H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
Table of Contents
Related Documents
65-IRF Configuration Examples
65-IRF Configuration Examples 412.36 KB
Introduction
This document provides examples for setting up IRF fabrics and configuring link aggregation and routing on the IRF fabrics.
This document assumes that you have basic knowledge of IRF.
General restrictions and guidelines
When you set up and configure an IRF fabric, follow the restrictions and guidelines in this section.
This section provides only the basic restrictions and guidelines that ensure a successful IRF deployment. For more information, see IRF configuration in the configuration guides for your devices.
Hardware requirements
The applicable switches in the IRF configuration examples can form an IRF fabric only with switches in the same series.
Software requirements
All IRF member devices must run the same system software version.
IRF physical interface requirements
Requirements for IRF physical interfaces vary by device model. To establish an IRF fabric successfully, use the installation guide for your device to identify the IRF physical interface requirements, including:
·     Interfaces that can be used for IRF connections.
·     Interface grouping status on the device. Typically, if you use one physical interface in a group as an IRF physical interface, you cannot use the remaining physical interfaces in the group for any other purposes than IRF connection.
·     Compatible transceiver modules and cables.
Connecting IRF ports
When you connect two neighboring IRF members, connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other.
Example: Setting up a four-chassis LACP MAD-enabled IRF fabric
As shown in Figure 2, use a four-chassis IRF fabric to replace the ToR switches in Figure 1 at the access layer. The access-layer IRF fabric provides Layer 2 forwarding services.
Run LACP MAD to detect IRF split.
Figure 1 Network diagram before IRF deployment
Figure 2 Network diagram after IRF deployment
Analysis
The requirements in this example include the following categories:
·     IRF setup
·     LACP MAD configuration
·     Network connectivity configuration
IRF setup
To set up an IRF fabric, determine the items in Table 1.
Table 1 Basic IRF setup
Item
Analysis
Choice in this example
Topology
You can use a ring or daisy-chain topology for a three- or four-chassis IRF fabric.
For reliability, use the ring topology.
Ring topology (see Figure 3).
Member ID assignment
IRF member IDs must be unique.
Device A—1.
Device B—2.
Device C—3.
Device D—4.
Master device
IRF members elect a master automatically. For a member device to be elected the master, assign it the highest member priority.
Device A.
IRF port bindings
Make sure the IRFport bindings are consistent with the physical connections.
For high availability, bind multiple physical interfaces to an IRF port. These ports will automatically aggregate for load balancing and redundancy.
See Table 2.
Figure 3 IRF fabric topology
Table 2 IRF physical interface bindings
IRF port
Device A:
IRF-port 1
GigabitEthernet 1/0/51
GigabitEthernet 1/0/52
IRF-port 2
GigabitEthernet 1/0/53
GigabitEthernet 1/0/54
Device B:
IRF-port 1
GigabitEthernet 2/0/51
GigabitEthernet 2/0/52
IRF-port 2
GigabitEthernet 2/0/53
GigabitEthernet 2/0/54
Device C:
IRF-port 1
GigabitEthernet 3/0/51
GigabitEthernet 3/0/52
IRF-port 2
GigabitEthernet 3/0/53
GigabitEthernet 3/0/54
Device D:
IRF-port 1
GigabitEthernet 4/0/51
GigabitEthernet 4/0/52
IRF-port 2
GigabitEthernet 4/0/53
GigabitEthernet 4/0/54
The first segment in a physical interface number is the IRF member ID. By default, the IRF member ID is 1. Table 2 shows the interface numbers after the member IDs are changed.
IMPORTANT
IMPORTANT:
For LACP MAD to run correctly, you must make sure the intermediate device supports extended LACPDUs for LACP MAD.
To run LACP MAD, the IRF fabric and intermediate device must each have a dynamic Ethernet link aggregation. LACP MAD cannot run on a static link aggregation.
If the intermediate device is also an IRF fabric, you must configure MAD for both IRF fabrics, and assign the two IRF fabrics different domain IDs for correct split detection. This example uses a four-chassis IRF fabric at the distribution layer. The access-layer and distribution-layer IRF fabrics are the intermediate device of each other, as shown in Figure 4.
In this example, each member in the access-layer IRF fabric has only two links to the distribution-layer IRF fabric. For high availability, you can connect each member in the access-layer IRF fabric to each member in the distribution-layer IRF fabric. After you aggregate these links, they are regarded as one link in the topology.
For quick split detection, assign high-speed ports for uplink aggregation connections. This example uses GE ports.
