interface. |
The L3VNI is shared among the VSI interfaces associated with the same VPN instance. |
quit |
quit |
Controller-based |
N/A |
vsi SDN_VSI_22000 |
vsi SDN_VSI_22000 |
Controller-based |
Create a VSI and enter its view. |
N/A |
gateway vsi-interface 22000 |
Controller-based |
Specify a gateway interface for the VSI. |
N/A |
arp suppression enable |
Controller-based |
Enable ARP flood suppression. |
N/A |
ipv6 nd suppression enable |
Controller-based |
Enable ND flood suppression. |
N/A |
flooding disable all |
Controller-based |
Disable flooding of local broadcast, unknown unicast, and unknown multicast traffic. |
N/A |
vxlan 22000 |
vxlan 22000 |
Controller-based |
Create a VXLAN and enter its view. |
N/A |
evpn encapsulation vxlan |
Controller-based |
Create an EVPN instance and enter its view. |
N/A |
route-distinguisher auto |
Controller-based |
Configure the RD of the EVPN instance. |
N/A |
vpn-target auto |
vpn-target auto |
Controller-based |
Configure import and export targets for EVPN. |
N/A |
quit |
quit |
Controller-based |
N/A |
vsi SDN_VSI_22001 |
vsi SDN_VSI_22001 |
Controller-based |
N/A |
gateway vsi-interface 22001 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
vxlan 22001 |
vxlan 22001 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
vpn-target auto |
vpn-target auto |
Controller-based |
Configure export targets for EVPN. |
N/A |
quit |
quit |
Controller-based |
N/A |
vlan 21 to 22 |
vlan 21 to 22 |
Controller-based |
Create VLANs. |
N/A |
Controller-based |
Enter the view of the interface to be configured with ACs. |
N/A |
Controller-based |
N/A |
undo port trunk permit vlan 1 |
Controller-based |
Remove the trunk interface from VLAN 1. |
N/A |
port trunk permit vlan 21 to 22 |
Controller-based |
Assign the trunk interface to VLAN 21 and VLAN 22. |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
service-instance 21 |
Controller-based |
Create an Ethernet service instance and enter its view. |
N/A |
encapsulation s-vid 21 |
Controller-based |
Configure the Ethernet service instance to match traffic by the outer VLAN ID. |
N/A |
xconnect vsi SDN_VSI_22000 |
Controller-based |
Map the Ethernet service instance to the VSI created previously. |
N/A |
service-instance 22 |
Controller-based |
N/A |
encapsulation s-vid 22 |
Controller-based |
N/A |
xconnect vsi SDN_VSI_22001 |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
Procedure summary
Leaf 3 |
Leaf 4 |
Purpose |
Remarks |
hardware-resource switch-mode DUAL-STACK |
Manual |
Set the hardware resource mode to DUAL-STACK for the MAC address table, ARP/ND table, and routing tables |
Manual |
N/A |
hardware-resource vxlan l3gw |
Manual |
N/A |
Manual |
N/A |
Leaf 3 |
Leaf 4 |
Purpose |
vlan 2 |
vlan 2 |
Manual |
Manual |
N/A |
ip address 50.50.50.2 255.255.255.0 |
ip address 50.50.50.3 255.255.255.0 |
Manual |
N/A |
vrrp vrid 2 virtual-ip 50.50.50.254 |
Manual |
N/A |
vrrp vrid 2 priority 100 |
vrrp vrid 2 priority 101 |
Manual |
VRRP determines the role (master or backup) of each router in a VRRP group by priority. A router with higher priority is more likely to become the master. The larger the priority value, the higher the priority. |
undo vrrp vrid 2 preempt-mode |
Manual |
Ensure consistency between the VRRP role and M-LAG role. This command is optional. Inconsistency between the VRRP role and M-LAG role does not affect traffic forwarding. |
quit |
quit |
Manual |
N/A |
ip prefix-list 1 index 10 permit 50.50.50.0 24 |
Manual |
Manual |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
Configuring IS-IS
Leaf 3 |
Leaf 4 |
Purpose |
Remarks |
router id 5.1.1.3 |
router id 5.1.1.4 |
Manual |
N/A |
isis 1 |
isis 1 |
Manual |
Enter IS-IS view. |
N/A |
is-level level-2 |
is-level level-2 |
Manual |
N/A |
cost-style wide |
cost-style wide |
Manual |
N/A |
timer spf 1 10 10 |
timer spf 1 10 10 |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
network-entity 51.0000.0005.0003.00 |
network-entity 51.0000.0005.0004.00 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
fast-reroute lfa |
fast-reroute lfa |
Manual |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
Exit IS-IS view. |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 5.1.1.3 255.255.255.255 |
ip address 5.1.1.4 255.255.255.255 |
Manual |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 5.1.1.102 255.255.255.255 |
Manual |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
vlan 10 |
vlan 10 |
Manual |
Create a VLAN. |
N/A |
Manual |
N/A |
ip address 10.2.1.1 255.255.255.0 |
ip address 10.2.1.2 255.255.255.0 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Leaf 3 |
Leaf 4 |
Purpose |
Remarks |
interface HundredGigE1/0/25 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 6.1.1.29 255.255.255.252 |
ip address 6.1.1.21 255.255.255.252 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
interface HundredGigE1/0/29 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 6.1.1.17 255.255.255.252 |
ip address 6.1.1.25 255.255.255.252 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
N/A |
Manual |
Disable static source check on the interface connected to Spine 2. |
N/A |
Configuring L2VPN
Leaf 3 |
Leaf 4 |
Purpose |
Remarks |
l2vpn enable |
l2vpn enable |
Manual |
Enable L2VPN. |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
Manual |
N/A |
Configuring M-LAG
Leaf 3 |
Leaf 4 |
Purpose |
Remarks |
Manual |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
ip address 192.1.2.68 255.255.255.0 |
ip address 192.1.2.69 255.255.255.0 |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
evpn m-lag group 5.1.1.102 |
Manual |
N/A |
evpn m-lag local 5.1.1.3 remote 5.1.1.4 |
evpn m-lag local 5.1.1.4 remote 5.1.1.3 |
Manual |
evpn global-mac 90e7-1060-2fe0 |
Manual |
N/A |
m-lag system-mac 90e7-1060-2faf |
Manual |
Manual |
Manual |
N/A |
m-lag keepalive ip destination 192.1.2.69 source 192.1.2.68 vpn-instance management |
m-lag keepalive ip destination 192.1.2.68 source 192.1.2.69 vpn-instance management |
Manual |
Manual |
N/A |
N/A |
m-lag mad include interface HundredGigE1/0/25 |
Manual |
m-lag mad include interface HundredGigE1/0/29 |
Manual |
Manual |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
Exit interface view. |
N/A |
N/A |
interface HundredGigE1/0/31 |
Manual |
Enter interface view. |
N/A |
N/A |
Manual |
Assign the interface to the aggregation group for the peer-link interface. |
N/A |
N/A |
interface HundredGigE1/0/32 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
