- H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-Multicast VPN Configuration Examples
- 28-MLD Snooping Configuration Examples
- 29-IPv6 Multicast VLAN Configuration Examples
- 30-Basic MPLS Configuration Examples
- 31-MPLS L3VPN Configuration Examples
- 32-ACL Configuration Examples
- 33-Control Plane-Based QoS Policy Configuration Examples
- 34-Traffic Policing Configuration Examples
- 35-GTS and Rate Limiting Configuration Examples
- 36-Priority Mapping and Queue Scheduling Configuration Examples
- 37-Traffic Filtering Configuration Examples
- 38-AAA Configuration Examples
- 39-Port Security Configuration Examples
- 40-Portal Configuration Examples
- 41-SSH Configuration Examples
- 42-IP Source Guard Configuration Examples
- 43-Ethernet OAM Configuration Examples
- 44-CFD Configuration Examples
- 45-DLDP Configuration Examples
- 46-VRRP Configuration Examples
- 47-BFD Configuration Examples
- 48-NTP Configuration Examples
- 49-SNMP Configuration Examples
- 50-NQA Configuration Examples
- 51-Mirroring Configuration Examples
- 52-sFlow Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS TE Configuration Examples
- 67-VXLAN Configuration Examples
- 68-VCF Fabric Configuration Examples
17-OSPF Configuration Examples | 73.31 KB |
Example: Configuring OSPF route filtering· 1
Applicable hardware and software versions· 2
Restrictions and guidelines· 3
Configuring route redistribution· 5
Configuring OSPF route filtering· 6
Verifying the configuration· 6
Introduction
This document provides OSPF route filtering configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of OSPF route filtering.
As shown in Figure 1, the devices of an enterprise reside in OSPF and RIP domains.
Configure route redistribution between OSPF and RIP to interconnect the devices.
Configure route filtering on Device E, Device C, and Device D to meet the following requirements:
· The route destined for R&D department 2 is not redistributed to OSPF.
· Marketing department 1 cannot reach R&D department 1.
· R&D department 1 and the After-sale service department cannot reach Marketing department 2.
Device | Interface | IP address | Device | Interface | IP address |
Device A | Vlan-int100 | 10.1.1.1/24 | Device B | Vlan-int100 | 10.1.1.2/24 |
| Vlan-int200 | 10.2.1.1/24 |
| Vlan-int300 | 10.3.1.1/24 |
| Vlan-int400 | 10.4.1.1/24 |
Device C | Vlan-int200 | 10.2.1.2/24 | Device D | Vlan-int300 | 10.3.1.2/24 |
| Loop0 | 192.168.3.1/24 |
| Loop0 | 192.168.1.1/24 |
| Loop1 | 192.168.2.1/24 |
Device E | Vlan-int400 | 10.4.1.2/24 | Device F | Vlan-int500 | 10.5.1.2/24 |
| Vlan-int500 | 10.5.1.1/24 |
| Loop0 | 192.168.4.1/24 |
| Loop1 | 192.168.5.1/24 |
Hardware | Software version |
S6520XE-HI switch series | Supported in Release 11xx |
S5560X-EI switch series | Supported in Release 111x |
S5500V2-EI switch series | Supported in Release 111x |
MS4520V2-30F switch | Supported in Release 111x |
S5560S-EI switch series S5560S-SI switch series | Supported in Release 612x |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series | Supported in Release 612x |
S5120V2-SI switch series | Not supported |
S5120V2-LI switch series | Supported in Release 612x |
S3100V3-EI switch series S3100V3-SI switch series | Supported in Release 612x |
S5110V2 switch series | Supported in Release 612x |
S5110V2-SI switch series | Supported in Release 612x |
S5000V3-EI switch series | Not supported |
S5000E-X switch series | Not supported |
WAS6000 switch series | Not supported |
E128C switch E152C switch E500C switch series E500D switch series | Supported in Release 612x |
MS4520V2 switch series (except the MS4520V2-30F switch) | Supported in Release 612x |
MS4320V2 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series | Supported in Release 612x |
WS5850-WiNet switch series | |
WS5820-WiNet switch series WS5810-WiNet switch series | Supported in Release 612x |
When you configure OSPF route filtering, follow these restrictions and guidelines:
· The filter-policy export command that filters redistributed routes takes effect only on an ASBR.