Figure 4 LACP MAD
In a Layer 2 network, IRF is typically used with link aggregation to simplify the network topology.
For high availability, you can connect each host or server to two ToR switches in the access-layer IRF fabric, and aggregate the links. On each link aggregation, you do not need to run the spanning tree protocol feature because an IRF fabric appears as one node in the network.
For VLAN tags to be processed correctly, assign ports and aggregate interfaces to the correct VLANs.
A link aggregation could span one member device, some of the member devices, or all member devices, depending on the link redundancy requirements and number of available links. The link aggregation used for LACP MAD must span all member devices.
Figure 5 Connection diagram for the IRF fabrics in a Layer 2 network
Hardware
Software version
S6520XE-HI switch series
Supported in Release 11xx
S5560X-EI switch series
Supported in Release 111x
S5500V2-EI switch series
MS4520V2-30F switch
S5560S-EI switch series
S5560S-SI switch series
Supported in Release 612x
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
S5120V2-SI switch series
S5120V2-LI switch series
S3100V3-EI switch series
S3100V3-SI switch series
S5110V2 switch series
S5110V2-SI switch series
S5000V3-EI switch series
S5000E-X switch series
WAS6000 switch series
E128C switch
E152C switch
E500C switch series
E500D switch series
MS4520V2 switch series (except the MS4520V2-30F switch)
MS4320V2 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
Not supported
WS5810-WiNet switch series
Not supported
Restrictions and guidelines for LACP MAD configuration
When you configure LACP MAD, follow these restrictions and guidelines:
·     You only need to run LACP MAD on a single link aggregation for IRF split detection.
·     The link aggregation must use dynamic aggregation mode.
·     The link aggregation must have a minimum of one member link from each member device.
Restrictions and guidelines for IRF physical interfaces
Make sure all IRF physical interfaces are operating in bridge mode (the default).
Procedures
This example assumes that the distribution-layer IRF fabric has been set up.
Setting up the access-layer IRF fabric
1.     Configure Device A:
# Shut down the physical interfaces used for IRF connection. This example uses the port group that contains GigabitEthernet 1/0/51 to GigabitEthernet 1/0/54 for IRF connection.
[DeviceA] interface range gigabitethernet 1/0/51 to gigabitethernet 1/0/54
[DeviceA-if-range] shutdown
[DeviceA-if-range] quit
# Bind GigabitEthernet 1/0/51 and GigabitEthernet 1/0/52 to IRF-port 1/1.
[DeviceA] irf-port 1/1
[DeviceA-irf-port1/1] port group interface gigabitethernet 1/0/51
[DeviceA-irf-port1/1] port group interface gigabitethernet 1/0/52
[DeviceA-irf-port1/1] quit
# Bind GigabitEthernet 1/0/53 and GigabitEthernet 1/0/54 to IRF-port 1/2.
[DeviceA] irf-port 1/2
[DeviceA-irf-port1/2] port group interface gigabitethernet 1/0/53
[DeviceA-irf-port1/2] port group interface gigabitethernet 1/0/54
[DeviceA-irf-port1/2] quit
# Bring up the physical interfaces.
[DeviceA-if-range] undo shutdown
# Assign IRF member priority 31 to Device A. This priority is high enough to ensure that Device A can be elected as the master.
[DeviceA] irf member 1 priority 31
# Save the running configuration.
[DeviceA] quit
<DeviceA> save
# Activate the IRF port configuration.
[DeviceA] irf-port-configuration active
2.     Configure Device B:
# Assign member ID 2 to Device B, and reboot the device to effect the member ID change.
[DeviceB] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB] quit
<DeviceB> reboot
# Shut down the physical interfaces used for IRF connection. This example uses the port group that contains GigabitEthernet 2/0/51 to GigabitEthernet 2/0/54 for IRF connection.
[DeviceB] interface range gigabitethernet 2/0/51 to gigabitethernet 2/0/54
[DeviceB-if-range] shutdown
[DeviceB-if-range] quit
# Bind GigabitEthernet 2/0/51 and GigabitEthernet 2/0/52 to IRF-port 2/1.
[DeviceB] irf-port 2/1
[DeviceB-irf-port2/1] port group interface gigabitethernet 2/0/51
[DeviceB-irf-port2/1] port group interface gigabitethernet 2/0/52
[DeviceB-irf-port2/1] quit
# Bind GigabitEthernet 2/0/53 and GigabitEthernet 2/0/54 to IRF-port 2/2.
[DeviceB] irf-port 2/2
[DeviceB-irf-port2/2] port group interface gigabitethernet 2/0/53
[DeviceB-irf-port2/2] port group interface gigabitethernet 2/0/54
[DeviceB-irf-port2/2] quit
[DeviceB-if-range] undo shutdown
[DeviceB] quit
<DeviceB> save
# Connect Device B to Device A, as shown in Figure 3.
[DeviceB] irf-port-configuration active
Device B has a lower priority than Device A, and Device B fails master election and reboots. A two-chassis IRF fabric is formed.
