- H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
- 00-1Cover
- 00-2Product Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Configuration Operation
- 06-Management VLAN Operation
- 07-Voice VLAN Operation
- 08-GVRP Operation
- 09-Port Basic Configuration Operation
- 10-Link Aggregation Operation
- 11-Port Isolation Operation
- 12-Port Security-Port Binding Operation
- 13-DLDP Operation
- 14-MAC Address Table Operation
- 15-Auto Detect Operation
- 16-MSTP Operation
- 17-Routing Protocol Operation
- 18-Multicast Operation
- 19-802.1x Operation
- 20-AAA-RADIUS-HWTACACS-EAD Operation
- 21-VRRP Operation
- 22-Centralized MAC Address Authentication Operation
- 23-ARP Operation
- 24-DHCP Operation
- 25-ACL Operation
- 26-QoS-QoS Profile Operation
- 27-Web Cache Redirection Operation
- 28-Mirroring Operation
- 29-IRF Fabric Operation
- 30-Cluster Operation
- 31-PoE-PoE Profile Operation
- 32-UDP Helper Operation
- 33-SNMP-RMON Operation
- 34-NTP Operation
- 35-SSH Terminal Service Operation
- 36-File System Management Operation
- 37-FTP and TFTP Operation
- 38-Information Center Operation
- 39-System Maintenance and Debugging Operation
- 40-VLAN-VPN Operation
- 41-HWPing Operation
- 42-DNS Operation
- 43-Access Management Operation
- 44-Appendix
07-Voice VLAN Operation | 108 KB |
Table of Contents
Chapter 1 Voice VLAN Configuration
1.1.1 Configuring Operation Mode for Voice VLAN
1.1.2 Supporting Information of Voice VLAN on Various Ports
1.2.1 Configuration Prerequisites
1.2.2 Configuring a Voice VLAN to Operate in Automatic Mode
1.2.3 Configuring a Voice VLAN to Operate in Manual Mode
1.4 Voice VLAN Configuration Example
1.4.1 Voice VLAN Configuration Example (Automatic Mode)
1.4.2 Voice VLAN Configuration Example (Manual Mode)
1.1 Voice VLAN Overview
Voice VLANs are VLANs configured specially for voice traffic. By adding the ports with voice devices attached to voice VLANs, you can perform QoS-related configuration for voice data, ensuring the transmission priority of voice traffic and voice quality.
S3600 series Ethernet switches determine whether a received packet is a voice packet by checking its source MAC address. If the source MAC addresses of packets comply with the organizationally unique identifier (OUI) addresses configured by the system, the packets are determined as voice packets and transmitted in voice VLAN.
You can configure an OUI address for voice packets or specify to use the default OUI address.
& Note:
An OUI address is a globally unique identifier assigned to a vendor by IEEE. You can determine which vendor a device belongs to according to the OUI address which forms the first 24 bits of a MAC address.
The following table shows the five default OUI addresses of a switch.
Table 1-1 Default OUI addresses preset by the switch
Number |
OUI Address |
Vendor |
1 |
0003-6b00-0000 |
Cisco phone |
2 |
000f-e200-0000 |
H3C Aolynk phone |
3 |
00d0-1e00-0000 |
Pingtel phone |
4 |
00e0-7500-0000 |
Polycom phone |
5 |
00e0-bb00-0000 |
3Com phone |
A voice VLAN can operate in two modes: automatic and manual. You can configure the operation mode for the voice VLAN according to data traffic passing through a port.
I. Processing mode of untagged packets sent by IP voice devices
l Automatic mode: an S3600 Ethernet switch automatically adds a port connecting an IP voice device to the voice VLAN by learning the source MAC address in the untagged packet sent by the IP voice device when it is powered on. When the aging time of a port expires, voice ports on which the OUI addresses are not updated (no voice traffic passes) will be automatically removed from the voice VLAN; voice ports can not be added into or removed from the voice VLAN through manual configurations.
l Manual mode: add a voice port to the voice VLAN or remove a voice port from the voice VLAN through manual configuration.
II. Processing mode of tagged packets sent by IP voice devices
For the tagged packets sent by IP voice devices, they are processed in the same way in either of the above two modes: forwarded within corresponding VLAN according to their VLAN ID in the tags.
& Note:
l An untagged packet refers to the packet without the VLAN tag.
l A tagged packet refers to the packet with the VLAN tag.
Voice VLAN packets can be forwarded by both trunk and hybrid ports in voice VLAN. You can enable a trunk or hybrid port belonging to other VLANs to forward voice and service packets simultaneously by enabling the voice VLAN.
As multiple types of IP voice devices exist, you need to match port mode with types of voice traffic sent by IP voice devices, as listed in Table 1-2.
