H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
Table of Contents
Related Documents
10-VLAN Tagging Configuration Examples
10-VLAN Tagging Configuration Examples 526.29 KB
Introduction· 1
Prerequisites· 1
General configuration restrictions and guidelines· 1
Example: Configuring QinQ·· 2
Network configuration· 2
Applicable hardware and software versions· 2
Restrictions and guidelines· 3
Procedures· 4
Configuring PE A· 4
Configuring PE B· 5
Configuring devices between PE A and PE B· 5
Verifying the configuration· 5
Configuration files· 6
Example: Configuring one-to-two VLAN mapping· 7
Network configuration· 7
Analysis· 9
Applicable hardware and software versions· 9
Restrictions and guidelines· 10
Procedures· 11
Configuring PE A· 11
Configuring PE B· 12
Configuring devices between PE A and PE B· 13
Verifying the configuration· 13
Configuration files· 14
Example: Configuring QoS policies for SVLAN tagging and 802.1p priority marking· 16
Network configuration· 16
Analysis· 18
Applicable hardware and software versions· 18
Restrictions and guidelines· 19
Procedures· 20
Configuring PE A· 20
Configuring PE B· 22
Configuring devices between PE A and PE B· 25
Verifying the configuration· 25
Configuration files· 26
Example: Configuring one-to-one and many-to-one VLAN mapping· 30
Network configuration· 30
Applicable hardware and software versions· 31
Procedures· 32
Configuring Switch A· 32
Configuring Switch B· 33
Configuring Switch C·· 33
Configuring Switch D·· 35
Verifying the configuration· 35
Configuration files· 36
Example: Configuring two-to-two VLAN mapping· 39
Network configuration· 39
Applicable hardware and software versions· 40
Restrictions and guidelines· 41
Procedures· 41
Configuring Switch A· 41
Configuring Switch B· 42
Configuring Switch C·· 43
Configuring Switch D·· 43
Verifying the configuration· 44
Configuration files· 44
Introduction
This document provides examples for using VLAN tagging features to extend customer VLANs (CVLANs) across an Ethernet service provider network.
VLAN tagging features enable service providers to separate or aggregate customer traffic in the service provider network. The following are available VLAN tagging operations:
·     Adding a layer of service provider VLAN (SVLAN) tag.
·     Modifying the SVLAN tag, CVLAN tag, or both.
To add an SVLAN tag, use one of the following VLAN tagging features:
·     QinQ—Tags all incoming frames (tagged or untagged) on the customer-side port with the PVID of the port.
·     One-to-two VLAN mapping—Adds different SVLANs for traffic with different CVLAN tags.
·     Policy-based VLAN manipulation—Uses QoS nest actions in a QoS policy to tag different classes of frames with different SVLAN tags. Traffic classifiers include CVLAN ID, IP address, and MAC address. In addition, you can use QoS priority marking to set the 802.1p priority in SVLAN tags.
To modify VLAN tags, use one of the following VLAN tagging features:
·     VLAN mapping—Includes the following features:
¡     One-to-one VLAN mapping—Replaces one VLAN tag with another.
¡     Many-to-one VLAN mapping—Replaces multiple VLAN tags with the same VLAN tag.
¡     Two-to-two VLAN mapping—Replaces the SVLAN ID, CVLAN ID, or both IDs for an incoming double-tagged frame.
·     Policy-based VLAN manipulation—Uses a QoS policy to modify the SVLAN ID by using the remark service-vlan-id action.
The devices in the service provider network learn MAC addresses of CVLANs into the MAC address table of the SVLAN.
This document assumes that you have basic knowledge of QinQ, VLAN mapping, QoS nesting, and QoS priority and CVLAN marking.
EVB and the VLAN tagging features are mutually exclusive. Do not use EVB with any VLAN tagging features on a port.
As shown in Figure 1:
·     The service provider assigns VLAN 1000 to Company A's VLANs 100 through 150.
·     The service provider assigns VLAN 2000 to Company B's VLANs 120 through 200.
Configure QinQ on PE A and PE B to transmit traffic in VLANs 1000 and 2000 for Company A and Company B, respectively.
Figure 1 Network diagram
Hardware
Software version
S6520XE-HI switch series
Supported in Release 11xx
S5560X-EI switch series
Supported in Release 111x
S5500V2-EI switch series
MS4520V2-30F switch
S5560S-EI switch series
S5560S-SI switch series
Supported in Release 612x
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
S5120V2-SI switch series
S5120V2-LI switch series
S3100V3-EI switch series
S3100V3-SI switch series
S5110V2 switch series
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
Not supported
S5000E-X switch series
Not supported
WAS6000 switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
MS4520V2 switch series (except the MS4520V2-30F switch)
MS4320V2 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
WS5850-WiNet switch series
WS5820-WiNet switch series
WS5810-WiNet switch series
When you configure QinQ, follow these restrictions and guidelines:
·     You only need to configure QinQ on customer-side ports of PEs.
·     The link type of the customer-side port can be access, hybrid, or trunk.
¡     If the link type is access, you must assign the port to the SVLAN.
¡     If the link type is trunk, you must assign the port to the SVLAN, and set the SVLAN ID as the PVID of the port.
¡     If the link type is hybrid, you must assign the port to the SVLAN as an untagged VLAN member, and set the SVLAN ID as the PVID of the port. The settings ensure that the port can forward traffic to the customer site with the SVLAN tag removed.
·     For QinQ frames to travel across the service provider network, you must perform the following tasks:
¡     Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of QinQ frames is treated as part of the payload during transmission.