Enter aggregate interface view. |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
You do not need to execute this command on S12500X-AF switches. Disable static source check on the peer-link interface and the uplink interfaces attached to spine devices. |
quit |
quit |
Manual |
N/A |
N/A |
NOTE: By default, if an M-LAG system uses a direct physical link as the peer link, each M-LAG member device creates a dynamic AC on the peer link when an AC is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, enable the M-LAG member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link. If you use a VXLAN tunnel as the peer link in an EVPN environment, you must retain a large number of logical interfaces (for example, tunnel and loopback interfaces) in up state. You can set the default M-LAG MAD action to NONE and execute the m-lag mad include interface command to specify interfaces that must be shut down by M-LAG MAD in addition to those already automatically specified by the system. |
Leaf 3 |
Leaf 4 |
Purpose |
Manual |
Manual |
Manual |
N/A |
Manual |
N/A |
interface Twenty-FiveGigE 1/0/21 |
interface Twenty-FiveGigE1/0/21 |
Manual |
N/A |
Manual |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
Leaf 3 |
Leaf 4 |
Purpose |
Remarks |
Manual |
Connect to the bare metal servers. |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
interface Twenty-FiveGigE1/0/55 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Leaf 3 |
Leaf 4 |
Purpose |
stp global enable |
stp global enable |
Manual |
N/A |
Manual |
N/A |
stp edged-port |
stp edged-port |
Manual |
Manual |
N/A |
stp edged-port |
stp edged-port |
Manual |
Leaf 3 |
Leaf 4 |
Purpose |
bgp 400 |
bgp 400 |
Manual |
N/A |
Manual |
router-id 5.1.1.3 |
router-id 5.1.1.4 |
Manual |
Manual |
N/A |
Manual |
N/A |
Manual |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
peer evpn enable |
peer evpn enable |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
quit |
quit |
Manual |
Exit BGP instance view. |
N/A |
Leaf 3 |
Leaf 4 |
Remarks |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
Controller-based |
N/A |
mtu 1450 |
mtu 1450 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
Controller-based |
Controller-based |
Controller-based |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
Controller-based |
N/A |
mtu 1450 |
mtu 1450 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
Controller-based |
Controller-based |
Controller-based |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
l3-vni 50034 |
l3-vni 50034 |
Controller-based |
quit |
quit |
Controller-based |
N/A |
vsi SDN_VSI_22000 |
vsi SDN_VSI_22000 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
vxlan 22000 |
vxlan 22000 |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
vpn-target auto |
vpn-target auto |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
vsi SDN_VSI_22001 |
vsi SDN_VSI_22001 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
vxlan 22001 |
vxlan 22001 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
vpn-target auto |
vpn-target auto |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
vlan 21 to 22 |
vlan 21 to 22 |
Controller-based |
Create VLANs. |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Procedure summary
· Configuring the M-LAG interfaces connected to the external network
· Configuring the M-LAG interfaces connected to the external network firewalls
Configuring basic settings
Configuring basic settings on S12500X-AF switches
Border 1 |
Border 2 |
Purpose |
Remarks |
vxlan ip-forwarding tagged |
Manual |
Enable Layer 3 forwarding for all VXLANs. |
Enable VXLAN tunnels to forward VLAN tagged packets. |
You must delete all VSIs, VSI interfaces, and VXLAN tunnel interfaces before you can change the forwarding mode. |
routing-interface base-mac 542b-de0c-0264 |
routing-interface base-mac 542b-de0c-0200 |
Manual |
Configure the base MAC address. |
Configure the start MAC address of the consecutive MAC addresses that are reserved for system use. |
You must configure the base MAC address prior to the subsequent settings. |
Configuring basic settings on S12500G-AF switches
Border 1 |
Border 2 |
Purpose |
Remarks |
hardware-resource vxlan L3GW |
Manual |
Set the VXLAN hardware resource mode to Layer 3 gateway. |
Enable the device to perform VXLAN Layer 2 and Layer 3 forwarding. |
Save the configuration and reboot the device for this command to take effect. |
Manual |
N/A |
Configuring IS-IS
Border 1 |
Border 2 |
Purpose |
Remarks |
vlan all |
vlan all |
Manual |
Create a VLAN. |
N/A |
N/A |
router id 5.1.1.7 |
router id 5.1.1.9 |
Manual |
N/A |
N/A |
isis 1 |
isis 1 |
Manual |
Enter IS-IS view. |
N/A |
N/A |
non-stop-routing |
non-stop-routing |
Manual |
Enable IS-IS NSR. |
Avoid forwarding interruption on the M-LAG system. |
N/A |
is-level level-2 |
is-level level-2 |
Manual |
N/A |
cost-style wide |
cost-style wide |
Manual |
N/A |
timer spf 1 500 10 |
Manual |
Set the maximum SPF calculation interval to 1 second, minimum SPF calculation interval to 500 milliseconds, and incremental SPF calculation interval to 10 milliseconds. |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
set-overload on-startup 770 |
Manual |
Set the overload bit for 770 seconds upon system startup. |
N/A |
network-entity 51.0000.0005.0007.00 |
network-entity 51.0000.0005.0009.00 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
fast-reroute lfa |
fast-reroute lfa |
Manual |
N/A |
import-route direct |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 5.1.1.7 255.255.255.255 |
ip address 5.1.1.9 255.255.255.255 |
Manual |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
interface LoopBack100 |
Manual |
Create Loopback 100 and enter its view. |
N/A |
N/A |
ip address 100.100.100.100 255.255.255.255 |
Manual |
Disable IS-IS on the interface for IS-IS to redistribute direct routes to speed up fallback and convergence after a border device reboots. |
quit |
quit |
Manual |
N/A |
N/A |
interface Vlan-interface 1000 |
Manual |
Create VLAN-interface 1000. |
N/A |
ip address 100.1.1.1 255.255.255.0 |
ip address 100.1.1.2 255.255.255.0 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Configuring STP
Border 1 |
Border 2 |
stp global enable |
stp global enable |
Manual |
Border 1 |
Border 2 |
Purpose |
Remarks |
interface HundredGigE1/0/16 |
interface HundredGigE1/0/13 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 6.1.1.34 255.255.255.252 |
ip address 6.1.1.38 255.255.255.252 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
interface HundredGigE1/0/12 |