Table 1-2 Matching relationship between port modes and voice traffic types
Port voice VLAN mode |
Voice traffic type |
Port type |
Supported or not |
Automatic mode |
Tagged voice traffic |
Access |
Not supported |
Trunk |
Supported Make sure the default VLAN of the port exists and is not a voice VLAN. And the access port permits the traffic of the default VLAN. |
Hybrid |
Supported Make sure the default VLAN of the port exists and is not a voice VLAN. The default VLAN must be in the list of the tagged VLANs whose traffic is permitted by the access port. |
Untagged voice traffic |
Access |
Not supported, because the default VLAN of the port must be a voice VLAN and the access port is in the voice VLAN. This can be done by adding the port to the voice VLAN manually. |
Trunk |
Hybrid |
Manual mode |
Tag voice traffic |
Access |
Not supported |
Trunk |
Hybrid |
Supported Make sure the default VLAN of the port exists and is in the list of the tagged VLANs whose traffic is permitted by the access port. |
Untag voice traffic |
Access |
Supported Make sure the default VLAN of the port is a voice VLAN. |
Trunk |
Supported Make sure the default VLAN of the port is a voice VLAN and the port permits the traffic of the VLAN. |
Hybrid |
Supported Make sure the default VLAN of the port is a voice VLAN and is in the list of untagged VLANs whose traffic is permitted by the port. |
Caution:
l If the voice traffic transmitted by an IP voice device is with VLAN tag, and the port which the IP voice device is attached to is enabled with 802.1x authentication and 802.1x guest VLAN, assign different VLAN IDs for the voice VLAN, the default VLAN of the port, and the 802.1x guest VLAN to ensure the effective operation of these functions.
l If the voice traffic transmitted by the IP voice device is without VLAN tag, the default VLAN of the port which the IP voice device is attached to can only be configured to a voice VLAN to ensure the effective operation of the voice VLAN function. In this case, the 802.1x authentication is unavailable.
1.2 Configuring Voice VLAN
l Create the corresponding VLAN before configuring a voice VLAN.
l VLAN 1 is the default VLAN and do not need to be created. And VLAN 1 does not support voice VLAN .
Table 1-3 Configure a voice VLAN to operate in automatic mode
Operation |
Command |
Enter system view |
system-view |
Enter Ethernet port view |
Required |
Enable the voice VLAN function on a port |
voice vlan enable |
Required By default, voice VLAN is disabled. |
Set the voice VLAN operation mode on a port to automatic. |
voice vlan mode auto |
Optional The default voice VLAN operation mode on a port is automatic. |
Quit to system view |
quit |
Set an OUI address that can be identified by the voice VLAN |
voice vlan mac-address oui mask oui-mask [ description text ] |
Optional By default, the switch determines the voice traffic according to the default OUI address. |
Enable the voice VLAN security mode |
voice vlan security enable |
Optional By default, the voice VLAN security mode is enabled. |
Set the aging time for the voice VLAN |
voice vlan aging minutes |
Optional The default aging time is 1,440 minutes. |
Enable the voice VLAN function globally |
voice vlan vlan-id enable |
Required |
Caution:
l For a voice VLAN operates in automatic mode, it does not support the adding of an Access port, and thus a voice VLAN cannot function when configuring with the VLAN VPN function.
l For a voice VLAN operates in automatic mode, it only supports that the Hybrid port to process the tagged voice traffic. However, the protocol VLAN feature requires the Hybrid port to remove tags from the packets, see the VLAN part of this manual for details. Therefore, a VLAN cannot be configured as a voice VLAN and a protocol VLAN simultaneously.
l For a port operates in automatic mode, a default VLAN cannot be configured as a voice VLAN, otherwise the system prompts you for unsuccessful configuration.
& Note:
When the voice VLAN is working normally, if the device restarts or the Unit ID of a device in a stack changes, in order to make the established voice connections work normally, the system does not need to be triggered by the voice traffic to add the port in automatic mode to the local devices as well as the IRF of the voice VLAN but does so immediately after the restart or the changes.
