- H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-Multicast VPN Configuration Examples
- 28-MLD Snooping Configuration Examples
- 29-IPv6 Multicast VLAN Configuration Examples
- 30-Basic MPLS Configuration Examples
- 31-MPLS L3VPN Configuration Examples
- 32-ACL Configuration Examples
- 33-Control Plane-Based QoS Policy Configuration Examples
- 34-Traffic Policing Configuration Examples
- 35-GTS and Rate Limiting Configuration Examples
- 36-Priority Mapping and Queue Scheduling Configuration Examples
- 37-Traffic Filtering Configuration Examples
- 38-AAA Configuration Examples
- 39-Port Security Configuration Examples
- 40-Portal Configuration Examples
- 41-SSH Configuration Examples
- 42-IP Source Guard Configuration Examples
- 43-Ethernet OAM Configuration Examples
- 44-CFD Configuration Examples
- 45-DLDP Configuration Examples
- 46-VRRP Configuration Examples
- 47-BFD Configuration Examples
- 48-NTP Configuration Examples
- 49-SNMP Configuration Examples
- 50-NQA Configuration Examples
- 51-Mirroring Configuration Examples
- 52-sFlow Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS TE Configuration Examples
- 67-VXLAN Configuration Examples
- 68-VCF Fabric Configuration Examples
09-VLAN Configuration Examples | 141.39 KB |
Example: Configuring port-based VLANs· 1
Applicable hardware and software versions· 1
Verifying the configuration· 3
Example: Configuring the super VLAN· 4
Applicable hardware and software versions· 5
Configuration restrictions and guidelines· 6
Verifying the configuration· 7
Example: Configuring the private VLAN· 9
Applicable hardware and software versions· 10
Configuration restrictions and guidelines· 11
Verifying the configuration· 12
Introduction
This document provides examples of configuring the port-based VLAN, super VLAN and private VLAN.
This document assumes that you have basic knowledge of VLANs.
As shown in Figure 1:
· Host A and Host C belong to Department A. VLAN 100 is assigned to Department A.
· Host B and Host D belong to Department B. VLAN 200 is assigned to Department B.
Configure port-based VLANs so that hosts only in the same department can communicate with each other.
Hardware | Software version |
S6520XE-HI switch series | Supported in Release 11xx |
S5560X-EI switch series | Supported in Release 111x |
S5500V2-EI switch series | Supported in Release 111x |
MS4520V2-30F switch | Supported in Release 111x |
S5560S-EI switch series S5560S-SI switch series | Supported in Release 612x |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series | Supported in Release 612x |
S5120V2-SI switch series S5120V2-LI switch series | Supported in Release 612x |
S3100V3-EI switch series S3100V3-SI switch series | Supported in Release 612x |
S5110V2 switch series | Supported in Release 612x |
S5110V2-SI switch series | Supported in Release 612x |
S5000V3-EI switch series | Supported in Release 612x |
S5000E-X switch series | Supported in Release 612x |
WAS6000 switch series | Supported in Release 612x |
E128C switch E152C switch E500C switch series E500D switch series | Supported in Release 612x |
MS4520V2 switch series (except the MS4520V2-30F switch) | Supported in Release 612x |
MS4320V2 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series | Supported in Release 612x |
WS5850-WiNet switch series | Supported in Release 612x |
WS5820-WiNet switch series WS5810-WiNet switch series | Supported in Release 612x |
Procedures
# Configure the ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to operate in bridge mode.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 to VLAN 100.
[DeviceA-vlan100] port gigabitethernet 1/0/1
[DeviceA-vlan100] quit
# Create VLAN 200, and assign GigabitEthernet 1/0/2 to VLAN 200.
[DeviceA-vlan200] port gigabitethernet 1/0/2
[DeviceA-vlan200] quit
# Configure GigabitEthernet 1/0/3 as a trunk port, and assign it to VLANs 100 and 200.
[DeviceA-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 100 200
2. Configure Device B in the same way Device A is configured. (Details not shown.)
3. Configure hosts:
a. Configure Host A and Host C to be on the same IP subnet. For example, 192.168.100.0/24.
b. Configure Host B and Host D to be on the same IP subnet. For example, 192.168.200.0/24.
# Verify that Host B and Host D can ping each other, but they both fail to ping Host A or Host C. (Details not shown.)
# Display information about VLANs 100 and 200 on Device A.
[DeviceA-GigabitEthernet1/0/3] display vlan 100
VLAN ID: 100
VLAN type: Static
Description: VLAN 0100
Tagged ports:
Untagged ports:
GigabitEthernet1/0/1
[DeviceA-GigabitEthernet1/0/3] display vlan 200
VLAN ID: 200
VLAN type: Static
Description: VLAN 0200
Tagged ports:
Untagged ports:
GigabitEthernet1/0/2
The output shows that:
· GigabitEthernet 1/0/3 and GigabitEthernet 1/0/1 permit packets from 100 to pass through.
· GigabitEthernet 1/0/3 and GigabitEthernet 1/0/2 permit packets from 200 to pass through.