interface HundredGigE1/0/1 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 6.1.1.42 255.255.255.252 |
ip address 6.1.1.46 255.255.255.252 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Configuring L2VPN
Border 1 |
Border 2 |
Purpose |
Remarks |
l2vpn enable |
l2vpn enable |
Manual |
Enable L2VPN. |
N/A |
N/A |
Manual |
N/A |
l2vpn m-lag peer-link tunnel source 5.1.1.9 destination 5.1.1.7 |
l2vpn m-lag peer-link tunnel source 5.1.1.7 destination 5.1.1.9 |
Manual |
Enable the device to automatically set up a VXLAN tunnel with the peer M-LAG member device. Perform this task when the M-LAG system uses a direct physical link as the peer link. |
N/A |
Execute this command only on S12500X-AF switches. |
Manual |
Execute this command if a controller issues forwarding entries to the device to save resources. |
N/A |
Manual |
N/A |
Manual |
N/A |
vxlan default-decapsulation source interface LoopBack100 |
Manual |
N/A |
N/A |
mac-address timer aging 900 |
Manual |
Set the aging time to 900 seconds for dynamic MAC address entries. |
mac-address mac-learning ingress |
Manual |
Configure the device to learn MAC addresses at ingress. |
N/A |
arp forwarding-conversational-learning |
Manual |
Enable conversational learning for remote ARP entries. |
Save forwarding entry resources. |
Execute this command only on S12500X-AF switches. Execute this command only when EVPN is configured. |
ip forwarding-conversational-learning |
Manual |
Enable conversational learning for IPv4 host route FIB entries. |
Execute this command only on S12500G-AF switches. Execute this command only when EVPN is configured. |
ipv6 forwarding-conversational-learning |
Manual |
Enable conversational learning for IPv6 host route FIB entries. |
NOTE: By default, if an M-LAG system uses a direct physical link as the peer link, each M-LAG member device creates a dynamic AC on the peer link when an AC is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, enable the M-LAG member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link. If you use two border devices to set up an M-LAG system and BMs in bond1 mode need to communicate with the external network, unidirectional tunnels exist between the ToR switches and SDN gateway. Typically, unidirectional tunnels are set up when a ToR switch is disconnected from the controller or new BMs come online. In this scenario, an online ToR switch advertises routes that contain its real IP address. The SDN will set up a tunnel to that real IP address, while the ToR switch uses the virtual VTEP IP address for tunnel setup. For the ToR switches to decapsulate the packets sent by the SDN gateway, enable default VXLAN decapsulation on the ToR switches. An S12500X-AF or S12500G-AF switch learns MAC addresses at egress by default. If you enable the switch to learn MAC addresses at ingress, the M-LAG peer will send the MAC addresses entries for the firewalls to that switch once the local M-LAG interface of the switch comes up. if the member ports of the local M-LAG interface exit M-LAG MAD DOWN state, MAC address entry changes will trigger ARP migration, and ARP entries will be moved from the peer-link interface to the M-LAG interface. |
Configuring M-LAG
Border 1 |
Border 2 |
Purpose |
Remarks |
Manual |
N/A |
interface M-GigabitEthernet0/0/1 |
Manual |
N/A |
Manual |
N/A |
ip address 192.1.2.74 255.255.255.0 |
ip address 192.1.2.100 255.255.255.0 |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
m-lag restore-delay 450 |
Manual |
N/A |
m-lag role priority 100 |
m-lag role priority 101 |
Manual |
Set the M-LAG role priority of the device. |
N/A |
AN M-LAG member device is assigned the primary or secondary role based on its M-LAG role priority. The lower the priority value, the higher the priority. |
m-lag system-mac 542b-de0c-0200 |
Manual |
N/A |
Manual |
N/A |
m-lag system-priority 10000 |
Manual |
N/A |
Manual |
N/A |
N/A |
m-lag keepalive ip destination 192.1.2.100 source 192.1.2.74 vpn-instance management |
m-lag keepalive ip destination 192.1.2.74 source 192.1.2.100 vpn-instance management |
Manual |
m-lag mad include interface HundredGigE2/0/5 |
Manual |
Enable M-LAG to shut down the interface connected to the C-spine device when the M-LAG system splits. |
N/A |
N/A |
m-lag mad include interface HundredGigE1/0/12 |
m-lag mad include interface HundredGigE1/0/1 |
Manual |
Enable M-LAG to shut down the interface connected to a spine device when the M-LAG system splits. |
N/A |
N/A |
m-lag mad include interface HundredGigE1/0/16 |
m-lag mad include interface HundredGigE1/0/13 |
Manual |
N/A |
N/A |
evpn m-lag group 100.100.100.100 |
Manual |
N/A |
N/A |
evpn global-mac 542b-de0c-0201 |
Manual |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
interface HundredGigE2/0/21 |
interface HundredGigE2/0/7 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
interface HundredGigE3/0/36 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
port trunk pvid vlan 4094 |
Manual |
Assign the interface as a trunk port to VLAN 4094. |
Prevent the peer link from forwarding the VLAN traffic that erroneously matches dynamic ACs. |
N/A |
Manual |
N/A |
Execute this command only on S12500G-AF switches. |
NOTE: If you use a VXLAN tunnel as the peer link in an EVPN environment, you must retain a large number of logical interfaces (for example, tunnel and loopback interfaces) in up state. To reduce configuration steps, set the default M-LAG MAD action to NONE and execute the m-lag mad include interface command to specify interfaces that must be shut down by M-LAG MAD in addition to those already automatically specified by the system. |
Border 1 |
Border 2 |
interface Bridge-Aggregation4 |
Manual |
Create Bridge-Aggregation 4. |
Manual |
Configure link type as trunk. |
Manual |
port trunk permit vlan 4089 |
Manual |
Configure the trunk interface to permit the VLAN of the external network. |
Manual |
Set the aggregation mode to dynamic. |
port m-lag group 4 |
Manual |
Assign the interface to M-LAG group 4. |
interface HundredGigE3/0/24 |
Manual |
Enter the view of an aggregation member port. |
Manual |
Manual |
Manual |
port link-aggregation group 4 |
Manual |
Assign the interface to aggregation group 4. |
quit |
quit |
Manual |
Border 1 |
Border 2 |
Remarks |
interface Bridge-Aggregation10 |
Manual |
Create the aggregate interface to be assigned to M-LAG group 10. |
N/A |
Manual |
Configure the interface as a trunk interface. |
N/A |
Manual |
Remove the interface from VLAN 1. |
N/A |
Manual |
N/A |
Manual |
Configure the aggregate interface to operate in dynamic mode. |
