- H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
- 00-1Cover
- 00-2Product Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Configuration Operation
- 06-Management VLAN Operation
- 07-Voice VLAN Operation
- 08-GVRP Operation
- 09-Port Basic Configuration Operation
- 10-Link Aggregation Operation
- 11-Port Isolation Operation
- 12-Port Security-Port Binding Operation
- 13-DLDP Operation
- 14-MAC Address Table Operation
- 15-Auto Detect Operation
- 16-MSTP Operation
- 17-Routing Protocol Operation
- 18-Multicast Operation
- 19-802.1x Operation
- 20-AAA-RADIUS-HWTACACS-EAD Operation
- 21-VRRP Operation
- 22-Centralized MAC Address Authentication Operation
- 23-ARP Operation
- 24-DHCP Operation
- 25-ACL Operation
- 26-QoS-QoS Profile Operation
- 27-Web Cache Redirection Operation
- 28-Mirroring Operation
- 29-IRF Fabric Operation
- 30-Cluster Operation
- 31-PoE-PoE Profile Operation
- 32-UDP Helper Operation
- 33-SNMP-RMON Operation
- 34-NTP Operation
- 35-SSH Terminal Service Operation
- 36-File System Management Operation
- 37-FTP and TFTP Operation
- 38-Information Center Operation
- 39-System Maintenance and Debugging Operation
- 40-VLAN-VPN Operation
- 41-HWPing Operation
- 42-DNS Operation
- 43-Access Management Operation
- 44-Appendix
40-VLAN-VPN Operation | 377 KB |
Chapter 1 VLAN-VPN Configuration
1.1.1 Introduction to VLAN-VPN
1.1.2 Implementation of VLAN-VPN
1.1.3 Adjusting the TPID Values of VLAN-VPN Packets
1.2.1 Configuration Prerequisites
1.3 Inner VLAN Tag Priority Replication Configuration
1.3.1 Configuration Prerequisites
1.4 TPID Adjusting Configuration
1.4.1 Configuration Prerequisites
1.5 VLAN-VPN Configuration Example
Chapter 2 BPDU Tunnel Configuration.
2.1.1 Introduction to the BPDU Tunnel Function
2.2.1 Configuration Prerequisites
2.3 BPDU Tunnel Configuration Example
1.1 VLAN-VPN Overview
The VLAN-VPN function enables packets to be transmitted across the operators’ backbone networks with VLAN tags of private networks encapsulated in those of public networks. In public networks, packets of this type are transmitted by their outer VLAN tags (that is, the VLAN tags of public networks). And those of private networks which are encapsulated in the VLAN tags of public networks are shielded.
Figure 1-1 describes the structure of the packets with single-layer VLAN tags.
Figure 1-1 Structure of packets with single-layer VLAN tags
Figure 1-2 describes the structure of the packets with nested VLAN tags.
Figure 1-2 Structure of packets with double-layer VLAN tags
Compared with MPLS-based Layer 2 VPN, VLAN-VPN has the following features:
l It provides Layer 2 VPN tunnels that are simpler.
l VLAN-VPN can be implemented without the support of signaling protocols. You can enable VLAN-VPN by static configuration.
The VLAN-VPN function provides you with the following benefits:
l Saves public network VLAN ID resource.
l You can have VLAN IDs of your own, which is independent of public network VLAN IDs.
l It allows for simple Layer 2 VPN solutions for small-sized MANs or intranets.
VLAN-VPN can be implemented by enabling the VLAN-VPN function on ports.
With the VLAN VPN function enabled, a received packet is tagged with the default VLAN tag of the receiving port no matter whether or not the packet already carries a VLAN tag. If the packet already carries a VLAN tag, the packet becomes a dual-tagged packet. Otherwise, the packet becomes a packet carrying the default VLAN tag of the port.
Tag protocol identifier (TPID) is a field of the VLAN tag. IEEE 802.1Q specifies the value of TPID to be 0x8100.
Figure 1-3 illustrates the structure of the Tag packet of an Ethernet frame defined by IEEE 802.1Q.