3.     Configure Device C:
# Assign member ID 3 to Device C, and reboot the device to effect the member ID change.
<DeviceC> system-view
[DeviceC] irf member 1 renumber 3
[DeviceC] quit
<DeviceC> reboot
# Shut down the physical interfaces used for IRF connection. This example uses the port group that contains GigabitEthernet 3/0/51 to GigabitEthernet 3/0/54 for IRF connection.
[DeviceC] interface range gigabitethernet 3/0/51 to gigabitethernet 3/0/54
[DeviceC-if-range] shutdown
[DeviceC-if-range] quit
# Bind GigabitEthernet 3/0/51 and GigabitEthernet 3/0/52 IRF-port 3/1.
[DeviceC] irf-port 3/1
[DeviceC-irf-port3/1] port group interface gigabitethernet 3/0/51
[DeviceC-irf-port3/1] port group interface gigabitethernet 3/0/52
[DeviceC-irf-port3/1] quit
# Bind GigabitEthernet 3/0/53 and GigabitEthernet 3/0/54 to IRF-port 3/2.
[DeviceC] irf-port 3/2
[DeviceC-irf-port3/2] port group interface gigabitethernet 3/0/53
[DeviceC-irf-port3/2] port group interface gigabitethernet 3/0/54
[DeviceC-irf-port3/2] quit
[DeviceC-if-range] undo shutdown
[DeviceC] quit
<DeviceC> save
# Connect Device C to Device B, as shown in Figure 3.
[DeviceC] irf-port-configuration active
Device C reboots to join the IRF fabric. A three-chassis IRF fabric is formed.
4.     Configure Device D:
# Assign member ID 4 to Device D, and reboot the device to effect the member ID change.
<DeviceD> system-view
[DeviceD] irf member 1 renumber 4
[DeviceD] quit
<DeviceD> reboot
# Shut down the physical interfaces used for IRF connection. This example uses the port group that contains GigabitEthernet 4/0/51 to GigabitEthernet 4/0/54 for IRF connection.
[DeviceD] interface range gigabitethernet 4/0/51 to gigabitethernet 4/0/54
[DeviceD-if-range] shutdown
[DeviceD-if-range] quit
# Bind GigabitEthernet 4/0/51 and GigabitEthernet 4/0/52 to IRF-port 4/1.
[DeviceD] irf-port 4/1
[DeviceD-irf-port4/1] port group interface gigabitethernet 4/0/51
[DeviceD-irf-port4/1] port group interface gigabitethernet 4/0/52
[DeviceD-irf-port4/1] quit
# Bind GigabitEthernet 4/0/53 and GigabitEthernet 4/0/54 to IRF-port 4/2.
[DeviceD] irf-port 4/2
[DeviceD-irf-port4/2] port group interface gigabitethernet 4/0/53
[DeviceD-irf-port4/2] port group interface gigabitethernet 4/0/54
[DeviceD-irf-port4/2] quit
[DeviceD-if-range] undo shutdown
[DeviceD] quit
<DeviceD> save
# Connect Device D to Device A and Device C, as shown in Figure 3.
[DeviceD] irf-port-configuration active
Device D reboots to join the IRF fabric. A four-chassis IRF fabric is formed. The command prompt changes to the name of Device A (the master).
5.     Change the name of the IRF fabric.
[DeviceA] sysname IRF
[IRF]
Configuring LACP MAD
1.     Configure the IRF fabric at the access layer:
# Assign domain ID 1 to the IRF fabric.
<IRF> system-view
[IRF] irf domain 1
# Create Bridge-Aggregation 2, set its aggregation mode to dynamic, and enable LACP MAD.
[IRF] interface bridge-aggregation 2
[IRF-Bridge-Aggregation2] link-aggregation mode dynamic
[IRF-Bridge-Aggregation2] mad enable
[Current domain is: 1]:
The assigned domain ID is: 1
Info: MAD LACP only enable on dynamic aggregation interface.