N/A |
port m-lag group 10 |
Manual |
Assign the aggregate interface to M-LAG group 10. |
N/A |
interface Bridge-Aggregation20 |
Manual |
Create the aggregate interface to be assigned to M-LAG group 20. |
N/A |
Manual |
N/A |
Manual |
N/A |
port trunk permit vlan 2000 to 2100 |
Manual |
Configure the trunk interface to permit the VLANs of the tenant network. |
Configure VLAN settings according to the planned configuration on the controller. |
Manual |
N/A |
port m-lag group 20 |
Manual |
Assign the aggregate interface to M-LAG group 20. |
N/A |
interface HundredGigE2/0/27 |
Manual |
Enter the view of the member port in the M-LAG group 10. |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
port link-aggregation group 10 |
Manual |
N/A |
interface HundredGigE2/0/11 |
interface HundredGigE2/0/29 |
Manual |
Enter the view of the member port in the M-LAG group 20. |
N/A |
Manual |
N/A |
Manual |
N/A |
port link-aggregation group 20 |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
Border 1 |
Border 2 |
Purpose |
Remarks |
route-policy 1 permit node 1 |
Manual |
Create a routing policy. |
N/A |
These settings are used for direct communication with the external network upon border device failure. You can execute these commands as needed. |
apply ip-address next-hop 5.1.1.7 |
apply ip-address next-hop 5.1.1.9 |
Manual |
Set the next hop to the real IP address of the device. |
Set up a tunnel used for communication upon border device failure. |
apply local-preference 50 |
Manual |
Set the local preference of advertised BGP routes to 50. |
Optimize the route pointing to the M-LAG peer upon border device failure. |
quit |
quit |
Manual |
N/A |
N/A |
bgp 400 |
bgp 400 |
Manual |
Enable a BGP instance and enter its view. |
N/A |
N/A |
non-stop-routing |
non-stop-routing |
Manual |
non-stop-routing |
non-stop-routing |
N/A |
router-id 5.1.1.7 |
router-id 5.1.1.9 |
Manual |
Configure a route ID. |
N/A |
N/A |
Manual |
N/A |
Use evpn as the name of the IBGP peer group. |
Manual |
N/A |
N/A |
Manual |
group pod1 external |
Manual |
Create an EBGP peer group. |
N/A |
Perform this task on EDs. |
peer pod1 as-number 100 |
Manual |
Configure the AS number of the peer group. |
N/A |
peer pod1 connect-interface LoopBack0 |
Manual |
N/A |
peer pod1 ebgp-max-hop 64 |
Manual |
Enable BGP to establish an EBGP session to the indirectly connected peer group and specify the maximum hop count. |
N/A |
group taosheng internal |
Manual |
Configure a peer group used for permitting traffic to the M-LAG peer upon border device failure. |
N/A |
N/A |
peer taosheng connect-interface LoopBack0 |
Manual |
Specify a source interface for establishing TCP connections to the fail-permit peer group. |
N/A |
N/A |
peer 2.1.1.7 group pod1 |
Manual |
Assign a peer to the peer group. |
N/A |
Manual |
N/A |
N/A |
peer 5.1.1.7 group taosheng |
peer 5.1.1.9 group taosheng |
Manual |
Assign the peer border device to the fail-permit peer group. |
N/A |
N/A |
Manual |
N/A |
N/A |
peer 16.16.16.16 group pod1 |
Manual |
N/A |
Manual |
Create BGP EVPN address family and enter its view. |
N/A |
N/A |
nexthop evpn-m-lag group-address |
Manual |
Set the next hop of advertised EVPN routes to the virtual VTEP address of the M-LAG system. |
Enable the device to advertise EVPN routes whose next hop is the virtual VTEP address of the M-LAG system. |
N/A |
peer evpn enable |
peer evpn enable |
Manual |
Enable the device to exchange routes with the IBGP peer group. |
N/A |
N/A |
peer evpn next-hop-local |
Manual |
Set the local router as the next hop for routes sent to the IBGP peer group. |
Enable the peer group to reach the local router. |
N/A |
peer evpn re-originated replace-rt |
Manual |
Replace the route targets of IP prefix advertisement routes received from the IBGP peer group. |
N/A |
N/A |
peer evpn re-originated mac-ip replace-rt |
Manual |
Replace the route targets of MAC/IP advertisement routes received from the IBGP peer group. |
N/A |
N/A |
peer evpn re-originated imet replace-rt |
Manual |
Replace the route targets of IMET routes received from the IBGP peer group. |
N/A |
N/A |
peer pod1 enable |
peer pod1 enable |
Manual |
Enable the device to exchange routes with the EBGP peer group. |
N/A |
peer pod1 router-mac-local dci |
Manual |
Enable route router MAC replacement for the peer group and set up VXLAN-DCI tunnels with the EBGP peer group.. |
Set up VXLAN-DCI tunnels with the peer group to speed up route convergence upon public-side link flapping. |
You do not need to execute the dci enable command to set up VXLAN-DCI tunnels. Perform this task on EDs. |
peer pod1 re-originated replace-rt |
Manual |
Replace the route targets of BGP EVPN routes received from the EBGP peer group. |
Enable inter-data center route exchange. |
peer pod1 re-originated mac-ip replace-rt |
Manual |
Replace the route targets of MAC/IP advertisement routes received from the EBGP peer group. |
N/A |
peer pod1 re-originated imet replace-rt |
Manual |
Replace the route targets of IMET routes received from the EBGP peer group. |
N/A |
peer taosheng enable |
Manual |
Enable the device to exchange routes with the fail-permit peer group. |
N/A |
peer taosheng route-policy 1 export |
Manual |
Apply the routing policy created previously to the outbound direction. |
N/A |
peer taosheng advertise evpn-route suppress mac-ip |
Manual |
Disable advertising MAC/IP advertisement routes to the fail-permit peer group. |
Prevent inter-data center Layer 2 traffic from being forwarded over the fail-permit tunnel. |
peer taosheng advertise vpn-reoriginate ibgp |
Manual |
Enable advertising the EVPN routes reoriginated in VPN instances to IBGP peer. |
N/A |
Border 1 |
Border 2 |
Purpose |
Remarks |
ip vpn-instance external_vpn_123 |
Controller-based |
N/A |
route-distinguisher 5:50035 |
Controller-based |
Configure an RD for the VPN instance. |
N/A |
bgp 400 |
bgp 400 |
Controller-based |
Start a BGP instance. |
N/A |
Controller-based |
Enter the view of the VPN instance on the private network. |
N/A |
Controller-based |
Enter BGP-VPN IPv4 unicast address family view. |
N/A |
balance 4 |
balance 4 |
Controller-based |
Enable load balancing and set the maximum number of BGP ECMP routes for load balancing. |
N/A |
advertise route-reoriginate replace-rt |
Controller-based |
Reoriginate the BGP unicast routes from other VPN instances and change the route target attribute of reoriginated routes to that of the current VPN instance. |
N/A |
network 123.0.0.0 255.255.255.0 |
Controller-based |