Figure 1-3 The structure of the Tag packet of an Ethernet frame
S3600 series switches adopt the protocol default TPID value (0x8100). Other vendors use other TPID values (such as 0x9100 or 0x9200) in the outer tags of VLAN-VPN packets.
To be compatible with devices coming from other vendors, S3600 series switches can adjust the TPID values of VLAN-VPN packets based on ports. You can configure the TPID value of a port connecting to the public network side by yourself. When a packet is forwarded through the port, the port replaces the TPID value in the outer VLAN tag of this packet with the user-defined value. Thus, the VLAN-VPN packets sent to the public network can be recognized by devices of other vendors.
As the position of the TPID field in an Ethernet packet is the same as that of the protocol type field in a packet without VLAN Tag, to avoid confusion in the process of receiving/forwarding a packet, the TPID value cannot be any of the protocol type value listed in Table 1-1
Table 1-1 Commonly used protocol type values in Ethernet frames
Protocol type |
Value |
ARP |
0x0806 |
IP |
0x0800 |
MPLS |
0x8847/0x8848 |
IPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
802.1x |
0x888E |
1.2 VLAN-VPN Configuration
l GARP VLAN registration protocol (GVRP), GARP multicast registration protocol (GMRP), intelligent resilient framework (IRF), neighbor topology discovery protocol (NTDP), spanning tree protocol (STP), 802.1x and centralized MAC address authentication function are disabled on the port.
l The port is an access port.
Caution:
l The VLAN-VPN function is unavailable to a port if any of the protocols among GVRP, GMRP, IRF, NTDP, STP, 802.1x and centralized MAC address authentication function is enabled on the port.
l By default, STP and NTDP are enabled on a device. You can disable these two protocols using the stp disable and undo ntdp enable commands.
l The VLAN-VPN function is unavailable to all the ports of a device if the fabric function is enabled on a port of the device.
1.2.2 Configuration Procedure
Table 1-2 Configure the VLAN-VPN function for a port
Operation |
Command |
Enter system view |
system-view |
Enter Ethernet port view |
Enable the VLAN-VPN function on the port |
vlan-vpn enable |
Required By default, the VLAN-VPN function is disabled on a port. |
Display VLAN VPN configuration information about all the ports |
display port vlan-vpn |
This command can be executed in any view. |
& Note:
After you enable the VLAN-VPN function for a port, you cannot change the port to be a trunk port or hybrid port, nor can you enable GVRP, GMRP, IRF, NTDP, or STP, 802.1x and centralized MAC address authentication function for the port.
l Error message appears if you try to change the port to be a trunk port or hybrid port or enable GVRP, GMRP, IRF, NTDP, STP, 802.1x or centralized MAC address authentication function for the port by executing corresponding commands.
l If you use the copy configuration command to duplicate the configuration of a port to a port enabled with the VLAN-VPN function, the configuration concerning port type (that is, access, trunk, or hybrid), GVRP, GMRP, IRF, NTDP, STP, 802.1x and centralized MAC address authentication function is not duplicated.
You can configure to replicate the tag priority of the inner VLAN tag of a VLAN-VPN packet to the outer VLAN tag to keep the original tag priority after the packet is inserted an outer VLAN tag.
The VLAN-VPN function is enabled.
1.3.2 Configuration Procedure
Table 1-3 Replicate the tag priority of the inner VLAN tag
Operation |
Command |
Enter system view |
system-view |
Enable the inner VLAN Tag priority replication function |
vlan-vpn inner-cos-trust enable |
Required By default, the inner VLAN tag priority replication function is disabled. And the priority of an outer VLAN tag is that of the default priority of the current port. |
Display the VLAN-VPN configuration of about all ports |
If you have configured the port priority, (refer to the QoS&QoS Profile part of H3C S3600 Series Ethernet Switches Operation Manual for more), after you configure to replicate the tag priority of the inner VLAN tag of a VLAN-VPN packet, the switch will prompt that the port priority configuration on the current port is invalid.
The TPID value of the peer end of the public network is available.