¡     Configure all the ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag.
Procedures
Configuring PE A
1.     Create VLANs 1000 and 2000.
<PE_A> system-view
[PE_A] vlan 1000
[PE_A-vlan1000] quit
[PE_A] vlan 2000
[PE_A-vlan2000] quit
2.     Configure GigabitEthernet 1/0/1:
# Configure the port as an access port, and assign the port to VLAN 1000.
[PE_A] interface gigabitethernet 1/0/1
[PE_A-GigabitEthernet1/0/1] port access vlan 1000
# Enable QinQ on the port.
[PE_A-GigabitEthernet1/0/1] qinq enable
[PE_A-GigabitEthernet1/0/1] quit
3.     Configure GigabitEthernet 1/0/2:
# Configure the port as an access port, and assign the port to VLAN 2000.
[PE_A] interface gigabitethernet 1/0/2
[PE_A-GigabitEthernet1/0/2] port access vlan 2000
[PE_A-GigabitEthernet1/0/2] qinq enable
[PE_A-GigabitEthernet1/0/2] quit
4.     Configure GigabitEthernet 1/0/3:
# Configure the port as a trunk port.
[PE_A] interface gigabitethernet 1/0/3
[PE_A-GigabitEthernet1/0/3] port link-type trunk
# Assign the port to VLANs 1000 and 2000.
[PE_A-GigabitEthernet1/0/3] port trunk permit vlan 1000 2000
# Remove the port from VLAN 1.
[PE_A-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[PE_A-GigabitEthernet1/0/3] quit
Configuring PE B
<PE_B> system-view
[PE_B] vlan 1000
[PE_B-vlan1000] quit
[PE_B] vlan 2000
[PE_B-vlan2000] quit
[PE_B] interface gigabitethernet 1/0/1
[PE_B-GigabitEthernet1/0/1] port access vlan 2000
[PE_B-GigabitEthernet1/0/1] qinq enable
[PE_B-GigabitEthernet1/0/1] quit
[PE_B] interface gigabitethernet 1/0/2
[PE_B-GigabitEthernet1/0/2] port access vlan 1000
[PE_B-GigabitEthernet1/0/2] qinq enable
[PE_B-GigabitEthernet1/0/2] quit
[PE_B] interface gigabitethernet 1/0/3
[PE_B-GigabitEthernet1/0/3] port link-type trunk
[PE_B-GigabitEthernet1/0/3] port trunk permit vlan 1000 2000
[PE_B-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[PE_B-GigabitEthernet1/0/3] quit
# Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. (Details not shown.)
# Configure all ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag. (Details not shown.)
# Verify that each company's PCs can ping each other in the same CVLAN across the service provider network. (Details not shown.)
# Verify that the two companies' PCs cannot communicate at Layer 2 even if their CVLAN IDs are the same. The ARP tables on one company's PCs do not contain entries for MAC addresses of the other company's PCs. (Details not shown.)
Configuration files
IMPORTANT
IMPORTANT:
The port link-mode bridge command is available only on the following switches:
·     S6520XE-HI switch series.
·     S5560X-EI switch series.
·     S5500V2-EI switch series.
·     MS4520V2-30F switch.
·     PE A:
vlan 1000
vlan 2000
 qinq enable
 qinq enable
·     PE B:
vlan 1000
vlan 2000
 qinq enable
 qinq enable
As shown in Figure 2:
·     Customer A and Customer B each have two branches that require Layer 2 connectivity over the service provider network.
·     Both customers have three types of traffic. For each customer, the service provider assigns one SVLAN by traffic type.
Configure one-to-two VLAN mapping on each customer-side port of PE A and PE B to meet the following requirements:
·     The service provider adds an SVLAN tag to packets from customer networks based on the traffic type, as described in Table 1 and Figure 3.
·     The SVLAN tag uses the same 802.1p priority as the CVLAN tag.
Figure 2 Network diagram
Table 1 VLAN mapping table
Traffic type
CVLANs
SVLAN
Customer A
Video
31 to 40
1003
Voice
21 to 30
1002
Data
10 to 20
1001
Customer B
Storage
36 to 40
2003
Voice
26 to 35
2002
Data
15 to 25
2001
Figure 3 Required traffic pattern in the service provider network
Analysis
To support multiple SVLANs and send traffic to the customer networks with the SVLAN tag removed, perform the following tasks on the customer-side ports:
1.     Configure the link type of the ports as hybrid.
2.     Assign the ports to the SVLANs as untagged VLAN members.
For the SVLAN tag to use the same 802.1p priority as the CVLAN tag, configure the customer-side port to use the 802.1p priority in incoming packets for priority mapping.
Hardware
Software version
MS4520V2-30F switch
E128C switch
E152C switch
E500C switch series
E500D switch series
When you configure ports on the forwarding path of double-tagged packets across the service provider network, follow these restrictions and guidelines:
·     Set the MTU to a minimum of 1504 bytes for each port.
·     Configure all ports to allow double-tagged packets to pass through without removing the SVLAN tag.
