- H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
- 00-1Cover
- 00-2Product Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Configuration Operation
- 06-Management VLAN Operation
- 07-Voice VLAN Operation
- 08-GVRP Operation
- 09-Port Basic Configuration Operation
- 10-Link Aggregation Operation
- 11-Port Isolation Operation
- 12-Port Security-Port Binding Operation
- 13-DLDP Operation
- 14-MAC Address Table Operation
- 15-Auto Detect Operation
- 16-MSTP Operation
- 17-Routing Protocol Operation
- 18-Multicast Operation
- 19-802.1x Operation
- 20-AAA-RADIUS-HWTACACS-EAD Operation
- 21-VRRP Operation
- 22-Centralized MAC Address Authentication Operation
- 23-ARP Operation
- 24-DHCP Operation
- 25-ACL Operation
- 26-QoS-QoS Profile Operation
- 27-Web Cache Redirection Operation
- 28-Mirroring Operation
- 29-IRF Fabric Operation
- 30-Cluster Operation
- 31-PoE-PoE Profile Operation
- 32-UDP Helper Operation
- 33-SNMP-RMON Operation
- 34-NTP Operation
- 35-SSH Terminal Service Operation
- 36-File System Management Operation
- 37-FTP and TFTP Operation
- 38-Information Center Operation
- 39-System Maintenance and Debugging Operation
- 40-VLAN-VPN Operation
- 41-HWPing Operation
- 42-DNS Operation
- 43-Access Management Operation
- 44-Appendix
41-HWPing Operation | 71 KB |
Table of Contents
Chapter 1 HWPing Configuration
1.2.1 Introduction to HWPing Configuration
1.2.3 Displaying HWPing Configuration
1.1 Introduction to HWPing
HWPing is a network diagnostic tool used to test the performance of protocols (only ICMP by far) running on network. It is an enhanced alternative to the ping command.
HWPing test group is a set of HWPing test parameters. A test group contains several test parameters and is uniquely identified by an administrator name plus a test tag.
You can perform an HWPing test after creating a test group and configuring the test parameters.
Different from the ping command, HWPing does not display the round trip time (RTT) and timeout status of each packet on the console terminal in real time. You need to execute the display hwping command to view the statistic results of your HWPing test operation. HWPing allows setting the parameters of HWPing test groups and starting HWPing test operations through network management system.
Figure 1-1 Illustration for HWPing
1.2 HWPing Configuration
The configuration tasks for HWPing include:
l Enabling HWPing Client
l Creating test group
l Configuring test parameters
The test parameters that you can configure include:
1) Destination IP address
It is equivalent to the destination IP address in the ping command.
2) Test type
Currently, HWPing supports only one test type: ICMP.
3) Number of test packets to be sent in a test
If this parameter is set to a number greater than 1, the system sends the second test packet once it receives a response to the first one, or when the test timer times out if it receives no response after sending the first one, and so forth until the last test packet is sent out. This parameter is equivalent to the –n keyword in the ping command.
4) Automatic test interval
This parameter is used to enable the system to automatically perform the same test at regular intervals.
5) Test timeout time
Test timeout time is the duration while the system waits for an ECHO-RESPONSE packet after it sends out an ECHO-REQUEST packet. If no ECHO-RESPONSE packet is received within this duration, this test is considered a failure. This parameter is similar to the -t keyword in the ping command, but has a different unit (the -t keyword in the ping command is in milliseconds, while the timeout time in the HWPing command is in seconds).
1.2.2 Configuring HWPing
Operation |
Command |
Enter system view |
system-view |
Enable HWPing Client |
hwping-agent enable |
Required By default, HWPing Client is disabled. |
Create an HWPing test group |
hwping administrator-name operation- tag |
Required By default, no HWPing test group is configured. |
Configure the destination IP address of the test |
destination-ip ip-address |
Required By default, no destination IP address is configured. |
Configure the test type |
test-type type |
Optional By default, the test type is ICMP. |
Configure the number of packets to be sent in each test. |
count times |
Optional By default, the number of packets to be sent in each test is 1. |
Configure the automatic test interval. |
frequency interval |
Optional By default, the automatic test interval is zero, indicating no automatic test will be performed. |
Configure the timeout time of the test. |
timeout time |
Optional By default, the timeout time is 3 seconds. |
Execute the test |
test-enable |
Required |
After the above HWPing configuration, you can execute the display command in any view to display the information of HWPing test operation status to you can verify the configuration effect.
Table 1-2 Display HWPing configuration
Operation |
Command |
Display the information of HWPing test history |
display hwping history [ administrator-name operation-tag ] |
The display command can be executed in any view. |
Display the latest HWPing test results |
display hwping results [ administrator-name operation-tag ] |
1.2.4 Configuration Example
I. Network requirement
Perform an HWPing ICMP test between two switches. Like a ping test, this test uses ICMP to test the RTTs of data packets between the source and the destination.
II. Configuration procedure
# Enable HWPing Client.
<H3C> system-view
[H3C] hwping-agent enable
# Create an HWPing test group “administrator icmp”.
[H3C] hwping administrator icmp
# Specify the test type as ICMP.
[H3C-hwping-administrator-icmp] test-type icmp
# Specify the destination IP address as 1.1.1.99.
[H3C-hwping-administrator-icmp] destination-ip 1.1.1.99
# Set the number of test packets sent in a test to 10.
[H3C-hwping-administrator-icmp] count 10
# Set the timeout time of test operations to 5.
[H3C-hwping-administrator-icmp] timeout 5
# Enable the test operation.
[H3C-hwping-administrator-icmp] test-enable
# Display the test results.
[H3C-hwping-administrator-icmp] display hwping results administrator icmp
HWPing entry(admin administrator, tag icmp) test result:
Destination ip address:1.1.1.99
Send operation times: 10 Receive response times: 10
Min/Max/Average Round Trip Time: 2/5/2
Square-Sum of Round Trip Time: 66
Last complete test time: 2000-4-2 7:59:54.7
Extend result:
SD Maximal delay: 0 DS Maximal delay: 0
Packet lost in test: 0%
Disconnect operation number: 0 Operation timeout number: 0
System busy operation number: 0 Connection fail number: 0
Operation sequence errors: 0 Drop operation number: 0
Other operation errors: 0
[H3C-hwping-administrator-icmp] display hwping history administrator icmp
HWPing entry(admin administrator, tag icmp) history record:
Index Response Status LasrRC Time
1 1 1 0 2004-11-25 16:28:55.0
2 1 1 0 2004-11-25 16:28:55.0
3 1 1 0 2004-11-25 16:28:55.0
4 1 1 0 2004-11-25 16:28:55.0
5 1 1 0 2004-11-25 16:28:55.0
6 2 1 0 2004-11-25 16:28:55.0
7 1 1 0 2004-11-25 16:28:55.0
8 1 1 0 2004-11-25 16:28:55.0
9 1 1 0 2004-11-25 16:28:55.9
10 1 1 0 2004-11-25 16:28:55.9
Refer to the HWPing Command Manual for detailed description on displayed information.
