H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
Table of Contents
Related Documents
53-OpenFlow Configuration Examples
53-OpenFlow Configuration Examples 108.20 KB
Introduction
This document provides examples for configuring OpenFlow.
OpenFlow separates the control plane and the data forwarding plane. An OpenFlow switch matches packets against one or more flow tables. A flow table contains one or more flow entries that are deployed by the controller and packets are matched based on the matching precedence of flow entries.
These examples use VLAN-interface 1.
This document assumes that you have basic knowledge of OpenFlow.
General restrictions and guidelines
When you configure OpenFlow, follow these restrictions and guidelines:
·     Enable LLDP globally on OpenFlow switches so that the controller can learn the OpenFlow topology through LLDP.
·     Configure each OpenFlow switch with an interface for communicating with the controller so that OpenFlow instances can establish connections with the controller.
·     Configure the Loosen mode when you associate VLAN 4092 and VLAN 4094 with an OpenFlow instance so that the access ports of switches can belong to the OpenFlow instance.
Example: Configuring OpenFlow to deploy flow entries
As shown in Figure 1, configure OpenFlow to meet the following requirements:
·     The controller can deploy dynamic flow entries.
·     Host A and Host C can communicate with each other based on the flow entries deployed by the controller.
·     Host B and Host D can communicate with each other based on the flow entries deployed by the controller.
Figure 1 Network diagram
Hardware
Software version
S6520XE-HI switch series
Supported in Release 11xx
S5560X-EI switch series
Supported in Release 111x
S5500V2-EI switch series
MS4520V2-30F switch
S5560S-EI switch series
S5560S-SI switch series
Supported in Release 612x
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
S5120V2-SI switch series
S5120V2-LI switch series
S3100V3-EI switch series
S3100V3-SI switch series
S5110V2 switch series
S5110V2-SI switch series
S5000V3-EI switch series
S5000E-X switch series
WAS6000 switch series
E128C switch
E152C switch
E500C switch series
E500D switch series
MS4520V2 switch series (except the MS4520V2-30F switch)
MS4320V2 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
WS5850-WiNet switch series
WS5820-WiNet switch series
WS5810-WiNet switch series
Procedures
Configuring Switch A
# Create VLAN 4092 and VLAN 4094.
[SwitchA] vlan 4092
[SwitchA-vlan4092] quit
[SwitchA] vlan 4094
[SwitchA-vlan4094] quit
# Configure GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, and GigabitEthernet 3/0/3.
[SwitchA] interface GigabitEthernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] port access vlan 4092
[SwitchA-GigabitEthernet3/0/1] quit
[SwitchA] interface GigabitEthernet 3/0/2
[SwitchA-GigabitEthernet3/0/2] port access vlan 4094
[SwitchA-GigabitEthernet3/0/2] quit
[SwitchA] interface GigabitEthernet 3/0/3
[SwitchA-GigabitEthernet3/0/3] port link-type trunk
[SwitchA-GigabitEthernet3/0/3] port trunk permit vlan 4092 4094
[SwitchA-GigabitEthernet3/0/3] quit
# Enable LLDP globally.
[SwitchA] lldp global enable
# Configure VLAN-interface 1 on Switch A for communicating with the controller.
[SwitchA] interface Vlan-interface 1
[SwitchA-Vlan-interface1] ip address 192.168.2.125 255.255.255.0
# Create OpenFlow instance 1. Associate VLAN 4092 and VLAN 4094 with it in loosen mode.
[SwitchA] openflow instance 1
[SwitchA-of-inst-1] classification vlan 4092 mask 4093 loosen
#Specify controller 0 with IP address 192.168.2.225 for OpenFlow instance 1 and activate the instance.
[SwitchA-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchA-of-inst-1] active instance
[SwitchA-of-inst-1] quit
Configuring Switch B
[SwitchB] vlan 4092
[SwitchB-vlan4092] quit
[SwitchB] vlan 4094
[SwitchB-vlan4094] quit
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] port access vlan 4092
[SwitchB-GigabitEthernet3/0/1] quit
[SwitchB] interface GigabitEthernet 3/0/2
[SwitchB-GigabitEthernet3/0/2] port access vlan 4094
[SwitchB-GigabitEthernet3/0/2] quit
[SwitchB] interface GigabitEthernet 3/0/3
[SwitchB-GigabitEthernet3/0/3] port link-type trunk
[SwitchB-GigabitEthernet3/0/3] port trunk permit vlan 4092 4094
[SwitchB-GigabitEthernet3/0/3] quit
[SwitchB] lldp global enable
# Configure VLAN-interface 1 on Switch B for communicating with the controller.
[SwitchB] interface Vlan-interface 1
[SwitchB-Vlan-interface1] ip address 192.168.2.125 255.255.255.0
[SwitchB-Vlan-interface1] quit
[SwitchB] openflow instance 1
[SwitchB-of-inst-1] classification vlan 4092 mask 4093 loosen
#Specify the IP address for controller 0 as 192.168.2.225 for OpenFlow instance 1 and activate the instance.