· OSPF filters routes calculated using received LSAs. It does not filter LSAs.
· IP communication is bidirectional. If a router filters out a route destined for Network A, the subnets attached to the router cannot reach Network A, and Network A cannot reach the subnets.
· When you configure route filtering by referencing an ACL, configure the rule permit source any item following multiple rule deny source items to allow unmatched routes to pass.
Procedures
Configuring IP addresses
# Configure an IP address for VLAN-interface 100.
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] ip address 10.1.1.1 24
# Configure IP addresses for other interfaces in the same way VLAN-interface 100 is configured. (Details not shown.)
Configuring OSPF
# Enable OSPF on Device A.
[DeviceA] ospf
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] area 2
[DeviceA-ospf-1-area-0.0.0.2] network 10.2.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.2] quit
[DeviceA-ospf-1] area 1
[DeviceA-ospf-1-area-0.0.0.1] network 10.4.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.1] quit
[DeviceA-ospf-1] quit
# Enable OSPF on Device B.
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] area 3
[DeviceB-ospf-1-area-0.0.0.3] network 10.3.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.3] quit
[DeviceB-ospf-1] quit
# Enable OSPF on Device C.
<DeviceC> system-view
[DeviceC] ospf
[DeviceC-ospf-1] area 2
[DeviceC-ospf-1-area-0.0.0.2] network 10.2.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.2] network 192.168.3.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.2] quit
[DeviceC-ospf-1] quit
# Enable OSPF on Device D.
<DeviceD> system-view
[DeviceD] ospf
[DeviceD-ospf-1] area 3
[DeviceD-ospf-1-area-0.0.0.3] network 10.3.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.3] network 192.168.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.3] network 192.168.2.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.3] quit
[DeviceD-ospf-1] quit
# Enable OSPF on Device E.
<DeviceE> system-view
[DeviceE] ospf
[DeviceE-ospf-1] area 1
[DeviceE-ospf-1-area-0.0.0.1] network 10.4.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.1] quit