Procedures
Configuring PE A
1.     Create CVLANs and SVLANs:
# Create CVLANs 10 to 40.
<PE_A> system-view
[PE_A] vlan 10 to 40
# Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
[PE_A] vlan 1001 to 1003
[PE_A] vlan 2001 to 2003
2.     Configure the customer-side port GigabitEthernet 1/0/1:
# Configure the port as a hybrid port.
[PE_A-GigabitEthernet1/0/1] port link-type hybrid
# Assign the port to CVLANs 10 through 40 as a tagged VLAN member.
[PE_A-GigabitEthernet1/0/1] port hybrid vlan 10 to 40 tagged
# Assign the port to SVLANs 1001 through 1003 as an untagged VLAN member.
[PE_A-GigabitEthernet1/0/1] port hybrid vlan 1001 to 1003 untagged
[PE_A-GigabitEthernet1/0/1] undo port hybrid vlan 1
# Configure one-to-two VLAN mapping to add SVLAN tag 1001 to traffic from VLANs 10 through 20.
[PE_A-GigabitEthernet1/0/1] vlan mapping nest range 10 to 20 nested-vlan 1001
# Configure one-to-two VLAN mapping to add SVLAN tag 1002 to traffic from VLANs 21 through 30.
[PE_A-GigabitEthernet1/0/1] vlan mapping nest range 21 to 30 nested-vlan 1002
# Configure one-to-two VLAN mapping to add SVLAN tag 1003 to traffic from VLANs 31 through 40.
[PE_A-GigabitEthernet1/0/1] vlan mapping nest range 31 to 40 nested-vlan 1003
# Configure the port to use the 802.1p priority in incoming packets for priority mapping.
[PE_A-GigabitEthernet1/0/1] qos trust dot1p
3.     Configure the customer-side port GigabitEthernet 1/0/2:
[PE_A-GigabitEthernet1/0/2] port link-type hybrid
# Assign the port to CVLANs 15 through 40 as a tagged VLAN member.
[PE_A-GigabitEthernet1/0/2] port hybrid vlan 15 to 40 tagged
# Assign the port to SVLANs 2001 through 2003 as an untagged VLAN member.
[PE_A-GigabitEthernet1/0/2] port hybrid vlan 2001 to 2003 untagged
[PE_A-GigabitEthernet1/0/2] undo port hybrid vlan 1
# Configure one-to-two VLAN mapping to add SVLAN tag 2001 to traffic from VLANs 15 through 25.
[PE_A-GigabitEthernet1/0/2] vlan mapping nest range 15 to 25 nested-vlan 2001
# Configure one-to-two VLAN mapping to add SVLAN tag 2002 to traffic from VLANs 26 through 35.
[PE_A-GigabitEthernet1/0/2] vlan mapping nest range 26 to 35 nested-vlan 2002
# Configure one-to-two VLAN mapping to add SVLAN tag 2003 to traffic from VLANs 36 through 40.
[PE_A-GigabitEthernet1/0/2] vlan mapping nest range 36 to 40 nested-vlan 2003
[PE_A-GigabitEthernet1/0/2] qos trust dot1p
4.     Configure the service provider-side port GigabitEthernet 1/0/3:
# Assign the port to SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
[PE_A-GigabitEthernet1/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
Configuring PE B
<PE_B> system-view
[PE_B] vlan 10 to 40
[PE_B] vlan 1001 to 1003
[PE_B] vlan 2001 to 2003
[PE_B-GigabitEthernet1/0/1] port link-type hybrid
[PE_B-GigabitEthernet1/0/1] port hybrid vlan 15 to 40 tagged
[PE_B-GigabitEthernet1/0/1] port hybrid vlan 2001 to 2003 untagged
[PE_B-GigabitEthernet1/0/1] undo port hybrid vlan 1
[PE_B-GigabitEthernet1/0/1] vlan mapping nest range 15 to 25 nested-vlan 2001
[PE_B-GigabitEthernet1/0/1] vlan mapping nest range 26 to 35 nested-vlan 2002
[PE_B-GigabitEthernet1/0/1] vlan mapping nest range 36 to 40 nested-vlan 2003
[PE_B-GigabitEthernet1/0/1] qos trust dot1p
[PE_B-GigabitEthernet1/0/2] port link-type hybrid
[PE_B-GigabitEthernet1/0/2] port hybrid vlan 10 to 40 tagged
[PE_B-GigabitEthernet1/0/2] port hybrid vlan 1001 to 1003 untagged
[PE_B-GigabitEthernet1/0/2] undo port hybrid vlan 1
[PE_B-GigabitEthernet1/0/2] vlan mapping nest range 10 to 20 nested-vlan 1001
[PE_B-GigabitEthernet1/0/2] vlan mapping nest range 21 to 30 nested-vlan 1002
[PE_B-GigabitEthernet1/0/2] vlan mapping nest range 31 to 40 nested-vlan 1003
[PE_B-GigabitEthernet1/0/2] qos trust dot1p
[PE_B-GigabitEthernet1/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
# Set the MTU to a minimum of 1504 bytes for each port on the path of double-tagged packets. (Details not shown.)
# Configure all ports on the forwarding path to allow packets from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the SVLAN tag. (Details not shown.)
1.     Verify VLAN mapping information:
# Verify VLAN mapping information on PE A.
[PE_A] display vlan mapping
Interface GigabitEthernet1/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  10-20         N/A           1001                     10-20
  21-30         N/A           1002                     21-30
  31-40         N/A           1003                     31-40
Interface GigabitEthernet1/0/2:
  15-25         N/A           2001                     15-25
  26-35         N/A           2002                     26-35
  36-40         N/A           2003                     36-40
# Verify VLAN mapping information on PE B.
[PE_B] display vlan mapping
2.     Verify that PCs of the same customer in a CVLAN can ping each other across the service provider network. (Details not shown.)