1.4.2 Configuration Procedure
Table 1-4 Adjust TPID values for VLAN-VPN packets
Operation |
Command |
Enter system view |
system-view |
Set a TPID value for the port |
vlan-vpn tpid value |
Required Do not set the TPID value to any of the protocol type values listed in Table 1-1. |
Display VLAN-VPN configuration information about all ports |
You can execute the display command in any view. |
Caution:
You will fail to execute the vlan-vpn tpid command on an IRF Fabric port.
I. Network requirements
l Switch A and Switch C are S3600 series switches. Switch B is a switch coming from another manufacturer, which uses the TPID value of 0x9100.
l Two user networks are connected to the Ethernet1/0/1 ports of Switch A and Switch C respectively.
l Switch B only permits packets of VLAN 10.
l It is required that packets of the VLANs other than VLAN 10 can be exchanged between the user networks connected to Switch A and Switch C.
II. Network diagram
Figure 1-4 Network diagram for VLAN-VPN configuration
III. Configuration Procedure
1) Configure Switch A and Switch C.
As the configuration performed on Switch A and Switch C is the same, configuration on Switch C is omitted.
# Set the TPID value of Ethernet1/0/2 port of Switch A to 0x9100, and add the port to VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] interface Ethernet1/0/2
[SwitchA-Ethernet1/0/2] vlan-vpn tpid 9100
[SwitchA-Ethernet1/0/2] port link-type trunk
[SwitchA-Ethernet1/0/2] port trunk permit vlan 10
# Add Ethernet1/0/1 port of Switch A to VLAN 10 and enable the VLAN-VPN function for the port.
[SwitchA] interface Ethernet1/0/1
[SwitchA-Ethernet1/0/1] port access vlan 10
[SwitchA-Ethernet1/0/1] vlan-vpn enable
[SwitchA-Ethernet1/0/1] quit
2) Configure Switch B
Because Switch B comes from another manufacturer, the commands involved may differ from those for S3600 series switches. So only the operations are listed, as shown below:
l Configure Ethernet3/1/1 and Ethernet3/1/2 ports of Switch B to be trunk ports.
l Add the two ports to VLAN 10.
& Note:
The following describes how a packet is forwarded from Switch A to Switch C.
l As the Ethernet1/0/1 port of Switch A is a VLAN-VPN port, when a packet from the user’s network side reaches Ethernet1/0/1 port of Switch A, it is tagged with the default VLAN tag of the port (VLAN 10) and is then forwarded to Ethernet1/0/2 port.
l Because Ethernet1/0/2 port is configured with VLAN-VPN TPID, Switch A changes the TPID value in the outer VLAN Tag of the packet to 0x9100 and forwards the packet to the public network.
l The packet reaches Ethernet3/1/2 port of Switch B in the public network. Switch B forwards the packet to Ethernet3/1/1, which belongs to VLAN 10.
l The packet is forwarded from Ethernet3/1/1 port of Switch B to the network on the other side and enters Ethernet1/0/2 port of Switch C. Then Switch C forwards the packet to its Ethernet1/0/1 port, which also belongs to VLAN 10. As Ethernet1/0/1 port is an access port, Switch C strips off the outer VLAN tag of the packet and restores the original packet.
l It is the same case when a packet travels from Switch C to Switch A.
After the configuration, the networks connecting Switch A and Switch C can receive data packets from each other.
2.1 BPDU Tunnel Overview
In MAN networking solutions, the requirements may arise that the branches of an enterprise be interconnected through the operator’s network. This can be achieved through VPN (virtual private network), which can integrate geographically dispersed networks to form a logical LAN. The tunnel function is required when you implement VPN. It enables packets of private networks to travel through operator’s network and reach another private network securely. To make networks of this kind essentially comparable with an actual LAN, Layer 2 protocol packets used to maintain the network are also required to travel across the tunnels.
2.1.2 BPDU Tunnel Fundamental
I. Layer 2 packet identification
Different from the processing of data packets, a Layer 2 protocol packet is classified first when it reaches a network device. A Layer 2 protocol packet conforming with IEEE standards carries a special destination MAC address and contains a type field. Some proprietary protocols adopt the same packet structure, where a private MAC address is used to identify the corresponding proprietary protocol, and the type field is used to identify the specific protocol type.