[DeviceE-ospf-1] quit
Configuring RIP
# Enable RIP on Device E.
[DeviceE] rip
[DeviceE-rip-1] version 2
[DeviceE-rip-1] undo summary
[DeviceE-rip-1] network 10.5.1.0 0.0.0.255
[DeviceE-rip-1] quit
# Enable RIP on Device F.
[DeviceF] rip
[DeviceF-rip-1] version 2
[DeviceF-rip-1] undo summary
[DeviceF-rip-1] network 10.5.1.0 0.0.0.255
[DeviceF-rip-1] network 192.168.4.0 0.0.0.255
[DeviceF-rip-1] quit
# Configure Device E to redistribute OSPF and direct routes to RIP.
[DeviceE] rip
[DeviceE-rip-1] import-route direct
[DeviceE-rip-1] import-route ospf
# Configure Device E to redistribute RIP and direct routes to OSPF.
[DeviceE] ospf
[DeviceE-ospf-1] import-route direct
[DeviceE-ospf-1] import-route rip
# Verify that Device E has routes to all networks.
[DeviceE] display ip routing-table
Destinations : 24 Routes : 24
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/24 O_INTER 10 2 10.4.1.1 Vlan400
10.2.1.0/24 O_INTER 10 2 10.4.1.1 Vlan400
10.3.1.0/24 O_INTER 10 3 10.4.1.1 Vlan400
10.4.1.0/24 Direct 0 0 10.4.1.2 Vlan400
10.4.1.0/32 Direct 0 0 10.4.1.2 Vlan400
10.4.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.4.1.255/32 Direct 0 0 10.4.1.2 Vlan400
10.5.1.0/24 Direct 0 0 10.5.1.1 Vlan500
10.5.1.0/32 Direct 0 0 10.5.1.1 Vlan500
10.5.1.1/32 Direct 0 0 127.0.0.1 InLoop0
10.5.1.255/32 Direct 0 0 10.5.1.1 Vlan500
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.1/32 O_INTER 10 3 10.4.1.1 Vlan400
192.168.2.1/32 O_INTER 10 3 10.4.1.1 Vlan400
192.168.3.1/32 O_INTER 10 2 10.4.1.1 Vlan400
192.168.4.0/24 RIP 100 1 10.5.1.2 Vlan500
192.168.5.0/24 RIP 100 1 10.5.1.2 Vlan500
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that other devices have routes to all networks. (Details not shown.)
# On Device C, configure IPv4 basic ACL 2000 to permit any subnet except 192.168.2.0/24.
[DeviceC] acl basic 2000
[DeviceC-acl-ipv4-basic-2000] rule 0 deny source 192.168.2.0 0.0.0.255
[DeviceC-acl-ipv4-basic-2000] rule permit source any
[DeviceC-acl-ipv4-basic-2000] quit
# On Device C, use ACL 2000 to filter received routes.
[DeviceC] ospf
[DeviceC-ospf-1] filter-policy 2000 import
# On Device D, configure IPv4 basic ACL 2000 to permit any subnet except 192.168.5.0/24.
[DeviceD] acl basic 2000
[DeviceD-acl-ipv4-basic-2000] rule 0 deny source 192.168.5.0 0.0.0.255
[DeviceD-acl-ipv4-basic-2000] rule permit source any
[DeviceD-acl-ipv4-basic-2000] quit
# On Device D, use ACL 2000 to filter received routes.
[DeviceD] ospf
[DeviceD-ospf-1] filter-policy 2000 import
# On Device E, configure IPv4 basic ACL 2000 to permit any subnet except 192.168.4.0/24.
[DeviceE] acl basic 2000
[DeviceE-acl-ipv4-basic-2000] rule 0 deny source 192.168.4.0 0.0.0.255
[DeviceE-acl-ipv4-basic-2000] rule permit source any
[DeviceE-acl-ipv4-basic-2000] quit
# On Device E, use ACL 2000 to filter routes redistributed from RIP.
[DeviceE] ospf
[DeviceE-ospf-1] filter-policy 2000 export rip 1
# Verify that Device C does not have a route to 192.168.2.0/24.
[DeviceC] display ip routing-table
Destinations : 22 Routes : 22
10.1.1.0/24 O_INTER 10 2 10.2.1.1 Vlan200
10.2.1.0/24 Direct 0 0 10.2.1.2 Vlan200
10.2.1.0/32 Direct 0 0 10.2.1.2 Vlan200
10.2.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.2.1.255/32 Direct 0 0 10.2.1.2 Vlan200