3.     Verify that PCs of different customers in a CVLAN cannot communicate at Layer 2. The ARP tables on one customer's PCs do not contain entries for MAC addresses of the other customer's PCs. (Details not shown.)
Configuration files
IMPORTANT
IMPORTANT:
·     PE A:
vlan 10 to 40
vlan 1001 to 1003
vlan 2001 to 2003
 qos trust dot1p
 qos trust dot1p
·     PE B:
vlan 10 to 40
vlan 1001 to 1003
vlan 2001 to 2003
 qos trust dot1p
 qos trust dot1p
As shown in Figure 4:
·     Both customers have three types of traffic and require different transmission priorities for the three types of traffic.
Apply a QoS policy to each customer-side port on PE A and PE B to meet the following requirements:
·     Separate the traffic by customer and traffic type.
·     Assign different 802.1p priority values to the traffic flows.
Figure 4 Network diagram
Table 2 shows the VLAN and 802.1p priority assignment scheme. For each customer, the service provider assigns one SVLAN by traffic type. Figure 5 shows the expected traffic transmission pattern after the QoS policies are applied to customer-side ports.
Table 2 VLAN and traffic priority assignment
Traffic type
CVLANs
SVLAN
Traffic priority
Customer A:
Video
31 to 40
1003
High
Voice
21 to 30
1002
Medium
Data
10 to 20
1001
Low
Customer B:
Storage
36 to 40
2003
High
Voice
26 to 35
2002
Medium
Data
15 to 25
2001
Low
Figure 5 Expected traffic pattern in the service provider network
Analysis
For the customer-side ports to support multiple SVLANs and send traffic to the customer site with the SVLAN tag removed, you must perform the following tasks:
1.     Configure the link type as hybrid on the customer-side ports.
To change the 802.1p priority for a class of traffic, use the remark dot1p action. By default, the 802.1p priority in the SVLAN tag added by a QinQ-enabled port depends on the priority trust mode on the port.
·     If the 802.1p priority in frames is trusted, the device copies the 802.1p priority in the CVLAN tag to the SVLAN tag.
·     If port priority is trusted, the port priority is used as the 802.1p priority in the SVLAN tag. For untagged incoming frames, the port encapsulates the port priority as the 802.1p priority in the SVLAN tag.
Hardware
Software version
MS4520V2-30F switch
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
When you configure an SVLAN tagging QoS policy, follow these restrictions and guidelines:
·     Use the nest action for SVLAN tagging. You can configure only one nest action in the traffic behavior for a traffic class.
·     You must apply the QoS policy to the inbound direction of customer-side ports.
·     For the nest action to take effect, you must enable QinQ on the customer-side ports.
·     If an incoming frame does not match the QoS policy, the port adds the PVID tag to the frame as the SVLAN tag.
For QinQ frames to travel across the service provider network, follow these restrictions and guidelines:
·     Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of QinQ frames is treated as part of the payload during transmission.
·     Configure all the ports on the forwarding path to allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the VLAN tag.
Procedures
Configuring PE A
1.     Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
<PE_A> system-view
# Configure the port to trust the 802.1p priority of frames.
3.     Configure the service provider-side port GigabitEthernet 1/0/3:
4.     Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create the class customer_A_pc to match traffic from CVLANs 10 through 20 (data traffic) for Customer A.
[PE_A] traffic classifier customer_A_pc
[PE_A-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_A-classifier-customer_A_pc] quit
# Create the classes customer_A_voice and customer_A_video to match Customer A's voice traffic and video traffic, respectively.
[PE_A] traffic classifier customer_A_voice
[PE_A-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_A-classifier-customer_A_voice] quit
[PE_A] traffic classifier customer_A_video
[PE_A-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_A-classifier-customer_A_video] quit
# Configure SVLAN tagging and 802.1p priority marking actions for Customer A's three traffic types.
[PE_A] traffic behavior customer_A_pc
[PE_A-behavior-customer_A_pc] nest top-most vlan 1001
[PE_A-behavior-customer_A_pc] remark dot1p 3
[PE_A-behavior-customer_A_pc] quit
[PE_A] traffic behavior customer_A_voice
[PE_A-behavior-customer_A_voice] nest top-most vlan 1002
[PE_A-behavior-customer_A_voice] remark dot1p 5
[PE_A-behavior-customer_A_voice] quit
[PE_A] traffic behavior customer_A_video
[PE_A-behavior-customer_A_video] nest top-most vlan 1003
[PE_A-behavior-customer_A_video] remark dot1p 7
[PE_A-behavior-customer_A_video] quit
# Create the QoS policy customer_A for Customer A, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_A
[PE_A-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_A-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_A-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_A-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of GigabitEthernet 1/0/1.
[PE_A-GigabitEthernet1/0/1] qos apply policy customer_A inbound
# Create traffic classes for matching Customer B's three traffic types.
[PE_A] traffic classifier customer_B_pc
[PE_A-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_A-classifier-customer_B_pc] quit
[PE_A] traffic classifier customer_B_voice
[PE_A-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_A-classifier-customer_B_voice] quit
[PE_A] traffic classifier customer_B_storage
[PE_A-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_A-classifier-customer_B_storage] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer B's traffic types.
