- H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
- 00-1Cover
- 00-2Product Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Configuration Operation
- 06-Management VLAN Operation
- 07-Voice VLAN Operation
- 08-GVRP Operation
- 09-Port Basic Configuration Operation
- 10-Link Aggregation Operation
- 11-Port Isolation Operation
- 12-Port Security-Port Binding Operation
- 13-DLDP Operation
- 14-MAC Address Table Operation
- 15-Auto Detect Operation
- 16-MSTP Operation
- 17-Routing Protocol Operation
- 18-Multicast Operation
- 19-802.1x Operation
- 20-AAA-RADIUS-HWTACACS-EAD Operation
- 21-VRRP Operation
- 22-Centralized MAC Address Authentication Operation
- 23-ARP Operation
- 24-DHCP Operation
- 25-ACL Operation
- 26-QoS-QoS Profile Operation
- 27-Web Cache Redirection Operation
- 28-Mirroring Operation
- 29-IRF Fabric Operation
- 30-Cluster Operation
- 31-PoE-PoE Profile Operation
- 32-UDP Helper Operation
- 33-SNMP-RMON Operation
- 34-NTP Operation
- 35-SSH Terminal Service Operation
- 36-File System Management Operation
- 37-FTP and TFTP Operation
- 38-Information Center Operation
- 39-System Maintenance and Debugging Operation
- 40-VLAN-VPN Operation
- 41-HWPing Operation
- 42-DNS Operation
- 43-Access Management Operation
- 44-Appendix
00-2Product Overview | 477 KB |
Chapter 1 Obtaining the Documentation
Chapter 3 Networking Applications
3.1 Broadband Ethernet Access for Residential Communities
3.2 Application for Connecting Branches or Small- to Medium-Sized Enterprises
3.3 Application in Large Enterprise and Campus Networks
H3C Technologies Co., Ltd. provides various ways for you to obtain documentation, through which you can obtain the product documentations and those concerning newly added new features. The documentations are available in one of the following ways:
l CD-ROMs shipped with the devices
l H3C website
l Software release notes
1.1 CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete product document set, including the operation manual, command manual, installation manual, and compatibility manual. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
1.2 H3C Website
Perform the following steps to query and download the product documentation from the H3C website.
Table 1-1 Acquire product documentation from the H3C website
How to apply for an account |
Access the homepage of H3C at http:// www.h3c.com and click on Registration at the top right. In the displayed page, provide your information and click on Submit to register. |
How to get documentation |
Approach 1: In the homepage of H3C at http:// www.h3c.com, select Technical Support & Document > Technical Documents from the navigation menu at the top. Then select a product for its documents. Approach 2: In the homepage of H3C at http:// www.h3c.com, select Support > Technical Documents. Then select a product for its documents. |
1.3 Software Release Notes
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
Chapter 2 Product Overview
2.1 Preface
H3C S3600 Series Ethernet switches are Ethernet equipment capable of multilayer switching. They come in two series: S3600-SI and S3600-EI. In addition to the basic service features, S3600 Series Ethernet switches support abundant Layer 3 features and enhanced extended functions.
l S3600-SI series switches support basic routing functions, DHCP, basic IRF functions and IGMP-Snooping.
l S3600-EI series switches support advanced routing functions, DHCP, enhanced IRF functions, and enhanced multicast functions (including PIM-DM and PIM-SM).
2.2 Switch Models
Table 2-1 lists the S3600 series Ethernet Switches models.
Table 2-1 Models in the S3600 series
Model |
Power supply unit (PSU) |
Number of service ports |
Number of 100 Mbps ports |
Number of 1,000 Mbps uplink ports |
Console port |
H3C S3600-28P-SI |
AC-input |
28 |
24 10/100 Mbps ports(electrical) |
4 Gigabit (SFP) ports |
1 |
H3C S3600-28P-PWR-SI |
AC-/DC-input |
28 |
1 |
H3C S3600-28TP-SI |
AC-input |
28 |
24 10/100 Mbps (electrical) |
2 Gigabit (SFP) ports 2 10/100/1,000 Mbps ports (electrical) |
1 |
H3C S3600-52P-SI |
AC-input |
52 |
48 10/100 Mbps (electrical) |
1 |
H3C S3600-28P-EI |
AC-/DC-input |
28 |
24 10/100 Mbps ports (electrical) |
1 |
H3C S3600-28F-EI |
AC-/DC-input |
28 |
24 100 Mbps (SFP) ports |
1 |
H3C S3600-28P-PWR-EI |
AC-/DC-input |
28 |
1 |
H3C S3600-52P-EI |
AC-/DC-input |
52 |
48 10/100 Mbps ports (electrical) |
4 Gigabit ports (SFP) |
1 |
H3C S3600-52P-PWR-EI |
AC-/DC-input |
52 |
1 |
H3C S3600-52P-PWR-SI |
AC-/DC-input |
52 |
1 |
2.3 Software Features
S3600 Series Ethernet Switches have abundant software features and can meet the requirements of different applications. Table 2-2 summarizes the features provided by each module.