10.3.1.0/24 O_INTER 10 3 10.2.1.1 Vlan200
10.4.1.0/24 O_INTER 10 2 10.2.1.1 Vlan200
10.5.1.0/24 O_ASE2 150 1 10.2.1.1 Vlan200
192.168.1.1/32 O_INTER 10 3 10.2.1.1 Vlan200
192.168.3.0/24 Direct 0 0 192.168.3.1 Loop0
192.168.3.0/32 Direct 0 0 192.168.3.1 Loop0
192.168.3.1/32 Direct 0 0 127.0.0.1 InLoop0
192.168.3.255/32 Direct 0 0 192.168.3.1 Loop0
192.168.5.0/24 O_ASE2 150 1 10.2.1.1 Vlan200
# Verify that Marketing department 1 cannot reach R&D department 1.
[DeviceC] ping -a 192.168.3.1 192.168.2.1
Ping 192.168.2.1 (192.168.2.1) from 192.168.3.1: 56 data bytes, press CTRL_C to
break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 192.168.2.1 ---
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
# Verify that Device D does not have a route to 192.168.5.0/24.
[DeviceD] display ip routing-table
Destinations : 25 Routes : 25
10.1.1.0/24 O_INTER 10 2 10.3.1.1 Vlan300
10.2.1.0/24 O_INTER 10 3 10.3.1.1 Vlan300
10.3.1.0/24 Direct 0 0 10.3.1.2 Vlan300
10.3.1.0/32 Direct 0 0 10.3.1.2 Vlan300
10.3.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.3.1.255/32 Direct 0 0 10.3.1.2 Vlan300
10.4.1.0/24 O_INTER 10 3 10.3.1.1 Vlan300
10.5.1.0/24 O_ASE2 150 1 10.3.1.1 Vlan300
192.168.1.0/24 Direct 0 0 192.168.1.1 Loop0
192.168.1.0/32 Direct 0 0 192.168.1.1 Loop0
192.168.1.1/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.1 Loop0
192.168.2.0/24 Direct 0 0 192.168.2.1 Loop1
192.168.2.0/32 Direct 0 0 192.168.2.1 Loop1
192.168.2.1/32 Direct 0 0 127.0.0.1 InLoop0
192.168.2.255/32 Direct 0 0 192.168.2.1 Loop1
192.168.3.1/32 O_INTER 10 3 10.3.1.1 Vlan300
# Verify that the After-sale service department cannot reach Marketing department 2.
[DeviceD] ping -a 192.168.1.1 192.168.5.1
Ping 192.168.5.1 (192.168.5.1) from 192.168.1.1: 56 data bytes, press CTRL_C to
break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 192.168.5.1 ---
# Verify that R&D department 1 cannot reach Marketing department 2.
[DeviceD] ping -a 192.168.2.1 192.168.5.1
Ping 192.168.5.1 (192.168.5.1) from 192.168.2.1: 56 data bytes, press CTRL_C to
break
Request time out
Request time out
Request time out
Request time out
Request time out
The output on Device C and Device D shows that Device E has filtered out the route destined for R&D development 2.
Configuration files
· Device A:
ospf 1
area 0.0.0.0
area 0.0.0.1
area 0.0.0.2
vlan 100
vlan 200
vlan 400
interface Vlan-interface100
interface Vlan-interface200
ip address 10.2.1.1 255.255.255.0
interface Vlan-interface400
ip address 10.4.1.1 255.255.255.0
· Device B:
ospf 1
area 0.0.0.0
area 0.0.0.3
vlan 100
vlan 300
interface Vlan-interface300
ip address 10.3.1.1 255.255.255.0
· Device C:
ospf 1
area 0.0.0.2
vlan 200
interface LoopBack0
ip address 192.168.3.1 255.255.255.0
ip address 10.2.1.2 255.255.255.0
acl basic 2000
rule 5 permit
· Device D:
ospf 1
area 0.0.0.3
vlan 300
interface LoopBack0
interface LoopBack1
ip address 192.168.2.1 255.255.255.0
ip address 10.3.1.2 255.255.255.0
acl basic 2000
rule 5 permit
· Device E:
ospf 1
import-route direct
import-route rip 1
area 0.0.0.1
rip 1
undo summary
version 2
import-route direct
import-route ospf 1
vlan 400
vlan 500
ip address 10.4.1.2 255.255.255.0
interface Vlan-interface500
ip address 10.5.1.1 255.255.255.0
acl basic 2000
rule 5 permit
· Device F:
rip 1
undo summary
version 2
network 192.168.4.0
network 192.168.5.0
vlan 500
interface LoopBack0
ip address 192.168.4.1 255.255.255.0
interface LoopBack1
ip address 192.168.5.1 255.255.255.0
ip address 10.5.1.2 255.255.255.0