[IRF-Bridge-Aggregation2] quit
# Create a named interface range that contains uplink ports to the distribution layer IRF fabric. In this example, the interface range name is lacp, and each member device has two links to the distribution layer IRF fabric.
[IRF] interface range name lacp interface gigabitethernet 1/0/49 to gigabitethernet 1/0/50 gigabitethernet 2/0/49 to gigabitethernet 2/0/50 gigabitethernet 3/0/49 to gigabitethernet 3/0/50 gigabitethernet 4/0/49 to gigabitethernet 4/0/50
# Assign the ports in the interface range to Bridge-Aggregation 2.
[IRF-if-range-lacp] port link-aggregation group 2
[IRF-if-range-lacp] quit
2.     Configure the IRF fabric at the distribution layer:
# Assign IRF domain ID 2 to the IRF fabric.
[Sysname] irf domain 2
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] link-aggregation mode dynamic
[Sysname-Bridge-Aggregation2] mad enable
[Current domain is: 2]:
The assigned domain ID is: 2
[Sysname-Bridge-Aggregation2] quit
# Assign the downlink ports that connect to the access-layer IRF fabric to Bridge-Aggregation 2.
[Sysname] interface gigabitethernet 1/2/0/1
[Sysname-GigabitEthernet1/2/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet1/2/0/1] quit
[Sysname] interface gigabitethernet 1/3/0/1
[Sysname-GigabitEthernet1/3/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet1/3/0/1] quit
[Sysname] interface gigabitethernet 2/3/0/1
[Sysname-GigabitEthernet2/3/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet2/3/0/1] quit
[Sysname] interface gigabitethernet 2/4/0/2
[Sysname-GigabitEthernet2/4/0/2] port link-aggregation group 2
[Sysname-GigabitEthernet2/4/0/2] quit
[Sysname] interface gigabitethernet 3/4/0/1
[Sysname-GigabitEthernet3/4/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet3/4/0/1] quit
[Sysname] interface gigabitethernet 3/3/0/2
[Sysname-GigabitEthernet3/3/0/2] port link-aggregation group 2
[Sysname-GigabitEthernet3/3/0/2] quit
[Sysname] interface gigabitethernet 4/2/0/1
[Sysname-GigabitEthernet4/2/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet4/2/0/1] quit
[Sysname] interface gigabitethernet 4/3/0/1
[Sysname-GigabitEthernet4/3/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet4/3/0/1] quit
Configuring network connectivity settings
This section provides the VLAN and link aggregation configuration procedure for end devices (for example, a server in VLAN 10).
# Create VLAN 10.
<IRF> system-view
[IRF] vlan 10
# Create Bridge-Aggregation 3, and set its aggregation mode to dynamic.
[IRF] interface bridge-aggregation 3
[IRF-Bridge-Aggregation3] link-aggregation mode dynamic
[IRF-Bridge-Aggregation3] quit
# Assign GigabitEthernet 1/0/10 and GigabitEthernet 2/0/10 to the aggregation group for Bridge-Aggregation 3.
[IRF] interface gigabitethernet 1/0/10
[IRF-GigabitEthernet1/0/10] port link-aggregation group 3
[IRF-GigabitEthernet1/0/10] quit
[IRF] interface gigabitethernet 2/0/10
[IRF-GigabitEthernet2/0/10] port link-aggregation group 3
[IRF-GigabitEthernet2/0/10] quit
# Assign Bridge-Aggregation 3 to VLAN 10.
[IRF-Bridge-Aggregation3] port access vlan 10
# Configure Bridge-Aggregation 2 as a trunk port, and assign it to VLAN 10.
[IRF-Bridge-Aggregation2] port link-type trunk
[IRF-Bridge-Aggregation2] port trunk permit vlan 10
# Create VLAN 10.
[Sysname] vlan 10
[Sysname-Bridge-Aggregation2] port link-type trunk
[Sysname-Bridge-Aggregation2] port trunk permit vlan 10
Verify the IRF setup, multichassis link aggregations, ring topology, and LACP MAD.
Verifying the IRF setup
# Verify that the IRF fabric has been formed.
[IRF] display irf
MemberID    Role    Priority  CPU-Mac         Description
 *+1        Master  31        00e0-fc0f-8c02  ---
   2        Standby 1         00e0-fc0f-8c03  ---
   3        Standby 1         00e0-fc0f-8c04  ---
   4        Standby 1         00e0-fc0f-8c05  ---
 The Bridge MAC of the IRF is: 0cda-414a-859b
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 1
 IRF mode                    : normal
The output shows that the IRF fabric has four member devices.