Configure BGP to advertise a local network. |
N/A |
network 123.0.0.1 255.255.255.255 |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
address-family ipv6 unicast |
Controller-based |
Enter BGP-VPN IPv6 unicast address family view. |
N/A |
balance 4 |
balance 4 |
Controller-based |
N/A |
Controller-based |
N/A |
network 2123:: 64 |
network 2123:: 64 |
Controller-based |
N/A |
network 2123::1 128 |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
route-distinguisher 5:50034 |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
Configure import route targets for the VPN instance. |
N/A |
N/A |
Controller-based |
Configure export route targets for the VPN instance. |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
Enter EVPN address family view of the VPN instance. |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
interface Vsi-interface 22000 |
Controller-based |
N/A |
N/A |
mtu 1450 |
mtu 1450 |
Controller-based |
Configure the MTU. |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
mtu 1450 |
mtu 1450 |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
interface Vsi-interface 50034 |
Controller-based |
N/A |
N/A |
Controller-based |
Bind the VSI interface to the VPN instance. |
N/A |
N/A |
Controller-based |
N/A |
N/A |
l3-vni 50034 |
l3-vni 50034 |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
vsi SDN_VSI_22000 |
vsi SDN_VSI_22000 |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
vxlan 22000 |
vxlan 22000 |
Controller-based |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
vpn-target auto |
vpn-target auto |
Controller-based |
Configure import and export route targets for EVPN. |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
vsi SDN_VSI_22005 |
vsi SDN_VSI_22005 |
Controller-based |
N/A |
N/A |
gateway vsi-interface 22005 |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
vxlan 22005 |
vxlan 22005 |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
Controller-based |
N/A |
N/A |
vpn-target auto |
vpn-target auto |
Controller-based |
N/A |
N/A |
mapping vni 123123 |
Controller-based |
Map the local VXLAN to a remote VXLAN. |
Enable Layer 2 communication between data centers. |
quit |
quit |
Controller-based |
N/A |
N/A |
vsi SDN_VSI_123123 |
Controller-based |
Create a VSI. |
vxlan 123123 |
vxlan 123123 |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
Configure the RD. |
N/A |
vpn-target 123123:1 export-extcommunity |
Controller-based |
Configure export route targets for EVPN. |
N/A |
vpn-target 123123:1 import-extcommunity |
Controller-based |
Configure import route targets for EVPN. |
N/A |
quit |
quit |
Controller-based |
N/A |
ip vpn-instance 5ndrrejtf68up8h4lbkloqqh59dto8 |
Controller-based |
Create a VPN instance for inter-data center communication. |
Enable Layer 3 communication between data centers. |
route-distinguisher 5:456456 |
Controller-based |
Configure the RD. |
N/A |
Controller-based |
N/A |
route-replicate from vpn-instance admin_route4_50025 protocol direct advertise |
Controller-based |
Redistribute routes from the private VPN instance to the VPN instance for inter-data center communication. |
N/A |
vpn-target 456456:1 1:50025 import-extcommunity |
Controller-based |
Configure import route targets for the private VPN instance. |
Edit the private routes to reoriginate routes. |
vpn-target 456456:1 export-extcommunity |
Controller-based |
Configure export route targets for the public device. |
Configure the export route targets same as those of the VPN instance for inter-data center communication. |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
ip route-static vpn-instance admin_route1_50034 0.0.0.0 0 200.3.1.3 description SDN_ROUTE |
Controller-based |
Configure a static route. |
Direct traffic to the firewalls. |
The controller issues static routes on demand. |
ip route-static vpn-instance admin_route1_50034 121.5.0.0 16 200.3.1.3 description SDN_ROUTE |
Controller-based |
ipv6 route-static vpn-instance admin_route1_50034 :: 0 200:3:1::2 description SDN_ROUTE |
Controller-based |
ipv6 route-static vpn-instance admin_route1_50034 121:5:: 64 200:3:1::2 description SDN_ROUTE |
Controller-based |
bgp 400 |
bgp 400 |
Controller-based |
Enter BGP instance view. |
N/A |
N/A |
Controller-based |
Create a BGP-VPN instance and enter its view. |
Create a BGP-VPN instance on the private network. |
N/A |
Controller-based |
N/A |
N/A |
default-route imported |
Controller-based |
Import default routes. |
Advertise the default routes issued by the controller. |
N/A |
balance 4 |
balance 4 |
Controller-based |
N/A |
N/A |
import-route static |
Controller-based |
Import static routes. |
Advertise the static routes issued by the controller. |
N/A |
Controller-based |
N/A |
Controller-based |
N/A |
balance 4 |
balance 4 |
Controller-based |
N/A |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
quit |
quit |
Controller-based |
N/A |
N/A |
Controller-based |
Create a BGP-VPN instance for the VPN instance for inter-data center communication. |
Controller-based |
N/A |
balance 4 |
balance 4 |
Controller-based |
N/A |
Controller-based |
Import direct routes. |
N/A |
Controller-based |
N/A |
balance 4 |
balance 4 |
Controller-based |
N/A |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
quit |
quit |
Controller-based |
N/A |
Configuring S12508X-AF or S12500G-AF switches as spine devices
Procedure summary
· Configuring the links between the spine and leaf tiers
· Configuring the links between the spine and border tiers
Configuring IS-IS
Spine 1 |
Spine 2 |
Purpose |
Remarks |
router id 5.1.1.6 |
router id 5.1.1.8 |
Manual |
N/A |
N/A |
isis 1 |
isis 1 |
Manual |
Enable IS-IS and enter IS-IS view. |
N/A |
N/A |
non-stop-routing |
non-stop-routing |
Manual |
Enable IS-IS NSR. |
N/A |
is-level level-2 |
is-level level-2 |
Manual |
N/A |
cost-style wide |
cost-style wide |
Manual |
N/A |
flash-flood |
flash-flood |
Manual |
Enable IS-IS LSP flash flooding. |
Changed LSPs can trigger SPF recalculation. To advertise the changed LSPs before the router recalculates routes for faster network convergence, enable LSP flash flooding. |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
network-entity 51.0000.0005.0006.00 |
network-entity 51.0000.0005.0008.00 |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
ip address 5.1.1.6 255.255.255.255 |
ip address 5.1.1.8 255.255.255.255 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
The following matrix uses an interface as an example. You can configure other interface in the same way.