Configuration files
IMPORTANT: The port link-mode bridge command is available only on the following switches: · S6520XE-HI switch series. · S5560X-EI switch series. · S5500V2-EI switch series. · MS4520V2-30F switch. |
Configuration files on both Device B and Device A are the same. The following configuration files use Device A as an example.
vlan 100
vlan 200
port access vlan 100
port access vlan 200
port trunk permit vlan 1 100 200
As shown in Figure 2:
· Users in VLAN 2 access the network through GigabitEthernet 1/0/1 of Device A.
· Users in VLAN 3 access the network through GigabitEthernet 1/0/2 of Device A.
· GigabitEthernet 1/0/3 of Device A and GigabitEthernet 1/0/1 of Device B are in VLAN 20.
· Users in VLAN 20 use the gateway address 192.168.2.1 and IP addresses on the IP network segment 192.168.2.0/24.
Configure a super VLAN to meet the following requirements:
· Users in VLAN 2 and VLAN 3 use the gateway address 192.168.1.1 and IP addresses on the IP network segment 192.168.1.0/24.
· Users in VLAN 2, VLAN 3, and VLAN 20 are isolated at Layer 2 but interoperable at Layer 3.
S5560S-EI switch series S5560S-SI switch series | Not supported |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series | Not supported |
S5120V2-SI switch series S5120V2-LI switch series | Not supported |
S3100V3-EI switch series S3100V3-SI switch series | Not supported |
S5110V2 switch series | Not supported |
S5110V2-SI switch series | Not supported |
S5000V3-EI switch series | Not supported |
S5000E-X switch series | Not supported |
WAS6000 switch series | Not supported |
E128C switch E152C switch E500C switch series E500D switch series | Not supported |
MS4520V2 switch series (except the MS4520V2-30F switch) | Not supported |
MS4320V2 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series | Not supported |
WS5850-WiNet switch series | Not supported |
WS5820-WiNet switch series WS5810-WiNet switch series | Not supported |
A super VLAN does not have physical ports. A VLAN that has physical ports cannot be configured as a super VLAN.
Procedures
Configuring Device A
# Create VLAN 10 and configure it as a super VLAN.
[DeviceA] vlan 10
[DeviceA-vlan10] supervlan
[DeviceA-vlan10] quit
# Create VLAN 2, and assign GigabitEthernet 1/0/1 to VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] port gigabitethernet 1/0/1
[DeviceA-vlan2] quit
# Create VLAN 3, and assign GigabitEthernet 1/0/2 to VLAN 3.
[DeviceA] vlan 3
[DeviceA-vlan3] port gigabitethernet 1/0/2
[DeviceA-vlan3] quit
# Associate super VLAN 10 with VLANs 2 and 3.
[DeviceA] vlan 10
[DeviceA-vlan10] subvlan 2 3
# Create VLAN-interface 10, and assign IP address 192.168.1.1 to it.
[DeviceA-Vlan-interface10] ip address 192.168.1.1 24
# Enable local proxy ARP on VLAN-interface 10.
[DeviceA-Vlan-interface10] local-proxy-arp enable
# Create VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
# Configure GigabitEthernet 1/0/3 as a trunk port, and remove the port from VLAN 1.
[DeviceA-GigabitEthernet1/0/3] undo port trunk permit vlan 1
# Assign GigabitEthernet 1/0/3 to VLAN 20.
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 20
# Create VLAN-interface 20, and assign IP address 192.168.2.1 to it.
[DeviceA] interface Vlan-interface 20
[DeviceA-Vlan-interface20] ip address 192.168.2.1 24
[DeviceA-Vlan-interface20] quit
Configuring Device B
# Create VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, and remove the port from VLAN 1.
[DeviceB-GigabitEthernet1/0/1] undo port trunk permit vlan 1
# Assign GigabitEthernet 1/0/1 to VLAN 20.
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 20
# Assign GigabitEthernet 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port gigabitethernet 1/0/2
# Verify the super VLAN configuration.
[DeviceA] display supervlan
Super VLAN ID: 10
Sub-VLAN ID: 2-3
VLAN ID: 10
VLAN type: Static
It is a super VLAN.
Route interface: Configured
IPv4 address: 192.168.1.1
IPv4 subnet mask: 255.255.255.0
Description: VLAN 0010
Tagged ports: none
Untagged ports: none
VLAN ID: 2
VLAN type: Static
It is a sub-VLAN.
Description: VLAN 0002
Tagged ports: none
Untagged ports:
VLAN ID: 3
VLAN type: Static
It is a sub-VLAN.
Description: VLAN 0003
Tagged ports: none
Untagged ports:
# Verify that Host A and Host B can ping each other. In the ARP table of Host A, the IP address of Host B corresponds to the MAC address of VLAN-interface 10. In the ARP table of Host B, the IP address of Host A corresponds to the MAC address of VLAN-interface 10. (Details not shown.)
# Verify that Host A and Host C can ping each other. In the ARP table of Host A, no entry about Host C exists. In the ARP table of Host C, no entry about Host A exists. (Details not shown.)
