H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
Table of Contents
Related Documents
05-Software Patching Examples
05-Software Patching Examples 61.20 KB
Introduction
This document provides software patching examples that use ISSU install commands.
Example: Patching software
As shown in Figure 1, the two-chassis IRF fabric and the TFTP server can reach each other. The IRF members are running CMW710-SYSTEM-T0001016, and they have not been patched before.
Use the patch image file CMW710-SYSTEM-T0001016H04.bin to fix bugs without rebooting the members.
Figure 1 Network diagram
Hardware
Software version
S6520XE-HI switch series
Supported in Release 11xx
S5560X-EI switch series
Supported in Release 111x
S5500V2-EI switch series
MS4520V2-30F switch
S5560S-EI switch series
S5560S-SI switch series
Supported in Release 612x
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
S5120V2-SI switch series
S5120V2-LI switch series
S3100V3-EI switch series
S3100V3-SI switch series
S5110V2 switch series
S5110V2-SI switch series
S5000V3-EI switch series
S5000E-X switch series
WAS6000 switch series
E128C switch
E152C switch
E500C switch series
E500D switch series
MS4520V2 switch series (except the MS4520V2-30F switch)
MS4320V2 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
WS5850-WiNet switch series
WS5820-WiNet switch series
WS5810-WiNet switch series
When you patch software for a centralized IRF device, follow these restrictions and guidelines:
·     The first time you install patch images, you must start with the master. For subsequent patch installations, you must start with the subordinate members.
·     The patch image version must match the device model and Comware version. For example, to fix bugs in CMW710-SYSTEM-T0001016, you must use CMW710-SYSTEM-T0001016H04.bin.
Procedures
# Download the patch image file CMW710-SYSTEM-T0001016H04.bin from the TFTP server to the root directory of the flash memory on the master.
<Sysname> tftp 2.2.2.2 get CMW710-SYSTEM-T0001016H04.bin
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 25.2M    0 25.2M    0     0   210k      0 --:--:--  0:02:02 --:--:--  209k
# Activate the patch images on the master first and then on the subordinate member. This sequence is used because no patch images have been activated on the IRF fabric.
<Sysname> install activate patch flash:/CMW710-SYSTEM-T0001016H04.bin slot 1
This operation maybe take several minutes, please wait.............Done.
<Sysname> install activate patch flash:/CMW710-SYSTEM-T0001016H04.bin slot 2
The patch images take effect immediately after they are activated.
# For the patch images to take effect after a reboot, commit the software changes.
<Sysname> install commit
# Verify that the patch images have been activated successfully.
<Sysname> display install active
Active packages on slot 1:
  flash:/CMW710-BOOT-T0001016.bin
  flash:/CMW710-SYSTEM-T0001016.bin
Active packages on slot 2:
# Verify that the patch image file has been added to the main startup software image list so the images can take effect after a reboot.
<Sysname> display install committed
Committed packages on slot 1:
Committed packages on slot 2:
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