Spine 1 |
Spine 2 |
Configuration method |
Purpose |
Remarks |
interface FortyGigE3/0/16 |
interface FortyGigE3/0/4 |
Manual |
Configure a connection to Leaf 1. |
N/A |
Manual |
N/A |
N/A |
ip address 6.1.1.2 255.255.255.252 |
ip address 6.1.1.6 255.255.255.252 |
Manual |
Assign an IP address to the interface. |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Spine 1 |
Spine 2 |
Purpose |
Remarks |
interface HundredGigE2/0/9 |
Manual |
Configure a connection to Border 1. |
N/A |
Manual |
N/A |
N/A |
ip address 6.1.1.33 255.255.255.252 |
ip address 6.1.1.41 255.255.255.252 |
Manual |
N/A |
N/A |
isis enable 1 |
isis enable 1 |
Manual |
N/A |
N/A |
Manual |
N/A |
Manual |
N/A |
Manual |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
Configuring BGP
Spine 1 |
Spine 2 |
Purpose |
Remarks |
bgp 400 |
bgp 400 |
Manual |
N/A |
N/A |
non-stop-routing |
non-stop-routing |
Manual |
Enable BGP NSR. |
If the device has two MPUs, BGP NSR ensures continuous routing by synchronizing BGP state and data information from the active BGP process to the standby BGP process. The standby BGP process can seamlessly take over all services when the active process fails. |
router-id 5.1.1.6 |
router-id 5.1.1.8 |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
N/A |
N/A |
Manual |
group vbgp internal |
Manual |
Create an IBGP peer group for communicating with the controller. |
N/A |
N/A |
peer vbgp route-update-interval 0 |
Manual |
peer 5.1.1.1 group evpn |
Manual |
N/A |
N/A |
peer 5.1.1.2 group evpn |
Manual |
N/A |
N/A |
peer 5.1.1.3 group evpn |
Manual |
N/A |
N/A |
peer 5.1.1.4 group evpn |
Manual |
N/A |
N/A |
peer 5.1.1.7 group evpn |
Manual |
N/A |
N/A |
peer 5.1.1.9 group evpn |
Manual |
N/A |
N/A |
peer 52.1.2.2 group vbgp |
Manual |
N/A |
N/A |
Manual |
Enter BGP EVPN view. |
N/A |
N/A |
undo policy vpn-target |
Manual |
Disable route target filtering for BGP EVPN routes. |
N/A |
N/A |
peer evpn enable |
peer evpn enable |
Manual |
N/A |
N/A |
peer evpn reflect-client |
Manual |
Configure the device as a route reflector and specify the evpn peer group as a client. |
N/A |
N/A |
peer vbgp enable |
peer vbgp enable |
Manual |
N/A |
N/A |
peer vbgp reflect-client |
Manual |
Configure the device as a route reflector and specify the vbgp peer group as a client. |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
quit |
quit |
Manual |
N/A |
N/A |
NOTE: When the TCP connection goes down, the hold timer expires, or the support for a new address family is added, BGP tears down and then re-establishes the peer sessions, which will cause traffic interruption. To avoid traffic interruption in these cases, enable BGP to reset peer sessions gracefully. |
Overlay traffic forwarding models
Overlay traffic characteristics
The forwarding model matrix provides the following characteristics of overlay traffic:
· No.—Traffic number in the O-X-XXX format:
¡ O—Overlay traffic.
¡ X—Protocol number, which can be 4 (IPv4) or 6 (IPv6).
¡ XXX—Traffic sequence number starting from 001.
· Traffic type—Type of overlay traffic, which can be known unicast/IPV4 and unicast/Layer 2.
· Direction—Direction of overlay traffic.
· Forwarding path—Nodes that overlay traffic traverses.
· Traffic simulation—Traffic simulation method. Typically a tester is used to simulate server traffic.
· Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
· Traffic direction to firewalls/LB—Configuration used to direct traffic to firewalls and load balancers, other than PBR, M-LAG, VRRP, static routes.