[PE_A] traffic behavior customer_B_pc
[PE_A-behavior-customer_B_pc] nest top-most vlan 2001
[PE_A-behavior-customer_B_pc] remark dot1p 3
[PE_A-behavior-customer_B_pc] quit
[PE_A] traffic behavior customer_B_voice
[PE_A-behavior-customer_B_voice] nest top-most vlan 2002
[PE_A-behavior-customer_B_voice] remark dot1p 5
[PE_A-behavior-customer_B_voice] quit
[PE_A] traffic behavior customer_B_storage
[PE_A-behavior-customer_B_storage] nest top-most vlan 2003
[PE_A-behavior-customer_B_storage] remark dot1p 7
[PE_A-behavior-customer_B_storage] quit
# Create the QoS policy customer_B for Customer B, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_B
[PE_A-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_A-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_A-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_A-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of GigabitEthernet 1/0/2.
[PE_A-GigabitEthernet1/0/2] qos apply policy customer_B inbound
Configuring PE B
<PE_B> system-view
5.     Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create traffic classes for matching Customer A's traffic types.
[PE_B] traffic classifier customer_A_pc
[PE_B-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_B-classifier-customer_A_pc] quit
[PE_B] traffic classifier customer_A_voice
[PE_B-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_B-classifier-customer_A_voice] quit
[PE_B] traffic classifier customer_A_video
[PE_B-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_B-classifier-customer_A_video] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer A's three traffic types.
[PE_B] traffic behavior customer_A_pc
[PE_B-behavior-customer_A_pc] nest top-most vlan 1001
[PE_B-behavior-customer_A_pc] remark dot1p 3
[PE_B-behavior-customer_A_pc] quit
[PE_B] traffic behavior customer_A_voice
[PE_B-behavior-customer_A_voice] nest top-most vlan 1002
[PE_B-behavior-customer_A_voice] remark dot1p 5
[PE_B-behavior-customer_A_voice] quit
[PE_B] traffic behavior customer_A_video
[PE_B-behavior-customer_A_video] nest top-most vlan 1003
[PE_B-behavior-customer_A_video] remark dot1p 7
[PE_B-behavior-customer_A_video] quit
[PE_B] qos policy customer_A
[PE_B-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_B-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_B-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_B-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of GigabitEthernet 1/0/2.
[PE_B-GigabitEthernet1/0/2] qos apply policy customer_A inbound
[PE_B] traffic classifier customer_B_pc
[PE_B-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_B-classifier-customer_B_pc] quit
[PE_B] traffic classifier customer_B_voice
[PE_B-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_B-classifier-customer_B_voice] quit
[PE_B] traffic classifier customer_B_storage
[PE_B-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_B-classifier-customer_B_storage] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer B's three traffic types.
[PE_B] traffic behavior customer_B_pc
[PE_B-behavior-customer_B_pc] nest top-most vlan 2001
[PE_B-behavior-customer_B_pc] remark dot1p 3
[PE_B-behavior-customer_B_pc] quit
[PE_B] traffic behavior customer_B_voice
[PE_B-behavior-customer_B_voice] nest top-most vlan 2002
[PE_B-behavior-customer_B_voice] remark dot1p 5
[PE_B-behavior-customer_B_voice] quit
[PE_B] traffic behavior customer_B_storage
[PE_B-behavior-customer_B_storage] nest top-most vlan 2003
[PE_B-behavior-customer_B_storage] remark dot1p 7
[PE_B-behavior-customer_B_storage] quit
[PE_B] qos policy customer_B
[PE_B-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_B-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_B-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_B-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of GigabitEthernet 1/0/1.
[PE_B-GigabitEthernet1/0/1] qos apply policy customer_B inbound
# Configure all ports on the path between PE A and PE B allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the VLAN tag. (Details not shown.)
# Verify the configuration on each port. This example uses GigabitEthernet 1/0/1 of PE A.
[PE_A-GigabitEthernet1/0/1] display this
 qinq enable
 qos trust dot1p
Return
# Verify the QoS configuration on each port. This example uses GigabitEthernet 1/0/1 of PE A.
[PE_A] display qos policy interface gigabitethernet 1/0/1
  Direction: Inbound
  Policy: customer_A
   Classifier: customer_A_pc
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 10 to 20
     Behavior: customer_A_pc
      Nesting:
        Nest top-most vlan-id 1001
      Marking:
        Remark dot1p 3
   Classifier: customer_A_voice
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 21 to 30
     Behavior: customer_A_voice
      Nesting:
        Nest top-most vlan-id 1002
      Marking:
        Remark dot1p 5
   Classifier: customer_A_video
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 31 to 40
     Behavior: customer_A_video
      Nesting:
        Nest top-most vlan-id 1003
      Marking:
        Remark dot1p 7
Configuration files
IMPORTANT
IMPORTANT:
·     PE A:
vlan 1001 to 1003
vlan 2001 to 2003
traffic classifier customer_A_pc operator and
traffic classifier customer_A_voice operator and
traffic classifier customer_A_video operator and
traffic classifier customer_B_pc operator and
traffic classifier customer_B_voice operator and
traffic classifier customer_B_storage operator and
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 qinq enable
 qos trust dot1p
 qinq enable
 qos trust dot1p
·     PE B:
vlan 1001 to 1003
vlan 2001 to 2003
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 qinq enable
 qos trust dot1p
 qinq enable
 qos trust dot1p
As shown in Figure 6:
·     Each household subscribes to PC, VoD, and VoIP services, and obtains the IP address through DHCP.
·     On the home gateways, PC, VoD, and VoIP service traffic is assigned to VLANs 1, 2, and 3, respectively.
To isolate traffic of the same service type from different households, configure one-to-one VLAN mapping on the wiring-closet switches. This feature assigns one VLAN to each type of traffic from each household.