Table 2-2 Service features of the S3600 series
Part |
Features |
1 CLI |
l CLI l Hierarchically grouped commands l CLI online help |
2 Login |
l Logging into a switch through the Console port l Logging into a switch through an Ethernet port by using Telnet or SSH l Logging into a switch through the Console port by using modem l Logging into a switch through Web or NMS |
3 Configuration File Management |
l Saving, restoring, and deleting the configuration file |
4 VLAN |
l IEEE 802.1Q-compliant VLAN l Port-based VLAN l Protocol-based VLAN |
5 IP Address and Performance Configuration |
l Configuring an IP address for a switch l Configuring the TCP attributes for a switch |
6 Management VLAN |
l Management VLAN configuration l Management VLAN interface configuration |
7 Voice VLAN |
l Voice VLAN |
8 GVRP |
l GARP VLAN registration protocol (GVRP) |
9 Port Basic Configuration |
l Three port states supported: Access, Trunk, and Hybrid l Setting broadcast storm suppression globally l Loopback detection supported l Cable test |
10 Link Aggregation |
l Link aggregation control protocol (LACP) |
11 Port Isolation |
l Port isolation group |
12 Port Security-Port Binding |
l Multiple security modes l MAC address-to-port binding |
13 DLDP |
l Device link detection protocol (DLDP) |
14 MAC Address Table |
l Manually configuring dynamic, static, and black hole MAC addresses l Configuring the aging time for MAC addresses l MAC address learning limit |
15 Auto Detect |
l Auto detect l Auto detect applications in static routing, VRRP, and VLAN interface backup |
16 MSTP |
l STP/RSTP/MSTP l VLAN-VPN TUNNEL l H3C-proprietary MSTP path cost standard |
17 Routing Protocols. |
l Static route l Routing information protocol (RIP) v1/v2 l Open shortest path first (OSPF) (S3600-EI series switches only) l Routing policy |
18 Multicast |
l Internet group management protocol snooping (IGMP Snooping) l Internet group management protocol (IGMP) (S3600-EI series switches only) l Protocol-independent multicast-dense mode (PIM-DM) (S3600-EI series switches only) l Protocol-independent multicast-sparse mode (PIM-SM) (S3600-EI series switches only) |
19 802.1x |
l 802.1X authentication l Guest VLAN l Huawei authentication bypass protocol (HABP) |
20 AAA-RADIUS-HWTACACS-EAD |
l Authentication, authorization, and accounting (AAA) l Remote authentication dial-In user service (RADIUS) l Huawei terminal access controller access control system (HWTACACS) |
21 VRRP |
l Virtual router redundancy protocol (VRRP) (S3600-EI series switches only) |
22 Centralized MAC Address Authentication |
l Centralized MAC address authentication |
23 ARP |
l Gratuitous ARP l Manually configuring ARP entries |
24 DHCP |
l DHCP server (S3600-EI series switches only) l DHCP relay l DHCP Snooping l DHCP accounting l Using Option184 in DHCP server (S3600-EI series switches only) l Using Option82 in DHCP relay |
25 ACL |
l Basic ACLs l Advanced ACLs l Layer 2 ACLs l User-defined ACLs |
26 QoS-QoS Profile |
l Quality of Service (QoS) l QoS profile |
27 Web Cache Redirection |
l (Supported by S3600-EI series only) |
28 Mirroring |
l Traffic mirroring l Port mirroring l Remote port mirroring (S3600-EI series switches only) |
29 IRF Fabric |
l IRF Fabric l Stack port optional l Peer end detection for stack ports |
30 Cluster |
l Huawei group management protocol (HGMP) v2 l Neighbor discovery protocol (NDP) l Neighbor topology discovery protocol (NTDP) |
31 PoE-PoE Profile |
l Power over Ethernet (PoE) l PoE profile |
32 UDP Helper |
l Forwarding UDP broadcast packets by using UDP Helper |
33 SNMP-RMON |
l Simple network management protocol (SNMP) v3, compatible with SNMP v1/v2 l Remote monitoring (RMON) |
34 NTP |
l Network time protocol (NTP) |
35 SSH Terminal Service |
l Secure shell (SSH) l Secure FTP (SFTP) |
36 File System Management |
l File system management l Configuration file backup and restoration l FTP/TFTP lighting |
37 FTP and TFTP |
l Operating as an FTP server/FTP client l Operating as a TFTP client |
38 Information Center |
l System logs l Hierarchical alarms l Debugging information output |
39 System Maintenance and Debugging |
l Configuring system time l Language (Chinese/English) selecting l Displaying and configuring system device state |
40 VLAN-VPN |
l VLAN VPN (QinQ) l Configuring VLAN VPN interior-layer priority replication l Configuring TPID value |
41 HWPing |
l HWPing |
42 DNS |
l Domain Name System (DNS) |
43 Access Management |
l Configuring the access IP address pool based on the physical port |
You can deploy S3600 series on many types of networks, such as enterprise networks and broadband access networks. Following are several typical networking applications.
On the broadband access network of a residential community, an S3600 series switch is located in the center. It is downlinked to S2000 or S3026 series switches to reach the Ethernet users and uplinked to a core Layer 3 switch through a GE extension module to connect to the MAN backbone.
Figure 3-1 Network diagram for connecting community Ethernet to MAN using S3600 series Ethernet switches
For small-to medium-sized enterprises or branches of a large enterprise, S3600 series switches can server as the backbone switches on their networks and can be connected to the headquarters or other branches through routers. As the enterprise size increases, the network also can expand by subtending the S3600 series.
Figure 3-2 S3600 series switches application in branch network of midsize/large enterprise
In a large enterprise or campus network, the S3600 series switches can operate on the convergence layer. They are downlinked to layer 2 switches, S3000 Series for example; and uplinked to a layer 3 switch through GE expansion modules. These switches together provide a network-wide intranet solution that covers Gigabit-to-backbone and 100 Mbps-to-desktop.
Figure 3-3 S3600 series application in large enterprise and campus network