Forwarding models
No. |
Traffic type |
Direction |
Forwarding path |
Traffic simulation |
Load |
Traffic direction to firewalls/LB |
Remarks |
O-4-001 |
Known unicast/IPv4 |
East to west, across leaf devices |
Server 3 > Leaf 3 > Spine 2 > Leaf 2 > Server 2 |
Bound4+ tester |
Light |
N/A |
BM-to-BM communication. |
O-4-002 |
Bound4+ tester |
Light |
N/A |
BM-to-VM communication. |
O-4-003 |
South to north |
Server 3 > Leaf 3 > Spine 2 > Border 2 > public device |
Bound4+ tester |
Light |
Static routes. Firewall: Through a VLAN on an M-LAG interface. LB: Through an AC on an M-LAG interface. |
BM-to-external network communication. |
O-4-004 |
South to north |
Server 3 > Leaf 1 > Spine 2 > Border 2 > public device |
Bound4+ tester |
Light |
O-4-005 |
Unicast/Layer 2 |
Server 2 > Leaf 1 > Server 1 |
Bound4+ tester |
Light |
N/A |
O-4-006 |
Server 2 > Leaf 1 > Leaf 4 > Server 4 |
Bound4+ tester |
Light |
N/A |
O-4-007 |
Server 2 > Leaf 2 > Spine 1 > Leaf 3 > Server 4 |
Bound4+ tester |
Light |
N/A |
VM-to-BM communication. |
O-4-008 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
N/A |
O-4-009 |
Server 1 > Leaf 2 > Spine 1 > Border > Spine 2 > Leaf 3 > Server 4 |
Bound4+ tester |
Light |
O-4-010 |
South to north |
Server 1 > Leaf 1 > Spine 2 > Border 2 > public device |
Bound4+ tester |
Light |
VM-to-external network communication. |
O-4-011 |
Unicast/Layer 2 |
Between data centers |
Server 1 > Leaf 1 > Spine 2 > Border 2 |
Bound4+ tester |
Light |
Inter-data center Layer 2 communication. |
O-4-012 |
Server 4 > Leaf 3 > Spine 1 > Border > Spine > Leaf 2 > Server 1 |
Bound4+ tester |
Light |
O-4-013 |
Server 4 > Leaf 3 > Spine 2 > Border > Spine > Leaf 2 > Server 2 |
Bound4+ tester |
Light |
O-4-014 |
East to west, same leaf device |
Server 4 > Leaf 3 > Spine > Border > Spine > Leaf > Server 4 |
Bound4+ tester |
Light |
N/A |
O-4-015 |
Server 4 > Leaf 3 > Spine 1 > Leaf 2 > Server 1 |
Bound4+ tester |
Light |
N/A |
O-4-016 |
Server 4 > Leaf 3 > Spine 1 > Leaf 2 > Server 2 |
Bound4+ tester |
Light |
O-4-017 |
Bound4+ tester |
Light |
O-4-018 |
South to north |
Server 3 > Leaf 3 > Server 1 |
Bound4+ tester |
Light |
N/A |
O-4-019 |
Unicast/Layer 2 |
Server 2 > Leaf 3 > Spine 1 > Leaf 2 > Server 1 |
Bound4+ tester |
Light |
N/A |
O-4-020 |
Bound4+ tester |
Light |
O-4-021 |
Server 2 > Leaf 1 > Spine > Border > Spine > Leaf > Server 4 |
Bound4+ tester |
Light |
O-4-022 |
South to north |
Server 2 > Leaf 1 > Spine 2 > Border 2 > public device |
Bound4+ tester |
Light |
N/A |
O-4-023 |
Server 4 > Leaf 4 > Spine 2 > Border 2 |
Bound4+ tester |
Light |
N/A |
Inter-data center Layer 3 communication. |
O-4-024 |
Unicast/Layer 2 |
Server 3 > Leaf 4 > Spine 2 > Leaf 2 > Server 2 |
Bound4+ tester |
Light |
N/A |
O-4-025 |
Server 3 > Leaf 4 > Server 4 |
Bound4+ tester |
Light |
N/A |
O-4-026 |
South to north |
Bound4+ tester |
Light |
O-4-027 |
North to south |
Public device > Border 2 > Spine 2 > Leaf 1 > Server 1 |
Bound4+ tester |
Light |
External network-to-VM communication. |
O-4-028 |
North to south |
Bound4+ tester |
Light |
External network-to-BM communication. |
O-4-029 |
North to south |
Public device > Border 2 > Spine 2 > Leaf 3 > Server 4 |
Bound4+ tester |
Light |
O-4-030 |
North to south |
Public device > Border 2 > Spine 2 > Leaf 3 > Server 3 |
Bound4+ tester |
Light |
O-4-031 |
North to south |
Public device > Border 2 > Spine 2 > Leaf 1 > Server 2 |
Bound4+ tester |
Light |
O-4-032 |
North to south |
Public device > Border 2 > Spine 2 > Leaf 1 > Server 4 |
Bound4+ tester |
Light |
O-4-033 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
N/A |
O-4-034 |
Border 1 > Spine 1 > Leaf 4 > Server 4 |
Bound4+ tester |
Light |
N/A |
O-6-035 |
Bound4+ tester |
Light |
N/A |
O-6-036 |
Bound4+ tester |
Light |
N/A |
O-6-037 |
South to north |
Server 3 > Leaf 3 > Spine 2 > Border 2 > Public device |
Bound4+ tester |
Light |
O-6-038 |
South to north |
Server 3 > Leaf 1 > Spine 2 > Border 2 > Public device |
Bound4+ tester |
Light |
O-6-039 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
N/A |
O-6-040 |
Bound4+ tester |
Light |
N/A |
O-6-041 |
Bound4+ tester |
Light |
N/A |
O-6-042 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
N/A |
O-6-043 |
Bound4+ tester |
Light |
O-6-044 |
South to north |
Server 1 > Leaf 1 > Spine 2 > Border 2 > Public device |
Bound4+ tester |
Light |
O-6-045 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
O-6-046 |
Bound4+ tester |
Light |
O-6-047 |
Bound4+ tester |
Light |
O-6-048 |
Bound4+ tester |
Light |
N/A |
O-6-049 |
Bound4+ tester |
Light |
N/A |
O-6-050 |
Bound4+ tester |
Light |
O-6-051 |
Bound4+ tester |
Light |
O-6-052 |
South to north |
Bound4+ tester |
Light |
N/A |
O-6-053 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
N/A |
O-6-054 |
Bound4+ tester |
Light |
O-6-055 |
Bound4+ tester |
Light |
O-6-056 |
South to north |
Server 2 > Leaf 1 > Spine 2 > Border 2 > Public device |
Bound4+ tester |
Light |
N/A |
O-6-057 |
Bound4+ tester |
Light |
N/A |
O-6-058 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
N/A |
O-6-059 |
Bound4+ tester |
Light |
N/A |
O-6-060 |
South to north |
Bound4+ tester |
Light |
O-6-061 |
North to south |
Bound4+ tester |
Light |
O-6-062 |
North to south |
Bound4+ tester |
Light |
O-6-063 |
North to south |
Bound4+ tester |
Light |
O-6-064 |
North to south |
Bound4+ tester |
Light |
O-6-065 |
North to south |
Bound4+ tester |
Light |
O-6-066 |
North to south |
Bound4+ tester |
Light |
O-6-067 |
Unicast/Layer 2 |
Bound4+ tester |
Light |
N/A |
O-6-068 |
Bound4+ tester |
Light |
N/A |
Testing network convergence upon single points of failure
Table 1 Network convergence upon single points of failure
Device |
Failure type |
Traffic interruption time |
Leaf |
Link failure when the traffic load is light. |
≤ 500 ms |
Node failure when the traffic load is light. |
≤ 2000 ms |
Border |
≤ 500 ms |
≤ 2000 ms |
Spine |
≤ 500 ms |
≤ 2000 ms |
Verification commands
Leaf 1 |
Leaf 2 |
display m-lag summary |
Displays summary information about the peer-link interface and M-LAG interfaces. |