To save VLAN resources, configure many-to-one VLAN mapping on the campus switch (Switch C). This feature transmits the same type of traffic from different households in one VLAN. Use VLANs 501, 502, and 503 for PC, VoD, and VoIP traffic, respectively.
Table 3 VLAN mapping scheme for each service
Service
VLANs on home gateways
VLANs on wiring-closet switches (Switch A and Switch B)
VLANs on campus switch (Switch C)
PC
VLAN 1
VLANs 101, 102, 103, 104
VLAN 501
VoD
VLAN 2
VLANs 201, 202, 203, 204
VLAN 502
VoIP
VLAN 3
VLANs 301, 302, 303, 304
VLAN 503
Figure 6 Network diagram
Hardware
Software version
MS4520V2-30F switch
E128C switch
E152C switch
E500C switch series
E500D switch series
Procedures
# Create the original VLANs 2 and 3. (VLAN 1 is the system default VLAN and already exists.)
[SwitchA] vlan 2 to 3
# Create the translated VLANs 101 through 102, 201 through 202, and 301 through 302.
[SwitchA] vlan 101 to 102
[SwitchA] vlan 201 to 202
[SwitchA] vlan 301 to 302
# Configure the customer-side port GigabitEthernet 1/0/1 as a trunk port.
[SwitchA-GigabitEthernet1/0/1] port link-type trunk
# Assign GigabitEthernet 1/0/1 to the original VLANs and translated VLANs.
[SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 1 2 3 101 201 301
# Configure one-to-one VLAN mapping on GigabitEthernet 1/0/1 to map VLANs 1, 2, and 3 to VLANs 101, 201, and 301, respectively.
[SwitchA-GigabitEthernet1/0/1] vlan mapping 1 translated-vlan 101
[SwitchA-GigabitEthernet1/0/1] vlan mapping 2 translated-vlan 201
[SwitchA-GigabitEthernet1/0/1] vlan mapping 3 translated-vlan 301
[SwitchA-GigabitEthernet1/0/1] quit
# Configure the customer-side port GigabitEthernet 1/0/2 as a trunk port.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port link-type trunk
# Assign GigabitEthernet 1/0/2 to the original VLANs and translated VLANs.
[SwitchA-GigabitEthernet1/0/2] port trunk permit vlan 1 2 3 102 202 302
# Configure one-to-one VLAN mapping on GigabitEthernet 1/0/2 to map VLANs 1, 2, and 3 to VLANs 102, 202, and 302, respectively.
[SwitchA-GigabitEthernet1/0/2] vlan mapping 1 translated-vlan 102
[SwitchA-GigabitEthernet1/0/2] vlan mapping 2 translated-vlan 202
[SwitchA-GigabitEthernet1/0/2] vlan mapping 3 translated-vlan 302
[SwitchA-GigabitEthernet1/0/2] quit
# Configure the network-side port GigabitEthernet 1/0/3 as a trunk port.
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] port link-type trunk
# Remove GigabitEthernet 1/0/3 from VLAN 1 and assign GigabitEthernet 1/0/3 to the translated VLANs.
[SwitchA-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[SwitchA-GigabitEthernet1/0/3] port trunk permit vlan 101 201 301 102 202 302
[SwitchA-GigabitEthernet1/0/3] quit
# Configure Switch B in the same way Switch A is configured. (Details not shown.)
1.     Configure basic settings required for many-to-one VLAN mapping:
# Enable DHCP snooping.
[SwitchC] dhcp snooping enable
# Create the original VLANs 101 through 104, 201 through 204, and 301 through 304, and enable ARP detection for these VLANs.
[SwitchC] vlan 101
[SwitchC-vlan101] arp detection enable
[SwitchC-vlan101] vlan 201
[SwitchC-vlan201] arp detection enable
[SwitchC-vlan201] vlan 301
[SwitchC-vlan301] arp detection enable
[SwitchC-vlan301] vlan 102
[SwitchC-vlan102] arp detection enable
[SwitchC-vlan102] vlan 202
[SwitchC-vlan202] arp detection enable
[SwitchC-vlan202] vlan 302
[SwitchC-vlan302] arp detection enable
[SwitchC-vlan302] vlan 103
[SwitchC-vlan103] arp detection enable
[SwitchC-vlan103] vlan 203
[SwitchC-vlan203] arp detection enable
[SwitchC-vlan203] vlan 303
[SwitchC-vlan303] arp detection enable
[SwitchC-vlan303] vlan 104
[SwitchC-vlan104] arp detection enable
[SwitchC-vlan104] vlan 204
[SwitchC-vlan204] arp detection enable
[SwitchC-vlan204] vlan 304
[SwitchC-vlan304] arp detection enable
# Create the translated VLANs 501 through 503, and enable ARP detection for these VLANs.
[SwitchC-vlan304] vlan 501
[SwitchC-vlan501] arp detection enable
[SwitchC-vlan501] vlan 502
[SwitchC-vlan502] arp detection enable
[SwitchC-vlan502] vlan 503
[SwitchC-vlan503] arp detection enable
[SwitchC-vlan503] quit
[SwitchC] interface gigabitethernet 1/0/1
[SwitchC-GigabitEthernet1/0/1] port link-type trunk
# Remove the port from VLAN 1, and assign the port to the original VLANs and translated VLANs.
[SwitchC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[SwitchC-GigabitEthernet1/0/1] port trunk permit vlan 101 102 201 202 301 302 501 to 503
# Configure the user-side many-to-one VLAN mapping to map VLANs for PC, VoD, and VoIP traffic to VLANs 501, 502, and 503, respectively.