# Verify that Host B and Host C can ping each other. In the ARP table of Host B, no entry about Host C exists. In the ARP table of Host C, no entry about Host B exists. (Details not shown.)
Configuration files
· Device A:
vlan 2
vlan 3
vlan 10
supervlan
subvlan 2 3
vlan 20
interface Vlan-interface10
interface Vlan-interface20
ip address 192.168.2.1 255.255.255.0
port access vlan 2
port access vlan 3
· Device B:
vlan 20
port access vlan 20
As shown in Figure 3:
· The aggregation-layer device Device A assigns VLAN 10 to Device B. Hosts access the network through VLAN-interface 10.
· Users connected to Device B are on the same subnet 10.0.0.0/24.
· Host A and Host B are in the Marketing department. Host C and Host D are in the Finance department.
Configure the private VLAN feature to meet the following requirements:
· Device A is only aware of the primary VLAN 10.
· Hosts in the same secondary VLAN are interoperable at Layer 2.
· Hosts in different secondary VLANs are isolated at Layer 2.
Requirements analysis
The private VLAN configuration is required only on Device B.
The system default VLAN (VLAN 1) does not support the private VLAN configuration.
Procedures
# Create VLAN 10 and configure it as a primary VLAN.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan primary
[DeviceB-vlan10] quit
# Create VLANs 201 and 202.
[DeviceB] vlan 201 to 202
# Associate primary VLAN 10 with secondary VLANs 201 and 202.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan secondary 201 to 202
# Configure the uplink port GigabitEthernet 1/0/1 as a promiscuous port of VLAN 10.
[DeviceB-GigabitEthernet1/0/1] port private-vlan 10 promiscuous
# Assign the downlink ports GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 to VLAN 201 as host ports.
[DeviceB] interface range gigabitethernet 1/0/2 to gigabitethernet 1/0/3
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port access vlan 201
[DeviceB-if-range] port private-vlan host
[DeviceB-if-range] quit
# Assign the downlink ports GigabitEthernet 1/0/4 and GigabitEthernet 1/0/5 to VLAN 202 as host ports.
[DeviceB] interface range gigabitethernet 1/0/4 to gigabitethernet 1/0/5
[DeviceB-if-range] port access vlan 202
# Create VLAN 10.
[DeviceA] vlan 10
[DeviceA] quit
# Assign GigabitEthernet 1/0/1 to VLAN 10.
[DeviceA-GigabitEthernet1/0/1] port link-mode bridge
[DeviceA-GigabitEthernet1/0/1] port access vlan 10
# Create VLAN-interface 10, and assign IP address 10.0.0.1 to it.
[DeviceA-Vlan-interface10] ip address 10.0.0.1 24
# Verify that Device A can ping Host A, Host B, Host C, and Host D successfully. (Details not shown.)
# Display the ARP table of Device A.
[DeviceA] display arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI Interface/Link ID Aging Type
10.0.0.2 d485-64a1-7e4a 10 GE1/0/1 19 D
10.0.0.3 7446-a0aa-7774 10 GE1/0/1 19 D
10.0.0.4 6805-ca05-39ae 10 GE1/0/1 20 D
10.0.0.5 6805-ca05-414e 10 GE1/0/1 20 D
# Display the private VLAN configuration on Device B.
[DeviceB] display private-vlan
Primary VLAN ID: 10
Secondary VLAN ID: 201-202
VLAN ID: 10
VLAN type: Static
Private VLAN type: Primary
Tagged ports: None
Untagged ports:
GigabitEthernet1/0/1 GigabitEthernet1/0/2
GigabitEthernet1/0/3 GigabitEthernet1/0/4
GigabitEthernet1/0/5
VLAN ID: 201
VLAN type: Static
Private VLAN type: Secondary
Description: VLAN 0201
Tagged ports: None
Untagged ports:
VLAN ID: 202
VLAN type: Static
Description: VLAN 0202
Tagged ports: None
Untagged ports:
GigabitEthernet1/0/1 GigabitEthernet1/0/4
· The promiscuous port GigabitEthernet1/0/1 is an untagged member of primary VLAN 10 and secondary VLANs 201 and 202.
· The host ports GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 are untagged members of secondary VLANs 201.
· The host ports GigabitEthernet 1/0/4 and GigabitEthernet 1/0/5 are untagged members of secondary VLANs 202.
# Verify that Hosts in the same secondary VLAN can ping each other, but they fail to ping hosts in the other secondary VLAN. (Details not shown.)
Configuration files
· Device B:
vlan 1
vlan 10
vlan 201 to 202
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 10 201 to 202 untagged
port hybrid pvid vlan 10
port hybrid vlan 10 201 untagged
port hybrid pvid vlan 201
interface GigabitEthernet1/0/4
port hybrid vlan 10 202 untagged
port hybrid pvid vlan 202
interface GigabitEthernet1/0/5
· Device A:
vlan 1
vlan 10
ip address 10.0.0.1 255.255.255.0
port access vlan 10