[SwitchB-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchB-of-inst-1] active instance
[SwitchB-of-inst-1] quit
# Display details for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1
Instance 1 information:
Configuration information:
 Description   : --
 Active status : Active
 Inactive configuration:
  None
 Active configuration:
  Classification VLAN, loosen mode, total VLANs(2)
   4092, 4094
  In-band management VLAN, total VLANs(0)
   Empty VLAN
  Connect mode: Multiple
  MAC address learning: Enabled
  Flow table:
   Table ID(type): 0(Extensibility), count: 1
  Flow-entry max-limit: 65535
  Datapath ID: 0x000174258a024c00
Port information:
Active channel information:
 Controller 0 IP address: 192.168.2.225 port: 6633
The output shows that GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, and GigabitEthernet 3/0/3 belong to OpenFlow instance 1 and can be used to forward packets in the OpenFlow forwarding process.
# Display controller information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 controller
Instance 1 controller information:
 Reconnect interval: 60 (s)
 Echo interval     : 5  (s)
 Controller ID           : 0
 Controller IP address   : 192.168.2.225
 Controller port         : 6633
 Controller role         : Equal
 Connect type            : TCP
 Connect state           : Established
 Packets sent            : 132
 Packets received        : 434
 SSL policy              : --
 VRF name                : --
The output shows that Switch A has established a connection with the controller.
# Display flow table information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 flow-table
Instance 1 flow table information:
Table 0 information:
 Table type: Extensibility, flow entry count: 1, total flow entry count: 1
MissRule flow entry information:
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem,
 byte count: 0, packet count: 0
Match information: any
Instruction information:
 Write actions:
  Output interface: Controller, send length: 65509 bytes
The output shows that Switch A has only one table-miss flow entry with the priority of 0 and the action of outputting packets to the controller. The default action in the table-miss flow entry varies by controller model. For more information, see the related documentation of the controller.
# Ping Host C from Host A.
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=4.582 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=1.299 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.389 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=6.688 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=1.294 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 1.294/3.050/6.688/2.213 ms
The output shows that Host A and Host C can reach each other.
# Display flow table information for OpenFlow instance 1 again on devices, for example, Switch A.
 Table type: Extensibility, flow entry count: 4, total flow entry count: 4
 Write actions:
Flow entry 1 information:
 cookie: 0x2328, priority: 29999, hard time: 0, idle time: 300, flags:
 flow_send_rem, byte count: 1, packet count: 1
Match information:
 Input interface: GE3/0/3
 Ethernet destination MAC address: 0cda-41b1-d1c5
 Ethernet destination MAC address mask: ffff-ffff-ffff
 Ethernet source MAC address: 7425-8a0f-8034
 Ethernet source MAC address mask: ffff-ffff-ffff
 Ethernet type: 0x0806
 Write actions:
  Output interface: GE3/0/1
Flow entry 2 information:
 flow_send_rem, byte count: 1, packet count: 4
Match information:
 Input interface: GE3/0/1
 Ethernet destination MAC address: 7425-8a0f-8034
 Ethernet source MAC address: 0cda-41b1-d1c5
 Ethernet type: 0x0800
 Write actions:
  Output interface: GE3/0/3
Flow entry 3 information:
Match information:
 Write actions:
·     The ARP request/reply packets and ICMP request/replay packets between Host A and Host C successfully trigger the controller to deploy flow entries.
·     Switch A forwards packets based on the flow entries that are deployed by the controller.
# Ping Host D from Host B.
Ping 20.1.1.2 (20.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 20.1.1.2: icmp_seq=0 ttl=255 time=1.620 ms
56 bytes from 20.1.1.2: icmp_seq=1 ttl=255 time=6.625 ms
56 bytes from 20.1.1.2: icmp_seq=2 ttl=255 time=1.454 ms
56 bytes from 20.1.1.2: icmp_seq=3 ttl=255 time=1.134 ms
56 bytes from 20.1.1.2: icmp_seq=4 ttl=255 time=1.260 ms
--- Ping statistics for 20.1.1.2 ---
round-trip min/avg/max/std-dev = 1.134/2.419/6.625/2.110 ms
The output shows that Host B and Host D can reach each other.
 Table type: Extensibility, flow entry count: 7, total flow entry count: 7
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Flow entry 4 information:
Match information:
 Ethernet destination MAC address: 0cda-41b1-d1c4
 Ethernet source MAC address: 7425-8a0f-8035
 Write actions:
  Output interface: GE3/0/2
Flow entry 5 information:
Match information:
 Input interface: GE3/0/2
 Ethernet destination MAC address: 7425-8a0f-8035
 Ethernet source MAC address: 0cda-41b1-d1c4
 Write actions:
Flow entry 6 information:
Match information:
 Write actions:
·     The ARP request/reply packets and ICMP request/replay packets between Host B and Host D successfully trigger the controller to deploy flow entries.
Configuration files
·     Switch A:
lldp global enable
openflow instance 1
interface Vlan-interface1
interface GigabitEthernet3/0/1
 port link-mode bridge
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
 port trunk permit vlan 1 4092 4094
·     Switch B:
lldp global enable
openflow instance 1
 ip address 192.168.2.126 255.255.255.0