[SwitchC-GigabitEthernet1/0/1] vlan mapping uni range 101 to 102 translated-vlan 501
[SwitchC-GigabitEthernet1/0/1] vlan mapping uni range 201 to 202 translated-vlan 502
[SwitchC-GigabitEthernet1/0/1] vlan mapping uni range 301 to 302 translated-vlan 503
# Enable DHCP snooping entry recording.
[SwitchC-GigabitEthernet1/0/1] dhcp snooping binding record
[SwitchC-GigabitEthernet1/0/1] quit
[SwitchC] interface gigabitethernet 1/0/2
[SwitchC-GigabitEthernet1/0/2] port link-type trunk
[SwitchC-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[SwitchC-GigabitEthernet1/0/2] port trunk permit vlan 103 104 203 204 303 304 501 to 503
[SwitchC-GigabitEthernet1/0/2] vlan mapping uni range 103 to 104 translated-vlan 501
[SwitchC-GigabitEthernet1/0/2] vlan mapping uni range 203 to 204 translated-vlan 502
[SwitchC-GigabitEthernet1/0/2] vlan mapping uni range 303 to 304 translated-vlan 503
[SwitchC-GigabitEthernet1/0/2] dhcp snooping binding record
[SwitchC-GigabitEthernet1/0/2] quit
4.     Configure the network-side port GigabitEthernet 1/0/3:
# Enable the network-side VLAN mapping function on the port.
[SwitchC] interface gigabitethernet 1/0/3
[SwitchC-GigabitEthernet1/0/3] vlan mapping nni
[SwitchC-GigabitEthernet1/0/3] port link-type trunk
# Remove the port from VLAN 1, and assign the port to the translated VLANs 501 through 503.
[SwitchC-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[SwitchC-GigabitEthernet1/0/3] port trunk permit vlan 501 to 503
# Configure the port as a DHCP snooping trusted and ARP trusted port.
[SwitchC-GigabitEthernet1/0/3] dhcp snooping trust
[SwitchC-GigabitEthernet1/0/3] arp detection trust
[SwitchC-GigabitEthernet1/0/3] quit
# Create the translated VLANs 501 through 503.
<SwitchD> system-view
[SwitchD] vlan 501 to 503
# Configure GigabitEthernet 1/0/1 as a trunk port.
[SwitchD] interface gigabitethernet 1/0/1
[SwitchD-GigabitEthernet1/0/1] port link-type trunk
# Assign GigabitEthernet 1/0/1 to the translated VLANs 501 through 503.
[SwitchD-GigabitEthernet1/0/1] port trunk permit vlan 501 to 503
[SwitchD-GigabitEthernet1/0/1] quit
# Verify VLAN mapping information on the wiring-closet switches, for example, Switch A.
[SwitchA] display vlan mapping
  1             N/A           101                      N/A
  2             N/A           201                      N/A
  3             N/A           301                      N/A
  1             N/A           102                      N/A
  2             N/A           202                      N/A
  3             N/A           302                      N/A
# Verify VLAN mapping information on Switch C.
[SwitchC] display vlan mapping
  101-102       N/A           501                      N/A
  201-202       N/A           502                      N/A
  301-302       N/A           503                      N/A
  103-104       N/A           501                      N/A
  203-204       N/A           502                      N/A
  303-304       N/A           503                      N/A
Configuration files
IMPORTANT
IMPORTANT:
·     Switch A:
vlan 1
vlan 2 to 3
vlan 101 to 102
vlan 201 to 202
vlan 301 to 302
 port trunk permit vlan 1 to 3 101 201 301
 port trunk permit vlan 1 to 3 102 202 302
 port trunk permit vlan 1 101 to 102 201 to 202 301 to 302
·     Switch B:
vlan 1
vlan 2 to 3
vlan 103 to 104
vlan 203 to 204
vlan 303 to 304
 port trunk permit vlan 1 to 3 103 203 303
 vlan mapping 1 translated-vlan 103
 vlan mapping 2 translated-vlan 203
 vlan mapping 3 translated-vlan 303
 port trunk permit vlan 1 to 3 104 204 304
 vlan mapping 1 translated-vlan 104
 vlan mapping 2 translated-vlan 204
 vlan mapping 3 translated-vlan 304
 port trunk permit vlan 1 103 to 104 203 to 204 303 to 304
·     Switch C:
vlan 101
vlan 102
vlan 103
vlan 104
vlan 201
vlan 202
vlan 203
vlan 204
vlan 301
vlan 302
vlan 303
vlan 304
vlan 501
vlan 502
vlan 503
 port trunk permit vlan 101 to 102 201 to 202 301 to 302 501 to 503
 port trunk permit vlan 103 to 104 203 to 204 303 to 304 501 to 503
 vlan mapping nni
 arp detection trust
 dhcp snooping trust
·     Switch D:
vlan 501 to 503
 port trunk permit vlan 1 501 to 503
As shown in Figure 7:
·     A company assigns its branch sites (Site 1 and Site 2) to VLAN 10, and the headquarters provides services in VLAN 30.
·     Service provider A uses SVLAN 100 to transmit VLAN 10 traffic for the branch sites.
·     Service provider B uses SVLAN 200 to transmit VLAN 30 traffic for the headquarters.
Configure two-to-two VLAN mapping to permit the two branch sites to access VLAN 30 of the headquarters without changing their VLAN assignment.