# Verify IRF fabric connectivity.
[IRF] display irf topology
Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 1           UP         2             UP         4           0cda-414a-859b
 2           UP         3             UP         1           0cda-414a-859b
 3           UP         4             UP         2           0cda-414a-859b
 4           UP         1             UP         3           0cda-414a-859b
The output shows that all the IRF links are in UP state. The four-chassis IRF fabric is established.
Verifying the link backup function of multichassis aggregations
# Ping the IP address of the IRF fabric at the distribution layer from a server.
C:\Users>ping 10.153.116.111 –t
# On the IRF fabric at the access layer, shut down GigabitEthernet 1/0/10, a member port of Bridge-Aggregation 3.
[IRF-GigabitEthernet1/0/10] shutdown
# Observe the output on the server configuration terminal.
Pinging 10.153.116.111 with 32 bytes of data:
Reply from 10.153.116.111: bytes=32 time<1ms TTL=128
Request timed out.
The output shows that the IP address can be pinged after transient traffic disruption.
# On the IRF fabric at the access layer, shut down GigabitEthernet 1/0/49 and GigabitEthernet 1/0/50 (member ports of Bridge-Aggregation 2). The server cannot access the distribution layer through Device A.
[IRF] interface range gigabitethernet 1/0/49 gigabitethernet 1/0/50
[IRF-if-range] shutdown
[IRF-if-range] quit
Request timed out.
The output shows that the IP address can be pinged after transient traffic disruption. The server accesses the distribution layer through another device in the access-layer IRF fabric.
Verifying link failure protection of the ring topology
# Disconnect all IRF links between two IRF member devices. (Details not shown.)
# Verify that the IRF fabric operates correctly in daisy-chain topology. (Details not shown.)
Verifying the LACP MAD configuration
# As shown in Figure 6, disconnect two IRF connections: one between Device A and Device D, and the other between Device B and Device C. The disconnect actions cause the IRF fabric to break up into two parts.
Figure 6 IRF split
# Observe the output messages to verify that LACP MAD takes the following actions:
·     Changes IRF 2 (Device C and Device D) to the Recovery state, because the master device in IRF 1 has a lower member ID than the master device in IRF 2.
·     Shuts down all service interfaces on Device C and Device D, except for the IRF physical interfaces and the service interfaces excluded from the MAD shutdown action.
The following is the sample output on IRF 1:
%Jan  1 05:19:10:176 2018 H3C STM/3/STM_LINK_STATUS_DOWN: IRF port 2 is down.
%Jan  1 05:19:10:184 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/53 link status is down.
%Jan  1 05:19:10:184 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/54 link status is down.
%Jan  1 05:19:10:176 2018 H3C STM/3/STM_LINK_STATUS_DOWN: IRF port 1 is down.
%Jan  1 05:19:10:184 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet2/0/51 link status is down.
%Jan  1 05:19:10:184 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet2/0/52 link status is down.
%Jan  1 05:19:10:186 2018 H3C DEV/3/BOARD_REMOVED: Board is removed from Slot 3, type is MAIN_BOARD_TYPE_54QT.
%Jan  1 05:19:10:186 2018 H3C DEV/3/BOARD_REMOVED: Board is removed from Slot 4, type is MAIN_BOARD_TYPE_54QT.
The following is the sample output from IRF 2:
%Jan  1 05:53:20:784 2018 H3C HA/5/HA_STANDBY_TO_MASTER: Standby board in slot 3 changes to master.
%Jan  1 05:53:20:831 2018 H3C DEV/3/BOARD_REMOVED: Board is removed from Slot 1, type is MAIN_BOARD_TYPE_54QT.
%Jan  1 05:53:20:831 2018 H3C DEV/3/BOARD_REMOVED: Board is removed from Slot 2, type is MAIN_BOARD_TYPE_54QT.
%Jan  1 05:53:20:860 2018 H3C DEV/1/MAD_DETECT: Multi-active devices detected, please fix it.
%Jan  1 05:53:20:886 2018 H3C IFNET/3/PHY_UPDOWN: M-GigabitEthernet0/0/0 link status is down.
%Jan  1 05:53:20:887 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol on the interface M-GigabitEthernet0/0/0 is down.
%Jan  1 05:53:20:912 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet3/0/49 link status is down.
%Jan  1 05:53:20:914 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet3/0/49 is down.
%Jan  1 05:53:20:912 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet3/0/50 link status is down.
%Jan  1 05:53:20:912 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet4/0/49 link status is down.