Table 1-4 Configure a voice VLAN to operate in manual mode
Operation |
Command |
Enter system view |
system-view |
Enter port view |
Required |
Enable voice VLAN on a port |
voice vlan enable |
Required By default, voice VLAN is disabled on a port. |
Set voice VLAN operation mode on a port to manual |
undo voice vlan mode auto |
Required The default voice VLAN operation mode on a port is automatic. |
quit |
Add a port in manual mode to the voice VLAN |
Access port |
Enter VLAN view |
vlan vlan-id |
Required |
Add the port to the VLAN |
port interface-list |
Trunk or Hybrid port |
Enter port view |
interface interface-type interface-num |
port trunk permit vlan vlan-id port hybrid vlan vlan-id { tagged | untagged } |
Configure the voice VLAN to be the default VLAN of the port |
port trunk pvid vlan vlan-id port hybrid pvid vlan vlan-id |
Optional Refer to Table 1-2 to determine whether or not this operation is needed. |
quit |
Optional Without this address, the default OUI address is used. |
Set the aging time for a voice VLAN |
Required |
Caution:
l The voice VLAN function can be enabled for only one VLAN at one time.
l If the Link Aggregation Control Protocol (LACP) is enabled on a port, voice VLAN feature cannot be enabled on it.
l Voice VLAN function can be enabled only for the static VLAN. A dynamic VLAN cannot be configured as a voice VLAN.
l When ACL number applied to a port reaches to its threshold, voice VLAN cannot be enabled on this port. You can use the display voice vlan error-info command to locate such ports.
l When a voice VLAN operates in security mode, the device in it permits only the packets whose source addresses are the identified voice OUI addresses. Packets whose source addresses cannot be identified, including certain authentication packets (such as 802.1x authentication packets), will be dropped. Therefore, you are suggested not to transmit both voice data and service data in a voice VLAN. If you have to do so, make sure that the voice VLAN does not operate in security mode.
To add a Trunk port or a Hybrid port to the voice VLAN, refer to the Port Basic Configurations part of the H3C S3600 Series Ethernet Switches Command Manual for the related command.
1.3 Displaying Voice VLAN
Table 1-5 Display configurations of a Voice VLAN
Operation |
Command |
Display the information about ports on which voice VLAN configuration fails |
display voice vlan error-info |
You can execute the display command in any view. |
Display the voice VLAN configuration status |
display voice vlan status |
Display the currently valid OUI addresses |
display voice vlan oui |
Display the ports operating in the current voice VLAN |
display vlan vlan-id |
I. Network requirements
l Create VLAN 2 and configure it as a voice VLAN.
l Configure port Ethernet1/0/1 as a Trunk port, with VLAN 6 as the default VLAN and permits the traffic of the default VLAN.
l Ethernet1/0/1 can be added to/removed from the voice VLAN automatically according to the data stream that reaches the port.
II. Configuration procedure
# Create VLAN 2.
<H3C> system-view
[H3C] vlan 2
# Configure Ethernet1/0/1 port to be a Trunk port, with VLAN 6 as the default VLAN and permits the traffic of the default VLAN.
[H3C] interface Ethernet 1/0/1
[H3C-Ethernet1/0/1] port link-type trunk
[H3C-Ethernet1/0/1] port trunk pvid vlan 6
[H3C-Ethernet1/0/1] port trunk permit vlan 6
# Enable the voice VLAN function on the port and configure its voice VLAN operation mode to automatic.
[H3C-Ethernet1/0/1] voice vlan enable
[H3C-Ethernet1/0/1] voice vlan mode auto
# Enable the voice VLAN function globally.
[H3C-Ethernet1/0/1] quit
[H3C] voice vlan 2 enable
l Create VLAN 3 and configure it as a voice VLAN.
l Configure Ethernet1/0/1 port as a Trunk port for it to be added to/removed from the voice VLAN manually.
l Configure the OUI address to be 0011-2200-0000, with the description string being “test”.
# Create VLAN 3.
<H3C> system-view
[H3C] vlan 3
[H3C-vlan3] quit
# Configure Ethernet1/0/3 port to be a Trunk port and add it to VLAN 3.
[H3C] interface Ethernet 1/0/3
[H3C-Ethernet1/0/3] port link-type trunk
[H3C-Ethernet1/0/3] port trunk permit vlan 3
# Enable the voice VLAN function on the port and configure its voice VLAN operation mode to manual.
[H3C-Ethernet1/0/3] voice vlan enable
[H3C-Ethernet1/0/3] undo voice vlan mode auto
[H3C-Ethernet1/0/3] quit
# Specify an OUI address.
[H3C] voice vlan mac-address 0011-2200-0000 mask ffff-ff00-0000 description test
[H3C] voice vlan 3 enable
# Display voice VLAN-related configurations.
[H3C] display voice vlan status
Voice Vlan status: ENABLE
Voice Vlan ID: 3
Voice Vlan security mode: Security
Voice Vlan aging time: 1440 minutes
Current voice vlan enabled port mode:
PORT MODE
Ethernet1/0/3 MANUAL
# Remove Ethernet1/0/3 port from the voice VLAN.
[H3C-Ethernet1/0/3] undo port trunk permit vlan 3