Figure 7 Network diagram
Hardware
Software version
MS4520V2-30F switch
E128C switch
E152C switch
E500C switch series
E500D switch series
Configure two-to-two VLAN mapping on one of the edge devices between the two service provider networks. This example uses Switch C.
Procedures
# Create CVLAN 10 and SVLAN 100.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (GigabitEthernet 1/0/1) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchA-GigabitEthernet1/0/1] vlan mapping nest single 10 nested-vlan 100
# Configure GigabitEthernet 1/0/1 as a hybrid port.
[SwitchA-GigabitEthernet1/0/1] port link-type hybrid
# Assign GigabitEthernet 1/0/1 to VLAN 10 as a tagged member.
[SwitchA-GigabitEthernet1/0/1] port hybrid vlan 10 tagged
# Assign GigabitEthernet 1/0/1 to VLAN 100 as an untagged member.
[SwitchA-GigabitEthernet1/0/1] port hybrid vlan 100 untagged
# Remove GigabitEthernet 1/0/1 from VLAN 1.
[SwitchA-GigabitEthernet1/0/1] undo port hybrid vlan 1
# Configure the network-side port GigabitEthernet 1/0/2 as a trunk port.
# Assign GigabitEthernet 1/0/2 to VLAN 100.
[SwitchA-GigabitEthernet1/0/2] port trunk permit vlan 100
# Remove GigabitEthernet 1/0/2 from VLAN 1.
[SwitchA-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[SwitchB] vlan 10
[SwitchB-vlan10] quit
[SwitchB] vlan 100
[SwitchB-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (GigabitEthernet 1/0/3) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchB] interface gigabitethernet 1/0/3
[SwitchB-GigabitEthernet1/0/3] vlan mapping nest single 10 nested-vlan 100
# Configure GigabitEthernet 1/0/3 as a hybrid port.
[SwitchB-GigabitEthernet1/0/3] port link-type hybrid
# Assign GigabitEthernet 1/0/3 to VLAN 10 as a tagged member.
[SwitchB-GigabitEthernet1/0/3] port hybrid vlan 10 tagged
# Assign GigabitEthernet 1/0/3 to VLAN 100 as an untagged member.
[SwitchB-GigabitEthernet1/0/3] port hybrid vlan 100 untagged
# Remove GigabitEthernet 1/0/3 from VLAN 1.
[SwitchB-GigabitEthernet1/0/3] undo port hybrid vlan 1
[SwitchB-GigabitEthernet1/0/3] quit
[SwitchB-GigabitEthernet1/0/1] port link-type trunk
# Assign GigabitEthernet 1/0/1 to VLAN 100.
[SwitchB-GigabitEthernet1/0/1] port trunk permit vlan 100
[SwitchB-GigabitEthernet1/0/1] undo port trunk permit vlan 1
# Configure GigabitEthernet 1/0/2 as a trunk port.
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port link-type trunk
[SwitchB-GigabitEthernet1/0/2] port trunk permit vlan 100
[SwitchB-GigabitEthernet1/0/2] undo port trunk permit vlan 1
# Create SVLANs 100 and 200.
[SwitchC] vlan 100
[SwitchC-vlan100] quit
[SwitchC] vlan 200
[SwitchC-vlan200] quit
# Assign GigabitEthernet 1/0/1 to VLANs 100 to 200.
[SwitchC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure a two-to-two VLAN mapping on GigabitEthernet 1/0/1 to map SVLAN 100 and CVLAN 10 to SVLAN 200 and CVLAN 30.
[SwitchC-GigabitEthernet1/0/1] vlan mapping tunnel 100 10 translated-vlan 200 30
# Assign GigabitEthernet 1/0/2 to VLAN 200.
[SwitchC-GigabitEthernet1/0/2] port trunk permit vlan 200
# Create CVLAN 30 and SVLAN 200.
[SwitchD] vlan 30
[SwitchD-vlan30] quit
[SwitchD] vlan 200
[SwitchD-vlan200] quit
# Configure the link type of GigabitEthernet 1/0/1 as trunk.
# Assign GigabitEthernet 1/0/1 to VLAN 200.
[SwitchD-GigabitEthernet1/0/1] port trunk permit vlan 200
[SwitchD-GigabitEthernet1/0/1] undo port trunk permit vlan 1
# Configure GigabitEthernet 1/0/2 as a hybrid port.
[SwitchD] interface gigabitethernet 1/0/2
[SwitchD-GigabitEthernet1/0/2] port link-type hybrid
# Assign GigabitEthernet 1/0/2 to VLAN 30 as a tagged member.
[SwitchD-GigabitEthernet1/0/2] port hybrid vlan 30 tagged
# Assign GigabitEthernet 1/0/2 to VLAN 200 as an untagged member.
[SwitchD-GigabitEthernet1/0/2] port hybrid vlan 200 untagged
[SwitchD-GigabitEthernet1/0/2] undo port hybrid vlan 1
[SwitchD-GigabitEthernet1/0/2] quit
# Configure a one-to-two VLAN mapping on the customer-side port (GigabitEthernet 1/0/2) to add SVLAN tag 200 to packets from VLAN 30.
[SwitchD-GigabitEthernet1/0/2] vlan mapping nest single 30 nested-vlan 200
  100           10            200                      30
Configuration files
IMPORTANT
IMPORTANT:
·     Switch A:
vlan 10
vlan 100
·     Switch B:
vlan 10
vlan 100
·     Switch C:
vlan 100
vlan 200
·     Switch D:
vlan 30
vlan 200