II. Transmitting BPDU packets transparently
As shown in Figure 2-1, the network on the top is the operator’s network, and the one on the bottom is a user network. The operator’s network contains devices that receive/transmit packets. The user network contains Network A and Network B. You can make the BPDU packets to be transmitted in the operator’s network transparently by enabling the BPDU Tunnel function on the devices with user networks connected to in the operator’s network.
l When a BPDU packet coming from a user network reaches a device in the operator’s network, the device changes the destination MAC address carried in the packet from a protocol-specific MAC address to a normal MAC address, which can be identified by both the local device and the peer device. In such a way, the BPDU packet is converted to a normal data packet and is forwarded in the operator’s network.
l Before the device in the operator’s network forwards the packet to the destination user network, the device restores the original protocol-specific MAC address. This ensures the data portion of the packet is consistent with that before the packet enters the tunnel. So, a tunnel here acts as a local link for user devices. It enables Layer 2 protocol packets to travel across a logical LAN.
Figure 2-1 BPDU Tunnel network hierarchy
Figure 2-2 and Figure 2-3 show the structure of a BPDU packet before and after it enter a BPDU tunnel.
Figure 2-2 The structure of a BPDU packet before it enters a BPDU tunnel
Figure 2-3 The structure of a BPDU packet after it enters a BPDU tunnel
2.2 BPDU Tunnel Configuration
You can establish BPDU tunnels between S3600 series Ethernet switches for the packets of the following protocols:
l ALCP (link aggregation control protocol)
l NDP (neighbor discovery protocol)
l Proprietary protocols, including CDP and VTP
One or more protocols among LACP, NDP, CDP, and VTP operate properly on the devices.
2.2.2 Configuring BPDU Tunnel
Table 2-1 Configure BPDU Tunnel
Operation |
Command |
Enter system view |
system-view |
Set the port to be a BPDU Tunnel uplink port |
Enable the function in system view |
bpdu-tunnel uplink interface-list |
You can enable the BPDU Tunnel in system view or in Ethernet view. By default, NDP is enabled globally. |
Enable the function in Ethernet port view |
Enable the BPDU Tunnel function |
bpdu-tunnel uplink |
Return to system view |
quit |
Enable the BPDU Tunnel function for the packets of a specific protocol |
bpdu-tunnel { lacp | ndp | cdp | vtp } |
Required By default, the BPDU Tunnel function is disabled on a port. |
& Note:
The BPDU Tunnel is unavailable to all the ports of a device if the device has the fabric function enabled on one of its ports.
l Custimer1 and Customer2 are access devices operating in a user network.
l Provider1 and Provider2 are access devices operating in the operator’s network. They are interconnected through their trunk ports, as shown in Figure 2-4.
l Enable the BPDU Tunnel function for NDP packets on the Ethernet1/0/1 and Ethernet1/0/4 port shown in the Figure 2-4.Set the port Ethernet1/0/2 and Ethernet1/0/3 to be BPDU Tunnel uplink ports.
II. Network diagram
Figure 2-4 Network diagram for BPDU Tunnel configuration
III. Configuration procedure
1) Configure Provide1.
# Enable the BPDU Tunnel fuction for NDP packets on port Ethernet1/0/1.
<H3C> system-view
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] undo ndp enable
[H3C-Ethernet1/0/1] bpdu-tunnel ndp
# Set the port Ethernet 1/0/2 to be a BPDU Tunnel uplink port.
[H3C-Ethernet1/0/1] quit
[H3C] interface Ethernet 1/0/2
[H3C-Ethernet1/0/2] bpdu-tunnel uplink
2) Configure Provider2.
# Set the port Ethernet 1/0/3 to be a BPDU Tunnel uplink port.
<H3C> system-view
[H3C] interface Ethernet 1/0/3
[H3C-Ethernet1/0/3] bpdu-tunnel uplink
# Enable the BPDU Tunnel function for NDP packets on port Ethernet1/0/4
[H3C-Ethernet1/0/3] quit
[H3C] interface Ethernet 1/0/4
[H3C-Ethernet1/0/4] undo ndp enable
[H3C-Ethernet1/0/4] bpdu-tunnel ndp