%Jan  1 05:53:20:912 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet4/0/50 link status is down.
The output shows that initially IRF 2 took over the master role because it falsely identified that IRF 1 has failed. LACP MAD shut down the service interfaces on IRF 2 after it detected an MAD conflict.
# If IRF 1 fails, use the mad restore command on IRF 2 to recover the member devices and bring up all service interfaces that have been shut down by LACP MAD.
You can log in to IRF 2 through the console port on Device C or Device D. If you have excluded a service interface from the MAD shutdown action, you can Telnet to IRF 2 through the service interface.
[Sysname] mad restore
This command will restore the device from multi-active conflict state. Continue? [Y/N]:y
Restoring from multi-active conflict state, please wait...
[Sysname]
%Jan  1 05:24:41:249 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet2/0/10 link status is up.
%Jan  1 05:24:41:249 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet2/0/10 is up.
%Jan  1 05:24:41:325 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet2/0/49 link status is up.
%Jan  1 05:24:41:325 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet2/0/50 link status is up.
%Jan  1 05:24:46:266 2018 H3C IFNET/3/PHY_UPDOWN: M-GigabitEthernet0/0/0 link status is up.
%Jan  1 05:24:46:268 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol on the interface M-GigabitEthernet0/0/0 is up.
The output shows that network connectivity of IRF 2 has been restored.
# Remove all IRF 1 and IRF link failures.
# After the link failure of IRF 1 is removed, the IRF ports recover. The following is the sample output on IRF 1:
%Jan  1 05:29:06:913 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/53 link status is up.
%Jan  1 05:29:06:914 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/53 is up.
%Jan  1 05:29:06:913 2018 H3C IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/54 link status is up.
%Jan  1 05:29:06:914 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/54 is up.
%Jan  1 05:29:07:106 2018 H3C STM/6/STM_LINK_STATUS_UP: IRF port 2 is up.
%Jan  1 05:29:07:810 2018 H3C STM/4/STM_LINK_RECOVERY: Merge occurs.
IRF 2 reboots automatically to merge with IRF 1.
# Verify that the IRF fabric is recovered with Device A as the master.
<IRF> display irf
 Auto upgrade                : yes
 Domain ID                   : 1
 IRF mode                    : normal
Configuration files
IMPORTANT
IMPORTANT:
The port link-mode bridge command is available only on the following switches:
·     S6520XE-HI switch series.
·     S5560X-EI switch series.
·     S5500V2-EI switch series.
·     MS4520V2-30F switch.
·     IRF fabric at the access layer:
sysname IRF
 irf domain 1
vlan 10
irf-port1/1
 port group interface GigabitEthernet1/0/51
 port group interface GigabitEthernet1/0/52
irf-port1/2
 port group interface GigabitEthernet1/0/53
 port group interface GigabitEthernet1/0/54
irf-port2/1
 port group interface GigabitEthernet2/0/51
 port group interface GigabitEthernet2/0/52
irf-port2/2
 port group interface GigabitEthernet2/0/53
 port group interface GigabitEthernet2/0/54
irf-port3/1
 port group interface GigabitEthernet3/0/51
 port group interface GigabitEthernet3/0/52
irf-port3/2
 port group interface GigabitEthernet3/0/53
 port group interface GigabitEthernet3/0/54
irf-port4/1
 port group interface GigabitEthernet4/0/51
 port group interface GigabitEthernet4/0/52
irf-port4/2
 port group interface GigabitEthernet4/0/53
 port group interface GigabitEthernet4/0/54
interface Bridge-Aggregation2
 mad enable
interface Bridge-Aggregation3
 port access vlan 10
interface GigabitEthernet1/0/49
 port trunk permit vlan 1 10
interface GigabitEthernet1/0/50
interface GigabitEthernet2/0/49
interface GigabitEthernet2/0/50
interface GigabitEthernet3/0/50
interface GigabitEthernet4/0/49
interface GigabitEthernet4/0/50
interface GigabitEthernet1/0/10
 port access vlan 10
 port access vlan 10
·     IRF fabric at the distribution layer:
 irf domain 2
 vlan10
 mad enable
interface GigabitEthernet1/2/0/1
interface GigabitEthernet1/3/0/1
interface GigabitEthernet2/3/0/1
interface GigabitEthernet2/4/0/2
interface GigabitEthernet3/3/0/2
interface GigabitEthernet3/4/0/1
interface GigabitEthernet4/2/0/1
interface GigabitEthernet4/3/0/1