display m-lag system |
Displays the M-LAG system settings. |
display m-lag keepalive |
Displays M-LAG keepalive packet statistics. |
display m-lag role |
Displays M-LAG role information. |
display m-lag consistency { type1 | type2 } |
Displays information about the configuration consistency check done by M-LAG. |
display m-lag consistency-check status |
Displays the configuration consistency check status. |
display interface Bridge-Aggregation [ brief ] |
Displays information about aggregate interfaces. |
display stp brief |
display stp brief |
Displays the brief spanning tree status and statistics. |
# Verify that nodes Border 1 and Border 2 has established an M-LAG system.
<POD2-Border1> display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
M-LAG interface information
M-LAG IF M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG4 4 UP UP -
BAGG10 10 UP UP -
BAGG20 20 UP UP -
# Verify the M-LAG system settings on Border 1.
<POD2-Border1> display m-lag system
System information
Local system number: 2 Peer system number: 1
Local system MAC: 542b-de0c-0200 Peer system MAC: 542b-de0c-0200
Local system priority: 10000 Peer system priority: 10000
Local bridge MAC: e0fd-0079-5020 Peer bridge MAC: e0fd-0079-5021
Local effective role: None Peer effective role: None
Health level: 1
Standalone mode on split: Enabled
In standalone mode: Yes
System timer information
Timer State Value (s) Remaining time (s)
Auto recovery Disabled - -
Restore delay Disabled 450 -
Consistency-check delay Disabled 150 -
Standalone delay Disabled 0 -
Role to None delay Disabled 60 -
# Verify the keepalive packet statistics on Border 1.
<POD2-Border1> display m-lag keepalive
Neighbor keepalive link status: Up
Neighbor is alive for: 192203 s 276 ms
Last keepalive packet sending status: Successful
Last keepalive packet sending time: 2021/03/12 07:22:20 278 ms
Last keepalive packet receiving status: Successful
Last keepalive packet receiving time: 2021/03/12 07:22:20 287 ms
M-LAG keepalive parameters:
Destination IP address: 192.1.2.100
Source IP address: 192.1.2.74
Keepalive UDP port : 6400
Keepalive VPN name : management
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
# Verify the M-LAG roles on Border 1.
<POD2-Border1> display m-lag role
Effective role information
Factors Local Peer
Effective role Primary Secondary
Effective role trigger: M-LAG system init
Effective role reason: -
Configured role information
Factors Local Peer
Configured role Primary Secondary
Role priority 100 101
Bridge MAC 7057-bff9-aa00 542b-de0c-020
# View information about the configuration consistency check done by M-LAG on Border 1.
<POD2-Border1> display m-lag consistency type2 global
Configuration Local Peer
Vlan-int 123, 1000, 2000-2005 123, 1000, 2000-2005
# View information about the aggregate interfaces on Border 1.
<POD2-Border1> display interface Bridge-Aggregation brief
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
BAGG1 UP 80G(a) F(a) T 1
BAGG4 UP 80G(a) F(a) T 1
BAGG10 UP 200G(a) F(a) T 1
BAGG20 UP 200G(a) F(a) T 1
# View the brief spanning tree status and statistics.
<POD2-Border1> display stp brief
MST ID Port Role STP State Protection
0 Bridge-Aggregation4 DESI FORWARDING NONE
0 Bridge-Aggregation10 DESI FORWARDING NONE
0 Bridge-Aggregation20 DESI FORWARDING NONE
Upgrading the devices
Upgrading the leaf devices
Checking the environment
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an upgrade.
Leaf 1 |
Leaf 2 |
display device |
display device |
Displays device information. |
display boot-loader |
Displays current software images and startup software images. |
display version |
display version |
Displays system version information. |
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the traffic interruption time is shorter than 500 ms during a switchover and shorter than 150 ms during fallback when the traffic load is light. For more information, see "Testing network convergence upon single points of failure."
Verifying the upgrade result
Execute the commands in "Verification commands" and the following commands to verify that the device is upgraded successfully.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Upgrading the spine devices
Spine 1 |
Spine 2 |
display device |
display device |
display version |
display version |
1. Use the display version command to verify the current BootWare image version and startup software version.
2. Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡ Software and hardware compatibility.
¡ Version and size of the upgrade software.
¡ Compatibility of the upgrade software with the current BootWare image and startup software image.
3. Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image.
4. Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command.
5. Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system.
6. Upgrade the device according to the configuration guides for the device.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Upgrading the border devices
Border 1 |
Border 2 |
display device |
display device |
display version |
display version |
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Expanding the network
An expansion operation adds two leaf devices.
Adding a leaf device
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an expansion.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Adding the device to the leaf tier
1. Disconnect the device from network management systems.
2. Upgrade the software of the device as needed.
3. Preconfigure the device.
4. Connect the device to network management systems.
5. Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Replacing a service module
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for a replacement.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
1. Switch service and management traffic on the target service module to other service modules.
2. Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the replacement result
Execute the commands in "Checking the environment."
Replacing a switching fabric module
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
